Arb lockers
Discussion in '2.5 Gen Tundras (2014-2021)' started by Jimes, Aug 17, 2019.
  1. Nov 13, 2019 at 4:13 PM
    #61
    Jimes
    Jimes [OP] New Member
    Bay Area, California
    2015 toyota tundra trd pro
    Ya the compressor is great. No issues there. It’s just how the engineers decided to make the air line go over that ring gear that kills me. I have the parts to replace it one final time. I replaced the seal housing the second time and it went out even faster. If it happens again after I do it, I will go with Eaton when it becomes available. This is how it looked the first time. I will take pics when I replace it myself, can’t wait to see what I find. Good times.94855520-2A6E-44C9-966F-6975B02527B7.jpgD93AB6F5-49A7-4FA9-816C-4FDB54230396.jpg04C86067-6F9C-4797-ABE5-C01777475757.jpg
    Badger Co-Op likes this.
  2. Nov 13, 2019 at 5:17 PM
    #62
    Worriedman50
    Worriedman50 New Member
    Richard
    West TN
    2015 Tundra Crewmax
    TRD Rear Sway Bar , 6112 front 5160 rear shocks, Retrofit Projector Headlights, Rear LED bumper lights lights, FRAC harness and front camera, TRD Pro Grill and color matched hood bulge.
    15whtrd likes this.
  3. Nov 13, 2019 at 5:32 PM
    #63
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    It is so awesome to finally see some new diff options. E locker is bad ass
  4. Nov 13, 2019 at 5:33 PM
    #64
    Worriedman50
    Richard
    West TN
    2015 Tundra Crewmax
    Question, could one install the rear locker for say a year and then add the front later, will the system work that way?
  5. Nov 13, 2019 at 6:07 PM
    #65
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    The system doesn’t care if you dont have a front locker. But you want to regear when you do a locker. Its the same labor cost...dont pay twice to open up the rear
    Jimes[OP] likes this.
  6. Nov 13, 2019 at 6:43 PM
    #66
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    You and I both.
    15whtrd and Hbjeff like this.
  7. Nov 13, 2019 at 7:40 PM
    #67
    ZPMAN
    Minnesota
    Kinda looks like it it might have been a clearance problem on the install, one wrong bump and it will put a hole in the line. Did they remove the complete rear end or just take the differential out?
  8. Nov 13, 2019 at 7:41 PM
    #68
    Worriedman50
    Richard
    West TN
    2015 Tundra Crewmax
    And I would need to re-gear why? Not trying to be smart, I just don't know...
  9. Nov 13, 2019 at 8:04 PM
    #69
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I
    If you wanted bigger tires too. Just a thought if you were gonna break the diffs open anyways.
    619Tundra likes this.
  10. Nov 13, 2019 at 8:13 PM
    #70
    619Tundra
    619Tundra New Member
    San Diego, Caifornia
    2017 Black Tundra Double Cab SR5
    What is the cost of the E-Locker?
  11. Nov 13, 2019 at 8:37 PM
    #71
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
    Website says 1700 Australian roughly so you’re looking at 1200ish US
  12. Nov 13, 2019 at 8:38 PM
    #72
    619Tundra
    Not bad.
  13. Nov 13, 2019 at 8:56 PM
    #73
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Totally worth it
  14. Nov 13, 2019 at 9:49 PM
    #74
    619Tundra
    $1,156.23 to be exact. Can't wait to buy it.
    rockmup and Hbjeff like this.
  15. Nov 14, 2019 at 3:06 AM
    #75
    coTony
    Tony
    Montrose, CO
    The front locker has been around for quite a while because it was developed on the front of the 200 Series LandCruiser. The Tundra’s front diff is the same as the 200 Series.
    There are basically no Tundras down under for whatever reason and Harrop said that they had one that was at their shop for a while when they developed the 2650 SC and it so happened I was contacting them a lot asking for info on an ELocker for the Tundra. I am sure I was not the reason they did it but it all worked out timing wise.
    619Tundra and rockmup[QUOTED] like this.
  16. Nov 14, 2019 at 3:19 AM
    #76
    coTony
    Tony
    Montrose, CO
    You would not "need" to regear and especially if you only put a locker in the rear and then plan to come back later to do the front.
    That would be an expensive move if you regear because you pay to have to rear diff installed and if you regear you pay for the front to have the gears installed. If you are happy with your current tire size and they way your truck moves then why regear?
    I regeared and currently at 125 miles into my 500 mile break in
  17. Nov 14, 2019 at 3:42 AM
    #77
    Worriedman50
    Richard
    West TN
    2015 Tundra Crewmax
    I do not do rock crawling, but I do move trailers around West TN loaded pretty heavy and I plan on staying with my stock tire size. 90% of my driving is road work, but the field roads in winter can be problematic. I hate having to call my father to come pull me out with a tractor when I am driving a $40K "4 wheel drive" truck.
