Anyone run 235/85/16's on a Stock Gen 1????? I have 255/70/16's on right now and they are snug.
Discussion in '1st Gen Tundras (2000-2006)' started by Bman95, Mar 20, 2021.
  1. Mar 20, 2021 at 10:47 AM
    Bman95
    Bman95 [OP] New Member
    Anyone run 235/85/16's on a Stock Gen 1????? On my 2005 Tundra, I have 255/70/16's on right now and they are snug and do not look right (see below pics). I have a 1.5" level kit on the front but I am still concerned about height and width causing tire rubbing. Also, any thoughts about spacers to help with the width issue on a larger tire????[​IMG]
  2. Mar 20, 2021 at 10:54 AM
    Jack McCarthy
    Jack McCarthy Truck repair enthusiast; Rust Aficionado
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    255/70/16s on a 2005 are snug? I have 265/70/16s which is standard with the alloy wheels option on an 02, 85s are definitely going to be tall. Good question though.
  3. Mar 20, 2021 at 11:21 AM
    2000 Limited TRD AC 4X4 Thunder Grey 270k miles. 2019 Limited TRD CM 4x4 Cement Grey 75k miles
    2000: Bilstein 5100's 16x8 589's with 265/75/16 and 1.25" spacers Flowmaster 50 series over the axle dump Pioneer touchscreen with backup camera Full interior and dash LED conversion Trailer brake controller with 7 pin Bedliner coat bumpers & trim ARE topper 2019: ARE topper with full Bedrug kit and Vortex rack TRD shifter 1.25" wheel spacers (I like to live dangerously) Red tow hooks for that +15 grip bonus
    those 235/85/16 tires are about the same height as a 265/75/16. Should fit on a stock wheel with your lift. Those will be around 31.5" tall. Can't see your images. I'm not sure I would want that particular tire as it is so skinny and has so much sidewall. If you go that route report back.
    Jack McCarthy and jimf909 like this.
  4. Mar 20, 2021 at 11:24 AM
    jimf909
    jimf909 Battery almost dead...
    Washington or Idaho
    '03 Tundra SR5 AC 4.7 TRD w/LSD
    Dead stock with oem 16" starfish wheels. We'll see how long that lasts. :) Topper of unknown origin.
    235/85 R16 tires will be about an inch narrower and an inch taller than stock 265/70 R16 tires.1DD55F3C-F244-4D55-86A8-8C8B43A7F9A5.jpg
    Your 255/70 R16 tires are about a half inch narrower and shorter than stock tires.
    I don't have experience with the 235/85 R16 size you mention.
  5. Mar 20, 2021 at 12:22 PM
    Bman95
    Thank you for the calcs Jim.
    The stock tires size posted on the door jam is 245/70/16's. Do you guys see something different? The 245's have a width of 9.6" and height of 29.5". I'm thinking the width of 10.4" on the 265/75/16's or 265/70/16's would cause it to rub as the 255/70/16's is barely missing.
  6. Mar 20, 2021 at 12:28 PM
    Captain Tenneal
    Captain Tenneal New Member
    NNV
    2005 SR5 Double Cab Off-Road Package, Sunroof
    Bilstein 5100 - 1 groove up
    What wheels are you using? If you are using Tacoma wheels, I wouldn't be surprised you may have issues rubbing on the inside. Stock Tundra wheels are about 15mm. Many Tacoma wheels are 25-30mm.
    I run LT245x70x17 with TRD Pro SEMA wheels (offset 4mm) and have no issues whatsoever.
    speedtre and MS22 like this.
  7. Mar 20, 2021 at 12:30 PM
    jimf909
    Washington or Idaho
    What year and model Tundra do you have? My 2003 TRD 4WD Access Cab came with 265/70 R16 tires. The 245 tire width is also listed on the door jamb sticker. I've heard here the 245 width may have been stock on other models.
    MS22 likes this.
  8. Mar 20, 2021 at 1:16 PM
    Bman95
    I bought the truck used and am assuming these are stock Tundra wheels. It’s a 2005 Double Cab SR5 Tundra w/4.7 V8.
  9. Mar 20, 2021 at 1:23 PM
    Jack McCarthy
    Bill
    North of Boston
    245s are stock steel wheels. 265s are an option which come on most packages that include the aluminum alloy wheels. One exception is the XSP package with upgraded wheels/tires I believe.
    jimf909 likes this.
  10. Mar 20, 2021 at 2:53 PM
    jimf909
    Washington or Idaho
    Can you post a photo of the wheels? As mentioned above, the wheel backspacing (and rim width and offset) can have a dramatic difference on how a wheel/tire package fits on a given car. If your wheels aren't stock, you'll need to measure the backspacing (wheel needs to come off the truck) and compare it to a stock wheel to see how a tire of a given width will fit.
    If your wheels have more backspacing than stock you'll need a narrower tire or spacers to fit a wider tire (rim width can also be a factor)
    https://www.4wheelparts.com/the-dir...J5SG3BtM2hi31hPPzgoR7pWlQybuUA_IaAnYXEALw_wcB
    Bman95[QUOTED][OP] and MS22 like this.
  11. Mar 20, 2021 at 3:31 PM
    Bman95
    That is interesting about the wheel possibly not being stock....never gave it much thought. Here is a pic of the wheel. It’s missing the center caps on all 4, can you tell if this is stock?
