Ask the Toyota mechanic!
Discussion in 'General Tundra Discussion' started by T-Rex266, Aug 15, 2015.
  1. Sep 29, 2018 at 4:18 AM
    #1231
    coldstorm
    coldstorm New Member
    57CFC4B3-1AAB-4471-9AFE-E909D978C6D9.jpg I’m in the process of replacing the front bumper on my 07 Tundra SR5 and came across two empty female plugs that are hanging behind the bumper on either side of the truck. They are right next to each of the fog lamp connections. Any idea what they are? I think they might be part of the parking sensor option (this truck doesn’t have that option). Thanks much!064CE9BA-101F-475F-B32B-14A69D77C389.jpg
  2. Sep 29, 2018 at 7:27 AM
    #1232
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    That would be my first guess. A friend of mine has a 2007 SR5 that came win the parking sensor option.
    NewImprovedRon likes this.
  3. Sep 29, 2018 at 3:29 PM
    #1233
    Istvank11
    Istvank11 Shine On
    AZ
    2016 CM
    Went in for my last free oil change today and after going home to change I headed to work. When I turned the A/C on it made a rattling sound under the dash and the front of the truck was shaking. I turned the A/C off for the rest of the trip, when I got to work I checked the cabin air filter and found what looked like pieces of a seal (pic attached).
    What could this be and how does it all of the sudden happen right after an oil change
  4. Sep 29, 2018 at 4:23 PM
    #1234
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I'd be more concerned about the front of your truck shaking when using the A/C than a foam seal in your cabin air filter.
    Sas, T-Rex266[OP] and NewImprovedRon like this.
  5. Sep 30, 2018 at 7:51 AM
    #1235
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    Me too:/
    Wynnded[QUOTED] likes this.
  6. Oct 10, 2018 at 2:14 PM
    #1236
    grpape
    grpape New Member
    Hey LOTSOFTOYS quick couple of questions for ya.
    Just inherited a 2001 2wd and am gonna change out the front coils with some Eibachs and have been watching vids that says to disconnect the UCA from the spindle or Swaybar to get room to install the new coils. Or could one just use a bar and pull down on the LCA to make room? I think I'm also gonna just ditch the sway, and I think somewhere in all of 44 pages I read that it's fine to run without it.
    Also was driving a couple of weeks ago in some down pours and went through some puddles and all of a sudden my Air bag light came on and stays on . Any way that water could have done this? Anywhere I should look for like fuses or sensors? I did install a new head unit three weeks prior to the light coming on. Coincidence? Crutchfield had me tap into a brown wire in the fuse box under steering wheel (said it was the reverse wire). The cover of the box said different but they they said it was the correct one. Have yet to fish the wire to actually get the camera working, so no idea if it is the correct one or not. Thought it might be the culprit and undid it. Light still on. I didn't disconnect the yellow connector to the passenger air bag when installing the unit. I did turn on to acc. to see if unit would come on. Turning the key turns "on" and "off" the passenger airbag. Any idea other than taking it into the dealership for them to scan (just real busy till end of November). Right to think that light "on" means bag won't deploy if I smash anything? Just don't want any surprised while driving. :)
    Any idea why the paint on the bed is starting to turn yellow? Weird. It looks almost like resin discoloring and peeling off. Thinking of just rattle canning it white.
    Also have a Leer top and want to tap the inside light and third brake light. Ok to tap brake light to brake wire in rear lights? Where to tap interior light? Maybe outside dome light?
    Sorry for the long questions. Thanks!
  7. Oct 10, 2018 at 4:08 PM
    #1237
    SouthWestGA
    SouthWestGA New Member
  8. Oct 12, 2018 at 11:17 AM
    #1238
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Yeah just pry the LCA down. And I would say scan the airbag code.
  9. Oct 12, 2018 at 1:13 PM
    #1239
    grpape
    grpape New Member
    Sounds good. Thanks for getting back so soon. Have a wonderful weekend!
    LOTSOFTOYS[QUOTED] likes this.
  10. Oct 12, 2018 at 5:59 PM
    #1240
    Steelyhead
    Steelyhead 2016 Tundra TRD
    America
    16 Tundra TRD/03 Limited TRD
    I have 03 Limited TRD 185k. Do all general maintenance on it, I’ve had brake issues and left exhaust manifold leak. Just wondering what the next common issues I should expect ??? Really try to take care of her. Few interior issues, front door panel starting to peel slowly(pleather) driver seat shot, mostly cosmetics, cv boots have been don a couple times, nothing major , any help would be great !!!
  11. Oct 12, 2018 at 6:29 PM
    #1241
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Rear axle seals leak, u joints and ball joints;) that's really it off the top of my head
  12. Oct 13, 2018 at 2:30 PM
    #1242
    TexBama
    TexBama New Member
    Rickey
    2019 Tundra SR5
    Hello Lotsoftoys,
    I have a 2019 SR5 Double Cab. It appears to be having the same issues with the pre collision malfunction that people were having with the 2018’s. I’m bringing it into my dealership on Monday and they are supposed to be looking at the software. Have you seen any 2019’s with this problem yet, and does it sound legitimate that it could be a software issue? Thanks for your time.
  13. Oct 15, 2018 at 11:57 AM
    #1243
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    No I haven't seen that, what issues exactly?
  14. Oct 15, 2018 at 12:09 PM
    #1244
    TexBama
    TexBama New Member
    Rickey
    2019 Tundra SR5
    My pre collision off light will come on out of the blue while driving but usually within the first 15 minutes of driving. You can scroll over to the PCS display and see that it is still on but it does not work. It usually last 5-10 minutes then it will go off and work normally for about 90% of the time. My front sensor is always clean when it does this so I’m not sure what may be triggering it. I just got a call from my dealership saying that they did not find any issue codes but after putting in my vin there was a software issue recall and they did an update. Hopefully this will fix it.
