Anyone used tunes to change shift points?
Discussion in 'Performance and Tuning' started by tnine, Apr 12, 2021.
  1. Apr 12, 2021 at 1:50 PM
    tnine
    tnine [OP] New Member
    Todd
    2016 TRD Off Road
    ADS External Reservoir Shocks Deaver Leaf Springs 35" Tires C4 Fabrication Bumper Warn Winch Baja design LP9
    Hey all,
    I have a 2016 with a 3" lift and 295/70/R18 tires. I find that I'm driving around in Tow/Haul mode all the time in order to stop the transmission from shifting up prematurely. While this workaround is adequate, I'd prefer to be able to change my default shift points to be a bit higher, as well as then increase the tow/haul mode shift points. Has anyone had any success modifying this via some tuning? Happy to take it to a shop, but I'd like to do a bit of homework first to see if the changes would actually be useful.
    Thanks!
    Todd
  2. Apr 12, 2021 at 4:41 PM
    SLA10
    SLA10 New Member
    2019 Tundra TRD Pro
    Don't have to have a tune done, up here everyone runs hikeit, plugs into your accelerater, modifies your shift points, similar to peddle commander.
  3. Apr 12, 2021 at 4:45 PM
    RobertD
    Robert
    DFW, Texas
    First I'm hearing of HIKEit, I also just learned about iDrive. Where is "up here"? Just curious where this is being used.
  4. Apr 12, 2021 at 4:47 PM
    SLA10
    SLA10 New Member
    2019 Tundra TRD Pro
    Washington, PNW Tundras, I don't have it but practically everyone else does, lol
    RobertD likes this.
  5. Apr 12, 2021 at 4:50 PM
    RobertD
    Robert
    DFW, Texas
    Thanks! Definitely something I'm interested in (any of the throttle response adjusters). Haven't heard many complaints from folks who get them. They all essentially say it wakes the Tundra up.
    Sorry for thread jack OP but maybe these might be what you are looking for?
  6. Apr 12, 2021 at 4:54 PM
    MTRock
    MTRock 1889
    Montana
    2024 Tacoma TRD Off Road
    I had the same problem with 34/12.5R17
    https://www.tundras.com/threads/breaking-down-the-d-a-p-the-what-and-the-why.17031/
  7. Apr 12, 2021 at 4:54 PM
    SLA10
    SLA10 New Member
    2019 Tundra TRD Pro
    For further regional data, lol Dap tunes are popular here.
    RobertD[QUOTED] likes this.
  8. Apr 12, 2021 at 4:56 PM
    TTund16
    TTund16 New Member
    Can the car re-learn by resetting the ECU (removing power?) and then driving more aggressively? I remember reading something about this.
    How does it compare to other methods?
  9. Apr 12, 2021 at 5:13 PM
    SLA10
    SLA10 New Member
    2019 Tundra TRD Pro
    You can try if the vehicle has been really babied by a different driver, but wouldn't expect factory shifts to be altered too much. But doesn't cost anything try, lol
    TTund16[QUOTED] likes this.
  10. Apr 13, 2021 at 8:59 AM
    tnine
    Todd
    2016 TRD Off Road
    I've had both the ECU and the CCM flashed by the dealership after my tire size changes. It does improve my shift points for a month or so. I find with my driving of city most of the week, then into the mountains on the weekends, it ultimately "learns" granny driving and doesn't really give me a long-term solution.
  11. Apr 13, 2021 at 9:16 AM
    SLA10
    SLA10 New Member
    2019 Tundra TRD Pro
    You might want to look at the hikeit then, it simply plugs into your throttle and has a controller with multiple modes, it runs about $200, unless you can catch a sale.
  12. Apr 13, 2021 at 9:24 AM
    tnine
    Todd
    2016 TRD Off Road
    Wouldn't the Hikeit just change the throttle response curve? I.E. it just simulates you smashing the gas pedal since it's intercepting the drive by wire signal in the pedal. I had the pedal commander and sent it back. I found it didn't really modify my shift points properly and caused the ride to be really jerky since it simulates pressing the gas pedal harder.
  13. Apr 13, 2021 at 1:03 PM
    SLA10
    SLA10 New Member
    2019 Tundra TRD Pro
    Essentially that's all they do remap throttle response and remove any lag, I don't actually use them, just every one I know that does insist the trucks shift better. If you weren't satisfied with pc, then I doubt any other would change that for you.
  14. Apr 13, 2021 at 10:15 PM
    TTund16
    TTund16 New Member
    Drive a Tacoma before getting in your Tundra. Problem solved :D
    HulkSmurf14 and tnine[OP] like this.
  15. May 11, 2021 at 11:13 PM
    dirtydeeds
    Keith
    USA
    more than I can list here
    Give Keith Carty of Dirty Deeds Industries a call at 760-877-4234. He is the master of Tundras and can answer any questions you have. Phone calls are really the best way to get ahold of Keith.
  16. May 12, 2021 at 3:03 AM
    CMB
    CMB New Member
    Cecil County MD.
    2010 Tundra DC 4X4 SR5
    Not nearly enough room here!
    The last time I had shifting issues was back in 2010. When I took the time and made the effort to learn about my Tundra's Sequential Shifter, those times ended forever.:thumbsup:
