Anyone using a higher viscosity oil in their Tundra?
Discussion in '3rd Gen Tundras (2022+)' started by LionsFan20, Mar 6, 2025.
  1. May 7, 2025 at 9:54 PM
    #121
    Retroboy1989
    Northern Utah
    2012 SR5 TRD OR (prev) 2025 SR5 TRD Rally (now)
    I appreciated it.
    Pine_Cone67[QUOTED] likes this.
  2. May 8, 2025 at 10:26 AM
    #122
    WestTexasCruisin21
    WestTexasCruisin21 New Member
    Andrew
    2021 Nightshade Limited 4X2 Crewmax
    I'm gonna swap mine over to 5W-30 and then I'm gonna change the oil fill cap to a 5W-30 so it will be the correct oil technically, cuz that's what the fill cap says. Lol
  3. May 8, 2025 at 10:47 AM
    #123
    carbinefreak
    carbinefreak New Member
    I've been running Kirkland 5w-30 for the last 30k with 5k changes. On sale it's $3/qt and well reviewed on BITOG. The Mobile 1 5w-30 sheared down to 0w-20 after 5k FYI.
    JH8473 likes this.
  4. May 8, 2025 at 3:05 PM
    #124
    Tom976
    Tom976 New Member
    Tom
    Just imagine what 0w20 becomes after 5k miles. Even worse at 10k.
    kirkb and Raven67 like this.
  5. May 8, 2025 at 4:34 PM
    #125
    Retroboy1989
    Northern Utah
    -5w10. It flows backwards in cold temps.
    Yes, I know there are multiple fallacies in that joke.
    Oil is not thinner at cooler temps.
  6. May 8, 2025 at 4:37 PM
    #126
    Retroboy1989
    Northern Utah
    Strong argument for running 5w30.
  7. May 8, 2025 at 4:45 PM
    #127
    carbinefreak
    Yah if I knew what I do now when I bought I would have run 5w-30 from the 500 mile mark.
    Retroboy1989[QUOTED] and Raven67 like this.
  8. May 9, 2025 at 6:35 AM
    #128
    Tom976
    Tom976 New Member
    Tom
    First oil change in the Tundra surprised me. Really looked like water when I pulled that drain plug.
    That was after 500 miles no less. Keep that in for the first 10k? No thanks Toyota
  9. May 9, 2025 at 2:22 PM
    #129
    Breathing Borla
    AZ
    just my .02, but I think the 0w20 is fine but no longer that 5K intervals.
    thats what Im doing anyways.
    Rcflyersd and Pine_Cone67 like this.
  10. May 9, 2025 at 3:43 PM
    #130
    Tom976
    Tom976 New Member
    Tom
    Better question becomes.... does the 0w20 really save on gas vs. 5w30 ?????????????????
  11. May 9, 2025 at 3:57 PM
    #131
    raylo
    raylo not so new member
    Frederick, MD
    DashCam, amp/sub, rear seat del, cat shield, AMP power boards
    I doubt anything significant. I got 21.5 on my last road trip segment, 170 miles, freeway and primary highways. This fill was 5 qts 5w-30 and 2.7 qts 0w-30. Now maybe if I did the same exact trip with the 0w-20 it would get a tenth or 2 better... but, of course, there really is no way to duplicate any given trip, traffic and weather conditions.
    Tom976[QUOTED] likes this.
  12. May 9, 2025 at 4:23 PM
    #132
    Retroboy1989
    Northern Utah
    Immaterial for us. Material for Toyota under the CAFE act.
  13. May 9, 2025 at 6:53 PM
    #133
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler, FRAC, RCI Skid
    5w-30 just feels right.
  14. May 24, 2025 at 10:54 AM
    #134
    Pine_Cone67
    Pine_Cone67 New Member
    2024 Tundra Limited
    Suryu and Tunrod like this.
