Anyone have Bushwacker Fender Flares?
Discussion in '2.5 Gen Tundras (2014-2021)' started by jay131866, Jan 17, 2017.
  1. Jan 17, 2017 at 11:07 AM
    jay131866
    jay131866 [OP] New Member
    anyone have any feedback on these flares? They claim to be bolt-less installation which i like.
    My tire/wheel setup currently sticks out about 1/2" past stock fenders, will adding the fender flares make the tires look too small? How far out do the flares stick out past stock?
    Any feedback or pics are appreciated. Thanks!
  2. Jan 17, 2017 at 11:10 AM
    sdhq_offroad
    sdhq_offroad New Member
    GILBERT, AZ
    We have done a couple of them by customer request. Both have had issues. Biggest issue was that they didn't want to sit flush on the truck and left inconsistent gap between the fender and body. Just some of our past experiences.
  3. Jan 17, 2017 at 11:36 AM
    louscrw
    louscrw all jacked up on Mt. Dew
    Lou
    Warner Robins, Ga
    2023 F150 Raptor
    What is your current tire size and wheel offset? I think +12 offset and less would be okay with flares. Anymore offset than that, the wheels may seem too far tucked in and will take away from the aggressive look
  4. Jan 17, 2017 at 12:18 PM
    mtntop
    mtntop New Member
    2004 4x4 Access Cab SR5
    I have them on my 2004 and one of the flares does not sit flush like mentioned before, it rides about 1/8 inch off the side. I think this side may be slightly dented? However, they were easy to put on and do catch the debris from my tires which stick out some. I have 9x18 wheels with a -12 offset with 265 75 18 tires.
  5. Jan 17, 2017 at 12:41 PM
    sc134
    sc134 O.P.S.
    2017 Tundra PreRunner
    Front 2.5 Fox Factory Extended Length Coilovers, Total Chaos Upper Control Arms, Swapped projector Headlights, Tint, Dual Carven Exhaust
    Been looking into fenders too. Not sure which ones to go with. Almost pulled the trigger on some cheap $150 flares on eBay.
  6. Jan 17, 2017 at 12:49 PM
    Spoony1
    Spoony1 New Member
    2016 tundra platinum crewmax
    Trd pro grill color match door handles and mirror. 4 1/2 bds lift
    I have the Bushwacker flares no fit issues at all with them. I think if your tires stick out 1/2 inch now they will set in about 1" from the edge of the flare.
  7. Jan 17, 2017 at 1:41 PM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    I had them on for about an hour then took them off. I have +18 offset it took away the aggressiveness of the truck but I'm sure would of worked well if you want to keep debris off the truck
    joem1cha3l likes this.
  8. Jan 17, 2017 at 4:02 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    I have the extend a fenders which is about 1.5" of coverage. I'm running +12 wheels. Mine sits fine and flush all around. I had a shop install some clear vinyl where the flares meet the body as I have read many people had it rubbing the paint off over time.
    54C22950-703F-400B-876B-21E404E58128_zps_70ec053d8c6cea73d948ba9b0e20dd915aad6479.jpg
    323BDEDA-DF9D-4D43-8628-096B0111F074_zps_cdc064df11bbdd57bdf2fe3d4952810c12ca38ff.jpg
  9. Jan 17, 2017 at 4:11 PM
    xtyfighterx
    Ty
    North Idaho
    Been thinking about getting the OE flares they don't stick out as much
  10. Jan 17, 2017 at 5:33 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    I like the fact that you can get them paint matched. But I like the shape better of the extend a fenders + they have better coverage for my setup. 1.5" vs 0.75".
  11. Jan 17, 2017 at 6:57 PM
    xtyfighterx
    Ty
    North Idaho
    What's your offset? I'm at 0
  12. Jan 17, 2017 at 7:39 PM
    chphilo
    chphilo Tundra addict
    Western PA
    No issues with Bushwacker fender flares. I have 295/70/18 on 18 mm offset wheels and tires are just about even with flares as you could see.
    Left side:
    Right side
    geno0506 likes this.
  13. Jan 17, 2017 at 7:43 PM
    chphilo
    Western PA
    By the way, I loved the Bushwacker pocket style fender flares so much that I had to get the tires/wheels to match them. Then in order to install them, I had to lift the truck, haha. Originally I was not planning to lift the truck nor was I planning to get new wheels/tires. I love the Bushwacker look.
