Ask the Toyota mechanic!
Discussion in 'General Tundra Discussion' started by T-Rex266, Aug 15, 2015.
  1. Mar 10, 2016 at 6:19 PM
    #361
    Patron77
    Patron77 New Member
    The Wire
    Not tow hitch or spare. They are tight. I'll have to check the bed liner, but this feels like a heavy thump so I can't imagine that's the case. Possible I guess. I'll let you know. If it is the source it will be just the excuse I need to take it out and linex the bed.
  2. Mar 10, 2016 at 6:26 PM
    #362
    jdm ctr '00
    jdm ctr '00 New Member
    los Angeles, CA
    2016 Tundra TRD PRO
    Are you sure the spare is tight? Get under there and use your feet to push on it. Also, open the tailgate and pull/push on the bedliner from the bottom. Do you have a bed cover?
    Does it always happen? Does it get harder when you take off faster or stop harder?
  3. Mar 10, 2016 at 9:00 PM
    #363
    SCRunner12
    SCRunner12 New Member
    Robert
    Santa Cruz, CA
    2015 SR5 Crewmax
    Jace, you'll probably know this answer from personal experience with your 1st gen. Sometimes when I'm going downhill or uphill and I let off the gas my transmission will downshift automatically to bring the rpms higher. It helps brake the tundra on downhill and accelerate uphill but when it flattens out the rpms won't return to normal for a while or until I press the overdrive on and off. Is this normal for these trucks? I'm hoping it's not signs of my trans going out or slipping.
  4. Mar 12, 2016 at 6:43 AM
    #364
    mkeller25
    mkeller25 New Member
    Hey guys - looking for some feedback on what this might be and figured this would be the spot to ask. Its on both sides and looks very deliberate so I'm hoping someone has a good explanation for me.
    Thanks!
  5. Mar 12, 2016 at 8:49 AM
    #365
    mkeller25
    What about the other cuts/lines to the right?
    You're saying every 2011 Tundra has this?
  6. Mar 12, 2016 at 9:51 PM
    #366
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    What yeah truck?
    Yup normal, mine does it too. Its just the logic in the ecu for trans shifting.
  7. Mar 13, 2016 at 12:19 AM
    #367
    SCRunner12
    Robert
    Santa Cruz, CA
    2015 SR5 Crewmax
    Sweet, thought so, but was worried since it didn't always return to normal. Thanks!
  8. Mar 13, 2016 at 8:16 AM
    #368
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    I think it has alot to do with towing. When I have the trailer behind it and I'm coming down from the mtn, it helps alot on the brakes when it down shifts like that.
  9. Mar 16, 2016 at 10:45 AM
    #369
    mtntop
    mtntop New Member
    2004 4x4 Access Cab SR5
    WTF??? you are one spoiled rotten SOB,
    sorry I was late to the game but I had to say something ;)
    rons23 likes this.
  10. Mar 16, 2016 at 11:13 AM
    #370
    Tracker
    Tracker New Member
    Shane
    Colorado, Denver Burbs
    2016 Silver Tundra SR5 Lifted
  11. Mar 16, 2016 at 1:28 PM
    #371
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Yeah we have a cement highway near our shop. Its normal
  12. Mar 26, 2016 at 7:03 AM
    #372
    4man
    4man New Member
    Jeff
    2009 tundra 4.7
    My 2009 tundra has a feeling of slack and a bump when I don't baby the throttle in the rear end/ driveline. I feel like it is similar to what Patrone77 was describing a few posts back. I bought my truck used with 70k a few months ago I guess the previous owner didn't take advantage of any service available to him. If this Is the driveline what do I need to do to make it right? It also has a bump when I brake hard.
    Thank you for your time !!!
  13. Mar 26, 2016 at 7:10 PM
    #373
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    I'd definitely start with lubricating the drive shaft, but I believe there was a tsb for a new driveshaft....
  14. Mar 27, 2016 at 1:44 AM
    #374
    Sefferston
    Sefferston #37sandlongtravel
    Seth
    Commufornia (not by choice)
    ERMERGERD TOYOTA
    For early 2nd gen there is I believe. I've been having the same thing with my 10, but I'm thinking about taking care of it myself in a different route.
  15. Mar 27, 2016 at 7:38 AM
    #375
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Neither of your trucks have block lifts in the rear right? It can cause axle wrap and make some funny feelings when loading and unloading the driveline.
  16. Mar 27, 2016 at 12:25 PM
    #376
    Sefferston
    Seth
    ERMERGERD TOYOTA
    See, that's what I thought might be causing the issue.
    I'm sitting stock height.
