Ask the Toyota mechanic!
Discussion in 'General Tundra Discussion' started by T-Rex266, Aug 15, 2015.
  1. Dec 8, 2016 at 9:34 PM
    #631
    4RNR
    4RNR トヨタ
    America
    16 Tundra SR5 CM
    Switched from 16 Taco
    Thanks for updates! I'm glad mine is not flex... right? Don't know if it's good or bad :)
  2. Dec 9, 2016 at 5:14 AM
    #632
    cdkenne
    cdkenne Toyota Master Technician
    Corey
    KS
    2002 Tundra SR5 TRD Offroad
    285/70R17, '15 4Run Trail Wheels, Westin Shopping Cart Basher, SnapOn license plate cover that adds >50 HP
    You hit all of the basics. :thumbsup:
  3. Dec 9, 2016 at 5:47 PM
    #633
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    So I went to start my 08 5.7 and it ran for 3-5 seconds and then shut off, tried to start it again and it did the same thing. Waited about a minute and tried again and it started fine???
    What could be causing this?
    The guy I bought it from said he went and got a spare key made last week but this was the original key I tried to start it with
  4. Dec 10, 2016 at 12:12 AM
    #634
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I wonder if there could be an intermittent communication failure between the truck and the key.
    Filthyphil likes this.
  5. Dec 10, 2016 at 1:15 AM
    #635
    Question for the Toyota Mechanic..or anyone who can assist...I'm running 35s with 4.5" lift...bought truck used.. came that way...what's the hub bub about gear ratio some guys out here have switched to what I believe is 4.88s??? I don't tow anything nor extreme 4wheeling should I change out or keep stock
  6. Dec 10, 2016 at 5:24 AM
    #636
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    @LOTSOFTOYS I have a '16 CM 5.7L, would I void my warranty if I installed an aftermarket CAI?
  7. Dec 10, 2016 at 6:19 PM
    #637
    Whitelightning
    Whitelightning New Member
    No it wont void the warranty unless its letting air passed the filter. But dont waste your money. The power gains are not there infact after the placebo effect wears off you will have a loss in power likely. Your airbox already is a cold air intake. If your wanting more power spend the money on a TRD or dirty deeds exhuast. Those seem to be the only two with proven gains over other options.
    NewImprovedRon likes this.
  8. Dec 10, 2016 at 6:19 PM
    #638
    Whitelightning
    2013
  9. Dec 10, 2016 at 7:42 PM
    #639
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    Up to you.... it would help your engine and trans not work so hard... probably better mpgs too
    Nope as already stated^^^
  10. Jan 12, 2017 at 4:15 PM
    #640
    tat2ude39
    tat2ude39 MYota
    Robert
    San Tan Valley, AZ
    2021 Tundra SR5 Crewmax ~ ARMY GREEN
    Does a squeaky serpentine belt mean it's bad? time to replace? noticed for a month or two. Truck has 32K, 2 years old.
  11. Jan 13, 2017 at 8:46 AM
    #641
    16plat
    16plat New Member
    2016 Platinum
    I installed the hypertech inline speedometer calibrator and every once in a while I get this same reading and I've never towed anything before ever. If I touch the hypertech calibrator behind the gauge cluster it goes away. I think I have a defective calibrator but obviously AutoAnything won't send me a new one bcuz they're return policy is crap.
  12. Jan 14, 2017 at 6:09 PM
    #642
    Wvmoonshiner
    Wvmoonshiner 2020 T4R Venture SE
    Chuck
    West Virginia
    2020 T4R Venture Midnight black
    Mine was a defective controller. They replaced it and no more trouble.
  13. Jan 16, 2017 at 10:27 PM
    #643
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    It could be that. It could be your pulley or idler. 32k is low miles for your pulleys to be going. Have it checked. If you get new serpentine belt, look into the Goodyear Gator Back. Great reviews. I put one on and no complaints whatsoever. Hope this helps
  14. Jan 17, 2017 at 10:58 PM
    #644
    tat2ude39
    tat2ude39 MYota
    Robert
    San Tan Valley, AZ
    Thanks Ron, I'll look into that make. A mechanic friend of mine said there was some part that may just need to be adjusted, but to throw a new belt on was easy just to be safe. This AZ heat and dryer climate doesn't help rubber components either.
    rons23[QUOTED] likes this.
