Ask the Toyota mechanic!
Discussion in 'General Tundra Discussion' started by T-Rex266, Aug 15, 2015.
  1. Sep 4, 2015 at 7:48 PM
    Tundra 12
    Tundra 12 New Member
    12 tundra
    None
    I just want to know is it safe for me to change to ngk that all.
  2. Sep 4, 2015 at 8:00 PM
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    Sure are they the same type of plug? Like iridium to iridium? Resistor to resistor?
  3. Sep 4, 2015 at 8:02 PM
    Tundra 12
    12 tundra
    None
    Is laser
  4. Sep 4, 2015 at 8:18 PM
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Haven't heard of them
  5. Sep 4, 2015 at 8:21 PM
    Tundra 12
    12 tundra
    None
    All I need to know. If I go to ngk is that going to hurt anything to the motor r performing
  6. Sep 4, 2015 at 8:25 PM
    Mike Tread lightly.
    south carolina
    Ngk and denso are the only spark plugs to use in a toyota.
    Ngk I have used in my tacoma nothing wrong with them.
  7. Sep 4, 2015 at 10:46 PM
    Tundra 12
    12 tundra
    None
    Thank you
  8. Sep 8, 2015 at 9:50 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Hoping I'm not stepping on toes.
    I've read that it can be swapped, but it's prohibitively expensive. Like over $1000 in parts.
    SouthBoundSteve likes this.
  9. Sep 8, 2015 at 12:19 PM
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    I actually have no clue Steve? If it is possible, what about finding a wrecked truck with it and get the tank? Cheaper?
  10. Sep 8, 2015 at 12:53 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    I hope no one has totaled a 2016 Tundra yet.
    darkknight2014 and rons23 like this.
  11. Sep 8, 2015 at 1:46 PM
    usmp97
    usmp97 New Member
    2019 Silver Sky CM Platinum
    Sold ‘15 CM
    Ok, changed my brake lights today, now truck won't shift into gear. HELP
  12. Sep 8, 2015 at 1:56 PM
    T-Rex266 [OP] Owner, CTO and executive chairman of X Staff Member
    Are there any lights on such as ABS?
    checked your fuses?
    iglenner and usmp97[QUOTED] like this.
  13. Sep 8, 2015 at 2:03 PM
    You can also over-ride it. Check the left side where the parking gear is. There should be a small square ...push the pin with a key or screw driver.
    Remember, it's in park for a reason...brake lights aren't obviously working.
    usmp97 likes this.
  14. Sep 8, 2015 at 2:13 PM
    usmp97
    usmp97 New Member
    Sold ‘15 CM
    Well found I keep blowing 15a fuses. Back to Autozone for fuses and no LED brakes...
  15. Sep 8, 2015 at 2:15 PM
    usmp97
    usmp97 New Member
    Sold ‘15 CM
    No other lights on
  16. Sep 8, 2015 at 2:59 PM
    usmp97
    usmp97 New Member
    Sold ‘15 CM
    Ok, new fuses but now I have to troubleshoot the brake lights. Atleast I can drive
  17. Sep 8, 2015 at 5:12 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Check that brake light switch, I'm pretty darn sure that I've read that it's part of the system that releases the gear change lever so you can take it out of Park. Jace may know more on that.
  18. Sep 8, 2015 at 5:48 PM
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Yeah seems like your new bulbs or wiring has a short. As soon as u steobon the brake the fuse blows. No shifting allowed
  19. Sep 8, 2015 at 9:09 PM
    #49
    usmp97
    usmp97 New Member
    Sold ‘15 CM
    I appreciate the responses. I put the factory bulbs back in, new 15a back in, now back in business
  20. Sep 9, 2015 at 3:09 PM
    #50
    usmp97
    usmp97 New Member
    Sold ‘15 CM
    UPDATE....I was installing Pilot LED 3157 bulbs into the brake lights. After troubleshooting today, found out that the fuse only blew if the light was in upside down. So with trial and error, I was able to fix!! Hard to see in the daylight, but they work!!
    bulldog93, T-Rex266[OP] and CaptTyler like this.
  21. Sep 9, 2015 at 6:14 PM
    #51
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Nicely done!
  22. Sep 9, 2015 at 8:36 PM
    #52
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    You'd think that there'd be some suggestions or cautionary words of wisdom on the packaging. Many know that LEDs have a polarity, but the lamp sockets for incandescents don't usually. Then again, maybe some do, I've not had my taillamps out yet.
  23. Sep 10, 2015 at 4:51 PM
    #53
    tacouser
    tacouser New Member
    Chicago
    2015 SR5 Tundra Dbl Cab 4X4
    Bilstein 5100 rear, Klein train horns! Swing Case, Tekonsha P3 brake controller, Bed LED's, Weathertech window visors and floor mats,Retrofit Source Fog Lights, Bakflip cover, Ford Rapter hood leds, Hellwig rear sway bar
    On a 2015 SR5 how do you remove the headlight bulb? I did figure out you have to access it from inside the wheel well, but I cant get the bulb out.
  24. Sep 10, 2015 at 6:23 PM
    #54
    usmp97
    usmp97 New Member
    Sold ‘15 CM
    On mine, it was easiest to remove the entire plastic housing. Then you remove the rubber ring, finally there is a metal clip holding the bulb in. I watched the Headlight Revolution video on YouTube to see removal.
  25. Sep 10, 2015 at 6:24 PM
    #55
    usmp97
    usmp97 New Member
    Sold ‘15 CM
    I agree. I know that most only work with polarity the right way, but not blowing fuses....
  26. Sep 10, 2015 at 6:58 PM
    #56
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    This^^^if u can't access it, most Toyotas it's easier to just remove the headlight assembly. Then replace the bulb
  27. Sep 10, 2015 at 7:12 PM
    #57
    tacouser
    tacouser New Member
    Chicago
    I thought of that, but didnt see how that came out. The person that designed the head light assy should be put away
  28. Sep 10, 2015 at 7:43 PM
    #58
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    Not sure why it took me so long to click on this thread, but having a Toyota mechanic on the forum is priceless. Glad you are here, Jace
    Dawgmech, rons23, JC303 and 2 others like this.
  29. Sep 11, 2015 at 12:14 PM
    #59
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    You have no idea how many times we say that about various things at work lol
    Thanks man! I'll try to help where I can
  30. Sep 12, 2015 at 4:21 AM
    #60
    T_dublecab14
    T_dublecab14 New Member
    RC
    2014 doublecab 4x4
    TRD
    I have 2014 trd tundra DC trd with alloy 18" wheels , it has stock lug nut that is not tapered but im looking to replace ßtock with after market wheel locks do i have use same or can i use tapered type?
