Anyone using the Kenwood DNR1007XR Excelon Reference?
Discussion in 'Audio & Video' started by Shadowfax1, Feb 10, 2022.
  1. May 18, 2022 at 3:55 PM
    #151
    TxLock21
    TxLock21 Bought a truck, got bit by the bug.
    Happy with the results…couldn’t have done it without your guys help
    Sleeper16plat, GOLEM and BrandonL812 like this.
  2. May 18, 2022 at 5:16 PM
    #152
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    Looking good there.
    TxLock21 likes this.
  3. May 18, 2022 at 6:20 PM
    #153
    TxLock21
    Thank you sir…and thank you for answering my endless list of questions
    BrandonL812[QUOTED] likes this.
  4. May 18, 2022 at 6:55 PM
    #154
    BrandonL812
    Brandon
    it’s not a problem at all. We are all here to help each other one way or another. I’m glad that you actually did the work yourself. Not only does it save you money, it also show you how simple it can be to not be intimidated by it.
    TxLock21[QUOTED] likes this.
  5. May 20, 2022 at 6:17 AM
    #155
    TxLock21
    Does anyone know what the difference is between the Maestro RR and Maestro RR2, for our trucks in particular?
    619Tundra likes this.
  6. May 20, 2022 at 5:02 PM
    #156
    BrandonL812
    Brandon
    619Tundra and TxLock21 like this.
  7. Jun 14, 2022 at 6:09 PM
    #157
    GOLEM
    GOLEM New Member
    08 & 18 Tundra
    Are younstill happy wiyh the head unit over the 8600nex? Does the screen size or how it mounts bother you? Are you still able to read the info screen on the upper dash?
  8. Jun 15, 2022 at 5:12 AM
    #158
    BrandonL812
    Brandon
    I’ve never had the 8600nex so cant compare. I am very satisfied with this unit it was worth every penny. Performance and quality. Never lag. I can still read the oem tiny display just fine the big screen doesnt block it at all. It doesn’t bother me how it is mounted. It’s a floating screen, so expect it to get mounted like that. if you prefer a flush look. The pioneer would be a better choice since you can custom mount it better.
    the only gripe I have about this unit, probably the same with kenwood, is how it would completely turn off if you key from ON to IGN. I wish it would stay on during that quick transition so you dont have to wait for the boot up again. But it does boot up quickly though.
    GOLEM likes this.
  9. Jun 15, 2022 at 5:51 AM
    #159
    dkrou
    dkrou New Member
    dan
    2019 tundra
    I'm right there with you....I love mine and have from the beginning. The floating screen looks good and I think most people wouldn't know or think this is aftermarket. In my opinion the new large screens in the 22 don't look nearly as good...almost too big and odd looking in my opinion. The stock head unit in my jbl was so bad I never looked back....
    BrandonL812 likes this.
  10. Jun 15, 2022 at 7:01 AM
    #160
    19TurdPro
    19TurdPro New Member
    2019 Tundra TRD Pro
    There's a setting for that.
  11. Jun 15, 2022 at 8:58 AM
    #161
    BrandonL812
    Brandon
    Any idea where? Would it be in the meastro for oem setting or something like that?
    Thanks
  12. Jun 15, 2022 at 9:55 AM
    #162
    19TurdPro
    2019 Tundra TRD Pro
    Off the top of my head, and I may have the wording wrong:
    Settings, OEM Setup, Maestro Features, Maestro Settings, Accessory During Crank
    It will still kill it if battery voltage drops too much.
    This is a Maestro setting, so you must be using one.
  13. Jun 15, 2022 at 12:31 PM
    #163
    BrandonL812
    Brandon
    I’ll give it a look after work this evening.
    update:
    I Enabled Accessory On During Crank in the Maestro setting. Only tested 2 time. It did work. But it is true that if the voltage is low it will still kill the radio. Thanks for the info @19TurdPro
  14. Jun 26, 2022 at 1:57 PM
    #164
    BrakeDust
    BrakeDust New Member
    Hill Country, TX
    2021 CM SR5 4x4 Magnetic
    Here's my solution to the wifi-dropping problem on Android, found it on a Reddit thread.
    Disable the first and last settings in your Android Wifi settings on your phone, see pic below:
    - Wifi/data switching
    - Hotspot 2.0 auto connect
    Your phone is trying to connect to other wifi networks in the city. (I never had drop in the countryside, but _always_ in the city)
    bulldog93 likes this.
  15. Jul 2, 2022 at 12:12 PM
    #165
    GOLEM
    GOLEM New Member
    08 & 18 Tundra
    Im about 90% done with my install (1000xr) and RR as i could not find an rr2.
    The Kenwood manual leave a lot to be desired.
    Im having issues with the supplied mic, people say i soind muffled.
