Ask the Toyota mechanic!
Discussion in 'General Tundra Discussion' started by T-Rex266, Aug 15, 2015.
  1. Jun 6, 2016 at 10:39 AM
    #451
    Yotalife
    Yotalife New Member
    2008 white sr5
    If you could take a few minutes to read my dilema, i would appreciate it and any advice will be welcomed. I changed the serpentine belt on 2008 tundra sr5 and then there was this squealing that started.It will go away after 15 to 20 seconds (almost like when a fan clutch would kick in). Mechanic told me that is was the bearing on the pulley that the fan hooks to. They say they replaced but the squeal is still there. Saw on you tube, where you can spray a little water on the ribbed side off the belt, and if squeal subsides then chances are that it is tensioner pulley.Also, i saw, where goodyear gatorback belts are the better ones to use. They seem to have more flexibility if the pulleys are misaligned. Also the shop said all my pulleys looked good and spun freely. What is the best test to do myself to remedy the problem?
    Svengalicanada likes this.
  2. Jun 6, 2016 at 2:00 PM
    #452
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    Good question... I know the rear housings aren't exactly the same. As for the cam she'll and thirds.... hmmmm
  3. Jun 6, 2016 at 2:01 PM
    #453
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Commonly seen where the belt is routed wrong causing squeeling
  4. Jun 6, 2016 at 2:52 PM
    #454
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    I changed to the gator back belt, when I replaced the pulleys. No complaints here. I will say, depending on your mileage, that I would change the pulleys out while your replacing belt. That's just my 2 cents. I have an 08 also and wasn't that bad on the pocket, especially if you do it yourself. Hope this helps
  5. Jun 7, 2016 at 3:17 AM
    #455
    Yotalife
    Yotalife New Member
    2008 white sr5
    Which pulleys? The idler and tensioner. And it looks like there is only one way to route the belt. Could not find any diagram on routing it. Any help? How hard are the pulleys to change?
  6. Jun 7, 2016 at 6:34 AM
    #456
    pinoyflayv
    pinoyflayv New Member
    2016 Tundra 1794
    TRD Pro Grill & Hood Bulge - TRD Pro Front Skid Plate - TRD Rear Sway Bar - TRD Dual Exhaust - TRD Pro Suspension - Fuel Krank 18x9 +20 Offset 5.75"BS - Toyo Open Country 35x12.50R18
    Getting the Coachbuilder1 shims & shackles this week. What is the quickest way to install the shims? Any tips? Thanks in advance!
  7. Jun 7, 2016 at 8:42 AM
    #457
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Here ya go
    mley1 likes this.
  8. Jun 7, 2016 at 8:47 AM
    #458
    Skidmarks
    Skidmarks New Member
    LOTSOFTOYS and any others please feel free to chime in. Ive ordered parts to level my 2016 CM RWD specifically the Bilstein 5100 and 1.5" toytec aluminum blocks for rear.
    My 2 questions are first would setting the 5100's at the highest setting cause me any issues such as alignment or ride issues? Is there a way to get a full 3" in front without screwing up ride/alignment problems ect?
    Also I got the Toytec blocks and noticed they were not beveled, so do I need to modify the angle with a bearing drop or is 1.5" not a big enough deal to adjust it?
    Thanks for all your help, Im no mechanic but I have read every issue posted in this thread and feel much more informed about any future issues. This is a good reference thread.
  9. Jun 7, 2016 at 3:21 PM
    #459
    rons23
    Ron
    Kill Devil Hills
    Yes the idler and tensioner. Yeah only one way for belt. I had a buddy do mine as I have no time for anything, was like a $120 in labor.
  10. Jun 7, 2016 at 6:57 PM
    #460
    Yotalife
    Yotalife New Member
    2008 white sr5
    Would that be for a 2008 as well?
  11. Jun 7, 2016 at 7:00 PM
    #461
    Yotalife
    Yotalife New Member
    2008 white sr5
    Thanks for the info. Oem parts ok?
    rons23[QUOTED] likes this.
  12. Jun 7, 2016 at 7:54 PM
    #462
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Yes u need to realign everytime u change the front suspension. Putting the 5100s on the top notch with stock springs would ride rough. Talk to toytec about a set of eibach springs maybe? And a 1.5 inch block I the back doesn't need a shim. Toss it in and see how it drives
    Yes all 5.7 is the same unless sc'd
    Skidmarks[QUOTED] likes this.
  13. Jun 8, 2016 at 5:39 AM
    #463
    Skidmarks
    Thank You for your response.
    I guess my main concern is getting this aligned properly without needing a control arm replacement. Do you know what seems to be the most tried and true combination of lift/shim all while keeping it in alignment spec. I keep hearing about the "Anatomy of your Truck" determines how much lift you will get? In your experience shouldn't all 2016 rwd CM models be almost exactly the same in the front end?
