Apple CarPlay issues
Discussion in 'Audio & Video' started by ChrisLopez, Jul 19, 2021.
  1. Jul 19, 2021 at 5:12 PM
    ChrisLopez
    ChrisLopez [OP] New Member
    Christian
    Chicago,Illinois
    2018 Tundra SR5 TRD off road Crew max
    I have a 2018 tundra sr5 and I upgraded the radio to the Kenwood DMX7706S. Apple CarPlay always worked great up until a week ago. It connects through usb and apple CarPlay comes up but it’s disconnects every so often. Sometimes it’ll disconnect every few minutes or it can not go out at all and it’s getting very frustrating. I even purchase a carlinkit wireless CarPlay adapter and it still does it. I have already erased and reconnected phone from radio. Does anyone know what it can be? Thanks for the help in advance.
  2. Jul 20, 2021 at 7:30 AM
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    I have had issues with CarPlay that were resolved by doing hard restart on my JBL head unit and I have had issues that came up after my iphone updated. I don't have much of an answer for you other than it is way too finicky for something with only a few functions.
    There was a thread a while back were the op's issues were fixed with a new cable.
  3. Jul 20, 2021 at 7:35 AM
    point08
    point08 New Member
    Kyle
    2014 Toyota Tundra 5.7L SR5 4WD DC
    AirLift LoadLifter 5000 Ultimate Plus, AirLift Wireless One 2nd Gen, TRD Rear Sway Bar, Bakflip G2 Tonneau Cover, Running Boards, Tint, Power Tailgate Lock, Hike-It X9 Throttle Controller, Tekonsha P3 Brake Controller with Custom In-Dash Housing, Method 701 Wheels, Toyo Open Country III Tires, 3WLiner Window Mod, External Fuse Box, Dash Cam, Pioneer DMH-1500NEX
    I have had similar experiences on my Pioneer... It was the cable and vibration from the holder. Swapped the cheap cable, laid it flat on my console, no more issues
  4. Jul 20, 2021 at 8:18 AM
    Justbass
    Justbass New Member
    Steven
    Ohio
    2020 Platinum
    TRD Sway bar, Lomax Tonnueau cover, Bed rug, Havoc HS2 Steps, Tech 12 Volts stereo upgrade, Yakima bed extender, misc trim and bling,
    Yep, the first thing I would try is a different cable, although BT having the same issue is puzzling.
  5. Jul 20, 2021 at 10:02 AM
    point08
    point08 New Member
    Kyle
    Well, the external wireless carplay is just a USB Dongle that you plug in to your existing USB port and connect via Wifi.
    Could be that your car USB port is a bit loose on the dash. You can run an external bypass to the back of the unit to see if it's that.
  6. Jul 20, 2021 at 10:31 AM
    DIYDad
    DIYDad New Member
    2020 Tundra 1794
    How do you do a hard restart? I'm starting to have issues. I'll have to check the cable too.
  7. Jul 20, 2021 at 10:33 AM
    crewmaxlmt
    scott
    On the JBL head unit, you hold down the volume button until it restarts. I would imagine that there is something similar on your unit.
  8. Jul 24, 2021 at 6:46 AM
    ChrisLopez
    Christian
    Chicago,Illinois
    So turns on it’s not the cable or the USB port. Realized it goes out when I hit a road bump. Phone stays charging but CarPlay disconnects and I have to plug and replug. I had Best Buy install when I purchased the head unit so I’m going to give them a call hopefully they can help me out.
  9. Jul 24, 2021 at 7:31 AM
    point08
    point08 New Member
    Kyle
    "honey, I need new shocks" is perfectly acceptable ;)
    ChrisLopez[OP] likes this.