  15. Oct 15, 2018 at 2:49 PM
    #1245
    TexBama
    TexBama New Member
    Rickey
    2019 Tundra SR5
    I attached the description of what the dealership did. Hopefully there will not be any further issues.
  16. Oct 15, 2018 at 3:16 PM
    #1246
    TexBama
    TexBama New Member
    Rickey
    2019 Tundra SR5
    Well, it wasn’t 15 minutes away from the dealership and the pre-collision sensor turned off on its own again, so back to the dealership tomorrow morning.
  17. Oct 15, 2018 at 8:05 PM
    #1247
    Matt1794
    Matt1794 New Member
    Matthew
    2014 stocked 1794 edition tundra black and chrome
    Quick question just bought a 2014 tundra 1794 edition I’m not home to take a look at it won’t be for a few weeks I haven’t even drivin the thing yet but my wife is saying the Bluetooth won’t let her connect and the nav won’t start up it should be the entune premium but any quick advice for me to text her how to fix this issue? She misses having music
  18. Oct 15, 2018 at 11:55 PM
    #1248
    Barbsaurus
    Barbsaurus New Member
    Columbia SC
    2018 Platinum Crewmax 4x4 Super White...Fastest Color!
    DIY TPMS Tools...I hope I'm not beating a dead horse but I searched the forum for TPMS tools and found very little info. I have two sets (like summer and winter tire/wheel sets) each with dedicated TPMS. I'd like to be able to swap the sets out and not deal with a dealer or tire store. Is there an economical TPMS tool for the Tundra (2018) for a DIY'r that you would recommend?
  19. Oct 16, 2018 at 4:44 AM
    #1249
    MikeyMTBs
    MikeyMTBs New Member
    Hey man, this is less mechanical and more of a fucking annoyance. I’ve got a constant rattle in my door panels, both front driver and passenger. Toyo Service has applied some felt tape in the handle areas from the inside, but that didn’t help - it’s something else. I had my kid video the sound while driving. The Service Advisor just says, “we don’t know,” and that’s it. No willingness to diagnose. I am literally about to trade the truck in over this constant rattling. Any thoughts?
    Listen to the first and last minute of the video for the highlights.
  20. Oct 16, 2018 at 5:00 AM
    #1250
    ARES
    ARES ARES Fabrications
    God Bless America
    2018 Tundra TRD Cement
    I had issues with this myself. I tried programming the oem tpms sensors and I could not find a tool to do so that would correctly communicate with the ecu and no tire store tried 5 different ones was able to do it. They said the tpms sensors on the 2018+ tundra had like 7 digit code that was currently not supported and only the dealership could program. So $60 later and the dealership programmed them. Only issue is that they will only program oem tpms sensors. This was last month so maybe there might be a work around now.
  21. Oct 16, 2018 at 5:47 AM
    #1251
    Lake.Life24
    Lake.Life24 New Member
    Shawn
    Upstate, NY
    2021 GMC Sierra 3500HD Gasser
    Has she tried plugging in a charging cord to the USB outlet and playing it through that? I had issues with the entune system and gave up because it sucks. But for the mean time if she plugs the phone in and hits the audio button above the home button there will be a source tab that appears on the top right of the screen. If she hits that it will bring up options for ways to play music (XM, AM, FM, Bluetooth and USB). If she hits the USB one it should play music.
  22. Oct 16, 2018 at 1:05 PM
    #1252
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Was gonna say.... that update was fr the airbag system not precollision
    Blueknights75 likes this.
  23. Oct 16, 2018 at 1:07 PM
    #1253
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    It may need an update or a new head unit:/
    theres gotta be a tool that the public license can buy. We have a toyota one and an aftermarket one. Both work great
  24. Oct 17, 2018 at 9:28 AM
    #1254
    Matt1794
    Matt1794 New Member
    Matthew
    So I looked up a few things and a lot of people said take the battery out for 20 mins or there is to many phones connected to it from the previous owner or do a hard reset I defiantly don’t wanna buy a new head unit takes away from my tint
  25. Oct 17, 2018 at 10:50 AM
    #1255
    vl184009
    vl184009 Cheers Boys!
    Vicky
    Southern, Ca.
    2016 MGM CM SR5 4x4 w/Tow Pkg
    Sounds like either the window is rattling on its frame , or a cable inside the door is rattling up against the window or against the sheet metal. You know there is know padding or anything inside those doors, just a bid piece of plastic covering. Try taking off the door panel and padding the two cables..
    MikeyMTBs[QUOTED] likes this.
  26. Oct 17, 2018 at 11:49 AM
    #1256
    mcroyo
    mcroyo New Member
    COS
    2017 MGM SR5 Crewmax
    I had to pad the cables for the door lock with some foam to solve it, same sound that he is having.
    MikeyMTBs likes this.
  27. Oct 17, 2018 at 12:00 PM
    #1257
    Shaggypeach
    Shaggypeach New Member
  28. Oct 17, 2018 at 12:08 PM
    #1258
    MikeyMTBs
    Awesome, thanks. That is exactly my next step. Pull the panels and wrap the cable housing in some sort of foam. Thanks for the suggestions.
  29. Oct 17, 2018 at 5:17 PM
    #1259
    Randy Morton
    Randy
    Deepinahearta, Texas
    2012 Tundra Double Cab (I call it my Land Yacht)
    Can you pull the panels and then drive it around? That should make it easy to pinpoint the sound.
  30. Oct 17, 2018 at 6:49 PM
    #1260
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Not sure if the cables would be in their original "noisy" position though. They'd be disconnected from the door panel and hanging loose.