    I plan on this (2015 CM SR5) being my last truck, I am 66 and if this one last like my 2000 Tacoma (guy that bought it is still driving it, sold it at 345K miles) it should do me, as I drive this one a lot less than I did that one. I have added a few things to suit my needs, decent headlights, killer back up lights, got 6112s and 5160s coming in for install next week.
    These e lockers are the next thing on my list to get the truck where I want it to be.
    15whtrd likes this.
  18. Nov 14, 2019 at 3:45 AM
    #78
    coTony
    Tony
    Montrose, CO
    I bought this truck to be my last because of health issues and I am 57 so I hear ya. If the truck performs as you like it with stock tires then you will be fine with a locker(s).
  19. Nov 14, 2019 at 5:02 AM
    #79
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    if you're worried about "field roads in winter" you should be looking at an auburn LSD, not a full locker
    joonbug and Badger Co-Op like this.
  20. Nov 14, 2019 at 5:04 AM
    #80
    osidepunker
    Alex
    2013 Tundra DC 4x4
    what are your symptoms when this line get a hole in it? It just doesnt lock? Or does your compressor constantly keep running?? Air out of the diff breather?? I just want to know what to look for in case it happens to me or anyone I wheel with
    joonbug likes this.
  21. Nov 14, 2019 at 6:30 AM
    #81
    coTony
    Tony
    Montrose, CO
    If you get a hole in that line your air compressor will never shut off. If you have a leak in the line or the infamous rubber o-ring type seal ARB Engineers decided was the best thing since sliced bread (don't get me started) then the compressor cycles constantly (shuts off then on shortly afterward and repeats)
  22. Nov 14, 2019 at 7:49 AM
    #82
    Jimes
    The compressor stays on the entire time. Then you’ll hear it in the diff as well as out of the diff breather. I hear it in my tail light cause I relocated it. It will NOT lock when this happens. I lifted the rear of the truck and tried it. No air no locker. Never had an issue with the o ring, just the line.
  23. Nov 14, 2019 at 8:01 AM
    #83
    Worriedman50
    Richard
    West TN
    2015 Tundra Crewmax
    Was not aware you could put one (Auburn LSD) on the front end of a Tundra?
    Dragging out a 18' trailer loaded with cut firewood, on a two-rut dirt road left by logging crews can leave some pretty nasty, deep, muddy slick clay traps, both differentials locked can save a lot of walking, digging and winching.
  24. Nov 14, 2019 at 8:35 AM
    #84
    coTony
    Tony
    Montrose, CO
    The locker needs the air "pressure" to lock and hold the lock until air is released.
    Also talk about finding out the hard way, I was in Colorado way the hell up in the mountains and we came to an up hill obstacle with no by pass. I got to the bottom and turned my compressor on (back in the LandCruiser days) and the compressor ran and ran and ran. Everybody gathered around my rig and nobody could figure it out. I have to be winched up, first and only time and I was not happy. Later at lunch I am thinking WTF happened to my compressor? How will I air up without bothering someone? Then it hit me, in order to compress air you need air to compress and at 10,000+ altitude there is very very thin air. I asked others to turn on theirs since they all had ELockers and same thing just run and run. For the next several days of our trip I had to fill up my air tank before I left camp in the morning before climbing up. The tank held plenty of air to last through the days requirement of air locking.
    Just an FYI
    joonbug likes this.
  25. Nov 14, 2019 at 8:46 AM
    #85
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    So compressors won’t work at 10,000 ft?Hmmm. Never tried using my compressor at that kind of elevation. Good to know.
  26. Nov 14, 2019 at 8:51 AM
    #86
    rockmup
    rockmup New Member
    Todd
    Greenwell Springs LA.
    I'd take a selectable in the front over an LSD any day of the week.
    Hbjeff likes this.
  27. Nov 14, 2019 at 8:53 AM
    #87
    Jimes
    Damn. I haven’t had that issue yet with the compressor. But good to know. I’ll try it next time I’m in the mountains.
  28. Nov 14, 2019 at 9:09 AM
    #88
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Well my arb has been working great so far
    joonbug likes this.
  29. Nov 14, 2019 at 9:28 AM
    #89
    Jimes
    Lucky.
  30. Nov 14, 2019 at 9:50 AM
    #90
    osidepunker
    Alex
    2013 Tundra DC 4x4
    its not luck. Working arb lockers are the majority, not the minority
    n0rth and rockmup like this.
