Are you happy with your stock brakes on your huge tundra, or do u want 2 upgrade?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Cg13055, Jul 27, 2021.
Would you be interested in this brake kit?
  1. Hell yeah!
    9 vote(s)
    13.2%
  2. Maybe in the near future
    10 vote(s)
    14.7%
  3. depends on final product
    20 vote(s)
    29.4%
  4. I am gonna stop faster than a nascar
    3 vote(s)
    4.4%
  5. Stock is fine for me
    26 vote(s)
    38.2%
  1. Jul 29, 2021 at 7:21 AM
    pman9003
    pman9003 New Member
    2020 Platinum 4x4
    This is true, the trade off here is that it could make the brakes more difficult to modulate. The reduced pedal effort can make it more difficult to apply the correct amount of braking at any given time. This is assuming you only increase the rotor diameter and change nothing else. Similar results could be achieved by changing to a high friction pad, which is what many people do.
    If you increase rotor diameter and reduce total piston area, you could improve pedal feel while still reaping the benefits of a BBK. This is why brake upgrades can get tricky, there are a lot of quantitative and qualitative factors at play and they all affect each other.
    Cg13055[OP] and Mallcrl like this.
  2. Jul 29, 2021 at 7:48 AM
    kaymonster
    kaymonster Member
    San Diego
    2018 Platinum
    I would love to upgrade to something that doesn't shudder so bad when braking on descents when towing. It's surprisingly bad.
    Cg13055[OP] and ATHiker like this.
  3. Jul 29, 2021 at 8:51 AM
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    What are they proposing? are they talking about the 8 pistons set up I've seen on other 1/2 tons?
    - What size of pads? what shape? what compound?
    - Will this be for stock rotors? or are they going to widen it like Alcon does with their bulletproof kits?
    - Are they going to use alloy pistons or stainless steel?
    - Will these be radial mounted?
    I have the ST60 kit on my truck, and it's a good improvement, but I'll tell you what really needs to be done:
    - Up the rotors to 360mm or 370mm so it can still fit behind 18"s 370mm should fit with spacers on stock wheels, so this way they can use slightly deeper pads, and please stick with standard FMSI shapes, so we can find replacements.
    - Widen the rotors to 36mm, or 38mm, we need more mass to absorb the heat.
    - Please update those calipers so we can remove pads without removing the calipers, I've had worked on SSBC's kit, and its very annoying and irritating to remove the whole calipers to change the pads.
    Cg13055[OP], Hightide and Mallcrl like this.
  4. Jul 30, 2021 at 4:18 AM
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    2200 miles in on my tundra Pro I think the brakes are fine. Coming from 2 4runner Pros. I like how the brakes work so far on my tundra.
    toyofan87 likes this.
  5. Jul 30, 2021 at 5:53 AM
    myt1
    myt1 New Member
    Richard
    Scottsdale, AZ
    2010 Tundra DC TRD SR5 Desert Sand Mica
    OME Lift, 275/70R 18
    If you want to rock, keep it stock.
