Ask the Toyota mechanic!
Discussion in 'General Tundra Discussion' started by T-Rex266, Aug 15, 2015.
  1. Nov 2, 2016 at 3:15 PM
    #571
    4RNR
    4RNR トヨタ
    America
    16 Tundra SR5 CM
    Switched from 16 Taco
    @LOTSOFTOYS
    I have a question, I have 2016 Tundra CM 4.6 with hitch. There is also looks like atrans cooler in front of radiator but I'm not sure. Does it mean that I have a tow package or not necessarily? And is there a way to check that somehow, I don't think window sticker said anything about tow package.
    Thank you much!
  2. Nov 2, 2016 at 4:05 PM
    #572
    4RNR
    4RNR トヨタ
    America
    16 Tundra SR5 CM
    None. I didn't have those on my 16 Tacoma but paperwork showed tow package.
  3. Nov 4, 2016 at 11:13 AM
    #573
    4RNR
    4RNR トヨタ
    America
    16 Tundra SR5 CM
    One more question. Again I have 2016 Tundra CM SR5 no jbl or anything like that. There is a box under passenger seat with wires going to it, what is that?
    Googled it found that people talked about it but no clear answer to what it is. Some said it's aamp, some think it's SRS.
    Thank you!
  4. Nov 4, 2016 at 9:19 PM
    #574
    ChucklesToy
    ChucklesToy Retired
    Chuck
    Georgetown , TX
    2024 Honda Ridgeline Black Edition
    @4RNR, its an Amp for the radio...
  5. Nov 4, 2016 at 9:37 PM
    #575
    4RNR
    4RNR トヨタ
    America
    16 Tundra SR5 CM
    Thank you! No wonder I got some bass going on:)
  6. Nov 5, 2016 at 7:31 PM
    #576
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    Thanks for looking out Ron and 4rnr... ive been busy
    NewImprovedRon likes this.
  7. Nov 6, 2016 at 4:01 PM
    #577
    Stig
    Stig New Member
    Doing the first oil change on my 2016. The new TRD filter looks to be damaged, with some of the fabric filter material torn away.
    I'm guessing it shouldn't have this tear. Question is, is it definitely okay to use still, or am I better off buying another one?
    Also some green ink on the fabric material.
  8. Nov 6, 2016 at 5:21 PM
    #578
    15whtrd
    15whtrd Mr. Blonde
    @Stig Get a new filter. I wouldn't worry about ink but definitely don't want a hole in the filter.
  9. Nov 6, 2016 at 5:33 PM
    #579
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
    Definitely get a new one. A hole in a filter defeats the purpose of a filter.
  10. Nov 6, 2016 at 5:39 PM
    #580
    T-Rex266 [OP] Owner, CTO and executive chairman of X Staff Member
    There's only 1 hole I look forward to. And it's not in a filter.
    mdavis, joonbug and ColoradoTJ like this.
  11. Nov 6, 2016 at 6:16 PM
    #581
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    I'd ask for another one.
  12. Nov 6, 2016 at 7:35 PM
    #582
    My god man, I have already had to replace an iPhone 6 that broke this month. Don't need my drink getting sprayed all over my MacBook..LOLLERS!!
  13. Nov 7, 2016 at 2:06 PM
    #583
    mtntop
    mtntop New Member
    2004 4x4 Access Cab SR5
    Hey Jace, 2004 Tundra SR5, approx 185k on it. A few months ago I noticed the fuel gauge started 'floating' ie when turning or accelerating or slowing it moves up and down some, as if it is measuring the fuel as it sloshes back and forth in the tank. Prior to this the vehicles motion did not affect it? Bad sending unit, or broken baffle (if one exists)?
  14. Nov 7, 2016 at 5:55 PM
    #584
    gdiep
    gdiep I like cookies
    Syracuse, New York
    2014 Red Tundra CM SR5
    Hey Jace, a very simple question for you. Can you confirm that the 3rd gen Tundras use m14x1.5 lug nuts? Also, I bought a set of steel tundra wheels for my winter setup. Can you post a picture of the correct lug needed for steel tundra wheels (I'm interested in buying aftermarket black acorn lug nuts).
    Thanks very much.
  15. Nov 8, 2016 at 7:09 AM
    #585
    Wilbur
    Wilbur New Member
    Savannah, GA
    2014 MGM
    Hey Jace,
    Im about to roll over 51K on my 14 Tundra. Ever since my Toyota Care went away at 25K miles i have been doing the maintenance. Oil and filter every 5k, did dif oil change at about 45K and also engine and cabin filters along the way. So my question is what else should i be doing or getting prepared for? I was flipping through my warranty and maintenance guide and it looks like oil at every 5K is the only thing to stay on top of. Should i do spark plugs at a certain interval? Any info would be great!
  16. Nov 8, 2016 at 8:19 AM
    #586
    ChucklesToy
    ChucklesToy Retired
    Chuck
    Georgetown , TX
    This might help you...Tundra Maintenance guide https://www.tundras.com/threads/tundra-maintenance-guide.315/
  17. Nov 8, 2016 at 9:39 AM
    #587
    Wilbur
    Wilbur New Member
    Savannah, GA
    2014 MGM
  18. Nov 8, 2016 at 2:14 PM
    #588
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    There is a baffle and this isn't uncommon. Shitty part is, it's difficult to diagnose because it's normally intermittent? sometimes it's the sender, sometimes its the combo meter fuel gauge.... if it were me I'd start with a sender first, maybe even throw a fuel pump in there while you're there. less to think about later.... then you know everything inside the tank is solid.
    If u were to diagnose it, it's gonna take work. gotta disconnect the combo meter from the circuit, under the seat I think. tap in with a volt meter and measure resistance of the sender. then drive the truck . see if the sender is actually throwing bad readings or if the gauge is displaying good readings poorly.
  19. Nov 8, 2016 at 2:16 PM
    #589
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Diff and t case every 30k. trans 60-90k and plugs I believe are good to 120
  20. Nov 8, 2016 at 3:42 PM
    #590
    Wvmoonshiner
    Wvmoonshiner 2020 T4R Venture SE
    Chuck
    West Virginia
    2020 T4R Venture Midnight black
    IMG_1458.jpg Jace, started my truck this evening and got this error on my screen. Have not towed anything in about a week or so. Is this something you have been seeing much of?
  21. Nov 8, 2016 at 6:39 PM
    #591
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    I have not... any problem with the plug in the back? corrosin or anything?
  22. Nov 8, 2016 at 6:48 PM
    #592
    Didn't the new Tundras have an issue with the factory brake controllers?
  23. Nov 8, 2016 at 6:52 PM
    #593
    Wvmoonshiner
    Chuck
    West Virginia
    There is no corrosion or dirt on the plug anywhere. Everything still looks new. Never had a problem before when towing. I have heard there was problems with them but I have never experienced any. Well till I got this error and I wasn't even towing.
  24. Nov 8, 2016 at 6:55 PM
    #594
    Wvmoonshiner
    Chuck
    West Virginia
    I'm going to take it to the dealer in the morning and see what they say. Just thought I would ask if this was something you have seen before.
    LOTSOFTOYS likes this.
  25. Nov 11, 2016 at 7:30 PM
    #595
    AnonVet
    AnonVet That's what she said!
    Weatherford TX
    2015 TRD SR5 CM
    7 inch pro comp 35x12.5 RPB Repulsars (Hate'em) 18x9 Rhino Glamis Bilstein 5100's TRD Pro grille Murdered out Spyder heads Smoked tails Leds all around her Debadged Go Rhino BR5 Front Bumper
    I have an SR5 that didn't comes with the high price ed leather and navigation, while I could are less about the leather, navigation would be awesome. is there a way to incorporate this into my head unit without changing out the whole thing?
  26. Nov 11, 2016 at 7:38 PM
    #596
    darkknight2014
    darkknight2014 Mods mods and more mods!!
    Phil
    New york
    2014 tundra sr5
    20" Cooper STT Pros on md rims, quadfire lights, pro grille, leather interior, navi, retrofitted headlights, blacked out chrome, TRD sway bar, hypertech interceptor, k&n air intake, Banks exhaust
    I just did mine a few months back it is plug and play but you need to buy the radio with navi. Also make sure it's non jbl if u don't have that speaker setup. Entunes won't work with vin but there is ways around that.
    AnonVet[QUOTED] likes this.
  27. Nov 11, 2016 at 7:41 PM
    #597
    AnonVet
    Weatherford TX
    2015 TRD SR5 CM
    Dang it. I was hoping there was some kind of 20 dollar miracle thing I could do, since there seems to be one for everything.
  28. Nov 11, 2016 at 7:42 PM
    #598
    AnonVet
    Weatherford TX
    2015 TRD SR5 CM
    Which deck would i go with? is there a part number for it?
  29. Nov 12, 2016 at 4:24 AM
    #599
    darkknight2014
    Phil
    New york
    2014 tundra sr5
    Do u have the premium jbl package? If not then look for a non jbl head unit with navigation. I swapped everything in thirty minutes very easy to do.
  30. Nov 12, 2016 at 6:06 AM
    #600
    Stig
    Stig New Member
    Got the new filter. Didn't care to return the damaged one for a few dollars.
    I used Mobil 1 0w20 advanced fuel economy, because that's all they had in the store. I had pretty loud valve train noise so I dumped it and filled it up with Toyota oil. All is better now. I'll just buy it from the dealership from now on.
    darkknight2014 likes this.
