Anyone use Shell Rotella oil?
Discussion in 'General Tundra Discussion' started by db52282, Nov 1, 2019.
  1. Nov 1, 2019 at 2:21 PM
    db52282
    db52282 [OP] New Member
    David
    Georgia
    2017 Silver Tundra Limited
    Is anyone using this oil in their Tundra? If so, how do you feel it compares to Mobil 1?
    I have used Shell Rotella in my diesel's for years. Just wondering if this is any good for a gas engine.
  2. Nov 1, 2019 at 3:54 PM
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    Perfectly fine and probably comparable to other brand name synthetics like M1
    For all I know it could just be rebranded Pennzoil Ultimate
  3. Nov 1, 2019 at 4:04 PM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    I’m more curious what makes it different for hauling and towing compared to any other full synthetic
    RitcheyRch likes this.
  4. Nov 1, 2019 at 4:10 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    $4.00 a jug more.
  5. Nov 1, 2019 at 4:18 PM
    db52282
    David
    Georgia
    Rotella Gas is $21.58 at Walmart (where I live) and Mobil 1 Ext. Perf. is $28.68.
    Both are 5 gallon jugs in 0W20.
    BTBAKER and Badger Co-Op like this.
  6. Nov 1, 2019 at 4:29 PM
    P-Factor
    P-Factor New Member
    Uhmmm.. 5 gallons and not quarts? Great deal!
    lakenorcan likes this.
  7. Nov 1, 2019 at 4:41 PM
    MOTORHEAD
    MOTORHEAD New Member
    DAVID
    LOS ANGELES CA
    2002 Toyota Tundra SR5 V-8 4.7L WHITE
    RCD 6" SUSPENSION LIFT,ICON EXTENDED FRONT COILOVERS,3" BODY LIFT,CAMBURG UPPER CONTROL ARMS.REAR DISK BRAKE CONVERSION,BIG BRAKE FRONT CONVERSION, AND MANY MORE
    All the major oil brands are good these days. I read all kinds of arguments/comments about certain oil brands about why this on is better than that one. Unless you are scientist, Kemists or work in an oil lab that analysts this stuff, you will never know the differnece.
  8. Nov 1, 2019 at 4:44 PM
    db52282
    David
    Georgia
    Ha Ha!! Good catch ... Thanks!! :rofl:
    Meant Quarts....
    YardBird and P-Factor[QUOTED] like this.
  9. Nov 1, 2019 at 4:47 PM
    MOTORHEAD
    DAVID
    LOS ANGELES CA
    I am not in the oil business and don’t claim to know everything about oil, but all the major brands are reputable and been around a long time
  10. Nov 1, 2019 at 5:10 PM
    ninjajay
    Spoolston, TX
    Formulated to be more resistant to breaking down under heavy engine loads, but every major brand does this in one way or another
    Jaypown[QUOTED] likes this.
  11. Nov 1, 2019 at 5:14 PM
    Professional Hand Model
    Hand Protectors
    Synthetic Oil is a confusing topic as the definition is very broad.
    In this case, any Dexos label on the bottle usually indictate high PAO (slippery waxes).
    High PAO (Dexos) in older engines (that never ran syn) will usually make them seep out of their OEM gaskets due to the molecular structure (perfectly aligned).
    Other synthetics (non PAO) with seal/gasket ‘conditioners’ work better in older engines.
    focal likes this.
  12. Nov 1, 2019 at 5:41 PM
    db52282
    David
    Georgia
    Just found this if anyone is interested...
    Purchase qualifying Shell ROTELLA® Gas Truck Full Synthetic motor oil and save up to $10 per 5-quarts after mail-in rebate.
    Offer ends on 12/31/19. Valid at participating retailers only.
    blizz86, Mountun Goat and Black Wolf like this.
  13. Nov 1, 2019 at 6:24 PM
    Bravohook
    Bravohook New Member
    Addame
    NY
    2007 RCSB
    Cool Things
    I use this oil in my commuter car. Its a 2016 Focus with a 1.0 ecoboost engine. It has a variable pressure oil pump so it is very finicky on the oil, this stuff is awesome. With the small turbo using Mobil 1 i would burn 1/2 a quart every 5000 miles. With this stuff I do not burn any off and I'm still averaging 41 to 42 MPG's. It definitely "feels" thicker then Mobil 1
    db52282[OP] likes this.
  14. Nov 1, 2019 at 6:29 PM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Shell owns and makes pennzoil so you are fully correct haha.
  15. Nov 1, 2019 at 7:40 PM
    Mr Badwrench
    Mr Badwrench New Member
    Anything with an API stamp is good oil, even Supertech. Oil is oil.
