Anyone mount a fire extinguisher in their truck?
Discussion in '2.5 Gen Tundras (2014-2021)' started by 996scott, Apr 12, 2017.
  1. Jul 3, 2020 at 6:40 PM
    I made mine for about $10.00. It doesn't interfere with the seat movement or leg room.
    mav7021234, DZ_, panicman and 4 others like this.
  2. Jul 3, 2020 at 6:44 PM
    TokerJoker
    TokerJoker ΜΟΛΩΝ ΛΑΒΕ
    Travis
    Nowhere, Specific
    2014 Black SR5 4.6 Dbl Cab
    None.....yet
    Not in the truck.....no but in my car.....YES.....
    Mountun Goat likes this.
  3. Jul 3, 2020 at 6:47 PM
    NewImprovedRon and TokerJoker like this.
  4. Jul 3, 2020 at 6:50 PM
    biebs96
    PA
    I have one on each side of the vehicle in the rear door cup holders. Fit is snug and out of the way.
  5. Jul 3, 2020 at 7:38 PM
    Flyinryank
    Flyinryank New Member
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    Got that OG Vizla mount :thumbsup:
    bulldog93, Buildn, 831Tun and 2 others like this.
  6. Jul 3, 2020 at 8:12 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    I did the same thing, only have one but it fits perfectly.
    biebs96[QUOTED] likes this.
  7. Jul 3, 2020 at 8:21 PM
    Over the LINE
    Over the LINE New Member
    New Orleans
    2016 Limited CM 4x4 2025 SR5 CM 4 x 4
    Mounted in my camper shell. I have side opening windows so it's easy to get to.
  8. Jul 9, 2020 at 7:02 PM
    sky_rpl
    sky_rpl New Member
    Sky
    2020 Tundra TRD Pro
    +1 for the Bracketeer. Fit perfectly in my 2020 Tundra.
  9. Jul 10, 2020 at 7:38 AM
    reneaux
    reneaux I've been around
    2017 SR5 CM 4x4
    biebs96 likes this.
  10. Jul 10, 2020 at 8:20 AM
    FlyingWolfe
    FlyingWolfe Wolfie
    Crystal
    Maine
    2018 TRD Off-Road Inferno
    Let me tell yall a story about a 25lb extinguisher going off inside the cab of a truck. It did. It made a mess. The end. :rofl:
    A cautionary tale and powdery lesson learned about transporting multiple extinguishers in the work truck without securing them properly.
  11. Jul 10, 2020 at 12:36 PM
    kevine0001
    kevine0001 New Member
    Kevin
    I made something similar. Flat bar has tabs that go under the front seat mounts. holds it into place. I have holes drilled into the flat bar to bolt extinguisher to. Mag light under the other seat. Don't get in the way at all, although they could probably be mounted a little further back
  12. Jul 11, 2020 at 7:51 PM
    cheehab
    cheehab Fan Boy
    Southern Maine
    2015 TRD Pro CrewMax
    Why exactly do you need a fire extiguisher in your vehicle? Is it specifically for vehicle fires? or for fires that might break out camping, shooting, etc?
    kevine0001 and 831Tun like this.
  13. Jul 11, 2020 at 8:37 PM
    :thumbsup:
    kevine0001[QUOTED] likes this.
  14. Jul 11, 2020 at 8:45 PM
    Rabidllamas
    Rabidllamas New Member
    Phil
    WA
    2019 Cement Crewmax TRD OffRoad
    My build- https://www.tundras.com/threads/rabbidllamas-old-man-build.80802/
    Got this design when I had my Tacoma (tacomaworld.com) and installed in the bed. Mainly set up for camping.
  15. Jul 11, 2020 at 9:49 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Friend of mine coached a kid, good kid, no drugs/ alcohol. He hit a tree one night and couldn't get out burned to death.
    @osidepunker and @papasmurf came across an elderly couple that had just hit a burro near Parker Az. The driver was still a little shocked/stunned and an electrical fire had started somewhere in the front end. Good Samaritans that they are, Alex and Bruce stopped, put out the fire and helped the couple out.
    I put an extinguisher in front of the passenger seats of all our vehicles. Sadly the braketeer didn't work in my wife's Passat so I made all the seat brackets. I have a 2nd extinguisher mounted to the bed rail in the Tundra. Like @Hattori said, "rather have it and not need it than need it and not have it."
  16. Jul 12, 2020 at 8:13 AM
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    yeah I was on scene first. They were elderly and the burro did a number to the car. Smashed up the passenger side pretty bad. They were both disoriented. The husband got out of the car, but wife was initially trapped. I couldn't open the passenger door and being elderly she couldn't climb over to the other side. Fire started inside the passenger head light housing. At first I thought it would just go out due to lack of air. But in 30 sec, it seriously started flaming up. I grabbed my extinguisher (5lb dry chem from H3R, mounted on my bed rack) kicked a hole in the head light and stuck the nozzle in. I put the flame out, then went to the driver side and we were able to pull her out from that side. When bruce @papasmurf arrived, we found the head light on fire again. I think it was HID and the ballast was continually arcing. This time Bruce disconnected the battery then I sprayed it and it stayed extinguished.
