Ask the Toyota mechanic!
Discussion in 'General Tundra Discussion' started by T-Rex266, Aug 15, 2015.
  1. Jan 6, 2019 at 5:58 PM
    #1381
    FXFormat
    FXFormat New Member
    It almost sounds like VTEC kicked in.
    jdm ctr '00 and OR18TRD like this.
  2. Jan 10, 2019 at 2:10 AM
    #1382
    KFed
    KFed New Member
    East Tennessee
    2018 Tundra Crewmax TRD Sport
    Tinted windows, Black badge overlays, ProZ hard bed cover, 32" grille light, 30" lower bumper light,...
    Fisherman951
    Sounds like my Truck! 2018 CM. Trd sport. Had it at the dealer last week and they replaced the front body mount bushings.... picked up truck the other day, it was quiet for the ride home, the whamo!!! Back to the same noise times 10. It's even worse Now! So back to the dealer.
  3. Jan 16, 2019 at 5:59 AM
    #1383
    KFed
    KFed New Member
    East Tennessee
    So the final analysis... dealer replaced the complete passenger side coil and shock assembly. No more noises!!!
    But, the dealer was also quick to blame the lower grille led bar mounting bracket.... how could that cause a suspension issue... nd why would they have replaced the coil over??
  4. Jan 16, 2019 at 6:14 AM
    #1384
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    KevinK likes this.
  5. Jan 16, 2019 at 7:01 AM
    #1385
    Tundra$
    Tundra$ White Trucks Matter
    Las Vegas
    2018 SR5 4x4 off-road CM 5.7 Super Fast White
    3/1 readylift, 35x11.5r20 ridge grapplers, 20’ fuel wheels, bakflip revolver bed cover, console safe, N-fab side rails, mini antenna, 2019 TRD Pro grill, color match hood bulge, front bumpershellz, baby car seat, to be continued...
    Small issue im having
    Have a new 2018 crew max with 5k miles and the rear passenger side door does not shut as easy as the rest of the doors. Takes a pretty decent slam to get it to shut. I’ve had a couple issues now where passengers haven’t fully shut it then came out to my dome light still being on due to that. When I went in for my 5k service I brought it up to the service guy. He agreed it wasn’t normal. When I picked it up service guy told me it wouldn’t be worth the trouble to try to fix because they would have to take off an put on new door seals and it would never be the same. He stated I would have air whistling in my cab. Paperwork states service manager checked another truck and the same door on another truck shuts the same way.
    Should I accept this outcome or make them fix it ?
    htw_hawaii likes this.
  6. Jan 16, 2019 at 10:25 AM
    #1386
    Cgn36
    Cgn36 New Member
    2008 Tundra 5.7L
    I replaced the starter with a reman Duralast (Autozone) and now in cold weather the starter makes an awful noise but it does start. My check engine light came on after it started. It went off after a few starts so I have not checked the codes. Here is a link to a video with the lovely noise. Only does this when it's below 32 degrees.
    Tell me I have to replace the starter again....
    https://youtu.be/4Qfi5kRL0l0
  7. Jan 16, 2019 at 10:45 AM
    #1387
    Randy Morton
    Randy
    Deepinahearta, Texas
    2012 Tundra Double Cab (I call it my Land Yacht)
    Yikes! That sounds like the bendix is slamming into the teeth on the flywheel after the starter has wound up to full speed. If that continues it could cause other problems. I'd take that starter back to Autozone and find one somewhere else.
    Filthyphil likes this.
  8. Jan 16, 2019 at 10:53 AM
    #1388
    htw_hawaii
    htw_hawaii Tundra N00b
    Victor
    Hawaii
    2018 Cement CM 4x4 TRD
    Nice to know I'm not alone! Exact same issue here. We've gotten used to it after a year of having it (2018 CM). But it can get annoying. Kids have adjusted to using their muscles to close the door.
  9. Jan 16, 2019 at 10:59 AM
    #1389
    Tundra$
    Las Vegas
    Hi shitty door buddy. Likewise. Feels good to hear not the only one. And sounds like you just justified what the service manager said to me.
    htw_hawaii[QUOTED] likes this.
  10. Jan 18, 2019 at 6:36 AM
    #1390
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    @LOTSOFTOYS
    2002 Tundra with 156K. I notice that when I'm coming up to a red light, just as the truck is about to reach a complete stop I get a bit of a jump or surge. Sometimes it feels more like a shudder. It doesn't do this all the time.
  11. Jan 26, 2019 at 12:00 PM
    #1391
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    are Denso O2 Sensors suitable replacements for OEM?
  12. Jan 26, 2019 at 2:25 PM
    #1392
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    To the best of my knowledge Denso is OEM for O2. May be wrong however
    lsaami[QUOTED] likes this.
  13. Jan 26, 2019 at 3:11 PM
    #1393
    Jrharvey02
    Jrharvey02 New Member
    2010 Tundra CM 5.7 Platinum Dark Black
    Seatbelt issue....
    2010 5.7 CM, Rear middle seatbelt does not “give” when pulled. My wife rides in the back between my two small kiddos and when she’s buckled in and needs to grab something off the floor or reach towards the front of the truck, the seatbelt is always locked and will not “give” any to let her lean forward...? She has to unbuckle herself, let the seatbelt “suck” its way back to the unused position and then pull it all the way out again and buckle herself back up. Happens every time she’s back there.
    HappyGilmore likes this.
