Ask the Toyota mechanic!
Discussion in 'General Tundra Discussion' started by T-Rex266, Aug 15, 2015.
  1. Oct 31, 2017 at 5:38 PM
    #1021
    TundraTss
    TundraTss The Mistress
    Brandon
    2019 TRD SR5
    Everything. Literally.
    @LOTSOFTOYS,
    When I install wheel spacers, can or should I just loc-tite them to the existing lugs or do I just torque them to spec and re torque them every so often?
    Thanks.
  2. Nov 1, 2017 at 11:41 AM
    #1022
    650h1
    650h1 New Member
    2013 Rock Warrior C/M
  3. Nov 1, 2017 at 6:30 PM
    #1023
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    I wouldn't loctite them... but why are they coming loose? Weird...
    Piston slap? A lot of these newere aluminum block engines are louder and cam hear piston slap when cold but it's considered normal.
    Yes go compare
    definitely loctite. Don't need red... but blue. And torque to 90-100
  4. Nov 2, 2017 at 7:25 AM
    #1024
    650h1
    650h1 New Member
    Yeah but it just started doing it... I've replaced the tensioner and idler pulley and it's still doing it. Starting to piss me off. It's s clear metal on metal rattle...
  5. Nov 2, 2017 at 8:47 AM
    #1025
    Biff_Elwood
    Biff_Elwood New Member
    Denver
    2014 Platinum
    Im working on it!
    Hi there. Im the new owner of a 2014 Platinum that was a previous lease and currently has 37,000 miles. I would like to do a maintenance baseline of the vehicle. What do you recommend to do first and can anyone recommend a shop to perform the work in the Denver area?
    Thanks!
  6. Nov 3, 2017 at 8:22 PM
    #1026
    Cemoto
    Cemoto New Member
    Al
    Hello - Thank you for answering our questions.
    I've done as much research as I can but have found nothing that works for my question.
    I have an '06 Tundra Double Cab 4wd Limited and would like to have the doors auto lock when put into drive or when the vehicle starts rolling like my Camry's do.
    Would you happen to know of a way to do this?
    I've tried the put it in N and hold the door lock button and have done the five on/off sequence as well without results.
    Thank you.
  7. Nov 5, 2017 at 10:47 PM
    #1027
    LittleBlue4x2
    LittleBlue4x2 New Member
    2010 4.6L Toyota Tundra 4x2
    3 inch lift, radio.
    I’ve been wanting to install the Flowmaster American Thunder 817664 on my 2010 4.6L v8 Tundra. Does anyone have this on their truck and does it sound good?
  8. Nov 16, 2017 at 9:53 AM
    #1028
    FISHMASTER
    FISHMASTER New Member
    KURT
    South dakota
    2017 TUNDRA
    clean it up and use pure Silicone adhesive
  9. Nov 17, 2017 at 7:53 PM
    #1029
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Yeah stevinson Toyota west;) u need a 30k service: driveline service, cabin filter, air filter, rotate& balance alignment wouldn't hurt
    I'm not sure our tundra have that capability
    You probably did get the Trans temp high. Don't do that anymore lol.
    Biff_Elwood[QUOTED] likes this.
  10. Nov 18, 2017 at 11:19 AM
    #1030
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Would help yes. I would also ask if your truck has the tow package and the extra Trans cooler up front?
  11. Nov 21, 2017 at 1:28 AM
    #1031
    Surhance
    Surhance New Member
    2007 Black Tundra TRD
    I just had the P2442 code come up on my 2007 Tundra, thought I fixed it a couple of days ago but came back. Upon further digging and these posts I now know what the problem is, my only concern is the cost. I bought my truck used 6 years ago and didn't know about this problem, never receive a letter from Toyota and now I'm over 170,000. Is it worth going to the dealership and getting it fixed or better to go to an outside shop? Which would be cheaper.
  12. Nov 21, 2017 at 7:11 AM
    #1032
    McTundra12
    McTundra12 New Member
    '12 CrewMax TRD
    Notta
    Long time listener, first time caller....
    I have a squeak coming from the outer edges of the steering rack, or at least it sounds like it. I hear the squeak while traveling over small bumps, and turning slightly, not when turned halfway to lock. I have lubes all bushings on front end, but i was thinking of poking small holes on the outer rack boots so that i could shoot some lube on the tie-rod shaft where it would enter the rack. No leaks are aparent.
  13. Dec 5, 2017 at 6:48 PM
    #1033
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    I wouldn't poke holes... racks don't typically make squeaks. Can u duplicate it by just bouncing on the truck when parked?
