ARK Splash Guards - Group Buy! 2007+ Tundra Guards
Discussion in 'Deals & Group Buys' started by 14burrito, Aug 14, 2020.
Thread Status:
Not open for further replies.
  1. Sep 17, 2020 at 9:07 PM
    #181
    TundraCoast
    TundraCoast Member In Good Standing
    Ian
    California
    1794 4x4
    1794 on the inside - PRO on the outside
    Installed mine over the weekend, pretty straight forward. I did notice an aluminum line that was right behind the 2 drill points (driver side). As others have stated, double check behind the area when're you drill. The metal line is slightly flexible so I just held it out of the way while I drilled and had no issue. Side-note, a few more push fasteners would be nice. I see in others pics they reused OEM fasteners like I did.
    In this pic you can see the aluminum line right behind the hole I drilled, It is flexible so I moved it up while I drilled and kept to clear.
    In this pic, you can see that aluminum line in both holes I drilled
    TylerDurden311 likes this.
  2. Sep 18, 2020 at 6:14 AM
    #182
    14burrito
    14burrito [OP] IG @14burrito
    2014 SR5 CM 4x4 5.7
  3. Sep 18, 2020 at 6:16 AM
    #183
    TylerDurden311
    TylerDurden311 Paper Street
    2018 Tundra CM
    I was also shorted a clip
  4. Sep 18, 2020 at 6:22 AM
    #184
    14burrito
    2014 SR5 CM 4x4 5.7
    Good to know, @Ark Splash Guards will probably be logged in later and see the posts.
  5. Sep 18, 2020 at 6:52 AM
    #185
    Rc23
    Rc23 New Member
    Ross
    Chesapeake
    '16 Super White CrewMax
    I'm so pissed i missed this.
  6. Sep 18, 2020 at 8:05 AM
    #186
    TundraCoast
    Ian
    California
    1794 4x4
    I had 1 ARK clip break and I was still short clips and had to reuse original clips. Not a big deal but more an FYI.
  7. Sep 18, 2020 at 8:06 AM
    #187
    Mine came with 24 ARK push pins. Didn't do the install yet. :facepalm:
  8. Sep 19, 2020 at 1:21 PM
    #188
    SIXSEVENONE
    SIXSEVENONE Island BASTRD
    Shane
    East Bay, CA
    2015 Super White CM Limited
  9. Sep 19, 2020 at 1:24 PM
    #189
    SIXSEVENONE
    Shane
    East Bay, CA
  10. Sep 19, 2020 at 2:03 PM
    #190
    14burrito
    2014 SR5 CM 4x4 5.7
  11. Sep 22, 2020 at 4:10 PM
    #191
    Major
    Major TTC #0181
    Josh
    NC
    2017 CM Attitude Black Platinum
    Stock.
    Love 'em!
  12. Sep 24, 2020 at 2:03 PM
    #192
    Architect
    Architect New Member
    marc
    New Jersey
    2020 CMTRDPRO
    Those are great.. I guess I missed the boat on the group buy.. Any other way to obtain a pair for my 2020?
  13. Sep 26, 2020 at 7:15 PM
    #193
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    I used one of these to make removal of stock splash guards a breeze
    Hole right behind air pump hose
    Zip tie in place
    Wire near proposed drilled hole.
    Knick in AC line
    Holes drilled in driver side wheel well. You can see the AC line right behind.
    FBE194A6-74DF-4359-9B5D-1A7A99BCFDDB.jpg Okay so installed my liners today. Let me first say thanks to @14burrito and @Ark Splash Guards got the killer deal on these things.
    the install was not straight forward as it seems. The instructions were a bit lacking as far as the forward most robots covered by the wheel well liner.
    so on the passenger side there is one rivet which is behind a line for the air pump and all behind the wheel well liner.
