Ask the Toyota mechanic!
Discussion in 'General Tundra Discussion' started by T-Rex266, Aug 15, 2015.
  1. Nov 12, 2016 at 7:22 AM
    #601
    darkknight2014
    darkknight2014 Mods mods and more mods!!
    Phil
    New york
    2014 tundra sr5
    20" Cooper STT Pros on md rims, quadfire lights, pro grille, leather interior, navi, retrofitted headlights, blacked out chrome, TRD sway bar, hypertech interceptor, k&n air intake, Banks exhaust
    That's weird cause my truck says mobil 1 0-20w as well
  2. Nov 12, 2016 at 7:24 AM
    #602
    darkknight2014
    Phil
    New york
    2014 tundra sr5
    For the price of synthetic I just let the dealership do that it and enjoy my free coffee and browse the showroom floor lol
    NewImprovedRon likes this.
  3. Nov 13, 2016 at 12:32 PM
    #603
    mtntop
    mtntop New Member
    2004 4x4 Access Cab SR5
    Thanks for taking the time to respond Jace, I will run the diagnostics you suggested. I was off roading and hit a pretty big hole and it seems to me this is when it started.
  4. Nov 13, 2016 at 1:30 PM
    #604
    Stig
    Stig New Member
    Yes, that is what the Toyota branded oil is. The problem comes when using the "advanced fuel economy" version that you can get in Walmart. I can't find regular Mobil 1 around here in any store so I just stop at the Toyota or Lexus dealership and pick it up there.
  5. Nov 14, 2016 at 11:47 AM
    #605
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    Knowing that... I might start at the tank;)
    cdkenne likes this.
  6. Nov 16, 2016 at 6:17 PM
    #606
    Mr.T
    Mr.T New Member
    Travis
    2018 Tundra
    Hi Jace,
    I have a 2005 Tundra 4.7 4x4. I have a question that hopefully you can help with.
    Starting the truck cold and driving it for the first few minutes it feels as if the engine is really pushing the truck forward when no throttle is applied. I have to use a lot of brake force to keep the truck from moving forward. To give you an idea of how much it pushes on its own when cold - I can have the truck on my driveway which is a fairly steep hill (5 degrees, 10 percent grade) and the truck will push itself up the hill in drive, first, or reverse. Once the truck has been driven and is warm it no longer pushes. The trans shifts smooth and feels normal.
    I went ahead and checked the trans fluid level. The level is good and the fluid looks fairly clean. The truck has done this "pushing" since I purchased it about 6 months ago. I originally thought it might be because the truck had a unichip installed and it that was messing with the timing or something, but I unistalled the unichip module and the truck is still doing it. The truck has a magna flow exhaust, but is otherwise stock.
    Any ideas why the truck does this and how I can solve the issue?
    Thanks,
    Travis
  7. Nov 16, 2016 at 7:27 PM
    #607
    cdkenne
    cdkenne Toyota Master Technician
    Corey
    KS
    2002 Tundra SR5 TRD Offroad
    285/70R17, '15 4Run Trail Wheels, Westin Shopping Cart Basher, SnapOn license plate cover that adds >50 HP
    What is the idle speed at when it does this? In P, R, and D.
  8. Nov 17, 2016 at 4:39 PM
    #608
    Mr.T
    Mr.T New Member
    Travis
    2018 Tundra
    When cold it idles at just under 1500 rpm in Park - when shifted to drive it drops to 1000. When warm it idles at 700 in P and drops to 600 in D. There are no dash lights and no codes on an scangauge.
  9. Nov 17, 2016 at 6:37 PM
    #609
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Sounds normal to me.
  10. Nov 18, 2016 at 7:14 AM
    #610
    cdkenne
    Corey
    KS
    Without seeing the vehicle, I would be inclined to inspect brakes and look for vacuum leaks. Your idle speeds seem normal and you are always going to idle higher with a cold engine.
    Some vacuum leaks, such as intake gaskets, may go away after vehicle has warmed up. The early 2000s Corollas had this issue but was normally accompanied by a P0171 code.
    Weak brake performance could be a contributing factor as well. Possible brake booster vacuum line or weak/leaking master cylinder. These symptoms may be reduced once idle speed has dropped.
