Ask the Toyota mechanic!
Discussion in 'General Tundra Discussion' started by T-Rex266, Aug 15, 2015.
  1. Mar 30, 2016 at 2:05 AM
    #391
    Sefferston
    Sefferston #37sandlongtravel
    Seth
    Commufornia (not by choice)
    ERMERGERD TOYOTA
    Well fuck. Might as well just do a custom 1 piece drive shaft. I'm outside the window and if I'm paying for a drive shaft I might as well have one that I want...
  2. Mar 30, 2016 at 5:52 PM
    #392
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    Not true^ if a customer complained of something with in warranty time line and it was not verified. But then is verified outside of warranty, you have a viable chance at getting it covered. I'd consult with ur dealer's service manager or shop foreman.
    I thought so too^ but the tsb only said 3 and 36. I'll look again tho
  3. Mar 30, 2016 at 5:53 PM
    #393
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    The only way I know of and have seen is to mount a basket ontop of the cross bars...
  4. Mar 30, 2016 at 6:18 PM
    #394
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    Well it's funny you should say that. I just spoke to an adviser, whatever that's supposed to be and she looked up where I had come in and explained what was going on, and it recorded on a ticket (thank you!) so I'm gonna schedule a appointment to find out exactly what's going on. The dealership should cover it being when the complaint and concern where brought to there attention my truck was under warranty. Speaking on this clunking, I also read where axle wrap was causing some problems, something about the Tundras not getting a beefy enough suspension and that it was pulled off the Tacoma. Crazy thread I read, lotsoftoys thanks for your response i appreciate it. I will provide any info I get and what problems they think it is.
  5. Mar 30, 2016 at 6:50 PM
    #395
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    The copy that I have (I just dug it up) says 60 months or 60,000 miles. It's dated 30 Sept 2011.
  6. Mar 30, 2016 at 7:30 PM
    #396
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Yeah an advisor is just the face of the service dept. The middle man between u and the tech. I hope they help u!
    rons23[QUOTED] likes this.
  7. Mar 30, 2016 at 7:33 PM
    #397
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    U are correct, just looked again. 5/60
  8. Mar 31, 2016 at 4:12 PM
    #398
    freerider8
    freerider8 Trucks Rule
    Fairview PA
    2014 Tundra, Lift Kit aftermarket wheels and tires. One Badass Toy!!
    Fuel Wheels. Lift Kit. Duel Exhaust.
    Just curious how hard a body lift is to do? I am looking to replace my shocks to bilsteins and figured that maybe a lift also if it isn't too difficult. I have never done that so not sure what is all involved.
    Thanks
  9. Mar 31, 2016 at 5:23 PM
    #399
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    A body lift isn't too hard... just one side at a time;) steering column and radiator shrouds can be a pain but if that's what u want go for it. A suspension lift is much better though
    Sefferston likes this.
  10. Apr 1, 2016 at 7:53 PM
    #400
    freerider8
    Fairview PA
    Thanks for the tip. I have looked into it a little further and may buy a full set of Bilstein shocks to see about installing those first and see if that gives me the look I want. Is there anything that I need to buy besides the shock sets themselves to install? The come with hardware to install but just want to be sure I get everything I need in one shot.
  11. Apr 2, 2016 at 8:53 AM
    #401
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Are you just talking the billstein 5100s? Adjustable by raising the clip? That should be all you need, don't compress your oe spring too much, it'll ride rough. I'd recommend removing your fround coilovers and bringing them to someone with a spring compressor to do the shock swap. Figure out how much lift you want from the front shocks.
    This is more of a leveling kit tho. Your initial idea of a body lift would give a much different look
    freerider8 likes this.
  12. Apr 2, 2016 at 6:52 PM
    #402
    freerider8
    Fairview PA
    Yes I am looking at the 5100's to replace the current ones. Can the front shocks be removed without taking out the coil springs? Or does it all come out as one unit and then need put back in? I have read the reviews on the Bilsteins and people say that they are all you need and help to give some lift as much as 2.5 inches in the front. I guess I would just like some lift and make the truck look level front to rear. I don't have to go the full lift limit but still want a nice ride.
  13. Apr 2, 2016 at 7:48 PM
    #403
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Yeah the coilovers come out as an assembly. Then need disassembled to swap to 5100s. And yes the 5100s would be agreat way to level the truck
  14. Apr 2, 2016 at 8:20 PM
    #404
    freerider8
    Fairview PA
    Thanks, appreciate it.
  15. Apr 4, 2016 at 12:45 PM
    #405
    Wilbur
    Wilbur New Member
    Savannah, GA
    2014 MGM
    I stay on top on my service intervals pretty heavily but somehow skipped doing diff fluids at 30k. im at 41k now and plan on changing them sometime this week. Will the internals be affected? and how hard is it to do?
  16. Apr 4, 2016 at 3:35 PM
    #406
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    No you're fine. Not hard, can be messy though. Makesure you get new gaskets for the 2 diffs and tcase. Dont over tighten the tcase, aluminum. Cracks easily... drain them, spin the plug back in and fill them back up. Tons of videos im sure on how to do it.
