Anyone know how to remove epoxy glue from paint?
Discussion in 'Detailing' started by yoneytan, Dec 22, 2018.
  1. Dec 22, 2018 at 1:34 PM
    yoneytan
    yoneytan [OP] New Member
    Asi
    14 CM
    Not sure how it got there but I somehow managed to get what looks and feels like some sort of epoxy glue on my paint. I tried goo gone which did nothing. I’m afraid to try with things I’m not familiar with a ruin the paint. Anyone have experience removing this stuff?
  2. Dec 22, 2018 at 1:51 PM
    ardnutoz
    ardnutoz
    OZ
    SE-PA
    2018 Black TRD OR CM Limited
    try a plastic scraper n see if it flakes off. start on the small pieces first. if your paint was either waxed or fairly dirty it should pop off as it possibly didn't bond to the paint.
  3. Dec 22, 2018 at 2:30 PM
    da_jeep_luva
    da_jeep_luva New Member
    Paul
    2017 CM and 2008 RCSB
    TRD Pro suspension, powder coated bumpers, wheels, tires, lowered, coated, list keeps going.
    I’d give this a whirl.
    If that doesn’t work, you might try a heat gun or hair dryer to soften it up and fingernail it gently.
    Sorry that happened to your truck. Shut sucks
    NewImprovedRon likes this.
  4. Dec 22, 2018 at 2:33 PM
    15whtrd
    15whtrd Mr. Blonde
    Maybe a little WD-40 and pick at it carefully with your finger nail or plastic scraper
    Rock 4x4 and NewImprovedRon like this.
  5. Dec 22, 2018 at 2:37 PM
    Heat gun to soften it up then try to take it off with a plastic scraper and some Goo Gone.
    Patriot likes this.
  6. Dec 22, 2018 at 3:28 PM
    Professional Hand Model
    Hand Protectors
  7. Dec 22, 2018 at 4:19 PM
    Adriver71x
    Adriver71x New Member
    Gerald
    2015 Tundra SR5
    Tow Mirrors
    Try bug & tar remover. I had what looked like the same thing on a old truck
  8. Dec 22, 2018 at 4:32 PM
    Cement_Trd
    Cement_Trd New Member
    2018 Cement TRD offroad
    Cement color match (dechrome), Tyger Side steps, TRD rear sway bar, Black badging (dechrome), TRD dual exhaust
    Could it possibly be calcified bubble gum?
    15whtrd likes this.
  9. Dec 22, 2018 at 5:28 PM
    yoneytan
    Asi
    14 CM
    Tried but didn't work
    I doubt it. This shit is hard as a rock.
  10. Dec 22, 2018 at 5:45 PM
    yoneytan
    Asi
    14 CM
    This will definitely remove the glue..... and the door while it's at it.
  11. Dec 22, 2018 at 5:45 PM
    yoneytan
    Asi
    14 CM
    Will give it a try.
  12. Dec 22, 2018 at 7:02 PM
    Hand Protectors
    I like to start with the easiest method, then work towards to more difficult.
    Seriously, how do you know this is epoxy on your door? You tried the finger nail removal test?
  13. Dec 22, 2018 at 7:17 PM
    yoneytan
    Asi
    14 CM
    Tried the finger nail method and failed. Also tried some wd40 and again not luck. I’m 90% sure it’s epoxy. It’s got a smooth texture and is hella hard. Gonna try heat gun and hope for the best.
  14. Dec 22, 2018 at 7:34 PM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    If it is epoxy, heat should soften it.
    For what it’s worth, most chemicals made to remove epoxy residues will also take your paint off.
    Good luck, and I hope you find something to get it off with!
  15. Dec 23, 2018 at 6:34 AM
    Hand Protectors
    If it is epoxy, then its basically impervious to all chemicals (the beauty of epoxy). Heat may help. The paint behind the epoxy might pop of with the specks. Use a touch up pen to conceal afterwards.
  16. Dec 23, 2018 at 7:51 AM
    Faht Nocker
    Faht Nocker Platinum Member
    Woody
    Milky Way
    2016 Super Fast White Platinum 4x4 Faux PRO Tundra
    I would take it and get it sanded out by a detailer or body shop.
  17. Dec 23, 2018 at 7:52 AM
    Fishman57
    Fishman57 New Member
    Wayne
    Bucks County, PA
    Just call it additional ventilation.
  18. Dec 23, 2018 at 9:34 AM
    Cement_Trd
    From the photos it really looks like you ran over some dubble bubble gum and it hadened like a rock. I got some on my front plastic inner fender liner and had to use a metal scraper to get it off and it still didnt fully come out. Ill see if I can find some photos I took of it
  19. Dec 23, 2018 at 9:40 AM
    1999cutiger
    1999cutiger Top Flow Lifestyle
    2017 Toyota Tundra SR5 4x4
    RBP 67R AK-8 20x9 wheels General Grabber ATX 275/60/20
    Try WD-40 or gasoline.
  20. Dec 23, 2018 at 9:40 AM
    15whtrd
    15whtrd Mr. Blonde
    You very well could’ve run over a tube of construction epoxy. You may have to tape off everything but the epoxied areas. Scrape it down as low as possible without damaging the paint. And then you may have to slowly sand down the epoxy with wet dry sandpaper. Do not attempt if you are unsure of yourself. You would basically be trying sand only the high points. Starting with the least aggressive grit sandpaper that is effective and stepping finer and finer. Then polishing and waxing the area.
