Ask the Toyota mechanic!
Discussion in 'General Tundra Discussion' started by T-Rex266, Aug 15, 2015.
  1. Apr 15, 2020 at 8:50 AM
    #1531
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
    @LOTSOFTOYS
    Regarding leaking rear shocks on my 2016 Tundra CM with 38k miles.
    Been using local shop for last 10 years to service our 2 Toyota's.
    Last visit they show me a small spot on rear shock below the "weep hole" if that's the name, where some fluid/oil has "dripped".
    I've seen the toyota graphic that shows normal wear and this leak falls within that category.
    I do not have any excessive bounce or anything that suggests there is a problem other than what I've posted here.
    The shop wants to replace them. I find it hard to believe they need replaced at 38k miles.
    Your opinion is appreciated. Thank you !
  2. Apr 15, 2020 at 8:59 AM
    #1532
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Probably just fine. You are right that Toyota allows a certain amount of sweating but they shouldn't drip. Take a rag and wipe down the body of the shock. Watch them closely for the next couple of months and see how they look.
  3. Apr 15, 2020 at 9:00 AM
    #1533
    TemujinNomad
    TemujinNomad New Member
    Much appreciated
  4. Apr 15, 2020 at 9:01 AM
    #1534
    purplenova
    Tom
    Ohio
    I will do just that.
    Thank you so much...
  5. Apr 29, 2020 at 4:50 AM
    #1535
    2a_TX_Tundra
    2a_TX_Tundra New Member
    2020 SR5 CM TSS in Quicksand
    Ok I've got one for you. I have a 2020 SR5 CM 4x4. The factory radio won't power on, the adjustable mirrors don't work. I have checked every fuse in the cabin and under the hood with a test light and they all appear to be good. (fuse labeled USB does not have power to either side for some reason.) I have 12v constant to the back of the radio and 2 wires have switched ACC power. Is there a fuse I'm missing? Do the mirrors and the radio share a circuit/relay somewhere? Any insight would be helpful as I can't find anything online and I have been looking for 3 days. I have attached pictures of the fuse box layouts for my truck in case that would help.
  6. Apr 29, 2020 at 5:45 AM
    #1536
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Why are you messing with a brand new truck. Bring it back to the dealer and it will be fixed for free.
    That was easy.
    JLS in WA likes this.
  7. Apr 29, 2020 at 5:47 AM
    #1537
    2a_TX_Tundra
    Trying to avoid 2 things. One trying to avoid spending the day at a dealer over a blown relay. Two I'm trying to avoid them trying to blame me for it because I have an amp and sub installed and trying to charge me for diag and repair all over a blown relay lol.
  8. Apr 29, 2020 at 6:02 AM
    #1538
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    The problem is if you find something needs replacing it could be very expensive. Can you not just return the truck back to stock and see if your problem is fixed? If the problem is still there then visit the dealer.
  9. Apr 29, 2020 at 6:08 AM
    #1539
    2a_TX_Tundra
    I have already attempted to remove power to the amp and disconnect the line out converter. That did not fix the issue.
  10. Apr 29, 2020 at 6:23 AM
    #1540
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Remove everything and return to the dealer. Don't take this as a insult but your electrical skills aren't sufficient to solve the problem and you may cause further damage.
    Working on a electrical problem without a wiring diagram is kind of like driving to Argentina without a road map.
  11. May 4, 2020 at 5:37 AM
    #1541
    mrn320
    mrn320 New Member
    2012 Black Tundra TRD Rock Warrior
    • 5.7-liter DOHC i-Force V8 381 horsepower and 401 lb.-ft. torque with TRD oil and radiator cap • Nitto Trail Grappler M/T LT305/55R20 performance tires • KMC Wheels XD801 Crank 20” cast aluminum wheels • ReadyLIFT 2.5” Front and 1" Leveling Kit • Bull Bar • Hella Halogen Headlights • Custom Window Tinting • WeatherTech Side Window Deflectors • Custom Notre Dame Trailer Hitch • Toyota TRD rear sway bar • Tonneau soft cover • Toytoa bedliner • Toyota Tundra Smoke Tail Light and Bed Light
    Hi Ruggybuggy - T/S question for you on my 2012 Tundra TRD Rock Warrior edition with 23K miles on it. My son and I installed the TRD Cold Air Intake mod. Went very well and took extra care with the MAF sensor. When we re-installed and connected the battery I received check engine code with P0102 and P0113 showing on my Innova scan tool. Did some weekend T/S and found the MAF and IAT harness giving me good volts and ground (12V on MAF and 5V on IAT). Local Toyota dealer had a new MAF sensor; so for $78 I picked it up and installed hoping to clear the codes. No luck. Still seeing P0102 and P0113 in the scan tool. Truck idles and runs well. The check engine light is also off but it bothers me to see the codes triggering in the scan tool. Any thoughts? Thanks. Mike from Fort Mill, SC
  12. May 4, 2020 at 12:44 PM
    #1542
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Hey Mike, do you have access to Techstream? You going to have to be able to read the data stream to diagnose it properly. Tundra's mass flow sensors are very reliable along with the wiring. You didn't mention what cold air intake you installed. Because you never had the problem before the install try putting back the stock intake, clear the codes and see if the problem returns.
  13. May 4, 2020 at 3:46 PM
    #1543
    mrn320
    mrn320 New Member
    Dave - Thanks for the quick reply. I installed the OEM TRD cold air intake (P/N - PRT0334100). Photo attached.