  17. Apr 4, 2016 at 5:25 PM
    #407
    astro-jason
    astro-jason New Member
    2022 CHEVROLET 3500 CC L/B Duramax 10spd
    New guy here, I have a 2016 dc 5.7 On a cold start it idles up at 1500 or 1600 for about a minute or so. Is it normal for such a high idle on a cold start?
    -Jason
  18. Apr 4, 2016 at 6:05 PM
    #408
    T-Rex266 [OP] Owner, CTO and executive chairman of X Staff Member
    I'm not a mechanic, but yes.
    TigerTanker and Sefferston like this.
  19. Apr 5, 2016 at 1:15 AM
    #409
    astro-jason
    Sean, thanks for the reply. I searched and couldn't find the answer.
    -Jason
  20. Apr 5, 2016 at 5:21 AM
    #410
    Wilbur
    Wilbur New Member
    Savannah, GA
    2014 MGM
    That makes me feel better. I found the how to vids, should be a cake walk. But apparently auto parts stores around here don't carry the amount i need to do rear, t case and front dif at one time. So now i get to go on a Easter egg hunt for Mobil 1 75W gear oil. When you are saying gaskets, are you referring to o-rings maybe? I noticed all of the drain points are just plugs and the rear diff is a sealed unit in the back. Thanks for all the help.
  21. Apr 5, 2016 at 6:23 PM
    #411
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Nope there are gaskets. Go to your dealer if u can and ask for the 6 driveline gaskets
  22. Apr 7, 2016 at 6:28 PM
    #412
    rvanwert24
    rvanwert24 New Member
    Rick
    San Antonio, TX
    2003 Tundra SR5 Extended
    3/1 Level lift, 33's, Custom Sound, Tint
    2003 SR5 2WD. Trouble starting. Roll the key over to start, makes one loud clunk/click (like the starter teeth are catching on the flywheel, but not spinning it) and then nothing. Does this all the time, starts OCCASIONALLY in the morning (when the starter(?) is cold). Lifted the manifold and dug out the old starter and replaced with new, dropped a new battery in, and replaced the alternator 2 months back. Still not starting. Checked the relay, pretty sure it's good. Thinking possibly the ignition switch?? Please, anything helps. Really tired of driving this POS Diesel F250 around.....
    @LOTSOFTOYS
  23. Apr 7, 2016 at 6:49 PM
    #413
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Hmmmmm most of the time its the starter. The starter plunges but doesnt spin. You need to see if proper voltage is making it to the starter. Good connections on the batter and starter? Sucks its under the intake....
  24. Apr 13, 2016 at 2:06 PM
    #414
    Coaldust
    Coaldust New Member
    heY I got 07 that makes a pop when it downshifts..sonunds like it is around the rear area. I checked the u joints,they are good...any suggestions? thks.
  25. Apr 13, 2016 at 4:24 PM
    #415
    rons23
    Ron
    Kill Devil Hills
    Ok so I just read a thread on Tundratalknet about the problem involving the drive shaft clunk from behind that made my head spin.... whoosh! Also my mom had that clunk feeling on her 2005 Sr5, and ive read that some 14's are experiencing problems. I'm taking my truck to where I bought it and see what they can do. It was documented in February 2012 when I brought my Tundra in concerned about this problem, so hopefully they will cover what needs to be done. Also will be looking into the charcoal canister fiasco involving certain Tundras, this TSB write up is on Tundra Headquarters. Has to do with water intrusion, and poor design. I have read where some Toyota dealerships are saying it's the owner overfilling there tank and fuel is getting down and damaging the filter. I will post up when everything is done or not, and let everyone know. I am surprised that I have not heard more about these issues on this forum. One quick thing, I did read about slip yoke almost dry and needing grease. Supposedly the 2wd does not have any grease fittings. Stay tuned o_O
    LOTSOFTOYS likes this.
  26. Apr 13, 2016 at 7:30 PM
    #416
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Lifted?
  27. Apr 14, 2016 at 1:37 AM
    #417
    rons23
    Ron
    Kill Devil Hills
    2.5" leveling kit, nothing in back. Gonna be going to 6112's in front and 5100's in back. I don't know if I will even need a block in back . Suggestions welcome definitely.
    NewImprovedRon likes this.
  28. Apr 14, 2016 at 1:17 PM
    #418
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    I'd check the springs and the u bolts for sure... I've seen them be loose and the axle moves all over the place. Normally is with a block style lift though....
    rons23 likes this.
  29. Apr 14, 2016 at 3:21 PM
    #419
    rons23
    Ron
    Kill Devil Hills
    Roger that
  30. Apr 15, 2016 at 10:01 PM
    #420
    freerider8
    Fairview PA
    Was wondering what type of spark plugs you would recommend? Research suggests NGK Iridiums. I did find one truck site suggest E3 DiamondFire Electrode on top. Bosch also makes an Iridium plug. I have not checked what is in the truck yet. Not having any performance issues, but figured with 97,000 miles it may be time to change them.
    Thanks
