Anyone running 17" rims on your 2.5 gen?
Discussion in 'Wheels & Tires' started by BuckWallace, Apr 2, 2018.
  1. Jun 1, 2022 at 10:56 AM
    #661
    king.cong.1119
    king.cong.1119 New Member
    17inch icon rebound with bfg ko2 in 315/70r17 load range E.
  2. Jun 1, 2022 at 3:37 PM
    #662
    jeffw6236
    jeffw6236 New Member
    Jeff
    San Antonio
    2019 MGM CrewMax 4x4
    I tried to get these a couple of months ago but there was a national back order.
  3. Jul 1, 2022 at 3:32 PM
    #663
    omer318
    omer318 New Member
    Monroe, LA
    2021 Tundra Crewmax 4WD
    trd front sway bar - trd rear sway bar - trd dual exhaust - trd smoked led headlights - amp research steps - jl stealthbox (two 10" subs) - 17” icon rebounds - 35" nitto rg’s
    Just installed 285/17r17 (33.86”) ridge grapplers on 17” icon rebounds, running fox 2.0s for 2” level in front, loving this setup!
    Coming from 285/65r20 (34.8”) ridge grapplers on 20” TSS wheels, on 2” spacer level
    Before:
    After:
  4. Oct 26, 2022 at 7:11 AM
    #664
    nyhc121
    nyhc121 New Member
    2017 Limited TRD Off Road
    I’m looking to get some 17x8 Methods +25 offset with 295/70/17s on stock suspension. Anyone know if this will work? Tiresize website shows the height the same as 275/70/18 but about an inch wider
    Gee Dub likes this.
  5. Oct 28, 2022 at 10:21 AM
    #665
    pvmike
    pvmike Home Depot flexing
    Los Angeles
    2014 Platinum Super White
    TRD Pro suspension, supercharger, 5.29 gears, Auburn LSD
    My guess is it will clear metal but not plastic. You'll be cutting liner, no big deal. But that's just a guess.
    nyhc121[QUOTED] likes this.
  6. Oct 30, 2022 at 6:22 PM
    #666
    pvmike
    Los Angeles
    Just remembered that there is a photo of 17" wheels on 295/70/17 on stock suspension, but 0 offset. Post #7 (and #19 and #20) in this thread:
    https://www.tundras.com/threads/anyone-running-17-rims-on-your-2-5-gen.23617/#post-584808
  7. Oct 30, 2022 at 6:31 PM
    #667
    jeffw6236
    Jeff
    San Antonio
  8. Oct 30, 2022 at 9:04 PM
    #668
    pvmike
    Los Angeles
    True that it has an aftermarket bumper, but I believe that his proposed setup will fit without a lift. 33" tires will fit without a lift given the right offset. A +25 is ideal for fitting tires (my previous wheels were +25, now +5), and the Methods he wants are only 8 inches wide. That will make 295/70/17 tires closer to 11" in width and just over 33" in height. He'll likely need to trim a little plastic, but it will clear the body mount and ucas.
    jeffw6236[QUOTED] likes this.
  9. Oct 31, 2022 at 5:11 AM
    #669
    Cthulhu
    17" Icon Vector 5 +25 offset wrapped in 35x12.5x17 Nitto Recon Grapplers.
    EvoTundra, KWC, FISHN43 and 2 others like this.
  10. Nov 1, 2022 at 2:02 AM
    #670
    Toe404
    Toe404 just a poser
    Tomas
    Concord ,CA
    '21 Cavalry TRD Sport CM Tundra & 25 TRD Pro Sequoia
    Relations race wheels RR7-H 17x8.5 zero offset, mounted to 35x12.5 Falken Wildpeaks AT3’s
    Gunner1020, Ceezurin, Dooders and 6 others like this.
  11. Nov 11, 2022 at 8:40 AM
    #671
    back_cast
    back_cast New Member
    Denver, CO
    New shoes yesterday. 17" Icon Rebounds w/ 35x12.5x17r MT Baja Boss A/Ts
    TS1794, Dooders, Skew12 and 9 others like this.
  12. Nov 11, 2022 at 9:56 AM
    #672
    FISHN43
    FISHN43 New Member
    Ohio
    2020 Super White TRD Pro
    What size did you replace?
  13. Nov 11, 2022 at 10:03 AM
    #673
    back_cast
    Denver, CO
    285/75/17 Toyo Open Country ATII
    pretty worn though
    Pillslinger and FISHN43[QUOTED] like this.
  14. Nov 11, 2022 at 6:40 PM
    #674
    Robster80
    Robster80 New Member
    No lift in rear? Just the 2” in front?
  15. Nov 24, 2022 at 2:01 PM
    #675
    omer318
    omer318 New Member
    Monroe, LA
    Yep, just 2" in front for a level. Most likely going 3/1 after these are finished and will throw some 35's on.