    First time in the 4 years I've had it mounted that I needed it. I wouldn't call that an extreme emergency, but I definitely felt better having it than not.
  17. Jul 12, 2020 at 8:14 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    FYI I also carry a 2lb halon from H3R in the cab where I can reach it from the driver seat. Its mounted to one of my gear boxes.
    831Tun and texasrho83 like this.
  18. Jul 12, 2020 at 8:38 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Glad you were there bud
  19. Jul 13, 2020 at 9:14 AM
    #49
    kevine0001
    Kevin
    I keep it there since it's easy to get to. I have a shell on my truck that is usually locked. whereas the cab, I can just open it with the remote. So if I'm outside the truck, I can get to the one under the front seat faster. If I drive up to a scene where there's a fire, I can get to it quicker. If I'm sitting at camp, whether it's in the front or in the back, it would be about same amount of time to retrieve, as the truck and shell would both be unlocked. However, for campfires, I keep a large jug of water nearby....or I piss out all the beer onto the hot coals before going to sleep...fastest and saves water
  20. Sep 5, 2021 at 2:22 PM
    #50
    t-bear
    t-bear New Member
    NE Okla
    2019 Tundra CM SR5
    Soon to be 4WC Raven host. Mods to come.
    Thanks for the advice on the Bracketeer. Ordered along with f.e. and metal bracket.
    jc153 likes this.
  21. Sep 5, 2021 at 3:51 PM
    #51
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
  22. Sep 5, 2021 at 4:49 PM
    #52
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Could always do this! Just like what @831Tun suggested.
  23. Sep 6, 2021 at 9:21 AM
    #53
    t-bear
    t-bear New Member
    NE Okla
    2019 Tundra CM SR5
    Yep, I went in cab because I will have a 4 Wheel Camper permanently installed in the bed.
  24. Sep 6, 2021 at 9:25 AM
    #54
    ZTundra
    ZTundra New Member
    ZACK
    Knoxville, TN
    2021 MGM Nightshade
    I had one mounted on some desert does it seat jackers and Molle panel. Used quick fists to mount it.
  25. Sep 6, 2021 at 4:49 PM
    #55
    COElkHunter
    COElkHunter New Member
    Jeremy
    2012 Silver Tundra TRD limited Crewmax 4x4
    3" OME lift w/ UCAs. ARE overland shell w/ ARE roof rack. 34" Falken Wildpeaks. ARB awning. Road shower. Wilco Offroad Hitchgate Solo High Clearance. LED lighting upgrades. Lockerdown console safe. Weathertech floormats. Duluth deluxe rear seat cover to go under the offroad approved car seats.... :P
    2nd the goldfire bracket mounted to the bedrail. It's rock solid, not going anywhere, but takes about 5 seconds to get it out. I like the cab mount in front of the seat, will definitely be adding one of those.
  26. Sep 6, 2021 at 6:26 PM
    #56
    Buildn
    Buildn 2022 Tundra Limited CM 6.5 Bed TRD Off Road
    Medina, Ohio
    TRD Air Filters, Front door windows tinted to match the rears. Wheel locks, Talons Garage cat shield, Tyger Automotive soft tonneau cover, WeatherTech floor mats with Tuff Skinz Custom Emblem kit, Toyota OEM Emblem Black Out kit. AVS vent covers on all four doors, Red Tundra letters on front bumper & TRD highlighted in Red on front grille. Tailgate Tundra Letters in Black.
    On the way!
  27. Sep 7, 2021 at 10:25 AM
    #57
    November Sun
    November Sun New Member
    Huntsville, Alabama
    2018 Limited Crew Max
    Pro Comp 7" Stage 1 Lift, 20" Fuel Wheels, Nitto Terra Grapplers, Bak Flip Tonneau Cover, King 2.5's, Custom Alcan Leafs, Coachbuilder Steering Kit, CBI Baja Front Bumper, NSV Light Bar, TRD Pro Intake, Southeast States Wireless Phone Charger Coachbuilder Plus 3 Shackles, Wheeler's Bumpstops, BAM 8" Exhaust, BAM Bomb Tip, Headlight Revolution LEDs everywhere, Warn EVO 12K Winch, Diode Dynamics SAE Fogs and Combo Light Bar
    Does that bracket come with everything to mount to the bed rails or does it just slide in there?
  28. Sep 7, 2021 at 10:28 AM
    #58
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    You'll also need the t-slot nuts which can be bought on Amazon too!
  29. Sep 7, 2021 at 10:32 AM
    #59
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    And you'll need bolts. For my mount I had to drill and open up the bolt holes slightly.
    pvn.beluga[QUOTED] likes this.
  30. Sep 7, 2021 at 10:39 AM
    #60
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Forgot to mention that! The t-slot nuts also come with bolts depending on which you buy. I think they are 3/8-16 if you want to go to your local HD/Lowes/Ace Hardware to buy them.
    831Tun[QUOTED] likes this.