  11. Nov 18, 2016 at 8:22 AM
    #611
    Mr.T
    Mr.T New Member
    Travis
    2018 Tundra
    I do not think it is simply a brake issue, but I can look into that. If it is a vacuum leak wouldn't the brake pedal drop after shutting the ignition off after starting the truck cold?
    It seems crazy that it would be normal for it to move uphill on a 10 percent grade without extra throttle applied. I was reminded yesterday when I left work that when the road is snow/icy the truck will actually spin the rear wheels (in 2wd) as you let off the brakes without even touching the gas. At least I know the brakes are working as they should with more bias towards the front. I have 34x10.5 KO2s on the truck so it is not like it is just spinning little slicks. I owned an 02 Tundra previously and it did not do this.
    When I purchased the truck last spring it had a cold air intake, unichip, and magnaflow dual exhaust. I thought the unichip might be causing the pushing issue so I decided to remove it along with the cold air intake (which was loud). I have only reset the computer by disconnecting the battery for a long period of time. Is there another way to clear the trucks computer in case the previous unichip install is still messing with the ECM somehow?
    Just so you guys know. I am not a noob. I rebuilt a 79 pickup including the entire engine and suspension complete with highsteer. I also did a 3.4 swap on an 88 pickup and did everything including the wiring myself.
  12. Nov 18, 2016 at 8:49 AM
    #612
    cdkenne
    Corey
    KS
    I don't doubt your ability. I'm just stating where I would start. There are 120 Toyota TSBs for the '05 Tundra and none of them relate to this, that I can see. If you had a Toyota Techstream, it is possible you could reset the fuel trim and learned values. Depends on Year/Model. I am unsure on an '05. I'll have to check the idle speeds on my '02 on my lunch break. Currently my truck is all factory. Have you cleaned the throttle body?
  13. Nov 18, 2016 at 11:50 AM
    #613
    balou
    balou Texas Tundra
    2016 tundra cewmax 4x4 tss option
    bilstein 5100 adj front shocks led lights for bed
    I have a question on wire harness for power folding mirrors. Is the wiring the same for a 2013 to 2016 at modular connections. If not is there a wiring harness that can be replaced from mirror to dash plug in. Im thinking about installing on a tss sr5 4x4. If possible could one get that section of wiring diagram
  14. Nov 18, 2016 at 12:14 PM
    #614
    cdkenne
    Corey
    KS
    They appear to be quite different. Which model/year mirrors are you installing on which model/year truck?
  15. Nov 18, 2016 at 12:59 PM
    #615
    Mr.T
    Mr.T New Member
    Travis
    2018 Tundra
    I appreciate you looking into it for me. I just wanted you to know that I might have enough knowledge to do the recommended diagnostic troubleshooting. I did clean the throttle body when I removed the Airaid intake and throttle spacer that was on the truck.
  16. Nov 18, 2016 at 4:41 PM
    #616
    balou
    balou Texas Tundra
    Im the one asking about the mirrors. I had a plan to buy power mirror switch with fold button and the find a diagram to run the two wires that would be needed to open and close mirrors to the doors
  17. Nov 18, 2016 at 4:52 PM
    #617
    cdkenne
    Corey
    KS
    It looks like the 2016 is much more complex than the 2013. Based on the diagram it looks like the Switch talks to the Main Body ECU which talks to the Outer Mirror Control ECU. I'm not sure that its a simple matter of a switch and a couple wires to make it work.
  18. Nov 18, 2016 at 6:33 PM
    #618
    balou
    balou Texas Tundra
    Thanks for the help thats what i wasnt sure of. Now that i know im just going to go with trailer mirrors that dont fold. Again thanks for the help
    cdkenne likes this.
  19. Nov 30, 2016 at 11:13 AM
    #619
    eutundra
    eutundra New Member
    hi, what brand shock absorbers do you recommend for 2013 tundra and 2008 land cruiser prado ?
    thanks
  20. Nov 30, 2016 at 11:14 AM
    #620
    cdkenne
    Corey
    KS
    Bilstein :thumbsup:
  21. Dec 1, 2016 at 7:54 PM
    #621
    Whitelightning
    Whitelightning New Member
    @LOTSOFTOYS
    Cold start problems....2013 5.7 CM 4x4 Sr5.
    when cold it cranks and cranks before it starts. I know its likely the Fuel density reading in the computer. Is there a final fix for it? I know the TSB I saw said take it to Toyota and they will reflash the computer. That was an old TSB. Some guys were saying that the problem reoccurs, any final fix on it?
