Anyone install fog lights?
Discussion in '1st Gen Tundras (2000-2006)' started by tunyota, Oct 18, 2020.
  1. Oct 18, 2020 at 2:03 PM
    tunyota
    tunyota [OP] Wrenching w/ the beautiful wife.
    Phantom Gray 2006 Regular Cab Long Bed 4WD V8 4.7L
    Front Hitch Receiver, Bilstein 5100s, Denso 130A alternator, LED interior and exterior lighting, Kicker 46CSS674 Car Audio 6 3/4" Component Full Range Stereo Speakers, Pioneer AVHX2700BS w/Pioneer NDBC8 Backup Camera, Transcend Drivepro 550 Dual Lens Dash Camera, and much more!
    Greetings fellow community members!
    I just installed fog lights, fog light switch, and relay. However, they are not turning on when toggling the switch. I thought it was going to be a simple plug and done but apparently I am missing something. I verified the issue is not with the switch, fuse, or relay.
    Is it possible that this switch position is for the rear view heated mirror and the fog lights are controlled by the turn signal lever? Toyota Parts - Switch Assy, Headlam (84140-0C050)
    Has anyone installed fog lights into their Tundra?
    I am hoping someone here with experience can help me out. I tried searching previous posts but couldn't find much of anything.
    Thanks in advance for any suggestions!
  2. Oct 18, 2020 at 3:59 PM
    RR60
    RR60 New Member
    2003 SR5 Tundra long bed
    On my 2003 I had to install a new turn signal lever that also had the fog light switch on it.
    If i remember right I found one on ebay for about 60.00.
  3. Oct 18, 2020 at 4:04 PM
    tunyota
    Thank you for sharing! I just ordered the turn signal/head lamp assembly lever with integrated fog light switch (84140-0C050). I will be sure to confirm once I have it installed later this week.
  4. Oct 18, 2020 at 5:44 PM
    tunyota
    Upon reviewing the owner's manual confirms the fog light switch is located on the turn signal/head lamp control lever for equipped models. I should have thought to check that before eagerly placing my order. I am feeling confident (84140-0C050) will be the ticket! Hopefully this will save some others a headache.
    SouthPaw likes this.
  5. Oct 18, 2020 at 7:51 PM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    Live and learn. You could always use your current switch but make sure it has power.
    tunyota[QUOTED][OP] likes this.
  6. Oct 18, 2020 at 8:39 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    that plug you used is for heated mirrors. the 03 and up fog switch is part of the turn stalk
    So good news is nothings hurt by doing this, Go get your self some heated mirrors another relay and the correct switch and enjoy heated mirrors! I installed both heated mirrors and the fog lights in my 05.
  7. Oct 18, 2020 at 8:41 PM
    empty_lord
    05 rollover special
    you can also add factory keyless entry, power door locks, windows ETC.. ive done it all in my 05 v8.
    Rex Kramer and tunyota[OP] like this.
  8. Oct 21, 2020 at 4:31 PM
    tunyota
    Update:
    I can confirm installing the new head-lamp lever assembly with equipped fog light switch (84140-0C050) did the trick as everyone mentioned.
    Thank you to those who responded and for sharing! :cheers:
  9. Oct 21, 2020 at 4:34 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    The pics you were trying to apply did not work. You can try again.
  10. Jan 19, 2021 at 6:57 PM
    AV8R4AA
    AV8R4AA New Member
    Greg
    Justin Texas
    2005 Tundra XSP
    Does anyone know if the Sequoia has the same stalk for later model fog lights?
  11. Jan 19, 2021 at 6:57 PM
    empty_lord
    05 rollover special
    Should. Mines out of a sequoia
  12. Jan 19, 2021 at 7:39 PM
    AV8R4AA
    AV8R4AA New Member
    Greg
    Justin Texas
    2005 Tundra XSP
    What are you guys using for the relay and the actual fog lamps?
