Anyone Help me Find a 3.91 2006 Limited Slip Rear Differential?
Discussion in '1st Gen Tundras (2000-2006)' started by bmwahba, Jan 5, 2022.
  1. Jan 5, 2022 at 4:59 PM
    bmwahba
    bmwahba [OP] New Member
    No they don’t…long story… I also had them check for stamping anywhere on the gears or housing and there’s nothing that says 3.91.
    So as long as there is no factory LSD with some other ratio exists it’s safe to assume it’s a 3.91. It’s a steal of a deal at $200…so I’m willing to take my chances..
  2. Jan 5, 2022 at 5:06 PM
  3. Jan 5, 2022 at 5:09 PM
    bmwahba
    Thanks, I’ll do that if this diff I found just now doesn’t work out. Just need to confirm that all LSD were 3.91 ratio
  4. Jan 5, 2022 at 5:12 PM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
  5. Jan 5, 2022 at 5:26 PM
    bmwahba
  6. Jan 5, 2022 at 5:29 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    No, the LSD was not just offered with 3.91 gears. 04 DCs have 4.10 gears and LSD.
    Source: my truck.
  7. Jan 5, 2022 at 5:38 PM
    bmwahba
    Shoot. Well let’s hope this diff I bought is indeed a 3.91. Lol…
    des2mtn likes this.
  8. Jan 5, 2022 at 5:44 PM
    des2mtn
    SW
    Tonto cover
    You're just going to buy a used completely assembled one and toss it in?
    Before you put it in, count the number of teeth on the ring gear then divide that by the number of teeth on the pinion gear.
    w666 likes this.
  9. Jan 5, 2022 at 5:52 PM
    bmwahba
    Yes. I found a steal for one from a shop had one laying around. It was $200 plus shipping. So, worth the gamble I suppose.
    des2mtn[QUOTED] likes this.
  10. Jan 5, 2022 at 6:15 PM
    bmwahba
    Here are pics of said diff....looks clean... just hope its the right ratio!
  11. Jan 5, 2022 at 8:01 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    The difference between 2wd, 4wd and RC/AC/DC is potentially the pinion flange.
    I'm using a 04 DC 4.10 LSD rear end in my 05 2wd AC rear diff. I did swap to a solid pinion spacer and put a new pinion seal in, when I swapped the flange.
    If you do not know how to swap pinion seals/flanges without messing the preload up, do NOT do it yourself.
    des2mtn likes this.
  12. Jan 6, 2022 at 4:36 AM
    bmwahba
    Wonder if that’s because it’s an 04? The only ones with 4.10?
    so I did find some marking, on the photo above, you can see “3.90” stamped on the main ring gear. So I think we’re good..
  13. Jan 6, 2022 at 10:14 AM
    bobjones
    bobjones New Member
    03 tundra on 37s
    The sequoia has the thick flange, all the truck 3rd members have a thin flange.
  14. Jan 6, 2022 at 12:54 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    Yep. I got that one specifically for the 4.10's.
  15. Jan 7, 2022 at 1:22 PM
    bobjones
    bobjones New Member
    03 tundra on 37s
    you can always count the teeth on the ring and pinion and divide them to give you the ratio if its not marked
  16. Sep 15, 2024 at 10:54 PM
    Glenn Kubin
    Glenn Kubin New Member
    Glenn
    I have a 3.91 limited slip diff in CA collecting dust.
  17. Sep 16, 2024 at 1:08 AM
    Slp82
    Slp82 New Member
    2005 Tundra RC 4.7 4x4; Toytec Boss 2.0 kit; SPC upper control arms; addicted offroad front bumper & 9k winch, Brute Force sliders & rear bumper, skid row skid plates, 285/75r16 Cooper AT3, Detroit trutrac in rear.
    2014 Tundra 4x4 5.7L DC; Bilstein 6112s @ 1.9"; 35x12.50 Nitto Ridge Grapplers on 20x9 wheels with +25 backspacing; DV8 front & rear bumpers, Engo 12k winch (SOLD) 2005 Tundra RC 4.7 4x4 w/3" spacer, addicted offroad tube winch bumper w/9k Engo, homemade sliders, skid row skid plate, 285/75r16 Cooper AT3, Detroit trutrac in rear.
    This is a 2 ½ year old thread. I'm pretty sure he found a solution by now.
  18. Sep 16, 2024 at 5:16 AM
    Want. What kind of shape is it in? Assuming this is just the 3rd member?
  19. Sep 16, 2024 at 6:20 AM
    #49
    Glenn Kubin
    Glenn
    I is in good shape it has around 150000 on it I put in one with 4.10 and a lunch box locker in it. Ring gear looks good no major ware .
  20. Sep 16, 2024 at 6:55 AM
    #50
    Shame we are so far apart