  15. May 24, 2025 at 11:04 AM
    #135
    Bulldog6
    Bulldog6 New Member
    ‘25 Lunar Limited
    BlackNBlu and Daedalus like this.
  16. Jul 2, 2025 at 12:53 PM
    #136
    Raven67
    Raven67 It wasn't me.
    Kentucky
    24 Limited, 21 Redeye
    Anyone who is running 5w-30, did you notice any difference in the way the engine runs? I'm especially concerned about VVT operation. From what I'm reading doing some research on this, it seems you could lose a little power not just due to thicker oil, but from VVT'S not operating as designed due to different oil pressure.
  17. Jul 2, 2025 at 2:05 PM
    #137
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    But mexico...
    sudobash and Raven67 like this.
  18. Jul 2, 2025 at 3:00 PM
    #138
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    Has anyone actually been denied of a Toyota warranty claim because you couldn't prove oil changes?
  19. Jul 2, 2025 at 3:02 PM
    #139
    bailey bulldog
    bailey bulldog New Member
    I ran 5w-30 for about 2500. I really didn't notice any difference, and my last oil change was free from the dealer so I'm back to 0w-20. I watched oil pressure and all, didn't seem to make much of a difference on the dummy oil gauge.
    JH8473 and Raven67[QUOTED] like this.
  20. Jul 2, 2025 at 3:45 PM
    #140
    2wheelsforfun
    2wheelsforfun New Member
    Foothills AB Canada
    Being that 5W30 is spec'd for the Tundra in other countries, then there is no way that running it will hurt the motor in any way. Neither is there any proof that running 0W20 will hurt your motor in any way either. Now if they start recommending 0W8, that may be another discussion.
    0W8 Motor Oil - Genuine Toyota Motor Oil
    Raven67 likes this.
  21. Jul 2, 2025 at 5:24 PM
    #141
    Raven67
    Kentucky
    I wasn't concerned with hurting it, just wondering how it may affect VVT'S. Friend of mine uses 5w30 & said he notices more pressure (on gauge) when hot & he mentioned it seems maybe possible that its slightly lower on power. Hence the VVT question.
    bailey bulldog likes this.
  22. Jul 4, 2025 at 8:45 PM
    #142
    Raven67
    Kentucky
    Ok, I did a test myself. Changed oil & ran some 5w30. First off, very noticeable higher oil pressure on gauge all the time, even hot, thats the first thing. Second, I lost almost 2mpg. Not kidding, which is probably partially caused by the third item I'm guessing, but I do think it messes with the VVT. Power seemed slightly down, but it also developed a slight hesitation. My truck has never had the hesitation that others speak of.
    After 500 miles, I switched back to 0w20, & right off the mileage came back up, hesitation was gone, & it seemed peppier. Just my observation.
    Now why different viscosity can be used in other countries is unknown, but from my unscientific test, it made a difference & the only improvement I saw was in oil pressure. FYI.
  23. Jul 9, 2025 at 3:22 AM
    #143
    JH8473
    JH8473 New Member
    2025 Tundra SR5
    None
    I drove from kentucky to Georgia. 20.5 MPG.
    I run supertech 5w 30.
    On the way back with 500 pounds in the bed. MPG was 19.7.
    Raven67 and sudobash like this.
  24. Jul 9, 2025 at 3:24 AM
    #144
    JH8473
    JH8473 New Member
    2025 Tundra SR5
    None
    LOL , I call BS
    VCheng and sudobash like this.
  25. Jul 9, 2025 at 4:40 AM
    #145
    Raven67
    Kentucky
    Ok, I'm just reporting what I found, like it or not. You are more than welcome to try it out yourself. I was just sharing my results..
  26. Jul 22, 2025 at 12:13 PM
    #146
    panthermike
    panthermike New Member
    My experience so far with 5w30 has been good. Truck runs the same, pressure gauge is same as well. Recent road trip that included 6000ft elevation gain on the 1st half and moving a couch for a buddy while there yielded 21mpg. My commute to work mpg has been consistent as well.
