Anyone using the Kenwood DNR1007XR Excelon Reference?
Discussion in 'Audio & Video' started by Shadowfax1, Feb 10, 2022.
  1. Apr 8, 2022 at 8:37 AM
    #61
    dkrou
    dkrou New Member
    dan
    2019 tundra
    How in the heck do you do that??? I have usb and hdmi hooked up to the back.
  2. Apr 8, 2022 at 12:07 PM
    #62
    Degausser
    Degausser New Member
    Kevin
    GA
    2024 LR SR5
    What kind of phone do you have? I believe it's only available with newer androids.
  3. Apr 8, 2022 at 12:25 PM
    #63
    TundraMidwesterner
    TundraMidwesterner What?
    Northern Illinois
    2019 Magnetic Gray Metallic CrewMax TSSOR 4x4
    Katzkins, Rostra heated seats(4), Tint (all), TRD rear sway bar, TSS wheels, OEM black lug nuts and wheel locks, OEM LED black fog lights, Driver side grab handle, Rough country LED Bumper bar, Rough Country Hard tri fold tonneau cover, AVS ventshades, Bilstein 5100's on top setting in front, Ready lift 1 inch ready block in the rear with Bilstein 5100's. Fluid Film. ESP under seat storage. LED interior lights and cargo lights swapped. Rear USB charger port swapped for 12v port. Remote start. Leather wrapped steering wheel kit. TRD shift knob. Kenwood dmx1037s. Hertz K170 door speakers/ tweeters, Infinity Reference 7005A 5 channel amp, 2 JBL WS1000 10 inch subs. DDI Seat Jackers. RCI engine Skid and Vahalla's Shields (front and rear) 1/4 aluminum. Stillen intake. LED Pro Headlights with iHacker harness. Cartrimhome auto up and down window switches. Coupe's aluminum battery tie down. Color matched mirror caps. Color matched door handles. Chalk bag cup holder. NFab podium step bars, herculined. Powerstop z36 drilled slotted brake discs w/ceramic pads.
    There is a "mirroring for kenwood" app on android, unsure on iOS but I'm sure its similar.
    I have used samsung Dex over the usb connection (s21 Ultra) on my 1037 a few times just to see if it would work, it plays pretty nice with every app on my phone I've tried including netflix, hulu, prime video, disney+, outlook, powerpoint, pdf editors, chrome. I also have a small handheld bluetooth keyboard I keep in the truck for typing but I can use the touch screen as a mouse.
  4. Apr 8, 2022 at 1:09 PM
    #64
    TundraMidwesterner
    Northern Illinois
    I will say, the volume knob on the kenwood is a little too easy to accidentally turn the volume up or down by a WIDE margin just from grazing the knob when using the touch screen. Once you get used to it its not bad but when you add an amp and subs and are already listening at a fairly loud level, cranking it up suddenly can be pretty jarring. I haven't found any setting that would help with that, the knob just moves very freely and its doesn't take much rotation to significantly adjust the volume.
    Other than that I've been very happy with mine and would absolutely do the same headunit and speakers all from tech12volts again.
  5. Apr 9, 2022 at 9:42 AM
    #65
    dkrou
    dkrou New Member
    dan
    2019 tundra
    Apple I phone 12
  6. Apr 9, 2022 at 9:48 AM
    #66
    dkrou
    dkrou New Member
    dan
    2019 tundra
    I have an HDMI cable hooked up I will see if that works....
  7. Apr 9, 2022 at 6:19 PM
    #67
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    Is your hdmi cable 1080p or 4k? It must be 1080p cable for screen mirroring to work. 2K, 4k cable will not work at all. You also need the lightning to hdmi adapter.
  8. Apr 10, 2022 at 7:26 AM
    #68
    dkrou
    dkrou New Member
    dan
    2019 tundra
    I think I have the wrong cable...I have the lightning adapter. Tried it yesterday and it said no signal....
  9. Apr 10, 2022 at 8:03 AM
    #69
    BrandonL812
    Brandon
    Get the 1080p cable. It will work. i have the jvc 10” same as kenwood. I am using the 1080p cable from Monoprice and it works perfectly. I also have Amazon firestick hooked up too. Both works great.
    you cannot use Carplay and screen mirroring at the same time. You HAVE to disconnect from Carplay if you want to screen mirror.
  10. Apr 10, 2022 at 8:19 AM
    #70
    dkrou
    dkrou New Member
    dan
    2019 tundra
    shoot me the link to the part number if you would....the kenwood cable looks sold out everywhere.
  11. Apr 10, 2022 at 10:51 AM
    #71
    BrandonL812
    Brandon
    Unfortunately the one i used i could not see it in the website. The cable i have is over 5yrs old. Best i can recommend is if you had bought any hd tv before all the 2k, 4k, 8k. It usually come with a cable. Try that.
    or try this.
    High Speed HDMI Cable, 1.5 Meter (5FT),1080P@60HZ, 3D & Audio Return Channel for HD TV, Laptop,Blu-Ray DVD, Projector,Apple TV & More https://www.amazon.com/dp/B01MCZTN0M
    TxLock21 likes this.
