Anyone running the Ready Lift kit?
Discussion in 'Suspension' started by Dlg_69, May 5, 2017.
  1. May 5, 2017 at 10:43 AM
    Dlg_69
    Dlg_69 [OP] New Member
    Louis
    Orange County, CA
    2017 Super White TRD Pro
  2. May 5, 2017 at 10:57 AM
    Check out www.toytec.com (boss kit) stay away from spacer lift i have a rough country 6" kit ride sucks feel every bump not good for mild to hard core off-roading IMO others here will chime in n assist you
    T-Rex266 and Law323 like this.
  3. May 5, 2017 at 11:07 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    No......just....no.....
    Opt for suspension ride like @aramirez73 said. Toytec's shocks are valved just for toyotas.
    T-Rex266 likes this.
  4. May 5, 2017 at 11:22 AM
    az1441
    az1441 6-0 G7s on the road
    Steeler Country
    2017 Toyota Tundra TRD Pro cement
    4" Readylift 35" Toyo M/T 20x9 0 BMF BATL Retrofit w RGB LED Halos and Strips
    I run this and I have had no issues. I recommend it if you want to retain those components.
  5. May 5, 2017 at 11:22 AM
    ktharbour6
    ktharbour6 New Member
    2016 Toyota Tundra TRD Pro MGM
    He is asking about the ready lift kit for the TRD Pro.
    2016 Toyota Tundra TRD Pro CM MGM
    IG: @kt_harb.protundra
  6. May 5, 2017 at 11:24 AM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    A friend has the same kind of lift on his 15 Tundra with 35's. It rides fine on the pavement and gravel. He doesn't like to take his truck off road and through brush, so its mainly for looks and clearance with out actual performance. I called him the other day to try to pull me out of a situation, slow driving through the rutted clay road was fine.
    GNTundra likes this.
  7. May 5, 2017 at 11:33 AM
    Oper8r
    Oper8r New Member
    Stuttgart
    Sold my 2016 TRD PRO - Currently in BMW 535d Wagon
    Looks like they have a 2-4-6 inch kits. It says it retains all your TRD PRO parts, just adds height. They even mention the 2 inches PRO models get out of the factory so 2=4, 4=6, 6=8.
  8. May 5, 2017 at 11:36 AM
    I've read quite a few complaints on that kit. Look into the BOSS or Radflo kit
    Dlg_69[OP] and Law323 like this.
  9. May 5, 2017 at 11:50 AM
    az1441
    Steeler Country
    links to what you "read"
    I run it and have zero issues.
  10. May 5, 2017 at 11:56 AM
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    I've been considering the BOSS kit as well. But after talking to some people, even Toytec themselves, they said the TU3 spacer kit would be just fine for me. I dont intend to do any off-roading of any kind. $300 vs $1800. Maybe later I'll upgrade.
  11. May 5, 2017 at 12:00 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    an in coil spacer is better than all height additions on top of the strut.
  12. May 5, 2017 at 12:31 PM
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    Add to the top like so, huh?
  13. May 5, 2017 at 12:33 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    hmm thought it was half in coil and half on top.
  14. May 5, 2017 at 12:46 PM
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    I looked up that kit, and I think it's just a spacer that goes in on top and bolts in. I'm sure the ready lift is the same way?
  15. May 5, 2017 at 12:47 PM
    Google searches and on FB ..one of the many Tundra groups. Feel free to check around :)
    Dlg_69[OP] likes this.
  16. May 5, 2017 at 1:20 PM
    az1441
    Steeler Country
    OP shoot me a PM if you get a chance.. done on this sandcastle thread
  17. May 5, 2017 at 1:24 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Most spacer lifts are the same way. I could've sworn toytec's was half in half top......
    Oh well.
  18. May 5, 2017 at 2:35 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Law323[QUOTED] and T-Rex266 like this.
  19. May 5, 2017 at 2:40 PM
    csuviper
    Broomfield, CO
    Here is the most recent top mounted spacer on stock shocks failure that i have seen. These are the TRD shock version for the Tundra like what i had stock on my Rock Warrior.
    18198151_10209179812554190_289466874_n.jpg 18253832_10209179908276583_431019516_n.jpg 18236677_10209179826314534_1065597086_o.jpg 18235839_10209179812394186_2032472076_o.jpg18236346_10209179931917174_1115038099_o.jpg
    Dlg_69[OP], Jsena and Law323 like this.
  20. May 5, 2017 at 2:44 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    That's what I thought.
    I knew readylift had all on top spacers but @TTU19 had me thinking toytec was the same way :confused::confused::confused: LOL
  21. May 5, 2017 at 2:47 PM
    csuviper
    Broomfield, CO
  22. May 5, 2017 at 2:48 PM
    az1441
    Steeler Country
    Wonder if OP will chime in and state that he wants 6" of lift while retaining the stock TRD pro suspension
    He did link the 4" readylift and state he wants to keep the 2" Pro stock
    4+2=6
  23. May 5, 2017 at 2:49 PM
    csuviper
    Broomfield, CO
    Owww yea dont stack lifts............
  24. May 5, 2017 at 2:51 PM
    csuviper
    Broomfield, CO
    Oh wait yea pro shock is built with a 2" lift currently. If you get the 4" lift kit and add on the top spacer then you will have a 6" lift on a 4" drop bracket. Might not be the best option. Would need to go with either a smaller top spacer or jump up to a 6" drop bracket lift with the 4" size top spacer.
    az1441 likes this.
  25. May 5, 2017 at 2:52 PM
    az1441
    Steeler Country
    my point the entire time viper
    I totally get mine isnt the best - but I went with it because I wanted 6" and to keep the pro shocks and components....
    so um yeah
    exhale
    Law323 likes this.
  26. May 5, 2017 at 2:54 PM
    louscrw
    louscrw all jacked up on Mt. Dew
    Lou
    Warner Robins, Ga
    2023 F150 Raptor
    I'd be curious what the "fail" rate is a spacer lifts. Sure, we've all seen pics like Brian posted above (and I've seen those very pics posted several times on different forums when people ask about spacer lifts), but how many people have zero issues compared to the ones that had problems.
    I ran a spacer lift on my GMC for 9yrs w/ zero issues. Of course, my trucks are pavement queens, so I know that reduces the chances of failure.
    So, to the OP, I personally don't think spacer lifts are 100% horrible depending on your intended use.
    Jsena, Law323 and az1441 like this.
  27. May 5, 2017 at 3:25 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
  28. May 5, 2017 at 3:29 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Yeah I had spacers before my BOSS coilovers. They were fine until I moved to a city with horrible road conditions and could feel every single bump up to my teeth, plus my trailblazing to my hunting camp didn't help the longevity. It was time for me to get new shocks and opted for coilovers due to my situation and time on the trails. Served me well to do that
  29. May 5, 2017 at 5:16 PM
    Dlg_69
    Louis
    Orange County, CA
    Appreciate all the reponses to my question.
    The intended use for me is going to be light offroading and sand use in the desert. I dont want to change out any of the suspension to accomodate a taller lift. I am looking to go up a few more inches to accomodate larger tire, while being able to retain the stock ride feel.
    I have lifted wrangler unlimited as well and I was getting tired of all the bouncing around, so I opted for what I believe to be the best truck out there.
    Thanks again for your input
    Law323 likes this.
  30. May 5, 2017 at 5:57 PM
    Dlg_69
    Louis
    Orange County, CA
    Thanks for letting me know. I realized that I created my account before I actually purchased my truck. Updated now.