    Here is a photo of where i installed it.
    This is the same position i had with my Pioneer that i replaced with the Kenwood.
    Is there a better mic anyone is using?
    Im a bit disappointed that the unit is not reading my tpms sensors or gas tank.
    How do i get the weather app to work?
    2008 Tundra w/JBL20220702_145136.jpg 20220702_145237.jpg 20220702_150101.jpg 20220702_150901.jpg 20220702_150928.jpg
  16. Jul 2, 2022 at 9:41 PM
    #166
    BrandonL812
    Brandon
    Look at the troubleshooting section of the maestro installation guide for your truck. You may have to run 2 extra wires from the obd2 port to the TO harness. In the instructions it will tell you the color wires on the TO harness to tap into and which pins on the obd2 port it need to tap into. I had to do this on my 2017 sequoia. This is the only way for my gauges to show up on the radio. I made 2 extra wires and run it along side the single obd2 plug that came in with the TO harness.
    Sleeper16plat likes this.
  17. Jul 4, 2022 at 12:09 PM
    #167
    GOLEM
    GOLEM New Member
    08 & 18 Tundra
    16569618450744985514110664750908.jpg Wired in my factory mic and its 1000000% times better.(bypassed the factory mic amp)
    People dont know im on BT now.
    1 issue fixed, 2 more to go.
  18. Aug 1, 2022 at 8:27 PM
    #168
    GOLEM
    GOLEM New Member
    08 & 18 Tundra
    If anyone is interested this hdmi/usb combo works
    texasrho83 and bulldog93 like this.
  19. Aug 2, 2022 at 1:02 PM
    #169
    TxLock21
    The wireless CarPlay has been sporadically disconnecting the past few days, with a prompt popping up on the screen saying to reconnect the GPS. I have an iPhone 12 Pro with the latest updates. Anyone else having this kind of issue?
  20. Aug 2, 2022 at 1:15 PM
    #170
    GOLEM
    GOLEM New Member
    08 & 18 Tundra
    Call VJ with Kennwood at
    6502430655
  21. Aug 28, 2022 at 8:09 AM
    #171
    TxLock21
    Good morning guys, got a problem and hoping someone is familiar with it. The battery in my 2018 died yesterday (factory battery, impressed it lasted this long). Tried jumping it a few times using another truck but to no avail. AAA came by with a jump box and I got it started, bought a new battery from the dealership and went home and installed it. Now the Navigation doesn’t want to work. I utilized the factory GPS when I installed the head unit. I also have these odd stats on my gauge cluster (24mi 28m). See pic. Wondering if anyone has run into this before and knows of a fix. Thanks!
  22. Aug 28, 2022 at 8:29 AM
    #172
    BrandonL812
    Brandon
    Can you go into the headunit and do a factory reset or reinitialize the unit?
  23. Aug 28, 2022 at 8:55 AM
    #173
    GOLEM
    GOLEM New Member
    08 & 18 Tundra
    How many miles have you driven the truck since the new battery? Automatic reset takes up to 50miles
  24. Aug 28, 2022 at 9:25 AM
    #174
    TxLock21
    I re-initialized it and it didn’t fix it.
  25. Aug 28, 2022 at 9:25 AM
    #175
    TxLock21
    Nope, haven’t driven 50 miles yet. I didn’t know about this. I will drive it around and see if it works.
  26. Aug 28, 2022 at 9:10 PM
    #176
    TxLock21
    After driving around for a while (50+ miles), the navigation started working again. You guys are geniuses, thank you!
  27. Aug 28, 2022 at 10:11 PM
    #177
    Thumper_6119
    Thumper_6119 I've seen things you people wouldn't believe.
    2011 Toyota Tundra SR5 Texas Edition (Crewmax) 4x4
    I have a DNX996XR, and I have to download and run an app called Kenwood Traffic by Inrix on my smartphone in order for the weather widget to work on the headunit. . (CarPlay or Auto has to be running). It gave me a free 5 year subscription.
  28. Sep 1, 2022 at 12:02 PM
    #178
    TxLock21
    Haven’t had a chance to make the call yet but I was curious about something: is it better to retain the factory GPS antenna with the Kenwood unit or use the GPS antenna that Kenwood supplies? This is the error I keep getting whenever I try to connect the wireless CarPlay…sometimes even happens when I connect the phone with a USB cable.
  29. Sep 1, 2022 at 12:04 PM
    #179
    BrandonL812
    Brandon
    I would use the kenwood gps antenna.
  30. Apr 1, 2023 at 11:06 AM
    #180
    Matt56258
    Matt56258 New Member
    Matthew
    Savannah GA
    2021 Tundra Platinum MGM
    TRD grille, TRD dual exhaust
