Ask the Toyota mechanic!
Discussion in 'General Tundra Discussion' started by T-Rex266, Aug 15, 2015.
  1. Jun 28, 2018 at 2:36 PM
    #1171
    AC Orange
    AC Orange New Member
    Do you know if Toyo ever issued a TSB for the throw-out bearing on the 1st gen Tundra ? The FJ had a TSB issued in 2010 (#T-SB-0365-10) to replace faulty TO bearings and associated parts which were plagued by repeated failures.
  2. Jun 28, 2018 at 4:38 PM
    #1172
    Professional Hand Model
    Hand Protectors
    Check here.
    https://www.nhtsa.gov/recalls
  3. Jun 28, 2018 at 7:19 PM
    #1173
    AC Orange
    Thanks anyway but I'm not sure it would show up there. I was wondering about a Toyota Technical Service Bulletin which is more of an internal corporate thing. For example when an FJ would come in with a faulty TO Bearing (a known issue on these at the time), the service manager would consult the appropriate TSB for the parts and procedure to make the repair. I'm looking at a 2006 Tundra with stick shift and am wondering if there was an issue with these TO bearings as well.
  4. Jun 28, 2018 at 8:45 PM
    #1174
    Nick T
    Nick T New Member
    Nick
    AC Tundra,
    It is a TSB, not a Service Campaign or recall. No gen 1 would not be covered under warranty now so you would have to pay for the TSB. If your clutch release bearing (Toyota speak for throw out bearing), just replace it and the slave cylinder as the TSB outlines
  5. Jun 29, 2018 at 11:01 AM
    #1175
    AC Orange
    Yes, thanks, I'm familiar with the TSB procedure as I owned an FJ 10 years ago with 6 speed stick and had to have the TO Bearing done twice under warranty following the TSB procedure. So presently I'm looking at a used 2006 Tundra with the stick shift (clean truck w/ well under 100k miles) and am trying to find out if a TSB was ever issued for those vehicles, not because I expect Toyo to honor a warranty, rather because I want to know if those 1st gen Tundras experienced the same faulty bearings issue. The bearing business in the FJ's got kind of messy on a lot of them and personally after 2 dealer fixes plus my own repair using the PDM kit I got kind of disgusted. Three TO bearings in under a 100k miles was a bit much and I sold it. I don't really want to get mixed up in another situation like that one if those Tundras were doing the same thing. So I'm wondering if the T-SB-0365-10 covering 2007 – 2011 FJ Cruiser and 2005 – 2011 Tacoma with manual transmissions were the only Toyo vehicles with TO bearing issues ?
  6. Jul 2, 2018 at 7:25 PM
    #1176
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    Not a clue... but the fuel pump being cooled by fuel is not true
    Not that I can recall...the fj tsb was way different, went through like 3 revisions.
  7. Jul 3, 2018 at 7:53 AM
    #1177
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    WOW. I cant believe how many times i've read that the reason why there is so much extra fuel in the tank when you are on E is to cool the pump.
    Can you lay any more knowledge on us about it?
    NewImprovedRon and driverdog like this.
  8. Jul 3, 2018 at 10:42 AM
    #1178
    TRD Pro Rookie
    TRD Pro Rookie New Member
    Rick
    D/FW
    2016 TRD Pro
    Nothing major
  9. Jul 3, 2018 at 11:11 AM
    #1179
    KevinK
    KevinK SGU - High Speed Overlander
    Back in Arizona. Again.
    SGU - Speed Glampers Uberfahrt
    Tundras to Sedona
    I think every toyota I've owned has been conservative on the fuel level. It just helps dipshits not get stranded by running themselves out of gas.
  10. Jul 5, 2018 at 7:52 PM
    #1180
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    This^
    The way the fuel pump is mounted it actually sits maybe an inch off he bottom. The pick up sock is damn near at the bottom. Newer trucks are all encapsulated in a plastic module. But again pump isn't on the very bottom, the pickup is
  11. Jul 12, 2018 at 7:45 AM
    #1181
    Js18tundra
    Js18tundra New Member
    18 Tundra sr5 TRD 4x4
    Diamondback se tonneau
    Question, I want to do a drain and refil of the p/s reservoir every oil change, what’s the best fluid to use on the power steering system? 2018 cm
  12. Jul 14, 2018 at 2:21 PM
    #1182
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    That is a gigantic waste of time and money... but it's your truck. At the dealer we use pennzoil. In my offroad rig I use Lucas oil, pricy tho
    BTBAKER and (deleted member) like this.
  13. Jul 14, 2018 at 2:34 PM
    #1183
    Norfolk757
    Norfolk757 עַם יִשְׂרָאֵל חַי
    Tom
    Norfolk, VA
    2015 White Tundra- CrewMax TRD Off Road
    Would you happen to know why I get a pic of white smoke when I start the truck. It only happens if the truck had been sitting between 2-12 hours on I initial start. I’ve changed the PVC valve and done a dealer oil flush. The truck is 2015 5.7 with 70k miles. Thank you.
  14. Jul 14, 2018 at 6:10 PM
    #1184
    Js18tundra
    Lucas atf dex 3?
  15. Jul 18, 2018 at 5:09 PM
    #1185
    Skippy
    Skippy Standing for the Flag
    San Antonio US of A
    2016 Tundra 1794
    I have the stock air flow box, but installed the TRD Airflow Accelerator along with an aFe Power Magnum dry filter. My question is this, I was thinking about getting a filter minder and wanted to know what would work best with my setup? Thx
  16. Jul 18, 2018 at 6:46 PM
    #1186
    Hand Protectors
    1) How much propeller movement is ‘normal’ inside a carrier bearing bushing? In other words, how much movement should/does the shaft have inside the rubber bushing? Mine has about 1/4” up movement if I go under and push it up. Rubber looks good (original).
    2) Also, I successfully greased all the zerks on the rear propeller. Using the same gun/tip, was UNABLE to grease the 4WD propeller zerks. The tip fit (barely as its tight), but the grease did not pump into zerks. The grease oozed off and around zerk. What trick do you use to grease these 4WD propellers?
    3) Slight leaking at valve covers back corners. I’ve tightened the cover bolts a few times over the years as they become loose from contraction/expansion. What mileages are you seeing the valve cover gaskets needing to be replaced? And what other things you recommend while ‘around there’?
    Thank you for your responses, sir.
    2002 Tundra SR5 AC 4WD
    157k miles
    No mods
  17. Jul 20, 2018 at 9:35 PM
    #1187
    Dhoyt88
    Dhoyt88 New Member
    Dylan
    2013 tundra cm 5.7
    Level kit on 35's and exhaust
    I am at a loss I purchased my tundra about 6 months ago and have had issues since I bought it. I just took it today to another mechanic and told me I am intermittently throwing misfires on almost all cylinders and no codes are being thrown or pending. If I accelerate heavily over 4500 rpm it feels as though a rev limiter is being hit. I changed out the spark plugs my truck has 85000 miles on it. It is 5.7 flex fuel. Please need help I love this truck just running into a wall at this point in fixing.
  18. Jul 25, 2018 at 6:44 PM
    #1188
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    White smoke? That's typically coolant burning... sure it's not blue ish grey? Flex fuel?
    I'm pretty sure it says p/s fluid in the title
    Just check the air filter e ery oil change?:shrug:
    Kind of all over the place... different for each vehicle. U should replace you spark plug tube seals and reseal the half moons while u do the vcg's. Also pcv PCv valve
    Bring it to a dealer. We are trained much more then independents. I'd be watching my air in and air out when its happening... also would be recording the misfires to really see which cylinders are showing.
  19. Jul 26, 2018 at 4:03 PM
    #1189
    Hand Protectors
    Thanks bud. Will be planning this repair into the future budget. Thank you for sharing your knowledge and experience. Its greatly appreciated.
  20. Jul 29, 2018 at 5:55 PM
    #1190
    jaredmillerdvm
    jaredmillerdvm Mods will never end!!
    Anderson, SC
    2018 MGM CM SR5 TRD Off Road 4x4
    Rough Country 3in leveling kit, SCS Ray 10s, 295/70/18 Toyo Open Country AT2 Extremes. TRD Shift Knob, Console Safe, Driver Side Grab Handle, WeatherTech Laser Measured Floor Liners, Katzkin Heated Leather Seats, Remote Start, TundraTex Frac Harness, Radio Vinyl Inlays, LED Interior Lightening. MGM Color Matched Hood Bulge and Surround, 18% Tinted Front Windows, 90% Ceramic Windshield Tint, 5% Banner, AntennaMast Stubby Antenna, Predator Step Bars, Skid Plate with Integrated Step, Line-X Spray in Bed Liner, Blacked Out Badges, Mirrors and Door Handles, Black Bedside Decals, Bak Revolver X2 Tonneau Cover, Swing Case Tool Boxes, DIY Tailgate Lock, Deck Rail System, Recon Smoked LED Tail Lights With LED Reverse Lights, Smoked Vinyl Wrapped Cargo Light, LED License Plate, Cargo, and 3rd Brake Lights, Dirty Deeds 8" BAMuffler, Black Powder Coated Front and Rear Bumpers, TRD Rear Sway Bar.