  16. Nov 24, 2022 at 6:17 PM
    #676
    Toe404
    Toe404 just a poser
    Tomas
    Concord ,CA
    Couple more shots to show the poke with zero offset
    TS1794, kingpin3919, Dooders and 4 others like this.
  17. Nov 28, 2022 at 12:21 PM
    #677
    kaymonster
    kaymonster Member
    San Diego
    2018 Platinum
    17" Icon Six Speed with 35x12 Recon Grapplers
  18. Nov 30, 2022 at 2:50 AM
    #678
    SumTingWong_Tundra
    SumTingWong_Tundra New Member
    Are you still keeping your same Fox 2.0 lift to do a 3/1 or you going to be upgrading?
  19. Dec 13, 2022 at 7:17 PM
    #679
    Part_time
    Part_time Not a new member
    Oregon
    2017 MICA BRONZE SR5
    Does anyone know where I could buy a spare type wheel tht will fit the tundra. I cannot find one. Also I have Method 17 with 0 offset.
  20. Jan 10, 2023 at 8:25 PM
    #680
    SamuelSandoval
    SamuelSandoval New Member
    Samuel
    Northern CO
    2019 Tundra SR5 TRD Sport
    Custom Dual Exhaust YotaWerx Tune S&B CAI Fox 2.5 Coilovers Fox 2.5 Remote Resi Rears w DSC Icon Rebound Pro Wheels 285/70/17 Duratrac Tires Tonneau Cover
    285/70/17 D rated Duratrac
    Icon Rebound Pro 17” 25 mm offset
    ~1.5” front lift
    huntsonora, equin, pvmike and 3 others like this.
  21. Jan 10, 2023 at 10:44 PM
    #681
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    2021 Tundra DC, 2022 4R, 2007 FJ
    Magnuson Supercharged, Dobinson Lift, 315/70r17 on Rockwarriors, Heftyfab bumper, Dirty Deeds 3” race exhaust
    I’d just buy an identical (or two) wheel to match the other ones you have, then you can rotate it too.
  22. Jan 11, 2023 at 4:03 AM
    #682
    FISHN43
    FISHN43 New Member
    Ohio
    Those Rebound Pro’s without the faux beadlock look way better than the regular Rebounds IMO. Nice set-up !!
  23. Jan 11, 2023 at 4:30 PM
    #683
    SamuelSandoval
    Samuel
    Northern CO
    Thank you. The fake beadlock bolts is honestly one of the main reasons I spent a little more money on the rebound pro’s instead of the rebounds. Plus the innerlock technology is functional, not just aesthetic.
    FISHN43[QUOTED] likes this.
  24. Jan 11, 2023 at 5:20 PM
    #684
    bmw345
    bmw345 New Member
    CT
    2018 Platinum Pro, Pro Fox's TRD Skid
    Method 701's 17x8.5 0 offset. 35x12.5x17Toyo AT3's 2.5" in the front and about 1.25" in the back. IMG_2095.jpg
    equin, Skew12, 316KS_Runner and 5 others like this.
  25. Jan 31, 2023 at 10:58 AM
    #685
    mZiggy
    mZiggy Honey badger
    Marc
    2020 Tundra SR5-CM; 2020 4R TRD Pro; 2008 4R SR5 v8
    SamuelSandoval likes this.
  26. Jan 31, 2023 at 11:21 AM
    #686
    Marvthehamster
    Marvthehamster New Member
    Tom
    CO
    2018 CM
    ADS/Deaver, Method's, 35's, RCI Armor, OTT Tune
    Hey dude, the RCI sliders are sweet, really enjoying them!
    I'm actually looking at this exact same wheels for my truck. Any issues with them? Balancing, fit, etc..?
  27. Apr 24, 2023 at 11:04 AM
    #687
    TRDren
    TRDren New Member
    2020 MGM Tundra TRD Pro
    CoachBuilder TRD Pro Lift Kit 1.25” BORA Wheel spacers Chassis Unlimited Front Bumper
    Method 705, 17x8.5, 0 offset
    Mickey Thompson Baja Boss M/T 35”x12.5”
    Did any of you have to cut fender liner nearest to body mount? Experiencing a little bit of rubbing on the liner in reverse.
  28. Apr 24, 2023 at 11:21 AM
    #688
    mgm16trdpro
    Northern NJ
    2016 mgm trd pro crewmax
    Truck and wheels look great, definitely a great combo. I had to trim mine and just thought it was due to the Pitbull Rockers being bigger than every other 35.
    TRDren[QUOTED] likes this.
  29. Apr 24, 2023 at 10:46 PM
    #689
    TRDren
    TRDren New Member
    These Mickeys are 34.8”, in the same boat I guess. You got any pictures of your cuts?
    Planning on trimming little at a time…
  30. Apr 25, 2023 at 4:08 AM
    #690
    mgm16trdpro
    Northern NJ
    Hope this helps.
    atc250r and TRDren[QUOTED] like this.
