Anyone running a Softopper?
Discussion in 'Tonneau Covers, Caps and Shells' started by JackWagon, May 23, 2018.
  1. Apr 6, 2024 at 8:01 PM
    #391
    nfarrall
    nfarrall New Member
    Southeast PA
    2019 TRD Sport
    Top is tan
  2. Apr 10, 2024 at 6:39 AM
    #392
    PAlittlematty
    PAlittlematty New Member
    Central PA
    2021 CrewMax TRD OR
    I like the color combo. Tan top and bronze wheels looks good with the white
    nfarrall[QUOTED] likes this.
  3. May 2, 2024 at 9:17 AM
    #393
    PAlittlematty
    Central PA
    2021 CrewMax TRD OR
    Aluminum bar through the front window? I bought my top used and there was no bar included. Am I missing a part or is this post wrong?
  4. May 12, 2024 at 2:42 PM
    #394
    MTBTANDRA801
    MTBTANDRA801 New Member
    Ben
    2018 Limited DC
    King suspension, TRD Exhaust
    Ok gents, i got my soft topper installed, beat the shit out of it in Moab on the white rim trail, slept out of the back, everything was great
    HOWEVER, my OCD is not letting my be comfortable with the way the bed rails are sitting, they have a slight inward lean, i have tried adjusting them multiple times, and got them in a better place, redid the clamps and made sure the feet were as flush as possible against the bed… the pivot bracket is not quite flush. I also did loosened the clamps a bit that helped.
    My small adjustments helped and at the most rear bar bottom plastic brackets are now straight
    i have a slight gap between the clamps and bed rail on the inner edge, but if i bring the rails in anymore the bottom end near the tailgate/weather stripping is going to hang into my bed, which idk if that’s better than having an inward lean?? I also moved the back clamps a little closer to the tailgate and the seemed to help
    Any of you guys have similar issues when installing?? Is it possible to get 100% flat / flush with the bottom of the bed rail and the edges of the bed?
    I also see my utility rails stuck out just a bit and i think that also prevents from sitting true flush. For some reason the passenger side is giving me a little more issues than the drivers side.
    koditten and Pillslinger like this.
  5. May 12, 2024 at 3:25 PM
    #395
    Retroboy1989
    Northern Utah
    2012 SR5 TRD OR (prev) 2025 SR5 TRD Rally (now)
    That's about my experience. Mine both have a inward lean. It's annoying but doesn't affect function. I've removed and installed mine several times and it's always the same story.
  6. May 13, 2024 at 5:10 AM
    #396
    Pillslinger
    Pillslinger New Member
    Rollin
    SWMO
    2018 Cement TRD CrewMax
    Bed light kit Jerry can mount Badge overlays (removed 2021) Pin stripe / TRD decal / pillar vinyl removal Raised tailgate lettering Center console badge/tray/divider Interior/exterior LED upgrade VLED footwells TVD Vinyl TRD Offroad wheels Icon 17x8 rebound titanium Bubbas Garage grab handles WeatherTech floor mats (Eagle Klaw added) Rough country front shackles (removed 2021) DD SS3 yellow fogs MESO map light replacement Softopper MESO Chrome delete
    Same here. I don't have the utility tracks so I'm using the other style clamps. I've always attributed it to clamp design and physics. Mine too improves if I ease up on the clamps a bit, but too much and it starts to leak when I wash it. :notsure:
  7. May 13, 2024 at 5:27 AM
    #397
    koditten
    Kirk
    Midland of the Mitten
    Mine has that lean as well.
    It doesn't bother me.
    MTBTANDRA801 likes this.
  8. May 15, 2024 at 5:42 AM
    #398
    PAlittlematty
    Central PA
    2021 CrewMax TRD OR
    Has anyone tried to shim between the clamp pieces? Slip a washer in between them so it pushes the bottom tip of the top piece in which may push the actual clamp out and flatten the pressure?
