Are 3/1 spacer kits always a bad idea?
Discussion in '2.5 Gen Tundras (2014-2021)' started by spyshot, Jan 17, 2019.
  1. Jan 17, 2019 at 2:48 PM
    spyshot
    spyshot [OP] 1Cor 15:55-57
    Ohio
    2019 Tundra Platinum
    Platinum pretending to be Pro
    So what’s the deal with the 3/1 leveling spacer kits? Seems like so many people are using them yet there are a few people out there that say “they are junk and don’t do it.” Are those people saying that because they are doing serious off-roading with them, or do they have a very high failure rate in general?
    I doubt ill be off road anyway other than a grass parking lot at the races. Im only on pavement and towing a camper and other equipment.
    Thanks for the input.
  2. Jan 17, 2019 at 3:04 PM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    They're not junk, there are just better options if you have the money. If you won't be doing much off-roading then a 3/1 will be fine. Your ride may be a little stiffer.
    Law323 and OR18TRD like this.
  3. Jan 17, 2019 at 3:18 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    I say buy once, cry once.
    Spacers will make the ride stiffer, and I’ve seen situations where shocks have snapped due to limited travel and a good pothole, also I’ve seen guys run them without a problem.
    It’s entirely up to you, I personally went with the spacer lift and ended up upgrading to Toytec BOSS and haven’t looked back since.
    Berdine and OR18TRD like this.
  4. Jan 17, 2019 at 3:19 PM
    spyshot
    Ohio
    Good info. Thanks!
    OR18TRD likes this.
  5. Jan 17, 2019 at 3:53 PM
    Degausser
    Degausser New Member
    Kevin
    GA
    2024 LR SR5
    It's kind of a get what you pay for situation. I don't do a ton of offroading, and what I do is fairly light compared to what some guys here do, but I knew going with a coilover kit would be better for the truck in the long run. You'll be able to get the look you're going for with just a spacer kit, and you may never have any major issues with it, but I like having the peace of mind that the suspension I'm running is designed for the height of my truck. Spacers ask your stock suspension to do something it isn't really designed to do.
    Law323 likes this.
  6. Jan 17, 2019 at 3:58 PM
    SoCalTundy
    SoCalTundy Tundra Owner since 2017
    Icon Shocks. Total Chaos UCA. Deaver u748 TC shackles Flowmaster super 50. Diode Dynamics fogs. 5.29 Revolution Gears. SSW 17" wheels on BFG 35x12.5
    I did spacers. 15k miles later and 17k total miles on my truck and my stock shocks were squeaking. Embarrassing coming from a new truck. Turns out the spacers put too much pressure on my lower shock mounts. I never went offroad on my spacers. Dealer did not honor the warranty because of the spacers. I ended up upgrading my suspension using ICON shocks.