  15. Jan 19, 2017 at 10:17 AM
    #645
    16plat
    16plat New Member
    2016 Platinum
    I just ordered a new one today. Should be here tomorrow so hopefully it will stop my issue that I keep getting with my controller. (every light on dash on, brake controller error, speedometer not working, rpm not working, etc...) -- hopefully autoanything.com accepts my return since this is costing a fortune just to get an accurate speedometer reading :censored:
  16. Jan 24, 2017 at 12:02 PM
    #646
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Been extremely busy buying a house.. sorry I've been absent
  17. Jan 24, 2017 at 12:04 PM
    #647
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Does this mean that you'll be expanding to answering home maintenance/repair questions?:D
    sprtbkr and T-Rex266[OP] like this.
  18. Jan 24, 2017 at 7:00 PM
    #648
    CM-LENNY
    CM-LENNY No Complaints
    San Diego, CA
    2015 4x4 CrewMax SR5
    PRO shocks, 37's Nitto G2's 4:88 diffs, few other mods
    Hey 16plat I had the same issue with numerous units and found the fix. Not sure how to copy and paste the article, but punch in " hypertech bricks " on this forum search bar and you will get the articles and my fix. Yell if you have any questions. Good luck........
  19. Jan 25, 2017 at 1:18 PM
    #649
    16plat
    16plat New Member
    2016 Platinum
    I installed my new one a few days ago and so far so good. My problem was just like what that hypertech bricks post was saying, I could wiggle my wires and it'd act up and shut off and light everything up etc. but it also happened when I went over any type of bump, etc. so I pulled it out and cut that zip tie. Same problem over and over. I really think it was a defective unit bcuz when I wiggled the black box on the calibrator, everything would act up. So hope my problem was solved with the new one. Thanks for the reply
  20. Jan 25, 2017 at 2:02 PM
    #650
    btanchors
    btanchors New Member
    LotsofToys,
    As you may know, 4WD Tundras beginning in model year 2014 began requiring a special 75W oil only available from Toyota in the Transfer Case. In your experience, when you service transfer cases for normal maintenance or whatever - do you replace it with the genuine Toyota 75W fluid, or do you use something else? If you use something else, what do you use?
  21. Jan 25, 2017 at 7:52 PM
    #651
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Absolutely not lol... I'm learning house stuff;)
    We use our Castrol 75w90.... same stuff we put I'm all diff and t cases and manual trans
  22. Jan 26, 2017 at 6:06 AM
    #652
    RW-3
    RW-3 May the Mods be with you
    Rob
    16 Black TRD CM 4x4
    Lights: 2018 OEM Black Chrome LED’s Morimoto XB Fogs Interior LED upgrade - VLED’s LED reverse / cargo - VLED’s Footwell lights, vanity lights, break lights, rear turn signals, 3rd break light - All VLED’s 30” Rough Country light bar hidden in bumper w/ Rago Fab Brackets Matt Gecko LED bed lights (red & white) and hood lights Exterior: Truxedo Lo Pro QT WeatherTech in-channel window deflectors Interior: Husky X-Act Contour front & rear Front, back and rear windows all tinted 10% Ceramic Heat Film on Windshield 70% OCD console organizer OCD console tray TRD 4x4 inserts on Husky mats by Achuop Tacoma TRD Pro shift knob with TRD leather boot AJT Design vent ring trim - chrome delete Center console wireless charger Drivers side grab handle Performance: Dirty Deeds BA Muffler 12” Budget Standard System TRD Rear Sway Bar AFE Pro Dry S Air Filter Bilstein 6112 1.9” clip Bilstein 5100 - rear Coachbuilder +1’s Nitto Ridge Grapplers 285/70/18 Audio: Infinity dash speakers Tech12Volts custom center dash speaker Hertz Uno door speakers JL Audio RD 900/5 amp 2 JL Audio 10w-0 v3 10” subs in custom Tech12Volts box Protection: McGuard Tailgate Anti theft lock OEM tailgate lock w/ Dynamat TRD Pro skid plate SNS ARB sensor guards Misc: TRD key fob case AJT Designs Rear diff breather mod Fortin remote start with Car Link CL6 TRD battery bracket by Coupe TRD valve stem caps TRD interior handle inserts by abomb60 (Adam)
    LotsofToys,
    First, thanks for all your help, expertise, and insight here. You are a good man for taking the time to do this!