    I will start by saying I have no mechanical experience, I had to google what UCA meant when I first joined the site, so please bear with me! Again, I will likely call parts by the wrong name but I would like your opinion. Had a leveling kit installed in December and had no problems until now. The other day I was in a parking lot and had to slam on the brakes to which it made an awful sound. Since then I would intermittently hear a loud popping sound coming from the front end. I took it to a local Toyota dealer where they told me whoever installed the leveling kit may have not torqued a bolt enough cause it was now loose. I THINK they said the bolt on the lower control arm OR lower part of control arm? Something about a cam being shifted out of position then falls back into place? They described 2-3 little metal tabs holding the cam in place. They said what likely happened was the bolt came loose and then when I slammed on the brakes it bent the metal tabs flat. If you understand what I’m saying do you think the guys who installed my leveling kit could tackle this? They agreed it’s their fault since they were the last people to touch that particular bolt. They said their mechanic could either re bend the tabs or order new ones from Toyota and weld them on. Whatcha think? Does this make sense? What is your advice?
    Shawn Sparks likes this.
  21. Jul 30, 2018 at 5:32 AM
    #1191
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Haha you did great because i know exactly what you are talking about. However they are telling you some misinformed info. The tabs cannot be bought from toyota. Once they are bent, the cam bolt and eccentric needs to be removed and the tab bent back vertical. Now that the tab is back vertical, they need to weld behind it so it cannot bend again. Alot of people weld behind the tabs before this happens to prevent it offroad. Total chaos makes a kit for an even beefier repair for vehicles that are best on heavily. I bend and weld behind tabs all the time.
  22. Jul 30, 2018 at 8:10 AM
    #1192
    jaredmillerdvm
    Anderson, SC
    Perfect. The mechanic was back in the shop today and did bend the tabs back. I will ask if they welded behind them for added support. Also the cam bolt was bent so they had to order another one. Should be all fixed up tomorrow! Thanks for your time!
  23. Aug 1, 2018 at 2:43 PM
    #1193
    txsundance
    txsundance New Member
    Just west of weird...
    2008 Crewmax
    Lear Topper
    connector.jpg Bought a used topper for my 08 crewmax and I'm trying to hookup third brake light, topper dome light, and I would like to add a dc outlet inside the topper as well. Searched the site but can't seem to find info on where I should hook into. Read somewhere I shouldn't just splice into the brake light wire. When looking under the truck bed I found this connector on the passenger side that seems to go to nowhere (four wires with a capped connector-what is it for?). I've found youtube videos online for other trucks that have a wire under the bed for a brake light connection. Any advice would be appreciated.
  24. Aug 3, 2018 at 11:44 AM
    #1194
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Why would u tap into a brake circuit for a auxiliary outlet?
  25. Aug 5, 2018 at 10:31 AM
    #1195
    txsundance
    2008 Crewmax
    Lear Topper
    Any where on the site where there are wiring diagrams for the gen 2 Tundra? If I'm running the hot wire back from the battery what gauge wire should I use, same with the trigger wire? I've only replaced existing relays on my vehicles, are they pretty standard or voltage specific? The hot power source is for DC outlets primarily for usb chargers and enough power for the dome-light and some additional interior led lighting. Eventually I would like to add a 2nd battery charged by the alternator (RV type setup) to keep from draining my primary battery while camping from the topper. I think I need a course on DC power.
    NewImprovedRon likes this.
  26. Aug 6, 2018 at 11:06 AM
    #1196
    txsundance
    2008 Crewmax
    Lear Topper
    I've spent a couple of hours this weekend studying info on relays and DC wiring. Thanks, this information is very helpful and I really appreciate it!
  27. Aug 8, 2018 at 8:00 PM
    #1197
    yoda4ever
    yoda4ever New Member
    Canada B.C.
    2014 Toyota Tundra TRD OR
    Anyone know if coachbuilder 3 shackles and bilstein 6112 on top setting ends up with the truck on a rake? Considering this with 5100's on the back and some firestone airbags for when I have to haul heavy loads. If theres a better place to post this question please let me know
  28. Aug 12, 2018 at 2:24 PM
    #1198
    Rider0120
    Rider0120 New Member
    Bucks County, Pa
    2018 White double cab SR 4x4 long bed
    Ranch Hand full replacement bumper
    I would like to revisit a question I asked in February about the safety sense sensor in the emblem. I have been watching the threads and FB to see who would put a grill guard on their tundra and have problems or success installing a “ranch hand bumper with grill guard”. Has they’re been any bulitens from Toyota about grills gaurds, fishing rod holders, or plows? I’m asking because I work shift work and get called in late at night and leave early in the morning and I would like to pull the trigger on some extra protection from deer and other drivers since winter will be here before we know it.
  29. Aug 13, 2018 at 1:30 PM
    #1199
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    As far as I know, nothing should be Installed that blocks the sensors field of view.
  30. Aug 16, 2018 at 6:46 AM
    #1200
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    Any tips for replacing the transfer case input seal in a 2000 4.7? Mine is leaking, looks like getting the front drive shaft out of the way might be a pain because its so tight with the exhaust and cross member.
