Ask the Toyota mechanic!
Discussion in 'General Tundra Discussion' started by T-Rex266, Aug 15, 2015.
  1. Jun 26, 2020 at 7:55 AM
    #1651
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I didn't look at the picture closely but wonder why the bar is touching the control arm.:monocle:
  2. Jun 26, 2020 at 7:58 AM
    #1652
    Johnders2586
    Johnders2586 New Member
    2017 Tundra SR5 W/TRD pkg
    Toytec Performance Aluma 3" Lift- Toytec rear shackle, Fuel Vector Wheels, Toyo Open Country C/T 295/70/18 Tires
    Yeah I think it's toast too.maybe part of the problem or a different problem. but my question would be. Is there. A better way to go about replacing it? As I said I had a hell of a time getting the bolt back through an lined up..
  3. Jun 26, 2020 at 7:58 AM
    #1653
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Looks like the rubber inside the eyelet is deteriorating and pulling apart allowing too much movement.
  4. Jun 26, 2020 at 8:03 AM
    #1654
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Loosening the two u-shaped clamps that hold the sway bar to the frame may make that easier giving a bit of loose movement to the sway bar. Some of it's a trial and error situation. Sometimes moving the LCA works better. Having the frame on jack stands and using a bottle or floor jack to raise the LCA may work too.
  5. Jun 26, 2020 at 9:41 AM
    #1655
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Is the sway bar attached when you took the picture? The only way it could be that out of position is if the LCA is set back to far or you have the truck lifted a lot. If the lift is the problem you can get drop down brackets for the sway bar.
    Here is what it should look like.
    Wynnded[QUOTED] likes this.
  6. Jun 26, 2020 at 9:44 AM
    #1656
    Johnders2586
    It is in my picture as it currently sits in my driveway. It's a 3 inch lift
  7. Jun 26, 2020 at 11:00 AM
    #1657
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    You need a sway bar drop down bracket so the link doesn't make contact.
  8. Jul 8, 2020 at 12:56 AM
    #1658
    Roberts9
    Roberts9 New Member
    Need Help. No drive, reverse only.
    Background :
    2013 Tundra 4.6L RWD A760e 6 speed transmission. 140K. The truck has never had any transmission issues before this. Started getting code "P0418 Secondary Air Injection System Relay A Malfunction" a few weeks prior but I don't see a correlation between the two systems.
    Failure :
    I changed the performed a drain and fill plus filter replacement. I drained about 2.5qts out of the pan. Replaced approx the same (the first time). First run and shifting was sluggish with the truck jerking into gear. Drove a mile or two (slow and steady) and it cleared up. Parked it but the next day now I had no forward gears. Reverse only.
    During the maintenance I put the truck in Fluid Temp Check Mode and I am fairly certain I have the correct fluid level. Especially now that I have dropped the pan at least 6 times for troubleshooting.
    Troubleshooting so far :
    After the first "test run" I pulled codes P0761 and P2714 and P2757. All solenoid related codes. I then drained the pan a second time and pulled all 9 solenoids and bench tested with 12V. All actuated properly. All Ohm'd out to spec. I disassembled the valve body, cleaned and rebuilt.
    No change, still only have Reverse. No forward gears. There was no shrapnel in the pan that would point to mechanical failure. I still suspect pressure or electrical/electronic related but am at a loss as how to proceed.
  9. Jul 8, 2020 at 5:45 AM
    #1659
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    What are you using to pull codes? Do you have techstream?
  10. Jul 8, 2020 at 8:06 AM
    #1660
    CTB Mike
    CTB Mike It's RED? My rods and cones must be screwed up!
    Southern Arizona
    2011 Red Rock Warrior
    There is absolutely zero relationship between the steering wheel being centered and alignment not correct. Centering the wheel is a simple toe adjustment. Whomever did the alignment was simply not careful when the toe was set, usually the last adjustment to be made. I would agree that if the mechanic did not center the wheel, then I would question his ability and/or attention to detail.
  11. Jul 8, 2020 at 9:35 AM
    #1661
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Thanks for your input. A centered steering wheel is part of your alignment and it's the last adjustment made after caster and camber adjustment. When the customer drivers their vehicle after an alignment the first thing they will notice is if the steering wheel is off centered. You could do an alignment with the steering wheel off 25° the tires wouldn't wear but would this qualify as a good alignment? A correctly adjusted steering wheel is always the final step in a properly aligned vehicle.
  12. Jul 8, 2020 at 9:43 AM
    #1662
    CTB Mike
    Southern Arizona
    I totally agree. As I had pointed out, the mechanic was not very careful, leading me to question whether the alignment was done to specification. I was just trying to say that just because the wheel is not centered, it has nothing to do with all the caster, camber, and toe being out of spec. It is a visual thing. And, for the record, It makes me crazy to drive a vehicle with a wheel that is not centered.
    NewImprovedRon likes this.
  13. Jul 8, 2020 at 9:46 AM
    #1663
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Dually noted.
    NewImprovedRon and CTB Mike like this.
  14. Jul 8, 2020 at 3:00 PM
    #1664
    Roberts9
    Roberts9 New Member
    I have used both a generic code reader and Tech stream. Both pull the same codes.
  15. Jul 8, 2020 at 3:28 PM
    #1665
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I'll check infostream and get back to you.
  16. Jul 11, 2020 at 7:11 AM
    #1666
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Ok some questions. What fluid did you use for the drain and fill? Did you put the transmission in fluid detection mode when setting the transmission level? Did you do a trans memory reset after removing the valve body and solenoids?
