Anyone running an Anderson WDH?
Discussion in 'Towing & Hauling' started by IowaGuy, Dec 21, 2021.
  1. Dec 21, 2021 at 5:45 PM
    IowaGuy
    IowaGuy [OP] New Member
    Arizona by way of Iowa
    2019 SR5 upgrade MGM
    In Process
    I found a used Anderson WHD for sale locally for $250. It comes with all the parts and instructions plus and anti-rattle attachment. I have read some mixed reviews on these from they are the greatest WDH ever to don't bother. This hitch lists for $600 brand new and is rated for 14,000 lbs.
    Anyone running one of these, thoughts ?
  2. Dec 21, 2021 at 6:50 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    It's not directly related to your question but I thought when it came to WDHs you want the weight rating to be close to the weight of your trailer. Like if you have an 8000 lb trailer, you want the 8000 or 10,000 lb hitch, not the 14,000 lb hitch. However, I believe on certain hitches all you have to do is swap out the bars for lighter ones (not sure if that's the case on this hitch or not).
    Omohundro likes this.
  3. Dec 21, 2021 at 7:12 PM
    BuckWallace
    BuckWallace Ball don't lie.
    Oregon
    Sierra 3500 AT4 L8T
    I read similar reviews and was close to buying one of these when I was looking, but ended up going with something else. However, that seems like a pretty good deal and might be worth trying out. At the very least I bet you could get what you paid for it if you didn't like it and decided to sell.
  4. Dec 21, 2021 at 8:20 PM
    Windsor
    Windsor Why do I do this to myself?
    Homeless in Oregon
    2008 Tundra Crewmax 5.7L
    Some.
    I assume you are referring to the No Sway?
    I run one with my cargo conversion, and have a spare hardware set to put on my new car trailer when I get it. My folks have one for their Airstream.
    They work very well when set up properly. That is the problem that most people have, they don't set them up properly and end up with loose chains which give no weight distribution and no sway control.
    The customer service is awesome. Even if you buy used, they take care of you. If it is the old model with the chain flange that does not pivot, contact them to get it replaced. They will send you a new kit with the upgraded friction material and flange. Then you put the old one in the box and schedule UPS to come pick it up. All at no cost.
    I already had the 2 5/16" kit and purchased a 2" kit at a pawn shop dirt cheap because it had been there so long. Contacted Anderson about getting new friction cups and they said they would exchange the hitches at no charge.
  5. Dec 21, 2021 at 8:31 PM
    WBW
    WBW Resident lurker
    Bruce
    Surface of the Sun - AZ
    2015 CM Tundra SR5 2WD
    I run the Anderson WDH with my trailer. My tongue weight loaded is 920 lbs, total trailer weight 6,500 lbs. I worked with Tiger at Anderson Hitch. He's great!
    The latest version is awesome! No sway at all and I'm actually transferring weight forward on my truck.
    PM me if you need addional guidance. I'm happy to share my scale tickets and what I've learned.
    Dansly56, Jmad92 and Windsor like this.
  6. Dec 22, 2021 at 1:26 AM
    Jmad92
    Jmad92 New Member
    Justin
    2021 Platinum Windchill peal
    stock
    I might message you if that’s ok. I just ordered an Andersen WDH for the travel trailer we just bought. Did you feel it decreased any squat on the rear end?
  7. Dec 22, 2021 at 4:58 AM
    WBW
    WBW Resident lurker
    Bruce
    Oh yes! Take good measurements both sides, front and rear, unloaded and loaded without WDH providing lift. Now, the Anderson Hitch is limited in its ability to shift weight compared to the torsion bar types. If your travel trailer requires 1200 lb bars then the Anderson Hitch won't work as well. I'm successfully transferring enough Wright to the front and back to the trailer that my rear squat is only about 3/4 inch. The Anderson Hitch is pulling it up about 1 inch.
    Yeah. PM me. There's a lot of info involved.
    Jmad92 likes this.
  8. Dec 22, 2021 at 5:29 AM
    2mchfun
    Great design on these hitches. There are no bars to deal with. Definately buy it!
  9. Dec 22, 2021 at 5:56 AM
    Gould71
    Gould71 Member
    2017 Platinum Midnight Black
    TRD swaybar, TRD shift knob, FN FX Pro wheels, Toyo AT/IIIs, VLED interior and puddles
    I sold my Equal-i-zer wdh I’ve been using for 4 years and got the Andersen early this year. I tow a travel trailer that’s about 6500 lbs loaded and the hitch weight is around 800 lbs or so.
    The Andersen has been great for my needs.
    In my opinion the Equal-i-Zer, using torsion bars, is a bit better at distributing weight but had a lot of disadvantages. It’s way heavier than the Andersen and requires a good amount of grease to keep it quiet. (Nothing like coming into a campground late and having that thing creak and groan for all to hear, then getting greasy taking it off and putting it away)
    The Andersen is super quiet, requires no grease, does a better job at sway control, doesn’t bounce, and is very easy to set up. Andersen has some very informative vids on YouTube on the proper installation and adjustment. Get it right and it definitely keeps the squat where it should be.
  10. Dec 22, 2021 at 6:01 AM
    IowaGuy
    In Process
    Here are the pics in the add. My trailer is a 17 ft toy hauler that we use for a camper and no toys. It is probably 4000 lbs loaded with our gear. I probably don't NEED this hitch, but a little more stability and weight distribution would be nice for a piece of mind and handling.
    Windsor likes this.
  11. Dec 22, 2021 at 6:03 AM
    IowaGuy
    In Process
    I think you can also backup while using the Anderson and not have to disconnect it?