  12. Apr 11, 2022 at 5:53 AM
    #72
    dkrou
    dkrou New Member
    dan
    2019 tundra
    Thanks I found the original Kenwood cable...that should work I would think.
    BrandonL812[QUOTED] likes this.
  13. Apr 11, 2022 at 5:55 AM
    #73
    dkrou
    dkrou New Member
    dan
    2019 tundra
    I did see that certain streaming services won't work because of copyright protection....How did you connect the firestick? I have FUBO tv on my phone I wonder if I can stream that?
  14. Apr 11, 2022 at 9:05 AM
    #74
    BrandonL812
    Brandon
  15. Apr 11, 2022 at 2:15 PM
    #75
    TxLock21
    TxLock21 Bought a truck, got bit by the bug.
    I just got this system…what will I need to be able to watch Netflix, YouTube, etc for passengers while driving?
    I have an iPhone, if that makes a difference.
    Shadowfax1[OP] likes this.
  16. Apr 11, 2022 at 4:10 PM
    #76
    BrandonL812
    Brandon
    get the Amazon firestick. Add youtube and Netflix to it. Then watch it.
  17. Apr 13, 2022 at 4:40 PM
    #77
    dkrou
    dkrou New Member
    dan
    2019 tundra
    does it matter what firestick you get? I just installed a hotspot in my truck for my blackvue dash cam....maybe that will work.
  18. Apr 13, 2022 at 4:51 PM
    #78
    dkrou
    dkrou New Member
    dan
    2019 tundra
    So do you plug in the usb power cord to the side of the firestick? Is that something you have to buy seperately?
  19. Apr 13, 2022 at 5:18 PM
    #79
    BrandonL812
    Brandon
    Your firestick will come with power cord and wall block. You dont need the wall block. Just the cord and one of those usb charger that goes into the cig port. I’m using this little guy:
    Anker Car Charger, Mini Aluminum Alloy 24W Dual USB Car Charger, PowerDrive 2 Alloy Car Adapter with Blue LED for iPhone12/11/XR/Xs, iPad Pro/Air 2/Mini, Galaxy (Not Compatible with Quick Charge) https://www.amazon.com/dp/B07PGT7LSR
  20. Apr 13, 2022 at 5:19 PM
    #80
    BrandonL812
    Brandon
    Nope. It doesn’t. You just need to set it up and add the extension for youtube and Netflix. There are plenty of how to on youtube. I would set it up inside your house first. Then move it to your truck.
    Sleeper16plat likes this.
  21. Apr 17, 2022 at 8:58 PM
    #81
    TxLock21
    Great, thanks!
    Also, do you know if I will I need a parking brake bypass to watch screen mirroring while driving?
  22. Apr 18, 2022 at 4:22 AM
    #82
    BrandonL812
    Brandon
    connect the green brake wire to ground. That will bypass and let you access menu and watch while in motion.
  23. Apr 18, 2022 at 4:15 PM
    #83
    dkrou
    dkrou New Member
    dan
    2019 tundra
    I'm waiting on the Kenwood cable....I have a hot spot for my blackvue dash cam through T mobile I am hoping i can connect to. Does it matter whether car play is wired or wireless to get this to work??
  24. Apr 19, 2022 at 4:29 AM
    #84
    BrandonL812
    Brandon
    You cannot use Carplay and HDMI at the same time. It is either one or the other. If you are using wireless carplay. You must disconnect from it in order for hdmi to work.
  25. Apr 19, 2022 at 8:17 AM
    #85
    WV_Warrior
    WV_Warrior New Member
    Cody
    West Virginia
    2011 Silver Platinum CrewMax
    It’s wireless carplay, right? Any issues with connectivity?
  26. Apr 19, 2022 at 9:39 AM
    #86
    OGDark Knight
    OGDark Knight New Member
    Jeff
    2019 Platinum, 14 4Runner Trail, 95 Land Cruiser 80
    Trans cooler. Pioneer 8600. TRD Pro suspension.
    Zero issues with connection with iPhone 11 pro
  27. Apr 19, 2022 at 1:20 PM
    #87
    BrandonL812
    Brandon
    Same here with wireless carplay no issue. Iphone 12 max.
  28. Apr 25, 2022 at 7:57 PM
    #88
    TxLock21
    Did you use the wireless screen mirroring? I can’t get the wireless screen mirroring to work on mine. I have an iPhone 12.
  29. Apr 26, 2022 at 2:38 AM
    #89
    Degausser
    Kevin
    GA
    2024 LR SR5
    Yes, wireless. From what I was told when I bought the unit, the wireless mirroring is only available with newer androids. I have whatever the newest Samsung Galaxy is.
    TxLock21[QUOTED] likes this.
  30. Apr 28, 2022 at 8:40 PM
    #90
    TxLock21
    So I bought the Apple hdmi to lightning adapter and the hdmi cable you recommended. Is there supposed to be a hmdi port that I’m supposed to plug this into? Or do I need a hdmi-to-USB adapter that I need to get to connect the hdmi to the USB port in the dash?