  9. May 15, 2024 at 5:51 AM
    #399
    PAlittlematty
    Central PA
    2021 CrewMax TRD OR
    In this spot. Put a washer in there to see if it changes the position of the top piece of the clamp. It can’t push the bottom in any further. But would it push the top out?
  10. Jun 16, 2024 at 6:54 PM
    #400
    Pillslinger
    Rollin
    SWMO
    Safari style down by the creek. Nice day and a bit of mud on the tires. 20240616_130447.jpg
  11. Jun 16, 2024 at 7:08 PM
    #401
    koditten
    Kirk
    Awesome!
    I love mine(s)? I love my ST for my 08, I couldn't bear to be without one for my '21.
    Rolling "safari" is great during warm weather.
    Pillslinger[QUOTED] likes this.
  12. Aug 13, 2024 at 9:20 AM
    #402
    gregers05
    gregers05 New Member
    I am looking at getting a soft topper in the near future...has anybody seen a way to add an awning to one of these? Would it be best to add an awning mounted to the cab I guess and have it shifted back towards the topper?
    I want the versatility of the soft top, but want to be able to mount an awning and I am not seeing a good way to do that. I don't want to go the metal rack over the soft topper route either.
    koditten likes this.
  13. Sep 19, 2024 at 2:34 PM
    #403
    roxysdad
    roxysdad New Member
    Gold Country, CA
    2021 DC MGM 4x4 SR5
    I put one on my new to me ‘21 and love it. I had one on the Tacoma and it was super handy with my day to day travels and wanderings around Northern California and Nevada. This one is quite a bit larger, but functions just the same. Love the utilitarian look as well. I considered the Tan color, and sometimes wish I would have with the decreased heat in the bed, but in the end the black Softopper won the debate.
    JrJrOffroad, Pillslinger and koditten like this.
  14. Sep 19, 2024 at 2:37 PM
    #404
    koditten
    Kirk
    I lost the Tan vs Black debate to the wife.
    Black it is.
  15. Sep 20, 2024 at 7:07 AM
    #405
    gregers05
    I was about to pull the trigger on the softopper but ran across the Fas-Top. Ended up getting the Fas-Top Traveler that also converts back to a tonneu cover
    WFD473 likes this.
  16. Oct 9, 2024 at 8:05 AM
    #406
    Softopper
    Softopper New Member
    Hey Softopper peeps! Just a heads up, EVERYTHING on our website is 10% off until midnight tonight 10/09/24. This includes all accessories, racks, merch, replacement parts, and full tops.
    Head over and gear up at a discount while you can! https://softopper.com/
  17. Oct 15, 2024 at 10:47 AM
    #407
    WFD473
    WFD473 Long Live The V8
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    How do you like it? Thinking of ordering one at some point.
  18. Oct 17, 2024 at 8:15 AM
    #408
    Softopper
    Back again with another deal for you!
    From 10/15/24 to 10/28/24, score $50 off all Napier tents. Whether you’re gearing up for fall camping or just want to upgrade your setup, now’s the time!
    Don’t miss out—grab yours while the deal lasts! 1f449_f9cca57e4caf8bdccd1efd7f4193c3c6ea8caeca.pnghttps://softopper.com/camping-accessories/
  19. Oct 17, 2024 at 8:25 AM
    #409
    JrJrOffroad
    JrJrOffroad Somewhere in the west
    Anthony
    Monument, CO // Cave Creek, AZ
    Oooo didnt know there was this thread here.
    I have had three soft toppers with my most current being my tundra. As someone who has had a GFC, steel bed racks, fiberglass shells from ARE and LEER… the soft topper has always been my absolute favorite for sheer simplicity, ease of use and quality of product.
    Previous rigs for reference -
  20. Oct 17, 2024 at 8:28 AM
    #410
    Softopper
    Awesome to hear that your Softopper has been your go-to, especially with all the setups. If you ever need anything or just wanna chat more about your setup, hit us up! Appreciate you being part of the Softopper fam!
