Anyone install the Singer Voltage Booster for their alternator?
Discussion in 'Electrical' started by nags, Apr 22, 2022.
  1. Apr 22, 2022 at 11:13 AM
    nags
    nags [OP] New Member
    2008 SC RCSB w/ all the goodies.
    Just got mine in and haven't had time to look too closely. Anyone got any pointers on how to swap this thing out without disassembling half the truck?
  2. May 9, 2022 at 8:07 PM
    allenjanthony
    allenjanthony New Member
    2019 Toyota Tundra Limited
    How difficult was it to install singer voltage booster? What were the results after the install?
  3. May 10, 2022 at 5:34 AM
    nags
    It was very easy once I found the right angle from under the truck to get to the alternator plug.
    Before installing it my voltage ranged from about 12.2-12.8 once at temp. now I'm usually 13.9-14.4
  4. May 10, 2022 at 5:34 AM
    nags
  5. May 10, 2022 at 5:40 AM
    allenjanthony
    Did you order the version 1 or version 2?
    Thanks
  6. May 10, 2022 at 6:11 AM
    nags
    619Tundra likes this.
  7. May 10, 2022 at 6:32 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Interested in this. Is there any negatives to the electrical system or battery in terms of over stress or longevity reduction?
    I see on the ebay listing it says Tundra 2007 to 2018. does this just need to be updated or is there a reason this wouldnt work on a 2021? I think the electrical system is the same.
  8. May 10, 2022 at 6:35 AM
    nags
    I don't know, but message him. He replies quickly and it's Mike directly.
    MadMaxCanon[QUOTED] likes this.
  9. May 10, 2022 at 6:36 AM
    MadMaxCanon
    Word, I will let everyone know what he says.
    nags[QUOTED][OP] likes this.
  10. May 10, 2022 at 7:09 AM
    MadMaxCanon
    I believe 2018+ will not work with this. The below is per the seller:
    "for a 2021 the plug is a LIN based system (which is pcm controlled without a sense connection)
    so there is not a voltage boost solution yet for this"
    nags[OP] likes this.
  11. Sep 21, 2022 at 8:48 AM
    619Tundra
    619Tundra New Member
    San Diego, Caifornia
    2017 Black Tundra Double Cab SR5
  12. Sep 21, 2022 at 8:54 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    @nags
    Any update on how this is working out?
    I wonder how it works compared to the hkb alt-s fuse replacement.
  13. Sep 21, 2022 at 8:54 AM
    nags
    My voltage always stays quite a bit higher now than before. Seems to be working great.
    What's the alternative you mention? I haven't heard of that.
  14. Sep 21, 2022 at 9:02 AM
    Danimal86
    Daniel
    Sacramento, CA
    https://www.hkbelect.com/products/toyota/?model=tundra&year=2017
    I went this route, but i feel like i still only see high 13v, but i haven't looked for a while.
