Apple Car Play Stereo Upgrade
Discussion in '1st Gen Tundras (2000-2006)' started by dunn4040, May 18, 2021.
  1. May 18, 2021 at 5:20 AM
    dunn4040
    dunn4040 [OP] New Member
    Michael
    2005 Toyota Tundra SR5 TRD
    Hey guys, just bought my first Tundra a few months back. I got a 05 and it still has the factory audio and head unit. I was wanting to replace the factory head unit to a touch screen with Apple car play. Has anybody on here done that with success and which head unit did you go with? I'm a bit of a novice when it comes to car audio so any tips are welcomed and appreciated.
    I'd like to install a sub and replace the factory speakers eventually but wanted to upgrade the head unit first.
  2. May 18, 2021 at 5:57 AM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    jerryallday and dunn4040[OP] like this.
  3. May 18, 2021 at 6:00 AM
    2006Tundra
    2006Tundra Financially Irresponsible
    Lou
    Long Beach, CA
    2006 Toyota Tundra Double Cab SR5, 4.7L V8
    Tons of people have does. Check out my build page (post #20) for pics of what head unit, sub and amp I used.
  4. May 18, 2021 at 6:24 AM
    Sbrow191
    Sbrow191 Jus Lerkin
    NC
    2006 DC Tundra XSP 4x4
    Sony XAV-AX100. CarPlay and android platform in one. Installation took me 8 hours but most of that was trying to find the reverse wire!!!! I hadn’t done stereo work in a decade but I figured it out and now have a modern unit with backup camera.
  5. May 18, 2021 at 6:53 AM
    dunn4040
    Michael
    Awesome, thanks for the quick replies guys. You've given me a great place to start.
  6. May 18, 2021 at 8:50 AM
    weadjust
    weadjust New Member
    Tupelo, MS
    2006 Tundra Limited DC
  7. May 18, 2021 at 9:07 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Speaking of Crutchfield, my suggestion would be that if/when prices/stock get back to normal, if that's a word, I would consider using Crutchfield....radio choice, recommendation of parts needed by inputing Truck details. They will then fix you up with necessary speakers, amp bypass, making of cables etc. Install becomes much more easier.
  8. May 18, 2021 at 9:19 AM
    robabeatle
    robabeatle New Member
    AZ
    2002 Tundra 4x4 LTD AC
    Bilstein 6112 & 5160, Katskinz, audio upgrades
    +1
  9. May 18, 2021 at 11:38 AM
    tacoguybill
    tacoguybill The Burrito Bandido
    Bill
    Saaaan Diaaago
    06 DC SR5 4x4 174k, 04 Sequoia SR5 4x4 105k
    I installed a Boss audio, super easy, I did lose steering wheel controls but I really don't find that to be all that inconvenient considering what you're gaining by adding touchscreen/appleplay (nav) the only thing that is unfortunate is that the license plate cameras go bad after 3-4 months probably getting wet going hunting etc. I did just order the master tailgater so the camera will be integrated into the tailgate latch and hopefully have increased longevity.
    radio is Boss Audio BVCP9685A
    https://www.walmart.com/ip/BOSS-Aud...uchscreen-Vehicle-Multimedia-Player/121071281
  10. May 19, 2021 at 11:25 AM
    eddieb02
    eddieb02 New Member
    Eddie
    2005 tundra sr5
    Stock for now
    i recently did this - i ordered from crutchfield and got new head unit and all new speakers - the hardest thing for me was the amp bypass wiring which was really just tedious - take your time and i think its a great and easy upgrade. cost in total about 250 for the head unit and 250 for all new speakers - takes a couple hours but def a huge upgrade from stock
  11. May 3, 2023 at 5:11 PM
    AMT
    AMT New Member
    Micah
    2005 DC 4x4
    Why not keep the factory amp? I recently purchased an Apple CarPlay head unit from Crutchfield with the pre-wired harness and the kit to keep the steering wheel controls and want to upgrade the door speakers and maybe add an under seat sub in the rear. I tried figuring out what to use in the front lower door speakers and got very confused on what would work. When upgrading the speakers should I bypass the factory amp?
  12. May 3, 2023 at 6:05 PM
    I doubt he's going to answer you, dude hasn't been here in 2 years.
    But why not keep the factory amp? Because trying to adapt it for use with an aftermarket stereo is a pain in the ass, plus it's dated 1-20 year old tech, and finally any quality modern head unit will likely have more, cleaner power in a smaller, more efficient package.
    If you can't figure out how to wire your stuff up, Crutchfield has free phone support. But this topic has been fully laid out in this thread, under the "Audio and audio upgrades..." section: https://www.tundras.com/threads/so-you-wanna-buy-just-bought-a-1st-gen-tundra-eh.115928/
    If you can't figure it out after reading and checking out pics in the linked threads inside that section of the 1st reply, create a new thread so we can help. 1 or two similar posts come through every month.
  13. May 16, 2023 at 9:47 AM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Do not cut any wires. They make kits and adaptors for all of that