    I have a 16 CM TRD with about 13,500 and I have a question about the trans. Bought it brand new last year and ever since the beginning when I slow down to about 5mph and then get back in the throttle, it's like the trans isn't sure if it should be in 1st or 2nd gear. It revs a little and kicks slightly and finally picks 2nd. Is this a slipping issue? It doesn't happen every time but I drive in a lot of stop and go traffic so it happens enough to be very annoying.
    I can even cost for a little bit (10-15 seconds) at 5mph and it will do it. I've asked the dealership about this at my 5k and 10k service and they said it's normal because it's an electronic transmission? Are they jerking me around on this?
    Another issue I noticed recently is if I'm on a hill starting from a standstill, the shift from 1st to 2nd seems to take longer than it should. Is this related?
    I installed a Hypertech Inceptor and it seemed to get better for a few weeks but now I feel like it's happing more often again (maybe a bad Hypertech unit or it needs to be updated).
    Going to try to get the service manager to ride with me at the 15k service to show him. Everything is stock for engine, tires, suspension and transmission. Any help or insight would be much appreciated.
    Thanks everyone
  23. Jan 26, 2017 at 9:17 AM
    #653
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I feel like this is the same behavior I've experienced in every 5-speed (or greater) automatic transmission I've had the opportunity to drive. It feels like it's programmed to anticipate a far more aggressive back on the throttle transition after slowing or rounding a corner. Say I come into a clearing roundabout or fresh green light and don't need to come to a complete stop. The trans seems to think that I'm going to hit the throttle aggressively and pre-selects a lower gear than what it turns out is needed in retrospect. The best comparison that comes to mind is if you've ever been a passenger in a vehicle with a manual transmission where the driver selects first gear for a rolling stop when second would be much smoother. When the driver "dumps" the clutch but doesn't rev-match, the vehicle abruptly slows further then jerks forward when the engine RPMs catch up. I've also notice that this is slightly more pronounced when the truck is cold. I suspect that the ECUs are programmed to hold a lower gear slightly longer to keep the revs up and warm things up faster to get to closed loop earlier for emissions. Kind of like driving around on high idle or with the choke pulled slightly. When all this business happens, it does have the sensation of a slipping clutch.
  24. Jan 26, 2017 at 11:00 AM
    #654
    RW-3
    Rob
    16 Black TRD CM 4x4
    Thanks Wynnded. I follow what you are saying and sounds like you know exactly what I'm referring to. I've just never experienced anything like that until this truck. Wife's 07 Camry doesn't do it and neither did my 99 4Runner or 13 Expedition(POS). Thanks for the explanation!
  25. Jan 27, 2017 at 8:46 AM
    #655
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    I would say it's normal, I know exactly what your talking about and can see how that could be annoying. Unfortunately it is an electronically controlled transmission. The ecu only has so much logic under certain conditions. I haven't noticed it in anything that doesn't have the 3ur. Sequoias cruisers and tundras seem to all do it. I personally can't stand the throttle response in these newer trucks. I'm sure u get used to it when u own one, but I drive them every day and still act like a damn bobble head... the snappy Ness of the throttle has the potential to confuse the shit out of the logic that controls transmission gear selection.
    Wynnded likes this.
  26. Jan 27, 2017 at 9:45 AM
    #656
    The throttle is a mite touchy to be kind...not.....throttle response does suck.
  27. Jan 27, 2017 at 10:35 AM
    #657
    RW-3
    Rob
    16 Black TRD CM 4x4
    Thank you for the response. The throttle is very touchy. I installed the Inceptor on the pedal too to help mellow it out but it was too much. Felt like I had to floor it just to get above 10mph. Took it off the pedal but left the one under the hood plugged in.
    Thanks again everyone for the responses!
  28. Jan 30, 2017 at 7:15 AM
    #658
    supermotobobby
    supermotobobby New Member
    Bobby
    2022 Tundra Platinum 4x4
    I would like to install my Intelitronix Trans Temp gauge but I don't know where to put the 1/8" NPT sending unit. Can you help me with that? 2010 Tundra CM 5.7 2wd.
  29. Feb 1, 2017 at 2:12 PM
    #659
    shudawg109
    shudawg109 New Member
    mike
    Does anybody know what size socket do the lug nuts take on a 16 pro
  30. Feb 1, 2017 at 7:14 PM
    #660
    CM-LENNY
    San Diego, CA
    7/8"
