Ask the Toyota mechanic!
Discussion in 'General Tundra Discussion' started by T-Rex266, Aug 15, 2015.
  1. Apr 29, 2018 at 5:26 PM
    #1141
    sargebt
    sargebt New Member
    Brandon
    2016 Platinum Tundra
    7 inch BDS, running 35’s
    Yes I do have an apps button
  2. Apr 30, 2018 at 9:39 AM
    #1142
    onsafari
    onsafari New Member
    Mark
    Castle Rock, CO
    2016 Tundra CM TRD
    Going to throw this question out to the mechanics of the site before I go to dealer to only be told we can't replicate the noise or it's normal but twice now on a cold start up I get about 2 seconds of load lifter noise or piston slap then it goes away. It's on a 2016 CM with 42,000 miles. To me it sounds like a stuck lifter and the only reason I say that is I had a similar issue on an older BMW. Anybody else have or heard of a similar issue?
  3. Apr 30, 2018 at 3:27 PM
    #1143
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    Then u have entune
  4. Apr 30, 2018 at 3:28 PM
    #1144
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Toyotas make weird noises when cold.... they just do
    GV1990, Rex Kramer and Black Wolf like this.
  5. Apr 30, 2018 at 3:42 PM
    #1145
    Sounds normal to me. Mine does and my 09 Taco did. Taco got quite noisy after a couple weeks at minus 20. Lucas Upper Cylinder treatment works. Quieted down my Taco quite a bit.
  6. Apr 30, 2018 at 8:03 PM
    #1146
    sargebt
    sargebt New Member
    Brandon
    So then why won’t my truck pick up the Bluetooth on my phone and connect the app?
  7. May 7, 2018 at 8:01 PM
    #1147
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Not sure, you have the appower on the phone? You connected via Bluetooth or cord?
  8. May 8, 2018 at 7:40 AM
    #1148
    Kanobi13
    Kanobi13 New Member
    I am having the same issue only 3500 miles does the mechanic have a real answer than there just noisy thanks
  9. May 9, 2018 at 11:46 AM
    #1149
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    You're both under pt warranty still, bring it in and have them start it fresh cold the next morning. Bet it doesnt do anything abnormal.
    Gotta realize oil drains out of thsee cylinder Der heads to the pan over night, if there's a split couple of seconds of tapping it's not a big deal. More commonly we hear piston slap a few rat a taps when cold and it goes away in 3 seconds. The pistona are designed to warm up and take full shape inside the cylinder.
  10. May 9, 2018 at 12:36 PM
    #1150
    Kanobi13
    Kanobi13 New Member
    Makes sense just started out of the blue did not happen any other time
  11. May 10, 2018 at 6:34 PM
    #1151
    sargebt
    sargebt New Member
    Brandon
    Bluetooth. App won’t connect.
  12. May 10, 2018 at 6:44 PM
    #1152
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    A question about drive shafts.
    How many RWD 5.7L RCSB owners have had their drive shaft replaced?
    Mine is original, and it has the metal dust cover bell on the front as pictured.
    The 6th version replacement shaft looks very different, and it replaces 5 previous drive shafts.
    What is leading me to these questions: The transmission oil seal 90311-49006 is leaking just a bit... is there a way to replace the seal without replacing the shaft, or must the shaft also be replaced?
  13. May 11, 2018 at 12:38 PM
    #1153
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Try connecting a cord. IT helps some phones
    awesuming 2wd?
    that's a parts question.... but I'm betting it's the same seal regardless of shaft
  14. May 11, 2018 at 3:23 PM
    #1154
    Rex Kramer
    Georgia
    10-4, RWD and the seal is the part # I posted.
    I am concerned with the drive shaft for the same RWD '07 with a 5.7L.
    The current & original drive shaft looks nothing like the replacement shaf
    Toyota lists for the truck via VIN# search and dealer parts guy look up.
  15. May 25, 2018 at 8:22 AM
    #1155
    Prime2016
    Prime2016 New Member
    Deerfield Beach, FL
    2016 Tundra SR5
    This is amazing. I'm re-posting this from another thread I made, any help would be greatly appreciated!
    ORIGINAL POST: 07-May-2018
    Hey everyone,
    I have a 2016 Tundra SR5 Double Cab 4.6L. First time truck owner and it's great, don't think I ever want to go back to a car, I use it for recreation and commute. However, immediately after I bought it, I started running into intermittent issues at slow speeds. Either leaving my driveway, taking off from a red light or stop sign, and even slow riding the parking lot, I felt like when I pressed on the gas it acted almost as if it were in neutral and would only rev loud and not move forward much until it finally shifted into gear. It didn't feel normal and it definitely didn't feel like that when I was test driving it along with other 4.6L double cabs. I took it to the dealership and they told me it was perfectly fine and no error codes came up from diagnosing. I told myself OK maybe this is just normal for a V8 truck - I didn't know. But it kept doing it after I took it home - so frustrating.
    After some research, I did an "idle-relearn" which seems to have fixed it for the moment - haven't driven it enough to feel completely comfortable about it yet, but it seems to drive like the other 4.6 double cabs I test drove before purchase. I was thinking maybe the previous owner hauled heavy loads on a daily basis and the truck was used to that style of driving? Any one else run into this? If you have, do you know what the root of the problem was/is and did you do anything to resolve yet?