  14. Jan 27, 2019 at 6:50 AM
    #1394
    Bo-Hunter
    Bo-Hunter I like fast
    Greg
    NOVA
    2009 RW 4x4 Truck
    Long Travel, DC Shortbed
    @LOTSOFTOYS I HAVE A 2009 Tundra DC 5.7 has 180K miles but runs great. Recently I started to have a problem where the fuel relay blows, not during operation but at ignition.. Replaced the relay and it immediately blew again, messed around with the wires on top of the fuel tank in the way of just feeling around and was able to get the truck started it worked for a few days and now I have the same problem. Never had the problem before and the only thing I have done recently and not sure if it is related but I put some soundproofing material on the back wall and floor of the cab. Is there any fuel system wiring that come through or in to the cab or on the back pillars of the cab that I may have shorted out or something ? My current plan is to replace the wiring harness that plugs in to the fuel tank. I previously had the tank in and out a few times for an unrelated issue and am thinking I may have compromised the wiring some how.
    Thanks
    Greg
  15. Jan 27, 2019 at 11:49 AM
    #1395
    Filthyphil
    Phil
    If the fuse is blowing it’s from too many amps. Unless you cut some wiring and your shorting our somewhere which I wouldn’t suspect from you just putting down sound matt. I would assume your fuel pump is going bad causing the motor to pull to many amps which would blow your fuse. My old dodge diesel did the same thing and when I replaced the fuel pump motor my issue went away.
  16. Jan 27, 2019 at 6:10 PM
    #1396
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    The Toyota mechanic hasn't logged on for nearly 2 months. I hope he's ok.
  17. Jan 27, 2019 at 6:14 PM
    #1397
    T-Rex266 [OP] Owner, CTO and executive chairman of X Staff Member
    He’s got a newborn
    FirstGenVol likes this.
  18. Jan 27, 2019 at 6:18 PM
    #1398
    Kn4x2
    Kn4x2 Common sense is not so common!
    3rd rock from the sun
    2010 DC 2WD
    Afe Pro Dry filter Tinted windows Coverking seat covers Traxion tailgate ladder Auto vox M1 backup camera
    Have you tried adjusting the striker?
    NewImprovedRon likes this.
  19. Jan 27, 2019 at 6:48 PM
    #1399
    Tundra$
    Las Vegas
    No. It’s brand new under warranty. I figured anything that needed adjusting the dealer would do. I’ll take a look at it though. Thanks
  20. Jan 27, 2019 at 7:16 PM
    #1400
    Mike Tread lightly.
    south carolina
    Tell him congrats for me then..
    T-Rex266[QUOTED][OP] likes this.
  21. Jan 30, 2019 at 5:59 PM
    #1401
    DM 2018 Tundra
    DM 2018 Tundra New Member
    South Carolina
    2018 Limted Tundra
    6inch RC with upgrade struts. 295/65/20 Nitto Ridge grappers 20x9 fuel vapor with 0 off set
    I have 18 in the shop getting a 6 inch lift. I will be running 295/65/20. What will I need to have reset? Thank you for ur help
  22. Jan 30, 2019 at 7:23 PM
    #1402
    lionix
    lionix The Grey Moose!
    Cape May, New Jersey
    2017 Tundra TRD Pro CM Cement
    BD Lights, Any Time Fog, Coachbuilder, Pelfreybilt, Bakflip, Custom Bed Rack w/ Tent
    Open another door and try it. Mine is sealed tight and doesnt close because of air pressure.
  23. Jan 30, 2019 at 8:14 PM
    #1403
    Tundra$
    Las Vegas
    I’ll check that out but wouldn’t that mean I should have this issue with any door if all 3 other doors or closed ?
  24. Jan 30, 2019 at 8:42 PM
    #1404
    lionix
    You would think not, perhaps that seal closes differently. But thats what I do on mine.
  25. Jan 31, 2019 at 11:05 AM
    #1405
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    See how the questionable door closes with a window open, that may give some insight regarding the idea of the seal. And it'll kill about a half a minute....
  26. Feb 5, 2019 at 11:41 AM
    #1406
    MarkBeast10
    MarkBeast10 New Member
    Mark
    2000 4.7l SR5
    When I come to a slow complete stop I can feel a minor shift under me barely rock back then forward. In my mind it feels like my tranny moves but it doesn’t do it again and only does it on the very first stop wherever I’m at. I know whatever it is is not coming from within the cab when I feel it. Where could this be coming from or why? No high severity just your thoughts, 2000 SR5. Thanks
  27. Feb 5, 2019 at 1:49 PM
    #1407
    Filthyphil
    Phil
    I would check your support bracket
    MarkBeast10[QUOTED] likes this.
  28. Feb 5, 2019 at 8:11 PM
    #1408
    MarkBeast10
    Mark
    2000 4.7l SR5
    Ok, I have to mess with one of the motor mounts to put on the headers so maybe I’ll just replace those too. I’ll lift it up tonight and take a look.
    Filthyphil[QUOTED] likes this.
  29. Feb 5, 2019 at 8:16 PM
    #1409
    Filthyphil
    Phil
    Report back on the headers, I’m trying to work up the nerve to do mine.
  30. Feb 5, 2019 at 8:26 PM
    #1410
    MarkBeast10
    Mark
    2000 4.7l SR5
    Will do! I noticed the gaskets that came with the JBL shorties look cheap and I’m concerned with the head bolts included. I think I’m going to have to pick up some better gaskets and maybe go to the dealership for OEM bolts to ensure quality control. Finished high temp wrap and coating on the headers. Hopefully I’ll have them on soon and sitting tight.
