AR-15 roof mount solutions?
Discussion in 'General Tundra Discussion' started by Zero One Actual, Jun 8, 2022.
  1. Jun 9, 2022 at 1:30 PM
    #61
    AT x AT
    AT x AT Trooper Transport
    Jimmy
    State 48 - East Basin of Arizona
    2021 Wind Chill Pearl Platinum
    Mods, what mods?
    HulkSmurf14 likes this.
  2. Jun 9, 2022 at 1:43 PM
    #62
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Was simply stating that the linked molle panel site says it won’t work with sunroof, but based on it sitting behind the dome light and only attaching at the grab handle, I can’t see how it would make a difference.
    My other comment was simply that based on the install video, it doesn’t seem like the most robust system with no reinforcement at the bends.
    Either way, it won’t work for OP’s request of something in the front versus the back. So probably a moot point either way.
    Blue Thunder and ToyoMafia like this.
  3. Jun 9, 2022 at 2:04 PM
    #63
    Hightide
    chadington von banks
    Abalama
    Magic School Bus
  4. Jun 9, 2022 at 2:22 PM
    #64
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Big Sky Racks are a cool bunch...down the road from my house...I drive by them twice a day...right next to Flir Headquarters...skeet skeet
    **Edit, not HQ, but has been there for 30 + years making cool sh!t...
    Hightide and ToyoMafia like this.
  5. Jun 9, 2022 at 2:43 PM
    #65
    Blue Thunder
    Washington
    I’ve wanted to find something that mounts above the rear view mirror and then has a one-hand quick release around the interior light in the middle of the cab. So the rifle is pointed forward along the centerline. Any occupant can grab-n-go.
  6. Jun 9, 2022 at 3:16 PM
    #66
    Saltyhero13
    Saltyhero13 Throbbing Member
    I thought you may have used the product before. Tracking.
    As I said in my first comment, depends on how it will be used. All designs have advantages and disadvantages when you assess them based on user requirements, safety is the biggest one.
    As far as robustness, the sides fold in giving the panel rigidity; it is a common technique used to give panels strength without adding thickness or weight. Truck frames often use a similar design (scaled up of course). You really only need it to hold 10lbs of kitted out rifle and other accoutrements. Probably can hold two if there is enough room for the rifles to 69 each other.
    Probably could be modded/adapted for a sunroof.
    To be fair, here is the video of the product ( or similar to) in the op:
    https://youtu.be/e7Gq9EeJMyU
    So when I look at these two items side by side what do I see?
    • Plastic + wedging for support vs integrated bolt on points - Sure modern automotive plastics are robust but they tend to deform and fail over time. 16 to 26 lbs hanging off of these points, banging around. The bolt on points are integrated into the truck support panels and support more weight than the Molle panel could support. I'm an all natural kinda guy but when it comes to bolt ons vs plastic + wedging, bolt-ons win in my book.
    • Forward vs Rearward position - I have zero space between my grape and my headliner, even less if I am wearing a helmet for wombat season. The forward position of the double rack would be a no go for me. OPs ergos are probably different.
    • Rearward position 2 - Rear windows tend to be tinted aiding in concealing. If you are in a lifted truck surrounded by height impaired people you may loose the advantage but I think a slightly rearward position boosts the grey man factor.
    • Rearward position 3 - check your state laws on storage as it varies by jurisdiction. Nuff said
    • Retention - velcrox2 vs Molle. I always thought velcro shoes were cool but Molle will always have my heart; especially if you already have the Molle full spring collection. Velcro is noisy too.
    • Orientation - starboard to port only vs 360 degree mounting. This deserves more attention if you have passengers. Also plays into drawing. Rifle length plays a role too.
    • Ergonomics/drawing - undoing velcro x 2 vs your favorite modular retention system. Now do it under stress. Now do it again while you are tired. Now do it again with one hand. You are not done yet, try it again with your weak hand. Get back and try it again with greasy/oil hands (simulates blood). As an example this is using retention that requires standard manual of arms manipulation: https://youtube.com/shorts/51zJbh7_dQk?feature=share
    I'm not endorsing either product without testing them both. I am just offering food for though. I don't like the idea of storing the rifle over the head, slightly rear or slightly forward sure (the shelf thing would probably obstruct visibility). Footwell or behind the passenger seat would be my first picks but I understand those aren't options. Overhead in a starboard to port orientation is a no go for me, maybe front to back but I would have to play around with it in that orientation.
  7. Jun 9, 2022 at 4:12 PM
    #67
    Zero One Actual
    Zero One Actual [OP] Member among Members
    These are the things that keep me awake at night.
    Ergos are the same. Im going to maybe order one on Amazon. Instal it then assess from there. If it doesn’t work, Amazon return at UPS and move on to next option.
  8. Jun 9, 2022 at 4:13 PM
    #68
    Zero One Actual
  9. Jun 9, 2022 at 4:18 PM
    #69
    Saltyhero13
    One night stand may not tell you if you want to marry her.
    Try it out is probably your best bet.