    What a complete bitch. So first I tried to losses the wheel well liner. Unless you want to spend 45 minutes removing it and breaking those factory lock clips just forget it. I removed the two clips closest to the splash guard and that created enough room. After that it seems the air pump hose is directly over the hole for the rivet. Since the new clips are longer than the factory ones it’s pretty frustrating trying to get that rivet in there. There is also a hard plastic guard that goes between the splash guard and flange metal that you have to keep in place while trying to hold the air pump hose out of the way, while trying to line up that plastic rivet, all while on your back working between the wheel well liner and the wheel well. I couldn’t do it. I tried for half an hour! I’ve installed everything on this truck from full suspension to full soundproofing and stereo system. This was the hardest thing I’ve ever tried to do. Also what happens when I have to remove them for a repair, I gotta do this all again? No F’n way in hell was I going to sandbag myself like that.
    Whipped a zip tie in there and had it done in like 20 seconds. I’ll just clip the zip tie if I ever have to remove them. It will be much easier than trying to back out that burly pin they provide for fastening. I feel like they should have already thought of this for ease of install and future removal.
    Also there should be some warning about drilling, on the passenger side there’s some wires and a bracket VERY close to the proposed drill locations for the splash guard, and on the driver side there’s an AC hardline directly behind the proposed holes. I tried my best but still ended up scraping the AC hard line a bit.
    They recommend a 3/8” drill bit but after comparing that to the existing holes and the fasteners provided I opted for a 5/16” bit and feel it was the right choice.
    I was also a clip short, nevermind that there should for sure be some extras.
    *DEEP BREATH*
    despite all the issues and potential issues with install these look great and provide much increased protection over the stock guards.
  14. Sep 26, 2020 at 9:06 PM
    #194
    Hightide
    chadington von banks
    Abalama
    Magic School Bus
    I hope this doesn’t come off the wrong way, but, you made the most simple install as difficult and time consuming as possible.
    Hope you didn’t do permanent damage to those lines.
    The Tundra seems to have some inconsistencies at times.
    The guards are nice.
    AggiePhil likes this.
  15. Sep 26, 2020 at 9:34 PM
    #195
    Tundyfundy
    Bay Area, CA
    Not taken the wrong way but not quite sure what you mean. I tried my best to get the pins where they were supposed to be but couldn’t. Other than that it went pretty smoothly. Did you have trouble with the pin behind the air hose?
    ditto about the scratched line. Seems pretty superficial but still.
  16. Sep 26, 2020 at 9:40 PM
    #196
    Hightide
    Abalama
    Magic School Bus
    Not really.
    15 min install. Was tight on the most forward passenger pin.
    Just used some plastic body panel tools to access.
    Tundyfundy[QUOTED] likes this.
  17. Sep 26, 2020 at 9:43 PM
    #197
    Tundyfundy
    Bay Area, CA
    Man that would have been nice. The Air hose was literally a half inch over the hole. I couldn’t even get the rivit into the hole because It wouldn’t clear the hose, let alone line up with the hole in the body panel. I tried to pry it out of the way but I couldn’t even get enough space for the rivit.
    Hightide[QUOTED] likes this.
  18. Sep 26, 2020 at 9:47 PM
    #198
    Hightide
    Abalama
    Magic School Bus
    It’s crazy how different these Tundras can be sometimes.
    My lines were clear on both sides.
    I’m weird about using drill stops as well.
    So I rarely go too deep.
    Years of dealing with track-bikes helps you learn all the little tricks to tight spots and push pins.
  19. Sep 26, 2020 at 9:50 PM
    #199
    Tundyfundy
    Bay Area, CA
    With all due respect I don’t see how It could have been my lack of skills or that I made the install hard. If the hole wasn’t covered it would have been a breeze but maybe my air pump hose was at a different position. Seems like the holes on my liners weren’t exactly over the existing holes as well. I kept having to kinda stretch the liner to get the holes in the right position.
  20. Sep 26, 2020 at 9:53 PM
    #200
    Hightide
    Abalama
    Magic School Bus
    I never said it had anything to do with your skill.
  21. Sep 26, 2020 at 9:53 PM
    #201
    Tundyfundy
    Bay Area, CA
    I’ll knock it up to some variation on n placement of my components. I really tried everything. Sounds like that may be the case since your lines were clear. Obviously mine were right behind the drill spot. I wasn’t pressing hard but as soon the drill pierced the metal it shot in too fast for me to stop. I should buy some drill stops, I would have loved to have them.
