Ask the Toyota mechanic!
Discussion in 'General Tundra Discussion' started by T-Rex266, Aug 15, 2015.
  1. Apr 16, 2016 at 8:46 AM
    #421
    Nit2wn
    Nit2wn New Member
    James
    Alabama
    2013 Crewmax TRD 4wd
    While I'm not the mechanic, avoid those E3 Diamond fire. Tried those in my 2013 for around 3-4k miles and wasn't impressed. No gains on fuel economy and seem like less power on the higher RPM bands. Went and grabbed some Denso u grooves Iridium tips from Advance Auto and those seem to be ok. Denso is factory Toyota parts, after that, there are several versions.
    freerider8 likes this.
  2. Apr 16, 2016 at 9:08 AM
    #422
    freerider8
    freerider8 Trucks Rule
    Fairview PA
    2014 Tundra, Lift Kit aftermarket wheels and tires. One Badass Toy!!
    Fuel Wheels. Lift Kit. Duel Exhaust.
    Thanks, that is very helpful. There seemed to be a lot of positive reviews on the E3's but sometimes you just never know about those reviews. When they seem to exaggerated it's almost difficult to believe a plug can do what they said.
  3. Apr 16, 2016 at 11:01 AM
    #423
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    I would just put in ngk plugs, that's what we use at the dealer, they work just fine
  4. Apr 16, 2016 at 11:15 AM
    #424
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Toyotas like the NGK plugs from what I have heard from many Toyota enthusiests including the old rock crawler guys and the guy right up there^^^
  5. Apr 16, 2016 at 4:36 PM
    #425
    freerider8
    Fairview PA
    Thanks. I went with the NGK Iridiums. I checked one of the plugs in already and they were the Denso brand so probably been there for awhile. It wasn't in too bad of shape, but figure I may as well change them out then I know when they have been changed. The electrode was worn down some so I figure they may have been there awhile. Changing them out tomorrow.
  6. Apr 17, 2016 at 8:56 AM
    #426
    freerider8
    Fairview PA
    Hey Lotsoftoys, I forgot to ask if I should gap the plugs or leave them how they came? I don't want to damage them since they do have the very fine point type electrode. Thanks
  7. Apr 17, 2016 at 10:04 AM
    #427
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Oftentimes they are pre-gapped correctly. 1.0-1.1mm
  8. Apr 17, 2016 at 4:59 PM
    #428
    freerider8
    Fairview PA
    I did a search and found two places that suggest 0.32 so that is what I went with. Only a minor adjustment from the pregap measurement. The truck runs great, will see if mileage is improved any.
  9. Apr 17, 2016 at 8:09 PM
    #429
    NCTundra
    NCTundra New Member
    2014 White Tundra TRD
    LOTSOFTOYS, I have a 2014 Tundra and the front right turn signal burnt out so I put a new bulb in and it promptly burnt out as well, any Idea where to start looking to see if there is a short or any other advice. Thanks for your time and advice.
  10. Apr 19, 2016 at 12:29 PM
    #430
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Probably needs a new bulb socket. The plastic piece that the bulb clips into
  11. Apr 20, 2016 at 6:13 PM
    #431
    Ancient1
    Ancient1 New Member
    Tallahassee
    2012 rclb tundra 4x4
    Same thing happened with my 2012. Tinkered with it several times and discovered the bulb wasn't pushed all the way in....works now
  12. Apr 22, 2016 at 5:19 PM
    #432
    NCTundra
    NCTundra New Member
    Bulb socket it was. Thanks!
    LOTSOFTOYS likes this.
  13. May 1, 2016 at 3:14 PM
    #433
    Coaldust
    Coaldust New Member
    I found it.....pinion loose.....i ran the nut in about a 1/16th "turn" and It took alot of it out. I need some air to get it to go on in. Probably take it to toyota so I don't overload it and destroy everything.
  14. May 2, 2016 at 6:28 AM
    #434
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    The pinion nut on the third member??? Yeah that needs to be properly torqued
  15. May 13, 2016 at 11:18 AM
    #435
    Jabraco
    Jabraco New Member
    2001 Tundra V6
    Can't shift into Park after replacing the transmission in my 2001 Tundra. Might the problem be a matter of adjusting the cable where it attaches to the transmission or will I have to open up the steering column? Other than that, I can put it in Neutral and it starts right up and runs great. Any suggestions?
  16. May 13, 2016 at 6:06 PM
    #436
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Probably need to adjust cable/park neutral safety switch
  17. May 19, 2016 at 10:09 AM
    #437
    HunkerDown1118
    HunkerDown1118 New Member
    Lynchburg, VA
    2004 White Tundra double cab limited 4x4
    I'm sure you've gotten a lot of questions about the shift actuators on 1st gen tundras. But I have the blinking 4Hi light w/o engaging. I want to know if I can fix or replace part by myself but I can't even find pics of what I'm looking for online. Thanks for the help
  18. May 20, 2016 at 7:07 PM
    #438
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    It's alot more difficult than just throwing parts at it. Do you know if it's the tcase actuator or the add?
  19. May 22, 2016 at 7:15 AM
    #439
    HunkerDown1118
    Lynchburg, VA
    Yea I figured. I'm not completely sure.
  20. May 22, 2016 at 11:43 AM
    #440
    Sefferston
    Sefferston #37sandlongtravel
    Seth
    Commufornia (not by choice)
    ERMERGERD TOYOTA
    Are the Blue Pit Bearing replacement hubs worth it? Started noticing a whine when I steer towards the right, and only to the right. Pretty sure it's the wheel bearing going and thought might as well replace both while I'm at it along with all the brake parts.
  21. May 22, 2016 at 1:28 PM
    #441
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Never heard if that brand?
  22. May 22, 2016 at 6:29 PM
    #442
    Sefferston
    Seth
    ERMERGERD TOYOTA
    It's all Toyota parts preassembled. I'll find the link here shortly.
    Sent from your mother's asshole
  23. May 23, 2016 at 7:57 AM
    #443
    Sefferston
    Seth
    ERMERGERD TOYOTA
  24. May 23, 2016 at 8:30 AM
    #444
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Huh... that's cool.
  25. May 23, 2016 at 8:55 AM
    #445
    Sefferston
    Seth
    ERMERGERD TOYOTA
    I'll get them and report back for those who might have to do a wheel bearing.
  26. May 24, 2016 at 5:04 PM
    #446
    Ancient1
    Ancient1 New Member
    Tallahassee
    Question on wheelbase and slider fitment. Reg cab, long bed has the same 145.7" wheelbase as the double cab 6'6" bed and the crewmax with 5'6" bed. Have not been able to find anyone that makes sliders for the rclb, yet many companies build them for the other 145.7" wheelbase trucks. Is there a difference in the same length frames?
  27. May 24, 2016 at 6:18 PM
    #447
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Shiuldnt be no, id get exact dimensions including where they have the legs of the sliders, so you can take some measurements to make sure they will fit yours
  28. May 24, 2016 at 6:21 PM
    #448
    Ancient1
    Ancient1 New Member
    Tallahassee
    Sounds like a good place to start.....thanks
  29. Jun 5, 2016 at 3:21 PM
    #449
    SCRunner12
    SCRunner12 New Member
    Robert
    Santa Cruz, CA
    2015 SR5 Crewmax
    Jace, do you know if the 1st gen tundra shares the same front and rear 8.4" diff as the 1st gen Tacomas? I'm pretty sure both are 7.5" and the rear is 8.4" (non-trd for Tacoma). Just wondering if built diffs for a Tacoma would work for my tundra.
  30. Jun 5, 2016 at 8:59 PM
    #450
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Yes.
