Anyone running 285/75r18 on stock Trd Pro Tundras
Discussion in 'Wheels & Tires' started by Jp-ProMamba, Jun 14, 2020.
  1. Jun 14, 2020 at 7:30 AM
    Jp-ProMamba
    Jp-ProMamba [OP] New Member
    Jp
    2020 Toyota Tundra Trd Pro
    Been contemplating on a set of 295/70r18 or 285/75r18 on my new Trd Pro Tundra but don’t know if they will have any running issues...I don’t want to modify the truck besides removing the front mud flaps. Any help will be greatly appreciated.
    jewsNbrews likes this.
  2. Jun 14, 2020 at 8:46 AM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Same boat. Some say they have done 285/75/18 but when asked what they did to fit they don't respond. I've seen hit and miss on the 295/70/18 as well. Some need just a mud flap removed others need to trim/manipulate wheel well liner some. I know there has been a lot of folks running 285/70/18 with no issues. They are running nitto ridge grapplers or bfg km3 it seems.
    Y0TA PR0, BTBAKER and BillsTundraBob like this.
  3. Jun 14, 2020 at 2:31 PM
    Jp-ProMamba
    Jp
    Seems like the Nitto Ridge Grappler is the way to go
  4. Jun 16, 2020 at 1:04 PM
    Dc2015
    Dc2015 New Member
    Danny
    2020 limited
    Bump....
    Anyone have an answer to this??
    :broccoli:
  5. Jun 23, 2020 at 7:27 PM
    wiretwister
    wiretwister Sorta new guy
    NJ
    '22 SR5 CM
    I will be ordering 285 75 18 (most likely Toyo at3) very soon. As far as fitment goes, the consensus seems to be that on stock wheels (18x8", 60et) the only rubbing will be on mud flaps and possibly fender liner in front, which can be corrected with some heat gun work.
  6. Jun 23, 2020 at 7:34 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Keep us posted on your setup! More options for 285/75 compared to 285/70.
    Y0TA PR0 and COTundra23 like this.
  7. Jun 23, 2020 at 7:37 PM
    mghtyducks93
    mghtyducks93 Bubble Head
    Southern California
    2015 White Double Cab
    285/75/r18 Nitto's. Truck isn't a pro but I put 2" spacers in so similar rake. Had to cut the front bumper liner as there was rubbing at full turn. Hope this helps
  8. Jun 23, 2020 at 8:14 PM
    Grendel
    Grendel New Member
    2016 Quicksand TRD PRO
    I had 295/70 18 put on my pro. Before that I had Alcan springs 2+ for rear and coach builder shims in front. Also my rims are +18 black
    Rhino. I took them to 4 wheel parts and they modified the liners. I have no idea if it needed to be done or they did it “just because”. Anyway I’m happy with results no rubbing
    Black Wolf and jewsNbrews like this.
  9. Jun 24, 2020 at 7:55 PM
    Mdjamesd
    Mdjamesd New Member
    2015 Silver Sky Crewmax
    Any chance you could take a pic of where/how much you trimmed? Any chance of a full side shot of your truck?
    AlaskanAssassin likes this.
  10. Jun 24, 2020 at 8:16 PM
    CyberViking
    CyberViking New Member
    The Ozarks
    2018 MGM Tundra TRD Sport
    295/70r18 with Cooper STT Pro MT. Had to remove flaps, manipulate liner, and cut body mount. 3” lift in front. I think wheels are +18 or 20 I don’t remember.
  11. Jun 24, 2020 at 8:50 PM
    mghtyducks93
    Southern California
    86696503-39FE-40A4-92B2-AA69C3761529.jpg BE1334C5-90CB-4DB7-8D1C-2219783ABC13.jpg D85EC97E-F1CB-49F2-AA2B-3CB1F61188C1.jpg
    I can take a better picture of the bumper liner installed tomorrow if you’d like
  12. Jun 24, 2020 at 8:53 PM
    Jp-ProMamba
    Jp
    Ended up going with the 295/70r18 and couldn’t be happier!! Even though it is a noticeable difference on ride quality it’s well worth it! lol
  13. Jun 25, 2020 at 4:58 AM
    Mdjamesd
    Mdjamesd New Member
    That would be awesome! I'm installing my 6112's finally (after having them sit unassembled in the box for over a year).
    Have them set at 1.9 for now. Looking at tire options, and what I might be able to fit at that setting on stock TRD wheels.
    I still need to be able to fit in parking garages.
  14. Jun 25, 2020 at 5:47 AM
    wiretwister
    NJ
    '22 SR5 CM
    Are you running wheels spacers?
    I think this is where the misinformation and confusion starts.
    OP: if @mghtyducks93 is using wheel spacers and bringing his offset lower, then we're starting to talk about 2 different scenarios.
    It looks like @mghtyducks93 cut off a TON of wheel well/fender liner, which frankly is not necessary using stock offset. Even with a lower offset created by adding wheel spacers, you should just have to push the fender liner out with a heat gun.