    Q1)Do you have access to Techstream?
    A1)No access to Techstream or Techstream Lite.
    Thanks for the suggestion on re-installing the factory intake. I can do that but before reverting back I might poke around for some additional T/S. If anything else comes to mind please do share.
  14. May 4, 2020 at 5:01 PM
    #1544
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I do have access to Techstream. You can download a pirated version. There is a link on the forum somewhere. Being able to see the live data stream you can verify the sensor values.
  15. May 4, 2020 at 5:38 PM
    #1545
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    did you clear the codes and see if it comes back?
  16. May 5, 2020 at 1:15 PM
    #1546
    mrn320
    mrn320 New Member
    Daniel - I did clear them. When I run the DTC the codes still trigger. Photos attached. Can you suggest any further T/S?
  17. May 5, 2020 at 1:24 PM
    #1547
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Those are being shown on your scanner as "permanent", they can't be cleared that I've ever read. I have a couple permanent codes set in my ECU, I think one is somethingsomething out of range. Since they first set as permanent they've never set the CEL again. I've bricked and recovered my ECU twice (long story) and they're still there. If your CEL is not on, I think that you're going to have to live with it.
  18. May 6, 2020 at 7:33 AM
    #1548
    Randy Morton
    Randy
    Deepinahearta, Texas
    2012 Tundra Double Cab (I call it my Land Yacht)
    I had a non-Toyota with permanent codes. The mechanic had to do some research and eventually drill down through several menus on his code reader (one of the fancy units from SnapOn) before he found a way to clear them. If you know a mechanic with one of of the fancy ODBII tester/code readers, it might be worth a trip and a six-pack to see if he can find a way to clear them.
    Wynnded[QUOTED] likes this.
  19. May 6, 2020 at 7:37 AM
    #1549
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I'm not worried about it for myself, but @mrn320 may be interested. That's certainly good information, thanks.
  20. May 6, 2020 at 10:53 AM
    #1550
    mrn320
    mrn320 New Member
    Thanks Randy and Wynnded. I'll deal with the permanent codes for now and down the road look for a fancy "Snap-on" or "Techstream" friend to try and clear them.
  21. May 6, 2020 at 12:14 PM
    #1551
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    FWIW, I wasn't able to clear the permanent code via my pirated version of TechStream. It's isn't the latest version though either.
  22. May 18, 2020 at 7:07 PM
    #1552
    TRDThirstyPRO
    TRDThirstyPRO New Member
    Tom
    New York
    2020 TRD pro
    Wondering if anyone would know if you can program your doors to lock at a set speed . I wanted to mask the abs self check with the door locks. ABS does check at 6mph. Asked the dealer to set it to lock at 6mph. Just picked it up and they set it to lock at 15mph . So the question. Can it be set like that or do they have a list of times it will lock(shift out of park, 5,10,15 mph) was looking to buy a TechStream if this is possible to do
  23. May 30, 2020 at 11:01 AM
    #1553
    Kenny1794
    Kenny1794 New Member
    Question my idle in drive drops to like 500 or 600rpm's, is there anything i can do to change that. sometimes causes the truck to run a lil rough?
  24. May 30, 2020 at 1:34 PM
    #1554
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    How many miles?
  25. May 30, 2020 at 2:05 PM
    #1555
    Kenny1794
    43,000miles. I bought it with 27,000 miles
  26. May 30, 2020 at 10:13 PM
    #1556
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    The idle is not adjustable but there are things you can do to make it idle better. If you don't have a check engine light on some basic maintenance can help. Many things can cause a slightly rough idle. Some are dirty fuel injectors, plugged air filter, dirty throttle body, contaminated mass air flow sensor from performance air filter and poor quality fuel. Make sure the air filter is clean, add a fuel system cleaner (Toyota parts department has a good one), clean your mass air flow sensor with a mass air flow cleaner (Napa) and use a good quality fuel. If none of that helps change the plugs.
    JohnLakeman likes this.
  27. May 31, 2020 at 5:52 AM
    #1557
    Kenny1794
    I cleaned my throttle body, replaced my air intake with the trd cai, and cleaned my mass air flow sensor not with cleaner from nappa, i will try fuel cleaner, then the plugs if all else fails.
  28. May 31, 2020 at 1:55 PM
    #1558
    jaymz11
    jaymz11 New Member
    2007 Sequoia, 170k, 4x4 - surging intermitently from 2k-3k rpms around 30 mph, happens more when going uphill - any hill- but also many times just in fnotmal conditions,
    replaced MAF, Cleaned throttle body, new pcv, ran redline through fuel system, new ngk plugs
    any help greatly appreciated.
  29. May 31, 2020 at 3:15 PM
    #1559
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    You need to monitor missfire data using Techstream to see if you have any missfires. I'm assuming you have no codes? I've also seen torque converter problems that feel like missfires but that's unlikely. Water in fuel can cause the issue as well so change the place your getting your fuel and run some isopropyl in the tank. I know you said you ran redline but you might have recontaminated from the fuel source.
  30. May 31, 2020 at 4:13 PM
    #1560
    jaymz11
    jaymz11 New Member
    Thank you. You are correct, no codes. Its only happening within a certain rpm range though within a certain speed range as well. ive burned through an entire tank of gas. yes used redline.
    would o2 sensors on the way out cause this?
    trying to avoid going to the dealer. im pretty handy around the engine just was hoping yall had had the issue solved here since ive seen it posted numerous times on multiple forums.