  12. Mar 20, 2021 at 5:45 PM
    jimf909
    Washington or Idaho
    I'm no expert but those don't look like stock Tundra wheels.
    Here are 20 pages of wheels that fit Tundras but hopefully someone will chime in with a call on what they are.
    https://www.tundras.com/threads/lets-see-1st-gen-with-toyota-rims.40487/
    Regardless, if you want to explore tire options and you're going to run those wheels you need to know the dimensions of the wheels, in particular the back spacing.
    If the truck is new to you now is also a good time to make sure your jack works and you have the special socket for those security lugs nuts.
    Remove the front wheel and measure the backspace. Straight edge from lip to lip, ruler from the straight edge to the face of the wheel...
    A oem 2003 16" Tundra alloy starfish wheel has 4 5/8" of backspace. If your backspace is deeper than that you have less space for tires before they hit suspension parts...
    Jack safely...
    20AAF528-8BE1-48F5-9963-67D170AB1B02.jpg 20AAF528-8BE1-48F5-9963-67D170AB1B02.jpg
  13. Mar 20, 2021 at 7:26 PM
    speedtre
    speedtre New Member
    Inland Northwest
    That is not a Tundra wheel...I think it's an early 2nd gen Tacoma wheel....which as mentioned is probably a +30 offst compared to a stock Tundra wheel being +15 offset. That's your issue.
  14. Mar 20, 2021 at 7:44 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    I know it’s not an apples to apples to comparison, but I ran 235/85R16’s on my 2006 Tacoma, the results were good enough for me to buy a second set when the first wore down. The thing was an absolute beast in deep snow with the pizza cutters.
    Fuel economy may have suffered as they’re only available in LR E / 10 ply rated, but tough rubber for a truck used in tough conditions.
    And I agree, those aren’t Tundra wheels. I’m thinking 4runner.
  15. Mar 21, 2021 at 12:55 AM
    Captain Tenneal
    NNV
    I'm not sure what wheel that is but its not Tundra. There should be a stamp on back of the wheel which indicates offset (E15 or ET15 for 15mm offset).
  16. Mar 21, 2021 at 4:33 AM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    Definitely not a OEM Tundra wheel.
    Bman95[OP] likes this.
  17. Mar 21, 2021 at 6:40 AM
    Bman95
    So it looks like the wheels are my issue. How do I find out stock backspace and offset? Is the 4 5/8” on the 03 the same for all 1st gens? Also, there were 3 tire size options for the 2005 Tundra:
    • 245/70 16
    • 265/70 16
    • 265/65 17
    Will all of these work on a stock Tundra regardless of what it came with originally?
  18. Mar 21, 2021 at 7:35 AM
    Professional Hand Model
    Hand Protectors
    The sweet spot on our 1st Gens is the 285/75/r16. Just do it. Slight rubs on inner frame, but only at tight hard parking spot turns. I found this chart for Really Dumb Hand Models to Understanding Wheels.
    two2cal likes this.
  19. Mar 21, 2021 at 7:37 AM
    Hand Protectors
    Here is another layout somewhere provided by a member I screenshot’d.
    jimf909 likes this.
  20. Mar 21, 2021 at 8:56 AM
    speedtre
    speedtre New Member
    Inland Northwest
    Short answer is yes. What size tire do you want to run? 1st Gen Tundras, all came with approximately +15 (gove or take 2)) offset wheels except for the Darrell Waltrip SE BBS 18 inch wheels that were +4 or +5 . Lower offset means the wheel is out more towards the fender and less toward the control arm. Pretty much all 5th Gen 4runner wheels run similar offset to FGT, so you can treat them like OEM FGT wheels. TRD Pro SEMA Wheels (what I run) have the same offset as the BBS rims.
  21. Mar 21, 2021 at 10:46 AM
    Bman95
    I want to go as tall and wide without rubbing. I’m now leaning towards 265/75/16’s. My new dilemma is what type of wheel to go with. I’m looking at the Mickey Thompson Classics below but neither option meets the stock specs exactly.
  22. Mar 21, 2021 at 11:01 AM
    speedtre
    speedtre New Member
    Inland Northwest
    If you want NO rub, that's the biggest on OEM stock rims. That rim pushes the wheels out quite a bit, but I think you'll be fine.
  23. Mar 21, 2021 at 11:35 AM
    Captain Tenneal
    NNV
    When I bought my truck it had 16x8.5, ET0 with 265x70x16 tires. No rubbing. I don't know if the extra 1" of tire (1/2" extra radius) with a 265x75x16 will cause a problem...you might be OK with an 8" wide wheel.
    Of the two wheels my vote is go with 0 offset.
    Isn't there a stamp in back of the wheel which indicates the offset?
  24. Mar 21, 2021 at 1:09 PM
    jimf909
    Washington or Idaho
    I found this on the wheels thread. The wheels look similar to what you're looking at. It's not the best shot of the wheels but it may help picture the look...upload_2021-3-21_13-5-31.jpg
  25. Mar 21, 2021 at 2:46 PM
    Bman95
    Let me make sure I understand offset. Anything less than the factory +15mm offset will move the tire further out away from the center of the truck? Therefore, the Mickey Thompson’s with the 0mm offset and same backspace as factory of 4.5” will move the tire/wheel 15mm or .59” outward? Also, will this decrease in offset more than compensate for the extra 1” of width on the wheel?
  26. Mar 21, 2021 at 2:48 PM
    Bman95
    Thank you for the pic of the MTs on the Tundra. That helps!
