Ask the Toyota mechanic!
Discussion in 'General Tundra Discussion' started by T-Rex266, Aug 15, 2015.
  1. Jul 5, 2016 at 7:15 PM
    #481
    T-Rex266 [OP] Owner, CTO and executive chairman of X Staff Member
    Pretty sure he meant fuel trims
  2. Jul 5, 2016 at 7:27 PM
    #482
    Nor7
    Nor7 Chilton Manual Guy
    2007 Tundra Limited CM, 5.7L
    That makes more sense, but I've never recorded this before. I assume I can run my scan tool on my way into work tomorrow and it will give me a readout?
  3. Jul 6, 2016 at 9:45 AM
    #483
    Nor7
    @LOTSOFTOYS
    Ok, here's the readings from this morning. They mean nothing to me.
    Edit: from the research I've been able to do, negative FT numbers point to a dripping injector which then send the other cylinders running lean. Wondering if an additive could fix this or if I need to pop them out and clean/replace them.
  4. Jul 6, 2016 at 12:03 PM
    #484
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    So long term fuel trim is how the engine is running. A negative number is the ecu backing fuel off. A positive number is the ecu adding. Anything over 25% either direction would alarm me... yours seems fine
  5. Aug 3, 2016 at 8:03 PM
    #485
    Bumping this for new members to see.
    Black Wolf likes this.
  6. Aug 6, 2016 at 10:23 AM
    #486
    Mannishboy
    Mannishboy New Member
    Indianapolis, IN
    2015 DC 4x4 Limited, Blue Ribbon Metallic.
    TRD exhaust, TRD cai, TRD rear sway bar, TRD shift knob, Sequoia front sway bar, bed extender, bed step, Weathertech floor mats and window vents, spray in bed liner, Morimoto fogs, Access tonneau bed cover.
    Question: I installed a TRD cold air intake, and want to get rid of the annoying "whistle". I plan on replacing the throttle body gasket with the screen with either the Sequoia gasket (no screen) or just cut out the screen. My question is, why is there a screen in the first place? Do I risk anything by eliminating it?
    Also, does anyone know if I add a tb spacer, and left in the stock gasket, would it help the whistle problem, or make it worse?
    Thanks.
  7. Aug 6, 2016 at 12:09 PM
    #487
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    That's the first I've heard of a whistle caused by the cai...
  8. Aug 6, 2016 at 12:12 PM
    #488
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
    Working on your honeymoon...
    T-Rex266[OP] likes this.
  9. Aug 6, 2016 at 12:21 PM
    #489
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Here is the DIY thread: https://www.tundras.com/threads/diy-fix-for-whistle-after-adding-high-flow-air-filter.2619/
  10. Aug 6, 2016 at 12:49 PM
    #490
    Mannishboy
    Indianapolis, IN
    Yes, thanks I've read the thread. Just want to know what I'll be risking to replace the gasket with no screen? Why isn't there one on the Sequoia?
  11. Aug 9, 2016 at 1:12 PM
    #491
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    She was in the shower ssshhhhh
  12. Aug 19, 2016 at 7:12 PM
    #492
    Tundrafreak
    Tundrafreak New Member
    Michael
    02 White Tundra
    Air intake, 33in Super Swampers, 2.5in Leveling kit
    Truck is running rough. Air intake is cleaned. Brand new ignition coils but was driving in the rain a few days after and started misfiring. Truck does see a lot of water but never sunk. And ignition coils has been the problem before. (02 with 262,xxx miles)
  13. Aug 19, 2016 at 7:22 PM
    #493
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Check engine light? Tell me the code
  14. Aug 19, 2016 at 7:27 PM
    #494
    Tundrafreak
    Michael
    02 White Tundra
    Check engine light is on cause 02 sensors. Will run a scan tomorrow sometime and will get back to you on any other codes.
    @LOTSOFTOYS
    LOTSOFTOYS likes this.
  15. Aug 19, 2016 at 7:28 PM
    #495
    So how was AK honeymoon? Had to be good I'm thinking. Catch fish???????? (Ask the mech)
    2cID likes this.