  12. Dec 22, 2021 at 6:15 AM
    WBW
    WBW Resident lurker
    Bruce
    The Anderson Hitch setup that you bought, based on the info your provided on your trailer, is absolutely perfect for your setup. Yes you can backup with the Anderson Hitch. Proper setup is the key but is easy to achieve and change on the fly.
    My trailer is tall and 18 ft. It is a huge sail with a side wind. I honestly get zero sway in side winds. No white knuckle driving for me!
  13. Dec 22, 2021 at 6:34 AM
    Gould71
    Gould71 Member
    That should be a good setup for your trailer. It looks like it’s one of the newer ones that has a collet to keep the friction material around the ball from backing out. It’s the black ring under ball in the pic. It was a problem with some of the earlier models. Andersen was very good with taking care of their customers with any problems.
    No issues whatsoever with backing up. I think you’ll be happy with the Andersen.
  14. Dec 22, 2021 at 6:35 AM
    IowaGuy
    In Process
    I haven't bought it yet but I think I am going to grab it up if it is still available.
  15. Dec 22, 2021 at 8:36 AM
    You could call Etrailer.com and ask if they ever heard of it. 800-940-8924
  16. Jan 8, 2022 at 12:59 PM
    shoe07
    shoe07 New Member
    Ohio
    2004 Tundra Double-cab SR5 Tow pkg
    I like mine, towed 10k + miles with it last year and about 13000 on it overall.
    IowaGuy[OP] likes this.
  17. Mar 1, 2022 at 8:09 AM
    dooododoo
    dooododoo New Member
    MGM '17 CM OR
    Fortin EVO-ONE Remote Start iBoard Running Boards (Black 5") LED interior lights Line-X Bed Plasti-Dip Emblems
    True, but not with this WDH. This is a completely different type of WDH, so you don't have to match your weight with the hitch's rating. The Andersen rating refers to the max it can support.
  18. Mar 25, 2022 at 9:07 PM
    Dansly56
    Dansly56 New Member
    daniel
    whats the part number of the one you have and how can if it’s the new model? I’m looking at a used one but not sure if it’s a old model.
  19. Mar 25, 2022 at 9:46 PM
    Windsor
    Homeless in Oregon
    Some.
    The newer models have the black cap ring on top to keep the cone from pushing out over time. The newest model has the welded ring (as in above picture) on the curved bottom plate. The model before the current has a hinge plate (hinges on the bottom pin), the model before that did not have the black cap ring and had a welded ring on a triangular bottom plate.
    You want the one of the models with the black cap ring. However, Anderson swapped mine out free of charge (shipping included) after I originally purchased the old model.
    The model numbers are based on ball size and drop length of the shank.
  20. Mar 25, 2022 at 9:51 PM
    Dansly56
    Dansly56 New Member
    daniel
    This is the one I’m looking at and it’s $200 used but wasn’t sure if it’s the newest one out. Is it?
  21. Mar 25, 2022 at 10:11 PM
    Windsor
    Homeless in Oregon
    Some.
    Yep, that is the latest version.
  22. Mar 25, 2022 at 11:17 PM
    Dansly56
    Dansly56 New Member
    daniel
    sweet
  23. Apr 3, 2022 at 2:07 PM
    Dansly56
    Dansly56 New Member
    daniel
    Why am I still sagging! What am I doing wrong? I have Timbrens, RAS, stock leaf springs, stock rear shocks, Anderson no sway hitch. I have 8 threads exposed
  24. Apr 3, 2022 at 2:29 PM
    Windsor
    Homeless in Oregon
    Some.
    Level the trailer, measure height of coupler with trailer level.
    Set ball height about an inch and a half higher than coupler.
    Connect coupler to ball, stop lowering tongue when it connects.
    Hand tighten nuts to get slack out of chain, then tighten nuts 4 additional turns.
    Brackets should have been installed following the above steps with 2 threads showing on the eye bolt when the brackets were pulled back to get the slack out of the chains.
  25. Apr 3, 2022 at 3:01 PM
    Dansly56
    Dansly56 New Member
    daniel
    Those directions weee followed to the T except I think I need to go up on the hitch ball
  26. Apr 3, 2022 at 4:04 PM
    shoe07
    shoe07 New Member
    Ohio
    The red bushing doesn’t look compressed so your not transferring much weight.
    Cut a link out. And try again.
    May need to remove two. If the bushing isn’t bulging you’re not transferring much weight
  27. Apr 3, 2022 at 6:55 PM
    shoe07
    shoe07 New Member
    Ohio
    I did not see your measurements, have you been to the scale? Maybe you have more tongue weight than you realize
  28. Apr 3, 2022 at 8:35 PM
    Dansly56
    Dansly56 New Member
    daniel
    so my front doesn’t move a millimeter unless I really crank it down to about eight threads showing versus six threads showing. The top measurements are not trailer loaded and the 2 bottom measurements are with the trailer loaded and Anderson hitch on with 6 threads showing.
  29. Apr 4, 2022 at 3:57 AM
    shoe07
    shoe07 New Member
    Ohio
    Take a link out and tighten back up.
  30. Apr 4, 2022 at 6:44 AM
    Dansly56
    Dansly56 New Member
    daniel
    Okay, let me try that. My trailer is 6400 dry and 820 of tongue weight not sure if I’m to heavy but I’m hearing a lot of people are in my range if not heavier and they’re not sagging. The disappointment is also my RAS allowing for sag like this. If it wasn’t for my Timbrens I would sag even more