  22. Sep 26, 2020 at 9:56 PM
    #202
    Tundyfundy
    Bay Area, CA
    I was referring to you saying that I made the install hard. NBD, just saying.
  23. Sep 26, 2020 at 9:56 PM
    #203
    Hightide
    Abalama
    Magic School Bus
    Flyinryank and Tundyfundy like this.
  24. Sep 26, 2020 at 9:57 PM
    #204
    Tundyfundy
    Bay Area, CA
    Absolutely. Ordering as we speak.
  25. Sep 26, 2020 at 10:00 PM
    #205
    Hightide
    Abalama
    Magic School Bus
    Maybe I worded it incorrectly.
    After seeing the *BREATH DEEP* it seemed as though it was frustrating for you.
    Seemed like a simple, straight-forward install to me.
    Some others have mentioned encountering the line but just pushed it over.
    That’s why it seems that the tundra can have some inconsistencies in placement of items.
  26. Sep 26, 2020 at 10:06 PM
    #206
    Tundyfundy
    Bay Area, CA
    Agreed. I was pretty twisted up because I spent so much time on that one rivit. Mine didn’t have much play in it and I couldn’t push it far enough out of the way for the rivit to line up. There also wasn’t much room for my one hand let alone my hand and another tool to keep pressure on the line. I would have loved to remove the liner but it had these square pressure clips that were a bitch to remove, which I’ve done but if that’s what it took then I’d rather just have the stock splash guards as I’m sure I’ll have to remove them for something one of these days and don’t want to have to remove the liner every time. I’m sorted now that I know the zip tie works. It’ll be a fast job that way.
    not to mention the lines directly behind the drilled holes, not to mention not having enough hardware, not to mention the seemingly incorrect size of drill bit.
    seemed like a lot for instructions which basically said,” take off the old ones and put on the new ones!” Lol
    No mention of the wheel well liner being in the way either.
  27. Sep 26, 2020 at 10:16 PM
    #207
    Tundyfundy
    Bay Area, CA
    I tried my best to capture the angle but it was directly over the hole
  28. Oct 6, 2020 at 8:10 PM
    #208
    Jonnynewton909
    Jonnynewton909 Jonnys_Tundra
    Jonny
    East Texas
    2017 Tundra CrewMax
    Accutune Fox DSC 2.5 front w/ SPC UCAs, Alcan custom spring pack and Accutune Fox DSC 2.5 rear. 37 Toyo RT Trails on Method 312s. SOB Fab F&R high clearance bumpers. AT Overland Atlas.
    Dang, wish I would have got in on this. Any way to get a new group buy going?
    WawaLunar likes this.
  29. Oct 6, 2020 at 8:33 PM
    #209
    Luckydog
    Luckydog New Member
    Dominic
    2015 DC TRD Offroad.
    Ranch Hand Summit front and rear bumpers. Diamondback SE tonneau cover. Rigid DOT fogs. LED headlight/fog replacement bulbs. Matt Gecko hood, and bed LED's. Foot well led's, and interior LED buld replacement. (warm) Broke the front shock of the 3" spacer lift, so replaced with 6112/5160 and 1' block rear. KO 2's. Speaker replacement, added amp and (2) 10's under seat. Weathertech floor mats. Salex organizers. Ziebart undercoating. RCI front, transmission/diff, and gas tank skids received, waiting for spring install. Compustar remote starter. front/rear dash cam.
    That 3/8 drill bit suggestion was too big to use included fasteners. I ended up using those square body fasteners for the wheel well liner. Small tap with hammer and got a great fit. I used the drill stops as suggested, and it worked great. I took front wheels off for easy access.
    Hightide and Tundyfundy like this.
  30. Nov 23, 2020 at 7:13 PM
    #210
    14burrito
    2014 SR5 CM 4x4 5.7
    FYI for those who were not able to grab a set during the GB
    Luckydog likes this.
Thread Status:
