Are all Gen 1 light housings all compatible thru the years?
Discussion in '1st Gen Tundras (2000-2006)' started by ToyotaJim, Jul 8, 2020.
  1. Jul 8, 2020 at 2:05 PM
    ToyotaJim
    ToyotaJim [OP] New Member
    I have two Tundras, years 2000 and 2002. Locally I've found a good inexpensive full set of light covers/units (front, rear, bed) for cheap, like $50, in great condition, from a 2006.
    I think these are all compatible years, but sometimes minor changes are made. Can anyone confirm or refute whether these are all compatible for all Gen 1?
    I don't have immediate use for them but like to set back affordable parts when I see them.
    Thanks in advance.
  2. Jul 8, 2020 at 2:07 PM
    Professional Hand Model
    Hand Protectors
    No. They are not.
    ToyotaJim[OP] likes this.
  3. Jul 8, 2020 at 2:09 PM
    ToyotaJim
    Really, that is interesting. Can you elaborate? Will it fit either or neither, what has changed, etc.?
  4. Jul 8, 2020 at 2:21 PM
    Hand Protectors
    Sure. The OEM Toy parts are different #’s.
    Aftermarket sizes are different #s.
    Maybe you could make it happen, but for the $50 you are spending you could add another $70 for $100ish brand new aftermarkets that are crystal clear.
    Hooptytrix likes this.
  5. Jul 8, 2020 at 2:29 PM
    ToyotaJim
    So Toyota changed the lights mid- generation 1? Interesting. Glad I asked.
  6. Jul 8, 2020 at 2:39 PM
    Hand Protectors
    Try doing an online parts search and you’ll see the Double Cab and Access Cabs are different. The Access Cabs change parts in 2005-05 it looks like.
    ToyotaJim[QUOTED][OP] likes this.
  7. Jul 8, 2020 at 7:21 PM
    ToyotaJim
    So as a follow up, I'm wondering if anyone has actual hands on experience that these are or are not compatible and/or Toyota just changed the part number? Or is there a change in the part that makes the not compatible, not fit, etc.?
    I've looked on Toyota's site and the part for the headlamps for 2000-2004 is: 81150-0C010. The "change" seemed to occur in 2005-2006 models and the part number is 81150-0C030 which replaces part number 81150-0C030 (discontinued); this one seems to fit 05-06 Tundra's and 05-07 Sequoias. It just seems illogical to change production of a headlight assembly mid-generation... all cost and no gain it would seem to alter production. Why bother?
    So has anyone actually tried this?
  8. Jul 8, 2020 at 8:13 PM
    There are tons of things that changed just between 2000-2003 and 2004-2006, not sure why it would be odd? There were significant engine changes for 05-06 also.
    Not attempting to debunk the headlight thing, but there's a clear delineation mid-generation - not uncommon, other vendors like GM did this with the C1500 platform, changing body style and engine types mid-generation - but clearly there are other examples in this.
    What I'd recommend is spending the $50 to bunk or debunk it, then get back to us. :D
  9. Jul 8, 2020 at 9:00 PM
    PenderBen
    PenderBen Forum lurker…
    Gulf Islands, BC Canada
    2003 Tundra AC 4x4
    From what I’ve seen, regarding AC and regular cabs:
    The headlights changed for sure, the most obvious difference being the drl relocated to the lower inside corner.
    Corner lights apparently mount differently.
    The tail lights changed style, later are just red/clear, but I think they fit earlier models (shape didn’t change, the wireharness on the light may be different).
    I don’t think the third brake/cargo light changed.
    The double cabs are all different (maybe not the third/cargo light).
    Maybe someone with more knowledge can back that up, or correct me.
    Personally, I’d like the later style tail lights on my ‘03, but I don’t want to spend the money to find out if they fit.
  10. Jul 9, 2020 at 9:10 PM
    MNtundra
    MNtundra New Member
    Tony
    Minnesnowta
    01' Tundra AC 4x4, 04' CRV 4WD
    Bilstein 5100's, 4runner Wheels 31" BFG, Rear Seat Delete
    I hate amber tails and want to buy 04-06 red/clear tail lights for my 00... I too agree the shapes and mounting positions look so similar contemplating buying and trying. Unless someone already has?
    artsr2002 and Tundra2 like this.
  11. Jul 10, 2020 at 5:36 AM
    Hand Protectors
    I’ll take your Ambers off your hands for cost of shipping if you would like when the time comes. :D
    MNtundra[QUOTED] likes this.
  12. Jul 14, 2020 at 2:25 AM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    I actually like the amber turn tails. I have comtemplated an idea though. On my 05 DC, take the amber bulb, replace it with an amber/white switchback. Tie the amber portion to the turn signal, tie the white portion to the reverse lights. Boom. Amber turns, that double as reverse bulbs for a little extra backup light. Opinions?
  13. Jul 14, 2020 at 3:23 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I like the idea in concept. I'm not familiar with the DC tail lights though.
    Do you think its possible that the reverse light voltage feeding into white part of light could back feed to the turn signal relay fooling it into thinking you're turning? May throw your whole idea in the can.
    I don't know much about how the turn signal relays work. Just a thought I had.
  14. Jul 14, 2020 at 3:53 AM
    artsr2002
    'Yonder
    Hmm. May need to throw a diode on the turn signal wire to keep juice from flowing backwards. Still just an idea.
  15. Jul 14, 2020 at 9:21 AM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    As someone who has worked all the gen 1 lights, no, they are the same.
    2000-2004 Access cabs are the same
    Everything after that, they are all different.
    bmf4069 likes this.
  16. Jul 14, 2020 at 9:53 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    I replaced the original tails on my 2002 RC with the better tails off a 2005 AC.
    Heads & tails on 4 door trucks are exclusive to 4 door trucks, so avoid them.
  17. Jul 14, 2020 at 10:03 AM
    SouthPaw
    2000 Limited 4x4 AC
    I like that! I am not a huge fan of having amber in the rear tailights. Is is it a direct swap including the plug?
  18. Jul 14, 2020 at 10:31 AM
    Rex Kramer
    Georgia
    Pretty much plug & play, but I remember having to free up the wiring harness just a little so the correct bulb & socket would reach it's new location, it's been 15 years and I don't remember exactly.
    SouthPaw[QUOTED] and MNtundra like this.
  19. Jul 14, 2020 at 11:41 AM
    MNtundra
    MNtundra New Member
    Tony
    Minnesnowta
    Definitely going this route. Look great!
  20. Apr 5, 2025 at 2:25 PM
    StratusDuo
    StratusDuo New Member
    Jared
    Jacksonville, Florida
    2001 2D 4.7 SR5 4WD 8FT
    ‘06 Tacoma wheels Rocky Mountain AT tires
    What did you do to level out the truck? I just purchased an ‘01 2D 8ft and am trying to get the same look without messing with the front suspension more than I have to.
  21. Apr 5, 2025 at 2:46 PM
  22. Apr 5, 2025 at 2:52 PM
    StratusDuo
    Jared
    I don’t even look at post date stamps, just now realizing this thread is 5 years dead lol
    KNABORES[QUOTED] likes this.
  23. Apr 6, 2025 at 5:51 AM
    Start here: https://www.tundras.com/threads/so-you-wanna-buy-just-bought-a-1st-gen-tundra-eh.115928/
    Note the suspension/wheel/tires section, but before you start dumping money, investigate the "big 4" Tundra killers (frame rot/timing belt+water pump if V8/non-OEM LBJ/radiator). We outlined it all pretty well in that community thread.
    StratusDuo[QUOTED] likes this.
  24. Apr 6, 2025 at 7:16 AM
    StratusDuo
    Jared