  16. Aug 20, 2016 at 7:24 AM
    #496
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Honeymoon was epic man. We had a great time. I was gonna post some pics in my build thread but I'll do some here. We took a few different tours around different towns. Learned alot, saw a lot of really cool animals as well. Highlight of the trip was the worlds lingest zipline!
    https://youtu.be/ibmdz5_8YHs
    Kim is on the left in pink. She flew past me and left me in the dust lol
    WATCH IN HD!
    be77solo, ColoradoTJ and Black Wolf like this.
  17. Aug 20, 2016 at 7:28 AM
    #497
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    A few pics
  18. Aug 23, 2016 at 11:29 AM
    #498
    dtrucksis
    dtrucksis New Member
    David
    2005 Toyota Tundra Limited
    K&N cold air intake
    I have an issue, a 2005 Toyota Tundra Limited, about a year ago I noticed that it acted as if the throttle seemed to close at some throttle settings under a medium load. Creates a feeling like I would be backing off the throttle and right back on. Does not do it under high power, putting the pedal way down or on light pressure. Toyota said it was the air pump, they changed it, problem not solved, AAMCO rebuilt the transmission, problem not solved. Could it be in the Throttle Position Sensor or MAP sensor? Or ?????
  19. Aug 23, 2016 at 6:36 PM
    #499
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Thats a very odd concern. Is there a check engine light? Id say start simple. Clean your thottle body up real good and disconnect your battery. Touch the neg and pos together for 10 mins. This clears all memory, even better than simply disconnecting the battery.
    NewImprovedRon and T-Rex266[OP] like this.
  20. Aug 25, 2016 at 6:22 AM
    #500
    dtrucksis
    David
    K&N cold air intake
    Cleaned the throttle body. No change. Are you say to short the battery? To clear the battery.
  21. Aug 25, 2016 at 7:15 AM
    #501
    That zipline looks like at Girdwood. Nice ski area too. Steep as s##t.
  22. Aug 25, 2016 at 11:09 AM
    #502
    dtrucksis
    David
    K&N cold air intake
    Thanks, will do.
  23. Aug 25, 2016 at 6:56 PM
    #503
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Yes what he said^ thanks Ron
    NewImprovedRon likes this.
  24. Aug 25, 2016 at 6:56 PM
    #504
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Nah this was in Hoonah Alaska
  25. Aug 25, 2016 at 7:50 PM
    #505
    Never made it to Chichagof Island. Crazy beautiful place. Tongass Nat'l Forest. Juneau climate is pretty much rain forest temporate. Big ass Spruce trees. Alaska is so crazy big. I'm thinking you two are already planning your next trip up there. Toyota Dealer mechs probably make decent money up there. (Especially if you have some experience installing lifts.) Truly "serious" offroading up there!! :mudding:
    ColoradoTJ likes this.
  26. Aug 26, 2016 at 11:32 AM
    #506
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Yeah its gorgeous, so much unexplored land. Truely is the last frontier. There are alot of Toyotas up there too! We liked juneau but I couldn't deal with that amount of rain. I need more snow in my life
  27. Aug 28, 2016 at 4:03 PM
    #507
    Mannishboy
    Indianapolis, IN
    Here's a none mechanical question. More like advice question.
    My 2015 has 18k miles on it.
    1. Am I wasting my money buy adding fuel injector cleaner to the gas tank at this point?
    2. Does that stuff really work?
    3. If so what brand do you recommend, or are they all the same?
  28. Aug 28, 2016 at 4:31 PM
    #508
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Yes wasting money. Truck is still brand new lol. Wait until your 30k sevice. Then go every 30k after that. I don't have a preference on brands... bg, Lucas oil. U get what u pay for
  29. Aug 28, 2016 at 4:39 PM
    #509
    Mannishboy
    Indianapolis, IN
    Thanks That's what I figured. What if I don't always use tier 1 fuel? Still every 30k miles?
  30. Aug 28, 2016 at 6:11 PM
    #510
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Yeah... if ur worried about it go every 15k. There are plenty of people with over 200k miles that haven't added a drop of additives....
