Anyone Running E88?
Discussion in 'Performance and Tuning' started by Kevin, Jun 19, 2018.
  1. Jun 19, 2018 at 7:28 AM
    Kevin
    Kevin [OP] New Member
    I've got a 2011 Tundra with the flex fuel badge. I've always heard not to run E85, but now I see a lot of E88 gas out there. Can anyone tell me if this is OK to run in my truck? Thanks
  2. Jun 19, 2018 at 7:29 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Pure dino juice for me.
    NCinCO and UTTundra like this.
  3. Jun 19, 2018 at 7:40 AM
    greghoro
    greghoro New Member
    Greg
    2012 Sequoia Limited
    Won’t hurt your engine, if that’s what you are asking.
    Lower gas mileage, so shorter range. Decreased mileage may or may not be offset by lower price of the higher ethanol blends. Have not seen any real-time tests or calculations to see where break even point between mileage & price is. Plus, with the constant fluctuations in prices, would need a calculator or spreadsheet to figure it out each time.
    Constant use requires more frequent oil changes but check your owners manual for specifics for your year.
    Greg
    TXMiamiFan likes this.
  4. Jun 19, 2018 at 8:06 AM
    dirtydeeds
    Keith
    USA
    2003 and 2013 tundra
    more than I can list here
    I’m running e85 in my 03 Tundra. It works well and makes a lot more power.
  5. Jun 20, 2018 at 9:02 PM
    HecticEnergy
    HecticEnergy New Member
    TJ
    SE Texas
    2017 MGM Tundra SR5
    Winjet Rear brake lights, leather seats, BackFlip tonneau cover, Spyder headlights, Pro Grille, pop&lock
    I think I read it’s like 20-30% reduction in fuel economy... so if it’s >20-30% cheaper, it’s a better deal tank for tank... but then you calculate in the more frequent oil changes... and if there are any other trade offs...
    I’ll stick to costco’s top tier blend of mid grade for now :)
  6. Feb 18, 2019 at 2:43 PM
    irage
    irage New Member
    2011 Toyota Tundra Crew Cab
    Cold Air Intake, CB, Fender Flares
    I have the same badge and I ran the mid-grade for a while and didn't really notice anything other than a delay when stomping on it. Then I switched to NO Ethanol based full and I liked the power, but I still had the delay off the line. Switched to e85 gas and over the next few tanks I noticed the delay was gone. Performed a Gumout intake treatment and now she flies off the line. I do have to change the oil more often, but it's worth it when you want to get on it.
  7. Jun 29, 2019 at 12:45 PM
    MikeR118
    MikeR118 New Member
    2012 CM RW
    I know it's an old thread, but I was looking for anyone else running Sheetz brand e88. I use it in my FFV 12 CM. I also run it in my 18 3500 Chevy work van. I swear it runs better than standard 87 octane. I really have no hard evidence to prove it. I'm about to pull my 6k lb trailer through the mountains and I've got 46 gallons of 88 in the tank. I guess we will see!
  8. Jul 5, 2019 at 8:57 PM
    Yodder J
    Yodder J New Member
    Northwest Arkansas
    2011 Silver Tundra SR5 4WD DC
    DAP Tune, Truxedo ProX15 bed cover, WildPeak AT3s
    Does the check engine light go off sooner or do you just track your mileage? I ran E85 for 2 months straight just to seen how the truck ran and what kind of mileage I got.