  17. Mar 27, 2016 at 5:07 PM
    #377
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    So its not that.... might seem weird, but you could put the truck 4wd. Then remove the rear driveshaft. Drive Around A Bit IN Front Wheel Drive carefully. See if the feeling goes away.... if it does, u may be looking at a slip yoke issue. If it were mine, I'd look into taking that slip yoke apart and lubricating the shot out of it upon reinstalling.
  18. Mar 27, 2016 at 9:32 PM
    Sefferston
    Seth
    ERMERGERD TOYOTA
    I'm 2WD :anonymous:
    I've already started looking at it, the only thing I haven't done is take the slip out.
  19. Mar 28, 2016 at 12:14 PM
    #379
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    I wouldnt worry too much of its not rubbing anymore. Doesn't look like anything is gonna break. Just get it back to somewhat normal and call it good. Then buy a real skid plate; )
    TRD15559 likes this.
  20. Mar 28, 2016 at 12:15 PM
    #380
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Ah haha that poses a problem.... I'll look up tsbs
    Sefferston[QUOTED] likes this.
  21. Mar 28, 2016 at 12:27 PM
    #381
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    You could add LOWER CONTROL ARM CAM TAB GUSSETS????
    http://www.chaosfab.com/2007-2013-Tundra-Off-Road-Suspension-Accessories.html
    TRD15559 and Sefferston like this.
  22. Mar 28, 2016 at 6:21 PM
    #382
    4man
    4man New Member
    Jeff
    2009 tundra 4.7
    I'm 2wd also. Curious about the TSB protocol for repair.
  23. Mar 28, 2016 at 6:24 PM
    #383
    JimP01
    JimP01 New Member
    2000 Green Access SR5 4.7
    Hey all,
    I am doing a timing belt change on my new to me 2000 4.7. I am using the kit with the water pump and lots of other bits. I did the crankshaft seal no problem. I can't find anything that says how to do the camshaft seals and I don't want to mess up the timing by trying to loosen the bolts and freeing everything up.
    What is behind the cam pulley bolts and what do I need to know and do to change the seals?
    Thanks
  24. Mar 29, 2016 at 12:03 PM
    #384
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Yes there is a tsb for 2wd and a seperate one for 4wd tundras. 07-12 calls for an updated driveshaft
    Sefferston likes this.
  25. Mar 29, 2016 at 3:31 PM
    #385
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    Correct me if I'm wrong, but a TSB is not guaranteeing a replacement right. It's not a recall from what i've read. I took my 08 in for the same issues everyone is dealing with- clunk at take off or coming to a stop. I brought my truck in and had the tech ride with me and he sad it was normal, so I went on my way. I did read where supposedly the slip yoke is the culprit. What would be the time and cost to fix this if Toyota doesn't want to replace this at no cost. I don't feel I should have to pay anything, especially when this Tundra has been babied for most of it's life. Thanks for your time Lotsoftoys.
  26. Mar 29, 2016 at 5:05 PM
    #386
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    You are correct it's not a recall. a tsb is a known problem that toyota has come out with a fix for. Its typically covered under the 3months /36k miles. But if you are out of that warranty then you would be liable for the cost
  27. Mar 29, 2016 at 5:11 PM
    #387
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    From what I read, it's a improper casting of the yolk. It needs to be something that the tech can verify, you typically can't go in and say that it's happening, and expect it to be sorted. The fix is a new drive shaft, cost varies depending upon the specific shaft for your truck.
    @LOTSOFTOYS, wouldn't this TSB be covered by the drive train portion, 6/60K?
  28. Mar 29, 2016 at 5:40 PM
    #388
    rons23
    Ron
    Kill Devil Hills
    And that's what I did, had him ride with me, I'm not a mechanic, but it sure as hell didn't sound right. If it was looked at at the time I brought it in it would've been under warranty, as of now it looks like I'm sol. Just wanted to know if there was a fix without replacing shaft. Thanks
  29. Mar 29, 2016 at 8:24 PM
    #389
    ConfusedZombie
    ConfusedZombie New Member
    2011 Tundra Texas Edition
    Well, after asking around and researching online, I figure maybe it's best just to ask an actual Toyota mechanic. I have a 2011 Crewmax and want to out a roof basket on. After talking with an INNO dealer, I was under the impression that in order to out a roof basket on, I needed to also purchase a roof rack to attach it to because my roof is a "naked roof". Can't I just attach it directly in mounting points in the gutter? I really don't want to add another $300 and 4" of height just to put a basket on. I am attaching (or trying to attach) photos of my roof gutte. Was the INNO dealer right in saying that I have a "naked roof"?
  30. Mar 29, 2016 at 11:47 PM
    #390
    Spvrtan
    Spvrtan Amateur fabricator
    Kris
    San Diego, CA
    You technically could attach it to the gutter but those aren't really mounting points and not sturdy enough for any serious roof rack or weight.
