Ask the Toyota mechanic!
Discussion in 'General Tundra Discussion' started by T-Rex266, Aug 15, 2015.
  1. Apr 13, 2017 at 10:59 PM
    #781
    Cat3ILS
    Cat3ILS The cheese goes on the bottom bun
    2014 platinum CrewMax 4x4 5.7L - white
    2.5 level, 285 Toyo OC, Or-Fab trans/cat skid, X2 Revolver, ESP storage, Husky's, Lock'er Down safe, OCD organizer, Interior LED's (red drivers), Glove and safe motion LED's, Rhino lined
    Valve cover gasket is definitely what I meant @Wynnded thanks for the save, it's been corrected :der:. IIRC you had this issue didn't you?
    @Fightnfire note the correction...
    Wynnded[QUOTED] likes this.
  2. Apr 14, 2017 at 4:44 AM
    #782
    spidertb
    spidertb New Member
    Todd
    St Thomas, Ont
    Yes it would be around 12 Mph. Thanks for the info.
  3. Apr 14, 2017 at 5:36 AM
    #783
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    Perfectly normal
    Cam tower leaKS are the biggest item to look out for
    Doubtful it would fit
    I'd wait for the service... if it does end up being the abs, that's a new one to me. Learned somethin;)
    Cat3ILS and T-Rex266[OP] like this.
  4. Apr 14, 2017 at 8:10 AM
    #784
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Ya, good time. Not really though.
    The door locks mask the sound at 12mph if that's set. It's rather subtle, but you'll recognize it for what it is. After a restart, lock the doors then begin to move the truck. At 12mph you'll hear it. It's so loud where you work, you may have still have trouble catching it.
    Cat3ILS[QUOTED] likes this.
  5. Apr 23, 2017 at 8:00 PM
    #785
    kyle7630
    kyle7630 New Member
    Kyle
    08 Tundra XSP
    None
    I'm having an issue with my '08 Tundra. I turned the key to start the truck and didn't get anything. No crank, no start. The check engine light and the traction control light illuminated solid, and the VSC off and 4LO lights began to blink. I turned the key to the off position and tried again. This time the engine would turn over, but not start. I tried again and the engine started. I have not had trouble starting the truck since, but the lights remain. This happened before, with the same light combination, but the truck would not do anything and the mechanic replaced the starter. I also read of a similar issue from another forum member here; https://www.tundras.com/threads/diagnosing-my-possessed-tundra.11989/ Maybe your knowledge can help two of us at the same time. Thanks in advance for any insight you can provide!
  6. Apr 24, 2017 at 5:23 AM
    #786
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Doesn't sound like a starter.... what codes are in it?
  7. Jun 8, 2017 at 7:42 PM
    #787
    Principal24
    Principal24 New Member
    I have an 02 Tundra with 4.7 V8. I have 25k on the water pump but the pulley on the front that is driven by the serpentine belt is making noise like a bearing is shot. I can find the part but was told today by an Autozone worker that this pulley is machine pressed onto the water pump and I will have to replace the entire water pump. Of course, I would like to just replace the pulley. Can anyone help me out with a little advice?
    Tomcat likes this.
  8. Jun 8, 2017 at 10:35 PM
    #788
    Tomcat
    Tomcat Ever see a motorcycle outside a shrinks office?
    2010 SR5 4X4 5.7 20" wheels Metallic Gray
    Bakflip
    If the pulley is pressed on you most likely will have to buy a new water pump. If you bought the last water pump from Autozone that may be a problem as well. I have not had good luck with parts from Autozone. Their parts are the cheapest for a reason. What kind of warranty did you have on the last water pump?
  9. Jun 9, 2017 at 6:36 PM
    #789
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Dosent make much sense... the serpentine belt doesn't drive the water pump. The timing belt dors. If u installed a new water pump 25k miles ago, doubtful that's the failed part don't u think? Maybe it's the fan clutch bearing?
  10. Jun 9, 2017 at 7:34 PM
    #790
    Principal24
    I used the old trick of placing the end of a long screwdriver to the different parts of the engine and listening to the handle end. It is the water pump making the noise. There are no leaks or elevated temp and it seems to be working fine. The water pump was replaced by Napa using a quality part. It is under warranty, but I will have to pay labor. I can easily replace that front pulley myself.
    Tomcat likes this.
  11. Jun 9, 2017 at 9:52 PM
    #791
    Tomcat
    Bakflip
    Easily replacing a pressed on part? The only way to replace a pressed on part is with a press. To do that you would have to remove the water pump. If you remove the water pump you might as well use your warranty. Wait, I'm not the Toyota mechanic just talking from experience with pressed on parts. Just my 2 cents, because I'm a lot better at thread jacking and shennanagin's. One day I will learn how to spell Shenanigins. Maybe not, but I will keep trying.
    NewImprovedRon likes this.
  12. Jun 9, 2017 at 10:35 PM
    #792
    Tomcat
    Bakflip
    She-nan-agins oops that is something my girlfriend in high school did repeatedly. I;m still trying.
    kenomouth64 and ToyotaDreaming like this.
  13. Jun 10, 2017 at 6:03 AM
    #793
    MookTastic
    MookTastic Because I was inverted!
    Trice
    Rapid City, SD
    2013 5.7L White D/C TSS Offroad Icon Stage 8
    Icon Stage 8 AlphaRex Headlights
    Every now and then I get a sluggish start. Usually in the morning when the truck has been sitting all night. Once in a blue moon. I get a failed start, but then afterwards it starts right up. My thoughts at this point are either fuel pump starting to go out or ECM. Also, for troubleshooting purposes, it's always better with a full tank, and slowly starts to present as tank goes down. Which makes me lean more towards fuel pump
  14. Jun 10, 2017 at 7:37 AM
    #794
    Spolar
    Spolar Going broke
    Zac
    Seal Beach CA
    2016 sr5
    Long story short I unknowingly had the wrong lug nuts on my wheels for a little while and on a long road trip had to crank on the lug nuts multiple times to keep them tight without a torque wrench. I'm sure I over-torqued them more than once and now I'm worried I stressed the lugs. Should I go ahead and replace them all to be safe or am I worrying to much? Last thing I want to have them shear off on the freeway...