  10. Jun 9, 2022 at 4:19 PM
    #70
    Hightide
    Abalama
    Magic School Bus
    What up brother?!?
    Missed ya man!
  11. Jun 9, 2022 at 4:21 PM
    #71
    Hightide
    Abalama
    Magic School Bus
    this is the good about Amazon… try it before ya buy it.
  12. Jun 9, 2022 at 4:22 PM
    #72
    Saltyhero13
    I'm just letting you know I'm a jealous bitch. <hiss>
  13. Jun 9, 2022 at 4:27 PM
    #73
    Hightide
    Abalama
    Magic School Bus
    Nothing but love.
    You just easing in like a colonoscopy.:eek::D
    Sneaky bastarg.
    Now get busy!
    Zero One Actual[OP] likes this.
  14. Jun 9, 2022 at 4:29 PM
    #74
    Saltyhero13
    That should be name of a military operation: Easy Colon. Perfect name for snooping and pooping.
  15. Jun 9, 2022 at 4:34 PM
    #75
    Hightide
    Abalama
    Magic School Bus
    Guys! We’re going in for operation “Easy Colon”.
    We will leave No man behind.
    The operation will run smooth, yet firm and we’ll clean up the end.
    No swollen prostates and an enema is the last resort.
    Kgfit85 and Saltyhero13[QUOTED] like this.
  16. Jun 9, 2022 at 8:38 PM
    #76
    Zero One Actual
    @Hightide @Saltyhero13 @FrenchToasty
    So what had happened was….I fell into a well. It wasn’t that bad. There was lotion and a small white dog and cool art work on the sides of the well from girls fingernails. Anyways, this guy(?) was going to make a skin suit out of me but I told him about onlyfans and how we could make a fortune. So we did. And ummm ya, now I want some overhead storage for an AR.
  17. Jun 9, 2022 at 8:39 PM
    #77
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    We missed you just like you missed fresh air!
  18. Jun 9, 2022 at 10:55 PM
    #78
    Hightide
    Abalama
    Magic School Bus
    I’m just hurt you didn’t invite any of us.
  19. Jun 10, 2022 at 5:55 AM
    #79
    Saltyhero13
    I'd fluff me.
  20. Dec 24, 2022 at 6:26 AM
    #80
    rocsteady
    rocsteady New Member
    Dave
    New Jersey
    2021 Super White SR7 Double Cab SX
    So, uh, what was the prognosis doctor? Did you end up with a solution? I was trying to think of a way to use this:
    https://tacticalwalls.com/product/modwall-air/
    Just not keen on having to then insert a mag before the zombies get ya...
  21. Dec 25, 2022 at 5:37 AM
    #81
    Zero One Actual
    I haven’t tried anything out yet. Still poking around looking for solutions.
    ColoradoTJ likes this.
  22. Dec 25, 2022 at 8:38 AM
    #82
    Wallygator
  23. Dec 25, 2022 at 4:15 PM
    #83
    D1227
    D1227 New Member
    Dustin
    Western Washington
    16crewmax
    watching for the outcome:spy:
  24. Dec 25, 2022 at 4:26 PM
    #84
    tech1208
    tech1208 Old Salt, New truck
    Orlando, FL
    2023 Tundra Platinum 4X4 Blueprint Blue
  25. Dec 25, 2022 at 4:29 PM
    #85
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
  26. Dec 22, 2023 at 4:46 PM
    #86
    Tooft
    Tooft New Member
    2016 Limited CM
    Everything...
    Hey, long time lurker and first time poster here. This forum has really helped fuel my mod obsession so thanks for all the insight gents. I just wanted to bump this and let you know the OG Fabrications molle panel can work on sunroof models. However, you'll need to make some custom mounting brackets to lower the panel. The difference between the sunroof and non sunroof models are that the SRoof models have a lowered bulge, to make room for the sliding SRoof. I just used some 1" aluminum strips and bent them in place. Turned out pretty fire and waiting for my AR mount to arrive to test a horizontal mount. 20231222_150425.jpg 20231222_150453.jpg 20231222_150425.jpg 20231222_150425.jpg 20231222_150550.jpg 20231222_150629.jpg
    How do I make these images smaller? Sorry to the real-estate grab
  27. Dec 22, 2023 at 4:52 PM
    #87
    RainMan_PNW
    Casey
    Clark County, WA
    What did you use for the black headliner?
    Tooft[QUOTED] likes this.
  28. Dec 22, 2023 at 5:07 PM
    #88
    Tooft
    Tooft New Member
    2016 Limited CM
    Everything...
  29. May 6, 2024 at 4:32 AM
    #89
    Rugerla1
    Rugerla1 New Member
    Tennessee
    2018 Tundra TRD Sport
    Like the way you made those brackets and the handles too. Did you ever get the gun mount set up, and if so how do you like it?
    Tooft[QUOTED] and Saltyhero13 like this.
  30. May 6, 2024 at 10:14 AM
    #90
    Saltyhero13
    Nice fab. Suspected it could be modified to fit. Good job and it looks clean.
