Anything other than KO2s I should look at?
Discussion in 'Wheels & Tires' started by Red Fox, Aug 15, 2018.
  1. Aug 15, 2018 at 6:33 PM
    Red Fox
    Red Fox [OP] New Member
    Kacie
    2016 Radient Red SR
    So I've been taking my time on deciding what wheels and tires I wanted. I've pretty much narrowed it down to 2 wheels, the MB 352s or the Method MR305 NVs both with a 25mm offset.
    I know this part has been discussed many times and I've been reading through all the threads but theres quite a few lol. So my next question....I thought I had my heart set on the BFG Ko2s...but I see a lot of back and forth on them.
    As of now I only have a 3" leveling kit on the front. Eventually I change that out for a full lift kit...probably the Toytec Boss as of now.
    So....tires....anything better than the Ko2s I should look at that is an all around good tire. I'm planning on the 285/65s right now....most of my driving is highway but I would like to try some offroad as well at some point.
    Thanks yall!
    BTBAKER and Toyota10s like this.
  2. Aug 15, 2018 at 6:40 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    I'm sure there are a lot of great options. I have been happy with my KO2's so far, no complaints.
  3. Aug 15, 2018 at 6:42 PM
    Yeah........Cooper STT Pro M/Ts, ST Maxx, AT3's
    Pudge and Red Fox[OP] like this.
  4. Aug 15, 2018 at 6:46 PM
    Red Fox
    Kacie
    2016 Radient Red SR
    That's good! Everything about them I've read outside of here seems good but there on here theres a lot of back and forth o_O
    MotoTundra[QUOTED] likes this.
  5. Aug 15, 2018 at 6:46 PM
    Red Fox
    Kacie
    2016 Radient Red SR
    Thank you! I'll look into those too!
  6. Aug 15, 2018 at 6:49 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Ditto
  7. Aug 15, 2018 at 7:20 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    I agree with these choices. There are a ton of great tires out there. Falken wild peaks get rave reviews and are light weight and very affordable
    I'm a sucker for the Michelin defenders myself but I doubt you're looking for a street tire
  8. Aug 15, 2018 at 7:28 PM
    But she is looking for a very good mostly highway tire with some ooomph!......Michelin's!
    Toyota10s and Red Fox[OP] like this.
  9. Aug 15, 2018 at 7:33 PM
    Pudge
    CT
    Ahhh I missed that part. If that's the case she can't go wrong with the Michelin defenders. Best all around tires I have ever owned. They don't look aggressive but their performance would fool you into thinking they were. I can't recommend these enough
  10. Aug 15, 2018 at 7:33 PM
    Hang in there Kacie...There are so many tires...more will chime in!
    Red Fox[OP] likes this.
  11. Aug 15, 2018 at 7:33 PM
    Red Fox
    Kacie
    2016 Radient Red SR
    Yes with some ooomph! :rofl: until I get a job that doesn't evolve driving interstate every day :D
  12. Aug 15, 2018 at 7:36 PM
    My two grand daughters are in Murfreesboro right now. 7 and 8. Just started school there. My ex is helping out. I see a Murfreesboro trip in my near future..
    Erichudgins likes this.
  13. Aug 15, 2018 at 7:38 PM
    Pudge
    CT
    I think we have 3 or 4 members now from murfreesboro. I had never even heard of it before. You guys all know each other?
    @Erichudgins @Nickhood23
  14. Aug 15, 2018 at 7:39 PM
    Red Fox
    Kacie
    2016 Radient Red SR
    That's awesome! We love murfreesboro!! Let me know when you do! We can meet up! And there are a few others around this area too that I'm sure would love to get together
  15. Aug 15, 2018 at 7:40 PM
    Red Fox
    Kacie
    2016 Radient Red SR
    I know @Erichudgins but hes then only one so far! I'm sure he knows more!
  16. Aug 15, 2018 at 7:40 PM
    JJ Cale was from Murfreesboro.
    Red Fox[OP] and Pudge[QUOTED] like this.
