Anyone install a Back-Up Camera on a 1st Gen?
Discussion in '1st Gen Tundras (2000-2006)' started by Bman95, Feb 24, 2021.
  1. Mar 21, 2021 at 10:30 AM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    NW Georgia
    2006 Tundra 4X4 Limited Dbl Cab
    If you're asking me then no, once you open the tailgate a few times you know where to reach / grab. It's really no big deal.
    KarmaKannon likes this.
  2. Mar 21, 2021 at 12:52 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    W.I.P - FOX 2.5 with DSC, SCS F5 wheels with MT Baja ATZ 285s
    What headunit do you have yours connected to? I have the same handle and camera but I can’t seem to get the display to work well. I tapped into aux and ground wires on the trailer wiring but the display is super grainy and can’t really see anything, even after getting a new camera sent out.
  3. Mar 21, 2021 at 2:09 PM
    Bman95
    Bman95 [OP] New Member
    I’ve got a JVC touch screen but I’ve got the RCA cable running to the rear view mirror display. Only the power and ground is tied to the head unit.
    Kimosabe likes this.
  4. Mar 21, 2021 at 8:32 PM
    Riverdale21
    Riverdale21 Speed seeker
    OTP ATL
    06 DC SR5 Tundra TRD Off Road
    Dirt Deeds injectors, Addco rear sway, AEM dry flow air filter, last ever set of Stan's Try-Y headers, Borla full custom exhaust, front level, wheel spacers, and lots of electronics.
    Almost forgot to upload the image from my camera setup. Nice wide angle high up view. Bottom right corner you can just make out the edge of the bumper. I can back into my garage right up against the wall if I need to.
  5. Mar 22, 2021 at 7:35 AM
    2KYOTA
    2KYOTA New Member
    2000 Tundra SR5 AC (Imperial Jade Green)
    Stock
    After 21 years of owning, I decided to make the first upgrade, added an Alpine with backup cam. Works well, have front facing camera too that allows me to hook up to my RV w/o needing to get the wife involved. Oh, and I had a drive-shaft disconnect put in so I could flat-tow it.
    Regarding the camera from Tailgate Masters, it looks like it only points at the hitch in the pictures. Can it be adjusted to be a typical rear view / back-up camera?
    pock, Pearl-snap, KarmaKannon and 3 others like this.
  6. Mar 22, 2021 at 8:01 AM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    Did you happen to do the install yourself? I have that same Alpine headunit and I'm trying to figure out why my camera view isn't working. Clean truck by the way. Looks great.
  7. Mar 22, 2021 at 6:14 PM
    2KYOTA
    2KYOTA New Member
    Stock
    Yes, I installed it myself, only a couple weeks ago. I bought it from Crutchfield along with their 'Ready Harness' which actually made things really simple. I also bought the Micro Bypass Switch for Alpine from Amz to handle the ebrake stuff. For the rear camera it just needs positive voltage on the trigger wire - from the trailer harness or reverse light.
  8. Mar 23, 2021 at 12:29 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    Thanks. Ya I got the ready harness also. I seem to keep having issues with it working. I just need to investigate more.
  9. Mar 23, 2021 at 2:08 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    What kind of issues....these guys have a world of knowledge and willing to help.
    Disregard, I see where you have commented in a number of your posts what your situation is. Keep us abreast of what you find !
    Kimosabe[QUOTED] likes this.
  10. Mar 23, 2021 at 2:33 PM
    APalmTree
    APalmTree Sometimes helpful
    Brandon
    SW Washington
    A few... Definitely more than 2
    Do the colors look right on your camera or is everything washed out? Your head unit could be doing light level "corrections" to let you have more visibility in the dark but it sacrifices quality and color accuracy during the day. Since you said that you are on camera #2 now I would doubt that it is a camera issue.
  11. Mar 24, 2021 at 9:12 AM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    There are some lines across the screen, but it mostly looks like a bad signal or connection. I'm suspecting a bad RCA cable connection, a bad ground, or maybe a setting that is messing it up.
    - I originally had it wired to the taillight but have since re-wired (splice/solder) into the trailer harness. Followed ED and write-up by @MrDirtjumper
    - I am going to pull the dash and try the front RCA cable to see if that works any better, and possibly try getting a new pre-out harness for the receiver just in case.
    - I've tried messing with the setting to see if for some reason the parking guide lines are screwing up the signal, or something along those lines, but no luck yet.
    - Last step is to re-do the ground to the trailer hitch receiver and see if that is a better ground than spliced into the ground wire on the harness.
    I haven't been able to make time lately to do anything.
  12. Mar 24, 2021 at 6:20 PM
    Bman95
    I did have a loose ground that caused the interior lights to flicker. It went away after I tightened that ground wire.
    Throughout the install, I checked the RCA feed at every step to ensure I had a good connection. I was concerned about damaging the cable while running it under the truck so I insulated it with flex tubing. I didn’t experience any issues but could see how the cable could easily get damaged.
  13. Mar 26, 2021 at 6:52 AM
  14. Mar 27, 2021 at 3:59 AM
    kb7
    kb7 New Member
    USA
    2003 Tundra SR5 TRD 4x4
    For those of you using the Master Tailgaters back up camera, do you mind posting a photo of what the camera captures? I know the quality will depend on the head unit but, trying to gauge the cameras field of vision
    mcharfauros likes this.
  15. Mar 27, 2021 at 10:19 AM
    Bman95
    It’s in my rear view but you can see the angle and view.
    abcinv, BubbaW and kb7 like this.
  16. Mar 27, 2021 at 12:39 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Have my Pioneer ND-BC8 mounted in a used tailgate handle and considering this Master tailgater. Mine is adjustable and I have it just at the outside edge of bumper which puts trailer ball in a good view. Is that camera adjustable ?