  15. Jun 10, 2017 at 8:55 AM
    #795
    Spolar
    Spolar Going broke
    Zac
    Seal Beach CA
    2016 sr5
    Yea they were steel. I had the TRD package wheels and the dealership by me sold me the acorn style TRD lug nuts for like the Tacoma wheels which weren't correct for TRD wheels... Didn't realize they were the wrong nuts until I went back to complain they were coming loose.
  16. Jun 10, 2017 at 9:01 AM
    #796
    Spolar
    Spolar Going broke
    Zac
    Seal Beach CA
    2016 sr5
    No they were fine. And I drove them for a couple thousand miles with no issues, wasn't until I I had to drive out to Utah one time and realized they were coming a little loose, so during the trip I kept stopping and cranking them with the tire iron like an idiot because I was scared they were gonna come off. Picked up some new wheels and lugs right after the trip but I cranked on each lug a few times on that trip. I probably should change all the lugs but I don't have the time right now and really don't want to pay $400 or $500 for the dealership to do it
  17. Jun 11, 2017 at 7:28 AM
    #797
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Flex fuel? Tsb if so...
    Up to u... studs aren't cheap when u are doing that many.
  18. Jun 13, 2017 at 7:31 PM
    #798
    MookTastic
    Trice
    Rapid City, SD
    Yes flex fuel...forgive me not sure what tsb means
  19. Jun 13, 2017 at 7:33 PM
    #799
    T-Rex266 [OP] Owner, CTO and executive chairman of X Staff Member
    Technical Service Bullentin
  20. Jun 14, 2017 at 10:40 AM
    #800
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Tsb stands for what sean just said^ toyota knows there is a problem so they created the TSB. DealeRS can perform the tsb for u
  21. Jun 14, 2017 at 11:35 AM
    #801
    vtran19
    vtran19 New Member
    kevin
    2016 White Tundra CrewMax
    I need some help . I'm hearing squeaking sound coming from the bed of the truck . Not sure what it is and can't seem to make it go away . Was wondering if anyone is having the same issue and how were you able to fixed it. Also , I googled it and some explanations for the sound is due to the lead spring . Thoughts and suggestions to make it go away . It's very annoying . Appreciate any help . Thanks
  22. Jun 14, 2017 at 11:42 AM
    #802
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    id first have someone jump around in the bed. lay on the ground and isolate the noise. so much going on back there a squeak from the bed area isnt very narrowed down
  23. Jun 14, 2017 at 11:47 AM
    #803
    vtran19
    vtran19 New Member
    kevin
    Yea , I tried jumping on the bed and it helped in the past but this time around is not going away. It makes the sound when the truck or bed experience torque or slightly bend when going into/ out of driveways and turning . Thx
  24. Jun 17, 2017 at 11:49 AM
    #804
    Jbjb2630
    Jbjb2630 New Member
    2008 Tundra 4x4 SR5 Double Cab
    Leveling kit, cab marker lights, custom entertainment
    2008 4x4 w/ 5.7
    Been having random transmission issues. First it was shift solenoid D high resistance. Replaced solenoid, cleared codes and drove good after I relearned transmission. Couple weeks later I'm getting on the interstate and noticed after a couple seconds of full throttle CEL on and won't shift past 4th gear. Then switched to sport shift after pulling over and cycling key. Still no change. Cleared code then took off again and now it won't shift past 3rd. I can manually shift into 4th and it will shift but soon after it will kick back in 3rd. I'm figuring I got either a short in harness or faulty ECM because today I recorded codes, cleared and test drove it. No problems at all. Truck shifts out to 6th and runs like a scalded ape. This Ghost is getting on my nerves.
    Here are the 3 codes it is showing.
  25. Jun 17, 2017 at 11:50 AM
    #805
    Jbjb2630
    Jbjb2630 New Member
  26. Jun 17, 2017 at 4:32 PM
    #806
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    That's gonna be difficultto diagnose man... have some one sit in the bed while u drive up the driveway? Gotta get creative...
    I would be leaning towards a transmission in that truck sir... high resistance could be caused by clutch material in the fluid clogging up your solenoid. Now you are throwing more then one code for the solenoids.... needs a transmission
    Jbjb2630[QUOTED] likes this.
  27. Jun 22, 2017 at 8:44 AM
    #807
    Walker
    Walker New Member
    Idaho
    Black 2011 crewmax
    Iron cross bumpers, 3 inch lift, custom made rocker guards, fender flares, lightbar, tow mirrors.
    Ok so I'm at 104,000 and went to change rear diff fluid. When I pulled the plug, I found a moderate amount of metallic sludge and a strip of metal (in picture) Any ideas what the deal is. The piece of metal is thin and about the size of a fine in diameter.
  28. Jun 22, 2017 at 11:02 AM
    #808
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Start with tightening down your bed bolts. And make sure your leaf springs aren't dirty.
  29. Jun 22, 2017 at 12:06 PM
    #809
    GayFish
    GayFish Member
    2016 Super White SR5 CM 5.7L 4X4
    @LOTSOFTOYS Any tips for replacing the alternator on a 2nd Gen 5.7L? Everything i'm reading makes it look pretty rough.
  30. Jun 23, 2017 at 12:32 PM
    #810
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Sounds normal. Make sure u do that every 30k
    Patients.... it is rough