    UPDATE: 24-May-2018
    Well the truck went back to sounding like annoying vacuum cleaner while driving at slow speeds (0-20mph). Sounds like too much gas being used for the amount of force being provided via the gas pedal.
    Sometimes it wouldn't make the sound but that was only when I had it warming up for a whopping time of 45 seconds to a minute and a half. I could tell this is the right time before taking off because the RPMs would suddenly dip to 800-900 from 1100-1200 and the the engine calmed. Anytime I drove off before any one of those factors the truck wasn't complying.. So thinking that even 45 seconds was probably a ridiculous amount of time to warm up, I unhooked the battery again, this time for three hours - and just as last time it started driving beautifully. It didn't have that vacuum cleaner sound and it purred deep and clean while smoothly shifting.
    A day later it started doing it again, it sounds like my shop-vac is under the hood during this process.
    Not sure what to do...I was really hoping unhooking the battery was going to solve my problem.
    A) Try emptying out the gas tank completely? I have already run it down to "4 miles until empty" then refilled.
    B) Take it a different location Toyota dealer for second opinion?
    C) Is this a lemon and should I trade now to get the most value?
    D) OTHER - I'm all ears
    Thanks everyone for all the help before and in advance.
  16. May 25, 2018 at 1:02 PM
    #1156
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    The vacuum cleaner noise is the air injection lol.... there are air pumps that inject air into the exhaust stream to warm up the cats for high efficiency.
    Prime2016 likes this.
  17. May 25, 2018 at 1:04 PM
    #1157
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    As for the lack of throttle response I'm not entirely sure I know what you mean... the flyby wire throttle on these things are touchy as hell imo. Is there any chance you are a 2 footed driver? I've seen where people will still be on the brake pedal for a split second when trying to accelerate and the truck wont have it
  18. May 25, 2018 at 8:54 PM
    #1158
    Xmax
    Xmax New Member
    2016 SR5 Crewmax
    I've done the two-footed thing, and you will swear that the truck is stalling. Bad habit!
  19. May 30, 2018 at 6:06 AM
    #1159
    Prime2016
    Deerfield Beach, FL
    2016 Tundra SR5
    Thanks for the feedback. No, have not driven with two feet while using automatics. Maybe the air injection system needs to be serviced... Based on everyone's feedback and to my unprofessional ear, it sounds like something is faulty with air or fuel system.
  20. Jun 3, 2018 at 12:27 AM
    #1160
    mini BEEFY
    mini BEEFY New Member
    Mitchell
    Mission Viejo, CA
    2017 Tundra SR5 CM 4X4
    Does anyone have info (step by step), links to articles, videos or something to help me.
    I am going to vinyl wrap my roof and I need to know how to remove the front passenger satellite antenna and 3rd brake light. I know I need to lower the headliner, but don't want to mess it up. Thanks in advance.
  21. Jun 3, 2018 at 7:32 PM
    #1161
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    The fact u are afraid of messing it up kinda hints towards u shouldn't do it. Very easy to fuck up a headliner... maybe let the vinyl shop do it?
  22. Jun 3, 2018 at 7:39 PM
    #1162
    lionix
    lionix The Grey Moose!
    Cape May, New Jersey
    2017 Tundra TRD Pro CM Cement
    BD Lights, Any Time Fog, Coachbuilder, Pelfreybilt, Bakflip, Custom Bed Rack w/ Tent
    Most vinyl places will leave them there and cut in around it.
  23. Jun 3, 2018 at 11:42 PM
    #1163
    mini BEEFY
    Mitchell
    Mission Viejo, CA
    400 bucks for them to do it, 80 for me
  24. Jun 4, 2018 at 6:44 AM
    #1164
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Drop a pillars, b pillars and c pillars, remove all door weather strips and lastly remove any clips and dome lights /sunroof trim
  25. Jun 4, 2018 at 6:44 AM
    #1165
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    That's a terrible vinyl install then
    lionix[QUOTED] likes this.
  26. Jun 4, 2018 at 7:07 AM
    #1166
    lionix
    That's very true. But most of the shops are just trying to make a quick buck. You get what you pay for seems to hold true when talking automotive applications.
  27. Jun 4, 2018 at 7:41 AM
    #1167
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I suspect that this is just your radiator fan engaging at start up and during low speed driving to keep air moving through the radiator. It's normal.
    Prime2016[QUOTED] likes this.
  28. Jun 25, 2018 at 2:49 PM
    #1168
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    @LOTSOFTOYS Have you cracked open one of the 38gal gas tanks? I'm curious at what fuel level the pump becomes exposed.
  29. Jun 26, 2018 at 6:13 PM
    #1169
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Actually put a fuel pump in one last week. Not sure I understand ur question tho?
  30. Jun 26, 2018 at 7:24 PM
    #1170
    Danimal86
    Daniel
    Sacramento, CA
    Every couple weeks, I see a thread about "the gas gauge was on E but when I filled up it only took 28g gallons of gas. I thought my tank was 38....."
    Then the answer is, "fuel pump is cooled by the gas, so it need to have a certain amount........."
    My question, is this true, and at what level does the pump become exposed.