  17. Mar 27, 2021 at 3:54 PM
    Bman95
    No, this particular camera is not adjustable. It is installed in a fixed position in the handle.
    BubbaW likes this.
  18. Mar 27, 2021 at 3:55 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Thanks....bummer !
  19. Mar 28, 2021 at 10:39 PM
    #49
    jImmegart
    jImmegart Second Youngest tundra owner in the west!
    Jonah
    California
    2003 Tundra TRD Sport
    FN Counter steer type X w/ 285/70r17 Geolanders JBA y-pipe and pro street 6000 muffler 2.5 king coilovers w/ total chaos uca and custom 2.0 king rears Skidrow front plate TRD Sport package W/ Factory rear swaybar and LSD
    I haven't ordered my reverse camera yet, but I am a little confused still.
    I have the crutchfield ready harness and there is a green wire that is connected to nothing that says "reverse". So I just wanted to know, if I connect that to a reverse signal in the cab, the reverse camera its self to the reverse light, and the RCA cable to the headunit? I cant just do the reverse light 12v from the camera and the RCA, I need to connect the green wire off the crutchfield harness correct?
    I would assume that the wire from the harness is to let the screen know I am now in reverse, but I didn't know if it would just automatically switch when power to the RCA came on.
  20. Mar 29, 2021 at 5:10 PM
    #50
    Bman95
    Are you running the RCA cable to your head unit or a review mirror display?
  21. Apr 5, 2021 at 11:36 AM
    #51
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    So strange thing happened. I've had my backup camera installed for about a month now and it hasn't worked for 3 weeks and because of too much stuff going on I haven't had a chance to look at it.
    Fast forward to last Friday, I'm leaving work, throw the truck in reverse, and the camera works fine... :crazy:
    I thought it was a fluke, but it has since been working just fine the last 3 days. And for @jImmegart here is the long anticipated camera view.
  22. Apr 5, 2021 at 12:28 PM
    #52
    jImmegart
    Jonah
    California
    Ah hell ya, Now I just need to order one!
  23. Apr 5, 2021 at 1:42 PM
    #53
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    Do it. I'm a big fan of it already. I'll work on a write-up for install, but I can help locate the reverse trigger wire for the headunit because Crutchfield has it wrong. Also, I recommend going the @MrDirtjumper route and wiring to the tow harness and specifically the aux wire so that you can use it even when not in reverse.
    Pearl-snap and jImmegart[QUOTED] like this.
  24. Apr 6, 2021 at 10:26 PM
    #54
    stonkson45
    stonkson45 New Member
    2001 Red Tundra SR5 V8 2WD
    There should be a wire that is running along the RCA cable from the backup camera to the head unit, and that is the wire you connect to that trigger wire to let the unit know that you are in reverse, and then it will automatically switch. Unfortunately, simply connecting an RCA will not automatically allow the unit to change on its own.
  25. Apr 7, 2021 at 5:13 AM
    #55
    terrward
    terrward New Member
    2004 DC SR5
    I decided to roll the dice on a dash cam/ mirror cam off of Amazon. Install was pretty straight forward and I’m happy with the results so far.
    Sirfive, abcinv and KNABORES like this.
  26. Apr 7, 2021 at 5:46 AM
    #56
    need more info on this
  27. Jun 19, 2021 at 12:42 PM
    #57
    NomadicFrog
    NomadicFrog Took 5 yrs, finally got rid of "New Member" here
    Mark
    Flagstaff, Arizona
    2003 Tundra SR5 4x4 TRD Off-Road Access Cab
    First mod: Gaffer tape over door lock/unlock beeper
    Hey that looks pretty good for what I think I want. Got a link to the product?
    And, after a couple of months, do you still like it? Are you someplace where it gets really hot (I'm in Phoenix...118 this week) and have you had issues related to temperature?
    Edit: looks like it's either the Carchet T12 or VanTop H612 (which...look like the same exact product?) They seem pretty great for the price.
    If it is either of those, though, they are only rated to function up to 140F, and I'm pretty sure our cabs get hotter than that if it's already 115+ outside. I don't want the thing to cook itself – or the battery blowing up and burning down my truck.
    Edit 2: I went ahead and bought the Carchet T12 (I had some scheduling issues that I used to rationalize my impatience) and sho nuff, whoever plagiarized the User Manual forgot to do a global search and replace for "VanTop" - at least one instance of that snuck in, so yeah, I think they are the same product.
    Edit 3: First impression: everything seems pretty good so far. Haven't been able to route the wiring to the actual backup camera, but the forward facing, mounting, recording seems ok. Don't have anything to compare it to, and I wish things like license plates were clearer, but I guess it's ok? Anyone else with direct experience with these?
    Also, all the stuff above it around your dome light – outside temp, compass, etc. – is that OEM for your model / year, or is that aftermarket? I've got a 2003 SR5 AC and don't have any of that.
  28. Jul 1, 2021 at 9:00 AM
    #58
    mbreed2
    mbreed2 Is not right
    Allentown PA
    2001 Tundra 4x4
    Master tailgaters sold out...:(
    ToyoLife and jImmegart like this.
  29. Sep 28, 2021 at 10:34 AM
    #59
    YarbianTheBarbarian
    YarbianTheBarbarian New Member
    Ian
    Bloomington, IN
    '05 SR5 TRD 4x4 double cab
    None yet!
    It appears they are back in stock now.
  30. Sep 30, 2021 at 10:36 AM
    #60
    Yotamaster
    Yotamaster New Member
    '04 Phantom Gray Tundra SR5 Access Cab
    Kenwood DDX773BH Head unit, Tailgate Handle Backup Camera
    jImmegart likes this.