  16. Nov 1, 2019 at 7:52 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    I ran shell retella diesel oil in my 6.0l gas Chevy truck for 4 years because it was a consumable at the job at had. Never had any issue and it was 0-40. Like @Mr Badwrench says oil is oil.
  17. Nov 21, 2019 at 5:45 AM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    I've been using it for the last 2 OCI. $21.xx for 5 qt jug - $6.50 store rebate - $10.00 Shell rebate. Comes out to be $1 and change per qt after local taxes. Grabbed some more from the store for 3 more oil changes.
    Haven't notice any adverse effects. Change it out every 5-6k. Truck keeps chugging along. I'm happy.
    Badger Co-Op and db52282[OP] like this.
  18. Nov 21, 2019 at 8:32 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    I agree because a retired GM engine designer told me the same. He used Supertech in his vehicles. I can't bring myself to do it. :(
    Anyone notice anything unusual about the API stamp on new oil labels?...Appears to no longer have the service rating code. Interesting. I wonder if it's because the applicable service ratings are changing faster than the shelf stock, and knowledgeable buyers won't buy the older stuff?
  19. Nov 21, 2019 at 9:00 AM
    Dabutcher
    Dabutcher New Member
    D
    Twin Cities
    2008 Nautical Blue Tundra SR5 CM 4x4 Beauty
    Toytec Boss coilover, Ray10’s ,Ridge Grapplers,Bilstein 5100,BAM 8”,TRD sway,
    I just bought two 5 w 40, 2.5 gallon jugs of Full Synthetic Rotella for $94.00 including shipping from Tractor Supply. There is a rebate from Shell for $17.50 per jug til the end of the year. Limit two rebates per household. So my price should be $59.00 after I get rebate back. Plan on using it in my 2012 Goldwing. Peace. DD6CEB779-B66F-4B5C-8467-E2653AB640B9.jpg
  20. Nov 21, 2019 at 9:07 AM
    blizz86
    blizz86 New Member
    Amazon also was selling this. $22 per 5 quarts with $10 rebates. Max per household was 4 so I got 4
  21. Nov 21, 2019 at 10:20 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Rebate is still active. I bought 4, thats a great deal!
  22. Nov 21, 2019 at 11:03 AM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    Check your local autozone too guys. If you frequent Bobistheoilguy, Rotella Gas Truck is supposedly on clearance. It's a slow seller. Some are reporting $10/jug. Rebate still works. So basically free oil.
  23. Nov 21, 2019 at 3:06 PM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    Our race team used to use Rotella in our race bikes; R1, CBR600RR, ZX1KRR, SV650, CBR1KRR, R6, 1098, 888. No problems at all!
    Badger Co-Op and astro-jason like this.
  24. Nov 21, 2019 at 5:24 PM
    Jeffro22
    Jeffro22 New Member
    2013 platinum crewmax 4x4
    Just saw that. Picked up 3 jugs. Sill give it a try.
  25. Nov 22, 2019 at 2:55 PM
    Jeffro22
    Jeffro22 New Member
    Check out auto zone!
    they have on clearance for $10 /5 qts
    basically free after rebate
  26. Nov 22, 2019 at 3:10 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    No wonder the guy at Autozone today was buying all of it.
    Zebruaj likes this.
  27. Nov 22, 2019 at 3:24 PM
    Jeffro22
    Jeffro22 New Member
    I bought a bunch too. Hard to pas up that deal
    Zebruaj likes this.
  28. Nov 23, 2019 at 7:39 AM
    Scuba
    Scuba Sober member
    Austin, Tx.
    Yeah I went to another Autozone this morning and found the 1QT jugs on sale for $2. I bought 9qts 0-20 for $18 and will get a $10 rebate. I would have bought 10qts but it’s all they had left. Can’t really beat that. I may switch the Tundra to this stuff. I did some reading last night and this stuff sounds really great for our trucks. Hard to change old ways though. I’ve been using M1 full synthetic for the last 10 years in my Tacoma and it still runs like a top.
    Zebruaj likes this.
  29. Nov 23, 2019 at 9:10 AM
    Theyfzman
    Theyfzman New Member
    Pa
    08 TRD
    I run rotella full syn. In everything I own even my race quad and never had an internal oil related issue
    Good stuff
    astro-jason likes this.
  30. Nov 23, 2019 at 9:54 AM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    I just grabbed 13 single qts and 4 jugs. Gonna have to use another family members address to complete the rebate but free oil after it comes back. Got enough to service the vehicles for the next yearish.
    Even at $2/qt clearance its a great price.
    Badger Co-Op likes this.