  14. Dec 6, 2017 at 4:03 AM
    #1034
    McTundra12
    '12 CrewMax TRD
    Notta
    I can dublicate to a point by rocking the truck. But the noise seems to be coming from the behind the skid plate, I just haven’t had time to remove it and test. Is there anything in the area around the rack that would squeak?
  15. Jan 5, 2018 at 7:28 AM
    #1035
    caboose
    caboose -1
    somewhere in the USA
    tundra dc trd
    ride rites w/ air compressor, trd pro grille, decked bed storage, nfab rkr rails w/steps, remote start.
    I noticed the other day my aftermarket remote door locker didn't cause my car to beep and the lights didn't flash. So I figured out that my front drivers and passenger side doors weren't locking. I then tried to use the door lock button on the inside and still no go. The back doors lock with both the use of the button and key fob thing. I also visually checked the all the fuses and used a continuity tester on them and they all seemed good as well as pulling the fuse for what was labeled door on my fuse cover(a white 25a fuse on the inside fuse box). Does this seem like a door lock actuator? Is this the type of thing covered under warranty I have a 2016 tundra with 32k miles? My third question if it is the actuator I have read on other forms that the motor can be ordered online and replaced in the current actuator to fix the problem for a fraction of the price?
  16. Jan 5, 2018 at 7:37 AM
    #1036
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I'm thinking that you're going to have to remove the skid, get under there and listen while someone else rocks the truck. Be super careful though. Also, I think that the rack is mounted on rubber bushings, maybe some crud got in there, not real common but could happen.
  17. Jan 5, 2018 at 7:38 AM
    #1037
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Sounds like you're within the warranty period, I'd pursue that first.
    NewImprovedRon likes this.
  18. Jan 13, 2018 at 10:32 AM
    #1038
    T-Rex266 [OP] Owner, CTO and executive chairman of X Staff Member
    Lots of mechanical questions popping up in threads.
    Bump
    fordguy1470 likes this.
  19. Jan 13, 2018 at 12:42 PM
    #1039
    Junior4888
    Junior4888 2007 Toyota Tundra Limited 4.7l
    Travis
    Moxee, WA
    2007 Toyota Tundra Limited Dbl Cab 4.7l
    I have a mechanical question. Wife and i are on a road trio and my truck us acting up. 2007 4.7l 125k. While driving at 70mph the throttle cuts out and engine loses power. If i lift off the throttle and push again the power comes right back. Been doing this for about the last 15 miles randomly. Has done it in the past but for short periods of time and then it doesnt happen again for a few days. Doesnt matter the speed or temperature. Never got any check engine light and guages are all normal. I am baffled at what would cause this and if i need to take it into the shop but not sure what the problem is.
  20. Jan 13, 2018 at 12:59 PM
    #1040
    Areith762
    Areith762 Go Avs!!!
    39.944182, -104.760113
    2017 Blazing Blue 5.7L CM SR5 4X4
    DAP Tune, Katskin interior leather, ESP rear under seat storage, door sill protector, door edge protector, TRD Pro shift knob, heated seats, all weather Tundra floor mats, driver side a-frame handle, Tundra trucks center console emblem, clear bra protection, Bushwacker fender flares, paint match front bumper caps, paint match rear bumper caps, paint match mirror caps, ProComp 3/1 lift, 20" Fuel wheels, 33-11.50/R20 Falcon tires, black TRD Pro badge's, black Tundra tailgate badge insert, TRD Pro headlights, Recon smoked tail lights, Recon smoked 3rd brake light, Roll N Lock tonneau cover, Line-X bed liner, Tundra bed mat, Cobra led remote alarm/remote start, N-fab tube steps, factory match window tint, TRD Pro grille -paint matched, paint matched hood bulge, TRD dual exhaust, Black out exhaust tips, led interior lights, led plate lights, Spyder smoked fog lights, TRD Cold Air Intake
    I had a similar issue in my work van (ford) just last week. I thought it was a vacuum issue of some sort so I took it into the shop. Turned out it was the spark plugs. 3 of 8 were not firing, but all needed replaced. The engine sounds different now, more smooth and I haven't had the issue since.
  21. Jan 15, 2018 at 11:09 PM
    #1041
    Ccrames
    Ccrames 2014 SSM CM 5.7
    Nor Cal
    Bilstein 5100s, Method Standard 18x9 +18 offset, 285/65R18 Toyo A/T2 Xtreme, trailer brake controller, bed liner, camper shell. All were on the truck at time of purchase.
    Hey LOTSOFTOYS, thanks a lot for answering everyones questions as im sure you get enough questions at work as it is!
    So, im not really sure if this is actually a problem or not, and i didnt have time to read through the whole 37 pages, so im sorry if someone has asked this before. When i go to start my truck, usually when its cold, it fires up like normal for about 1 second, then dips down to 500-600 rpms for another 1.5 to 2 seconds before going back to the normal idle speed. It doesnt always do it, and ive had no issues, but i drive a lot as it is my DD and really dont want any unforseen mechanical issues. Thanks again for your help and the knowledge you are willing to share with all of us!
  22. Jan 17, 2018 at 3:48 PM
    #1042
    multirc
    multirc New Member
    Ron
    2018 Tundra 1794 Edition
    Hello, I finally had a chance to check out the outside of my 2018 1794 Edition truck in daylight somewhat and I was looking through the rear wheelwells and I see rust???? On a brand new truck I picked up a week ago that had only 2 miles on it? Is this normal for a brand new truck? I live in New Jersey so we had snow but the truck hasn't moved since I bought it last week and I don't believe the 2018 truck has been sitting in the let THAT long. Is this normal? I mean, am I being nit picky? I had a 2007 4Runner that I bought new and didn't see any rust at all.IMG_2202.jpgIMG_2297.jpgIMG_2296.jpg
  23. Jan 17, 2018 at 5:58 PM
    #1043
    multirc
    multirc New Member
    Ron
    Yeah but I didn't think it would form that quick. Maybe after 6 months yeah. Fluid Film eh?...Never heard of it and I will definitely check it out and take care of it. I thought it might have been the rusted recall crap on the Toyotas I was reading about. Thanks for your reply. I really appreciate it.
  24. Jan 17, 2018 at 6:38 PM
    #1044
    multirc
    multirc New Member
    Ron
    yeah, I will put some of that on the cables as well. By any chance, would you happen to know what this Toyota Security is for? I checked the manual and they just have it whited out with no explanation. I feel like the Government is listening to me in my truck...LOL!!
  25. Jan 18, 2018 at 5:27 AM
    #1045
    multirc
    multirc New Member
    Ron
    Yeah thats what I was thinking. Have to be careful now conversating in the truck, you never know...just like the iPhone with the finger print unlock...thats how they get ya!...lol
  26. Jan 18, 2018 at 7:07 AM
    #1046
    ChucklesToy
    ChucklesToy Retired
    Chuck
    Georgetown , TX
    2024 Honda Ridgeline Black Edition
    yes, it is the glass break sensor...lol
  27. Jan 20, 2018 at 7:35 AM
    #1047
    fordguy1470
    fordguy1470 Member-ish
    West Columbia, SC
    22 CM SR5
    Getting there
    Ok. I'm having a cold start issue. My truck is an 18 with the 5.7, 1100 miles. The problem is intermittent. What's happening is during some cold start situations it'll turn over once and shut right back off, the second attempt, it starts with no issue. The problem only seems to happen if I've idled a lot the last time I ran it, which with the weather has been a lot. It's almost like it's loading up like something with a carburetor would, but there's no roughness or hesitation after it does start, and I always give it a little Italian tune up after this happens. No codes it anything.
  28. Jan 20, 2018 at 7:52 AM
    #1048
    Kilos
    Kilos YotaPro
    Brett
    AZ
    2017 TRD Pro Barcelona Red
    Icon Stage 6 suspension Method NVs matte black w/Toyo Tires 35x12.5s SDHQ Sliders Cab mount chop Precision LED interior lights (6000k) GTR reverse LEDs 20% acrylic tint (heat resistant) Inyati spray in bedliner Black TRD Pro bed inserts Vivid Racing Leather wrapped steering wheel AJT Designs TRD shift knob AJT key fob Morimoto LED fog lights Full JL Audio sound system upgrade Kenwood 995S HU
    For those of you that installed sliders, did you use (red) loctite? SDHQ references it, but is not included in the instructions.
  29. Jan 20, 2018 at 8:40 AM
    #1049
    757TUNDRA
    757TUNDRA Not a New Member
    Illinois
    2018 Barcelona Red Metallic Platinum 4x4
    OEM Bed Cover, OEM Bed Rail System, OEM Bedmat, OEM Doorsill Protectors, OEM TRD Rear Sway Bar, OEM Color Matched Door Handles, OEM Color Matched Mirror Caps, OEM Bed Net, OEM Driver Side Grab Handle, BFG K02 LT275/60/20, WeatherTech Digifit FloorLiners, Salex OCD Console Organizer, Salex Console Tray
    If it's flex fuel you may need the reflash at the dealer. I've never dealt with it but have seen a few others have your issue. It's a quick software fix, something to do with the flex fuel electronics.
  30. Jan 20, 2018 at 9:14 AM
    #1050
    fordguy1470
    West Columbia, SC
    22 CM SR5
    Getting there
    Mine isn't FF but I'll take it in Monday and see if they'll reflash it, and that solves the problem. It's just one of those minor annoyances.