  15. Jun 25, 2020 at 6:29 AM
    mghtyducks93
    Southern California
    Yes sorry for the confusion, I meant to mention it in my first post but I do have 1.25” spidertrax spacers on original wheels
  16. Jun 25, 2020 at 6:55 AM
    palehorse
    palehorse @grey_ghost_trdpro
    Mount Pleasant, SC
    2020 TRD PRO
    2020 Pro
    285 / 70 - 18 Nitto RG
    No rubbing
    No cutting
    No spacers
  17. Jun 25, 2020 at 6:56 AM
    palehorse
    Mount Pleasant, SC
    2020 TRD PRO
  18. Jun 25, 2020 at 7:17 AM
    motoryder
    motoryder ^^ I probably crashed after that pic
    Rancho Cucamonga, CA
    2500HD AT4
    I'd love to see more posts like this. Simple.
    Most of the time it's, "i'm running 295/70-18 with no rubbing at all!..............all I had to do was, add +xxx offset wheels and xxx" lift and BMC and cutting and blah blah blah
  19. Jun 25, 2020 at 9:10 AM
    wiretwister
    NJ
    '22 SR5 CM
    Agreed. It's either...
    1) see my build page
    -which offers zero help
    OR
    2) I'm running size XYZ with no problems at all...
    -then we find out 6 pages later that they chopped, cut and otherwise mangled their truck to make it all work.
    It's like everyone's unwilling or unable to write another sentence to fill us all in.
  20. Jun 25, 2020 at 6:51 PM
    Jp-ProMamba
    Jp
    No wheel spacers or extra lift on my Tundra Pro
    bulldog93 and motoryder like this.
  21. Jun 25, 2020 at 9:39 PM
    TonyNCo
    TonyNCo New Member
    Tony
    2019 VooDoo Blue TRD Pro
    Audio, 11 channels Kenwood HU, Mini DSP Digital Sound Processor 2 Alpine 4 Channel Amps, 3 Alpine Sub Amps approx 4K watts 3 way Focal in dash, front doors. 6 1/2" in door swapped for 8" 10" Focal Sub, front passenger floor, custom sealed box 2 way Focal rear doors 2 JL Audio 12W6 Subs, behind backseat Aux lights, all but ditch on modified bumper light bar (3 Hella Rally 4000) Spot, Fog, and Euro beam. Euro beam has yellow bulb. 4 White Spot beam LED Ditch 4 Yellow Spot beam LED 42" Curved, Yellow/Fog LED light bar 50" Curved, White LED light bar 295/70/18 Falken Wildpeak, Revolver Bed Cover
    Great look!
    Did you have to cut mud flaps? Do they clear at full articulation? Which tires did you get?
  22. Jun 26, 2020 at 7:57 AM
    Jp-ProMamba
    Jp
    The only “mod” I did was remove the front mud flap. I didn’t cut or lift the Pro anymore. I went with 295/70r18 Ridge Grappler. I’ve had countless compliments on the new look! To my understanding this is the biggest sz tire you can install on the Trd Pro without any suspension mods
    gregm76 likes this.
  23. Dec 13, 2020 at 5:05 PM
    TheMolenator
    TheMolenator New Member
    Jake
    2020 Tundra TRD
    TBD
    Have you towed with this setup? Notable power loss? I tow 7k lbs on weekends in summer 3 hours at a time so I don’t want to be pissed when she is searching for gears.
  24. Dec 13, 2020 at 5:28 PM
    mghtyducks93
    Southern California
    Have not towed yet, sorry I’m no help
  25. Dec 13, 2020 at 5:49 PM
    TheMolenator
    Jake
    2020 Tundra TRD
    TBD
    Dang it! I love this look but don’t want to sacrifice towing. Sweet truck
  26. Dec 13, 2020 at 6:25 PM
    YotaBro
    Calvin
    FL
    Lots of shenanigans.
    Whats your MPG now? Are you experiencing any rubbing? Do you think you'd have any rubbing if you had a bunch of weight on it? I.e decked system, front bumper with a winch and lights?
    Snikskytter9 likes this.
  27. Dec 13, 2020 at 6:27 PM
    YotaBro
    Calvin
    FL
    Whats your MPG now? Are you experiencing any rubbing? Do you think you'd have any rubbing if you had a bunch of weight on it? I.e decked system, front bumper with a winch and lights? (I realized that I asked the same thing to @palehorse but he has 285s compared to your 295)
  28. Dec 13, 2020 at 7:26 PM
    palehorse
    Mount Pleasant, SC
    2020 TRD PRO
    When not towing, I average 15.5-16mpg
    No, I've had the wheels balls deep in the fenderwells.
  29. Dec 13, 2020 at 7:27 PM
    palehorse
    Mount Pleasant, SC
    2020 TRD PRO
    I'm going to 295 or 305 next, but I've put a Westcott lift on since then so I have 1.5/1 more clearance.
  30. Dec 13, 2020 at 7:28 PM
    Snikskytter9
    Snikskytter9 New Member
    Rich
    New Hampshire
    2017 Tundra SR5 TRD off road
    2” level Nitto Ridge Grapplers Switch Pros 9100 Alpine wireless CarPlay Pillar post lights / amber / white Grille mounted light bar TRD Pro grille Dipped/blacked out badges 20% front window tint RCI 12” rack DECKED bed system LED bed lighting OEM Tow mirrors Crappy awful magnum research side steps.
    yeah dude, I tossed on 275 70r 18 on my stock wheels 60k miles ago, they’ve been awesome in the New Hampshire winters and everything else. I’m going up a size later this winter and staying with the grapplers. Can’t say enough about them.