  14. Jun 8, 2016 at 1:33 PM
    #464
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    They Are yes but payload changes from truck to truck... I can say it's possible to have a decent alignment without ucas and 3 inches of lift. Decent, nowhere near what ucas can help achieve.
    Imho, if u are worried already about how it's gonna feel and how the alignment is gonna be and u don't wanna do ucas, you shouldn't lift the truck.
    Wynnded likes this.
  15. Jun 9, 2016 at 6:35 AM
    #465
    Skidmarks
    Thanks for your response and advice.
    While I wait for my parts to get here unfortunately I read the setups that work well and also the ones that are problematic. At least this way I know what to expect when I tackle the job.
    Its more about improving the stock ride than the lift.
    Thanks again
    LOTSOFTOYS likes this.
  16. Jun 13, 2016 at 11:16 PM
    #466
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I appreciate your help and effort in answering so many questions. Here's mine.
    On the newer tundras like mine, a 2015 DC Pro, the wheel sensors in the front are held in place with little bolts. The ones holding the rear are short studs with a nut. These sure look like an adjustable setting is intended. Is this an adjustment? Why are the fronts different from the rear?
  17. Jun 14, 2016 at 12:02 PM
    #467
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    No clue why they are different, and absolutely not, no adjustment. They need to be flush or they won't read correctly
  18. Jun 14, 2016 at 8:19 PM
    #468
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Thanks for that! How can I find out why the rears have the little stud and locknut assembly?
  19. Jun 15, 2016 at 5:53 PM
    #469
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Call toyota and ask an engineer; ) jp jp I have no clue man, not a clue why they did that
  20. Jun 22, 2016 at 12:03 PM
    #470
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
    Which way does the air flow through the cabin air filter? Common sense tells me top to bottom, but my brain tells me to ask someone that knows.
  21. Jun 22, 2016 at 1:20 PM
    #471
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    It may be molded on the outside of the filter door. I thing that it's printed on the filter too, but that wouldn't do a person any good if they didn't know which way to install it in the vehicle.
    So I Googled it and found a video on YouTube that says the air flows from the top down.
  22. Jun 22, 2016 at 2:19 PM
    #472
    JMB
    Chesapeake, VA
    Thanks. The door only says up but I got home I opened it and the filter is marked with airflow. Top down as you said.
  23. Jun 22, 2016 at 7:25 PM
    #473
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Yup top to bottom.
    JMB likes this.
  24. Jun 23, 2016 at 10:07 AM
    #474
    Nor7
    Nor7 Chilton Manual Guy
    2007 Tundra Limited CM, 5.7L
    @LOTSOFTOYS
    How much wood could a Tundra chuck if a Tundra could chuck wood?
  25. Jun 24, 2016 at 3:06 PM
    #475
    Seanson
    Seanson New Member
    2010 Tundra TRD Reg Cab Short Box
    Will removing the over load leaf mess anything up? destroy the shocks? Ruin handling ? I'm looking for an easy way to lower the rear to level the truck. I've heard you can get about an 1'' of drop
  26. Jun 24, 2016 at 3:19 PM
    #476
    rons23
    Ron
    Kill Devil Hills
    If you are trying to level your truck, lowering the rear is not the best choice. Bring the front end up. Having a little bit of rake is good for them lighter loads. Just sayin
  27. Jun 24, 2016 at 3:28 PM
    #477
    Seanson
    Seanson New Member
    Changing any of the suspension from stock is going to affect towing and payload capacity. With a leveling kit up front you'll end up with a sagging rear end. If and when I start towin I'll add airbags.
    Everyone has lifted or leveled tundras I'm just trying to be different
  28. Jul 5, 2016 at 10:25 AM
    #478
    Nor7
    @LOTSOFTOYS
    Fuel system question. I recently noticed a temporary increase in power and fuel efficiency. I think it was after I took the engine to high rpms one day. It lasted for about a week and a half and has now returned back to previous condition which I thought was normal but now I suspect I have a minor issue in the fuel or injector system.
    I'm averaging 16-18 mpg on the highway but last week I was able to average 24 mpg on the same stretch of highway (using cruise control both times). I have a code scanner and don't have any codes present or pending. i also checked each cylinder log for misfire counts and all read 0. Is there anything issue that might be present that is not throwing a code? Anything I can do such as an additive to possibly clean out any gunk in the fuel system?
    I'm currently at 110,xxx miles.
  29. Jul 5, 2016 at 6:54 PM
    #479
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Fuel injector cleaner isn't a bad idea? We sell bg products and haven't had issues. Bg 44k is good stuff. Run some through a tank and see what happens. With out any codes tough to say man... what are your long term fuek trims?
  30. Jul 5, 2016 at 7:13 PM
    #480
    Nor7
    Sorry I'm obviously not up to snuff with ya'lls fancy shop lingo, what are 'fuek trims'?