  17. Aug 15, 2018 at 7:41 PM
    Certainly possible. Nothing planned yet. I've got my 3 yr old grandson most of the time. He needs to see grandma. So.... it will happen......but when. It would be great to meet up with fellow Tundra owners in TN!
    Red Fox[QUOTED][OP] likes this.
  18. Aug 15, 2018 at 7:43 PM
    Atomic City Tundra
    Devin
    New Mexico
    2013 Tundra 5.7FFV CM 4X4
    I currently run K02s. I am about to get some new tires - I will probably pull about 45,000 out of these - which is the best I have gotten out of BFG tires on any of my trucks. However, I won't be getting the KO2s again. If you have any type of uneven wear with the KO2s - they get loud as hell. I had a slight alignment issue that led to some uneven tire wear which led to such a noise coming from the front end that I was sure that my front diff was going. I hunted and hunted for the sound - even went so far as to replace the driver's side needle bearing in the diff housing with the ECGS replacement bushing with no noise resolution. Someone mentioned that it might be my tires. So, I swapped tires with a fellow Tundra owner for just a spell and viola, the sound was gone.
    Just my 2 cents.
    Toyota10s, Red Fox[OP] and Black Wolf like this.
  19. Aug 15, 2018 at 8:01 PM
    Erichudgins
    Erichudgins New Member
    Eric
    Murfreesboro, TN
    2017 Super white Limited DC
    https://www.tundras.com/threads/the-un-limited-build.25949/
    I'm very fond of my stt pros!! Drove to az and back on them! They balance good and they seem to wear well! Plenty of oomph lol
  20. Aug 15, 2018 at 8:05 PM
    Red Fox
    Kacie
    2016 Radient Red SR
    I just looked those up and I do like those!
    Pudge likes this.
  21. Aug 15, 2018 at 8:07 PM
    Pudge
    CT
    I would go with the stt pros over KO2s any day. But I have no need for a aggressive tire and do have a need for a quiet tire that gets good mileage. If that ever changes I'd get the coopers for sure.
  22. Aug 15, 2018 at 8:11 PM
    Red Fox
    Kacie
    2016 Radient Red SR
    I like the price of the stt's over the ko2's too. And if I can get a better tire at a better price I'm good with that too :D
    Pudge[QUOTED] likes this.
  23. Aug 15, 2018 at 8:12 PM
    easleycrawler
    Travis
    Easley, South Carolina
    17 Tundra SR5 DC Black 5.7
    I've been running the BFG ko's 1 and 2's for the last 12-15 yrs, not a single problem out of any of them. Ran the mud terrains before the all terrains. I won't run anything else.
  24. Aug 15, 2018 at 8:13 PM
    Red Fox
    Kacie
    2016 Radient Red SR
    Wow that's pretty good! Thank you!
  25. Aug 15, 2018 at 8:14 PM
    easleycrawler
    Travis
    They are pricey, but worth every penny.
  26. Aug 15, 2018 at 8:44 PM
    TundraLaw
    TundraLaw New Member
    Northern Nevada
    24 GMC Sierra At4x AEV
    ST maxx or ST Pro. can't go wrong.
  27. Aug 15, 2018 at 9:24 PM
    CaptTyler
    CaptTyler Life’s too short to have an ugly boat.
    Tyler
    2018 Ram 2500 Cummins
    Absolutely love my Cooper AT3 XLT. Look real aggressive, super quiet and excellent wet traction. Best tire I’ve ran yet.
  28. Aug 15, 2018 at 9:25 PM
    01erionracing
    01erionracing KJ6RKU
    Jimmy
    2000 SR5 4WD 2002 SR5 4wd 2008 CM Limited 4wd
    Squirrel and Red Fox[OP] like this.
  29. Aug 15, 2018 at 9:26 PM
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
  30. Aug 15, 2018 at 9:31 PM
    01erionracing
    Jimmy
    I was fans of Goodyear Wrangler M/T with Kevler my whole Jeep crawler life until tried out first time BFG KO on my Gen1 Tundra, it last almost 40k miles street and some fireroad trail. I then move to KO2 and happy so far.