  21. Oct 17, 2024 at 4:05 PM
    #411
    WFD473
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    How did you like that Gladiator? Every time I see one, I get the itch. Please tell me it was a piece of crap lol.
    JrJrOffroad[QUOTED] likes this.
  22. Oct 17, 2024 at 4:17 PM
    #412
    JrJrOffroad
    Anthony
    It looked cool but that was about it. It’s awful at everything- Slow, long wheelbase, heavy, super low weight capacity, awful to tow with. I put 15k miles on it before I sold it and in that 15k miles I went through:
    • rear diff that grenaded itself on the freeway
    • bricked infotainment that required a full unit replacement
    • Driver Headlight DRL stopped working at 4k miles
    • Engine developed a ticking that sounded like it was badly broken
    • Issues with the aluminum steering box (to be fair they fixed this in recent model years by swapping to a steel one)
    it spent more time at the dealer than any vehicle I have owned. They fixed everything (except the engine tick) under warranty but I certainly wont buy another Jeep.
    lots of people like them and I know people who have zero issues with them so YRMV
    Dam she was pretty tho
    WFD473[QUOTED] likes this.
  23. Oct 17, 2024 at 5:03 PM
    #413
    WFD473
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    Just what I needed to hear! Thank you Sir and sorry about your experience with that thing. Now it makes sense why those things are sitting on dealer lots. And I get what you're saying with Jeeps being a crapshoot. I had a 93 Wrangler that was bulletproof and a 98 Grand Cherokee that was hot garbage.
  24. Oct 23, 2024 at 6:51 AM
    #414
    Jhon
    Jhon New Member
    On the Oregon Trail
    2021 SR5 TRD OR
    How much clearance is there between the bed rail system and the tubes for the Softopper frame? From pics here it's hard to tell. I have a panel currently hanging off my bed rail and am wondering if the tube frame will hit it?
  25. Nov 25, 2024 at 10:31 AM
    #415
    Softopper
    Just a heads up, we are running our BIGGEST sale ever right now! 11/25/24-12/02/24 you can get 15% off our entire site PLUS a free limited edition boot cover will the purchase of every full truck top.
    If you have been thinking about getting a Softopper or want to upgrade with some of our accessories, now is definitely the time!
    Shop Now: https://softopper.com/
    Let us know if you have any questions!
    *This offer does not include the Datin Metal Fab Canvas Cage Rack*
    WFD473 likes this.
  26. Nov 25, 2024 at 12:40 PM
    #416
    Xcumminsguy
    Xcumminsguy New Member
    NY
    2021 Tundra TRD Pro Crew Max
    Stock, with a few cosmetic mods.
    @Softopper I’m on the website now and have been considering a tan top for my truck. The cover automatically seems to be loaded, and available in gray only. Doesn’t seem to be an option to change cover color to tan. Is a tan cover available? Thanks.
  27. Nov 25, 2024 at 12:59 PM
    #417
    Softopper
    Great question! For this promotion, the free boot cover that is included is a limited edition grey cover. Our standard cover is black. Unfortunately, we do not offer the boot cover in tan at this time.
  28. Nov 25, 2024 at 1:07 PM
    #418
    Xcumminsguy
    NY
    Ok thanks.
  29. Dec 6, 2024 at 6:47 PM
    #419
    Scortow
    Scortow New Member
    Kyle
    2021 Tundra SR5 TSS CrewMax, Calvary Blue
    @Softopper I have a softopper from my 2021 Tundra SR5 Crewmax 5.5 ft bed. I recently upgraded to a 2025 Tundra Limited Crewmax 5.5 bed. Can I make my old softopper work on the new truck? Is there anyway to modify it to fit?
  30. Dec 17, 2024 at 12:25 PM
    #420
    Softopper
    With the body style change for the new Tundra's we did have to make a whole new Softopper model for them to ensure the best fit. The dimensions of the bed changed slightly. You can definitely try your old Softopper on the new truck to see if you are okay with it. However, we do recommend getting the new Softopper model to ensure the best fit and function.