  17. Jul 11, 2020 at 10:36 AM
    #1667
    Roberts9
    Roberts9 New Member
    Fluid type - WS. If by " fluid detection mode" you mean the procedure were pins 4&13 are jumpered out and I wait until the fluid temp is at temperature? Indicated by the "D" staying solidly lit. Then yes I did that. I have tried to reset the memory. But can't get my bootleg Techstream to do it yet. However the battery has been unplugged for more than 48hrs at a time.
  18. Jul 11, 2020 at 3:40 PM
    #1668
    Roberts9
    Roberts9 New Member
    Ok figured out how to reset trans memory with Techstream. Unfortunately still no change.
  19. Jul 11, 2020 at 5:31 PM
    #1669
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I'll look further.
  20. Jul 12, 2020 at 11:59 AM
    #1670
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Check the data stream on techstream and make sure that the switch shift (D range) is displaying on when the truck is in gear.
  21. Jul 13, 2020 at 12:17 AM
    #1671
    Roberts9
    Roberts9 New Member
    It is NOT "on" in any of the Data Files. Diagnosis?
    Note : I have gone down this troubleshooting list from the Service Repair Manual. I ruled out the items checked off. The transmission is now out of the vehicle so I can check the remaining 2 items. Or replace the trans, which is begrudgingly where I am at currently.
    Nedybest likes this.
  22. Jul 13, 2020 at 12:18 AM
    #1672
    Roberts9
    Roberts9 New Member
    And I don't think I've said it yet but THANK YOU very much for all the help.
  23. Jul 13, 2020 at 2:46 AM
    #1673
    jwatt
    jwatt I heart men
    Jack
    Oregon
    I do not plan on re installing the passenger seat in the forseeable future after removing it to install sound deadener. Removing the seat caused the airbag dash light, and the weight sensor light to come on. I m assuming the airbags are disabled. Is there anything, besides the obvious, I can do to turn the dash lights off, and get airbags working again, something that would possibly fool the computer into thinking the passenger seat is plugged in?
  24. Jul 13, 2020 at 5:34 AM
    #1674
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    If the range selector switch (PRNDL switch) should display ON.
    The two remaining items on your list are the torque converter and the rear planetary gear set. I would have a hard time believing that those are the issues. You had the pan down and didn't find any debris in the pan. It's very rare for the Tundra transmissions to fail.
  25. Jul 13, 2020 at 10:42 AM
    #1675
    Roberts9
    Roberts9 New Member
    I agree with you that it is unlikely that the torque converter or any of the gears are gone. I still see no signs of shrapnel in the pan or the housing now that I have it out of the truck. When the trans was still installed I had my son shift through the range selector while I was underneath the truck with the pan off. It actuated through all position in sync with the PRNDL. Also I can turn the input shaft by hand and the output shaft turns with it. I did this in every gear and they all turn, except neutral of course. This should mean that all the gears are working.
  26. Jul 13, 2020 at 11:45 AM
    #1676
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Turning the input shaft and having a result of the output shaft is turning isn't an indication that everything is OK. The auto is not like a manual. The auto uses planetary gear sets and one member is is held with clutches and or bands hydraulically so the pump has to be working and engine running. At this point I would probably take the transmission in to a transmission rebuilt shop. They can hook it up to a tester that spins the torque converter and can read pressures to make sure the tranny is working properly
  27. Jul 14, 2020 at 6:29 PM
    #1677
    PSYCHO WHITE TUNDRA
    PSYCHO WHITE TUNDRA Still Gonna Send It...
    Jake
    New Mexico
    White 2011 Tundra SR5 TRD (Psycho White)
    Chopped and dumped dual exhaust; 6" fully adjustable ProComp lift w/ FabTech rear shocks, 12.5x20 Pro Comp rims on 37x12.50x20 tread wright mud tires, pedal commander throttle programmer and sound system from hell which consist of Sony double din headunit, 4 Morel Maximo Ultra 603 component door speakers w/ 4 tweeters ran on a Rockford fosgate P500-4 punch amp under drivers seat then the bass comes from a custom 15” 4000rms sub made from a Skar 15” Skar basket and motor with sundown x series components made by Patrick @ Robot Underground in Mesa AZ which is powered by 2 C.A.B. Audio 2000.1D amps strapped together at .08ohm which produces just under 5000rms. Also installed 100sq.ft. 10mil dynamat sound deadening on all 4doors (both exterior and interior chambers) double layer on roof and back wall as well as inside side mirror covers and behind side mirrors
    My expansion valve is clogged and needs replaced on my 2011 Tundra SR5 TRD DC. I’m very mechanically inclined but have never done this job before. Approx How long should it take to swap out and anything I need to look out for or any tricks to make the job quicker. Any info is greatly appreciated
  28. Jul 14, 2020 at 7:41 PM
    #1678
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    How do you plan on recharging the system?
  29. Jul 15, 2020 at 11:09 AM
    #1679
    PSYCHO WHITE TUNDRA
    Jake
    New Mexico
    With my buddies a/c recharge and recovery machine
  30. Aug 13, 2020 at 7:12 AM
    #1680
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
    Hey @LOTSOFTOYS question for you.
    Regarding ebrake light on dash
    It will come on at odd times, not while driving !
    Parked on incline/decline
    Parked on flat ground or garage
    Sometime Its on, I shut truck off, restart and it goes off.
    Read that possibly the fluid is low. Couple weeks ago I went out and bought some and added a little and when I started the truck it went off.
    Not sure if it was really low, couldnt tell since its almost clear.
    Earlier this week it was on after sitting in the driveway. Shut off, restarted and it went out.
    Brakes actually feel fine, pedal is firm and doesnt go to the floor
    Truck has about 42,700 miles on it.
    I would think that if the fluid is low that it would be leaking somewhere. Not finding any proof of that either.
    Anything I should look at specifically or let the shop take a look?
    Thanks - I appreciate your help !!!
