ARB lockers
Discussion in '1st Gen Builds (2000-2006)' started by Ludogg808, May 4, 2019.
  1. May 4, 2019 at 8:43 AM
    Ludogg808
    Ludogg808 [OP] New Member
    Luis
    2001 Tundra Sr5
    Weather Tech floor liners, Debadged
    so im kind of a noob. Running an 01 tundra 4.7 trd offroad. Which from my understanding does not have locking diffs. Wanting to get the arb rear locking diffs but I tow and daily drive... are they selectable lickers?!? Can’t find that answer anywhere lol unless it’s in terms to technical for me to comprehend lol
  2. May 4, 2019 at 8:48 AM
    Lsmweld1752
    Lsmweld1752 New Member
    Louis
    Easton Pa
    2011 tundra limited CrewMax
    Yes it's a selectable. It uses air to lock and unlock the differential so you need a air compressor as well.
  3. May 4, 2019 at 8:49 AM
    because_wumbo-truck
    because_wumbo-truck TTC#036 & 1st Degenerate
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    flowmaster 40, DDI injectors, sliders, bumper
    Yeah the diff lock is selectable. Either it's locked or unlocked at the flip of a switch.
    What makes you think you need a locker?
  4. May 4, 2019 at 8:58 AM
    Ludogg808
    Luis
    2001 Tundra Sr5
    Just a little extra security when I do offroad. I don’t often but I live near a lot of wilderness areas and wouldn’t mind being able to tackle something a bit more rugged...
    And to be totally honest... I watched a video for the ‘18 trd pro Tacoma and he got stuck and got out when he engaged his lockers... I can’t let the new tacos show up the og tundys now cmon lol
  5. May 4, 2019 at 9:01 AM
    because_wumbo-truck
    Jon
    Houston, Texas
    Trust me, they don't. Unless they use their cheater tech. Like crawl control.
    I would check your rear axle for this sticker
    If it's there, you don't need a locker. Just drop into low range and let the v8 and the lsd do their thing.
    Ludogg808 [OP] likes this.
  6. May 4, 2019 at 9:05 AM
    Ludogg808
    Luis
    2001 Tundra Sr5
    Heard that. Imma go look right now!
  7. May 4, 2019 at 9:08 AM
    Ludogg808
    Luis
    2001 Tundra Sr5
    A2EB4580-475C-4F62-A7D0-A0C53BA8E52F.jpg It’s a possibility that once a long long time ago that was the sticker
  8. May 4, 2019 at 9:57 AM
    Ludogg808
    Luis
    2001 Tundra Sr5
    MNtundra likes this.
  9. May 5, 2019 at 7:10 AM
    Brown Bear
    Brown Bear New Member
    Nor cal
    03 TRD offroad
    -6" RCD lift in front. -Custom leaf springs in rear 4" lift. -17" race line, raptor wheels. -35" Goodyear Duratrac. -4.88 gears. -ARB rear air locker. -ARB air compressor and tank. -Custom front sway bar quick disconnect -Custom one piece driveshaft -Black Oak Led 40 watt ditch lights.
    I have an ARB air Locker on my 03. It is selectable. Just turn on your air then turn on the locker. My opinion some form of locker or LSD is the best upgrade you can make to improve your off-road capability. Even if you're not a serious off-roader but you do take it down dirt roads. We've all encountered some form of twist ditch. If you have an open differential you can get stuck in what seems like the stupidest places.2018-09-03 16.50.46.jpg 20180820_155639.jpg
  10. Oct 30, 2019 at 11:41 AM
    jemnoriega
    jemnoriega THANOS TUNDRA
    Migz
    Henderson, NV
    2020 Tundra Platinum CM
    STOCK
    I just bought a 2020 Tundra CM platinum.
    I want to build for a mixture of capabilities.
    OVERLANDING/ DESERT Runner
    I live here in Las Vegas NV
    My plan is to put ARB air lockers in the front diff. and get the auburn LSD in the rear. Might also re-gear not sure yet.
    (obviously over upgrades such as suspension, tires, and armor are also in the mix)
    any thoughts on the differential build plan ??
    thanks for any feedback
  11. Oct 30, 2019 at 12:14 PM
    Pinay
    Pinay Ultimate Grand Supreme Member Staff Member
    Monet
    2015 Black - SR5 - CrewMax - 4x4 - TSS
    Mahal kita Kuya
    Try asking in the 3rd Gen section.