    Does the dealer charge for every time you have the problem? or is it common enough that they are doing it under good faith?
    If I have to pay every time I may just buy techscan and reset the density reading myself......
    J4RR3N4 likes this.
  22. Dec 6, 2016 at 8:02 PM
    #622
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    I have a question, I'm not sure if you've answered this so bear with me,
    I just bought a 2008 tundra 5.7 are these known to have any head gasket issues or anything else.
    I came to find out my old 2005 Tacoma was prone to head gasket failures. And can't seem to find any info if these are prone to problems.
    Thank you sir
  23. Dec 7, 2016 at 4:20 AM
    #623
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I haven't read anything...
    Filthyphil[QUOTED] likes this.
  24. Dec 7, 2016 at 12:12 PM
    #624
    J4RR3N4
    J4RR3N4 New Member
    South east Texas
    14 Tundra
    3” lift on 35’s
    @LOTSOFTOYS 2014 sr5 5.7 flex
    Seems like after shifting from reverse to drive the transmission kinda lags a bit till it actually engages completely to drive. (More so when the truck is cold and has been sitting)Is this normal with Toyota trucks? my prerunner would kinda do this too. Thank you for time.
  25. Dec 7, 2016 at 7:17 PM
    #625
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Sorry everyone... been busy, buying our firat house;)
    I have yet to do the fix and have the same truck come back...
    No, timing covery leaks tho
    haven't had that concern....
  26. Dec 8, 2016 at 8:01 AM
    #626
    lostbrit
    lostbrit New Member
    08 tundra for work
    5100 shocks, volant intake, flow master
    This winter season I noticed that it takes for ever for my truck to blow warm air, warm air not hot. What could be the problem as we are just getting in to the winter season and I don't want to freeze driving around.
  27. Dec 8, 2016 at 11:53 AM
    #627
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Coolant level good?
    cdkenne likes this.
  28. Dec 8, 2016 at 1:14 PM
    #628
    Whitelightning
    @LOTSOFTOYS
    thanks for the reply. I took it in yesterday and just asked about it. Service writer said that it was covered up to 80k/96months. not sure why but i was happy. I picked it up last night. Ill know here in a couple of hours if its fixed.
    LOTSOFTOYS and NewImprovedRon like this.
  29. Dec 8, 2016 at 6:52 PM
    #629
    4RNR
    4RNR トヨタ
    America
    16 Tundra SR5 CM
    Switched from 16 Taco
    Any updates? Just curious if they found anything wrong.
  30. Dec 8, 2016 at 8:57 PM
    #630
    Whitelightning
    Yes, i knew the problem going in. As soon as i started talking to the service writer, he knew right away too. The problem is on a flex motor, sometimes the alcohol density reading is off. There is a sensor that reads the alcohol density of fuel to tell the truck if its running flex fuel or if its running regular unleaded. With flex fuel, it needs more to run, more to start. So when your running flex fuel it dumps extra fuel to the motor.
    Here's the problem: if your alcohol density reading is off (too high) the truck thinks its full of E85 and dumps more fuel to the motor. When the motor is cold it causes an extended crank problem. In temps below 50 degrees my truck would crank for an extended time.... Tip the starter, it would crank for one cycle, tip it again and it would crank and barely start on the last cycle. A cough and. A grunt later the truck ran fine. It only happened in temps less than 50 degrees.
    Toyota has a Technical Service Bulliten that covered my truck for 80K miles or 96 months. They do something with the computer (reflash or calibration or something) pull the battery cables for 30 min, add 3 gallons of fuel and recheck it.
    They completed the service yesterday and i just started it in 43 degrees and it fired right up with out a hitch.
    I hope i explained it well enough... I probably messed up some of the technical jargon but @LOTSOFTOYS can correct me where ive messed up. I dont want to give incorrect information..
    This is only a common issue on flex fuel motors.... non flex extended crank cycles will be some other cause.