    Tundra805 and Motor71 like this.
  14. Jan 17, 2017 at 8:17 PM
    Spoony1
    Spoony1 New Member
    Mine are zero also and I have 3/4" bolt on spacers so they just barely stick out past the flare. I have 305/55/20 toyo tired but also a BDS 4 1/2 lift.
  15. Jan 20, 2017 at 1:30 PM
    jay131866
    I have +25 offset on an 8.5" wide wheel. Running 275/70/18 tires, so they stick out about 1/2" outside fenders now. Not sure if that would look stupid once flares were put on. Don't really want to pay all the money for flares and then find out I need new wheels to make them look good.
  16. Jan 20, 2017 at 1:34 PM
    jay131866
    Thats what I am worried about. I have +25 on 8.5" wide wheel currently. How far would you say the flares add to the width of the truck? I think i remember reading they are about 1.75" wide.
  17. Jan 27, 2017 at 6:28 PM
    Tony'sToy
    Tony'sToy New Member
    Tony
    Savannah, MO
    2015 Toyota Tundra SR5 TRD OFF ROAD
    6" Rough Country lift kit 20" BMF Novakane Wheels 35"X12.50R20 Nitto Trail Grappler MT AIRAID Cold Air Intake Flowmaster Outlaw Exhaust System Bushwacker Pocket Style Fender Flares Recon Projector Headlights (Smoked) Recon 35 Watt Hid Headlights Recon 35 Watt Hid Foglights Recon LED Brake Lights (Smoked) Recon LED 3rd Brake Brake Light (Smoked) Recon LED Tailgate Light Bar(Smoked) Recon LED Big Rig Light Bar (Smoked) Recon LED Bulbs Every Bulb Location Rough Country 30" Bumper Mount Single Row Light Bar. Headlight Revolution LED Interior Light Kit Replaced Every Bulb Blue LED Bulbs Toyota TRD PRO Grille (Black) TRD Shift Knob All Windows Tinted 20% WeatherTech In Channel Window Deflectors WeatherTech Floor Liners Extant Encore Tonneau Cover
    Yes they are 1.75" wide. I have them on my truck and love them. I run 35x12.50xR20 on BMF Novicane wheels. I think they look great!
  18. Feb 26, 2017 at 11:49 AM
    cthomaschase
    cthomaschase New Member
    I got mine delivered but unfortunately they have scratches and blemishes on them. Anyone else have this issue?
  19. Feb 26, 2017 at 4:16 PM
    Les7311
    Les7311 Look up, what do you see
    2008 Blue Tundra TRD 4x4
    OEM flares from PSI auto restyling located in Texas
    Paid $160 and comes in matte black (eBay)
    $200 painted by shop
    Took a little over two hours to prep and install
  20. Dec 17, 2017 at 2:28 PM
    BreezyP
    BreezyP New Member
    Brad
    2015 Toyota Tundra
    @chphilo did you paint the red accent on those rims or did they come like that?
  21. Dec 17, 2017 at 2:44 PM
    What headlights are those?
  22. Dec 17, 2017 at 2:46 PM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    Had them on my 08 no problems at all. Fit pretty good also
    CJ21 likes this.
  23. Dec 17, 2017 at 6:40 PM
    chphilo
    Western PA
    Moto Metal 961. The wheels come with two accent pieces, one in red, the other in chrome. I tried red pieces first then I like it so I never even got to try the chrome pieces.
    BreezyP[QUOTED] likes this.
  24. Dec 17, 2017 at 6:47 PM
    birdman076
    birdman076 Bird, bird, bird...bird is the word
    Chuck
    Montana
    2015 Brown Tundra Crew Max Limited
    Airbox with K&N Filter, 2" lift on 33's, Alpine iLX-F309 head unit, Pull out bed tool boxes, brown with black trim, rims, etc, black leather interior, matching topper. Muffler delete (too loud..) 62k miles!!!
    Did Bushwackers on 2 Tacoma's without issue at all. Yes they do need some "adjustments" if they don't sit right buts its pretty easy and a couple of hours work on a Tacoma that had factory flares on it that I had to pull off first. Both sets were Linex coated and I will do the same for my Tundra at some point. The truck bed sides are just a big damn canvas for parking lot painters to hit with whatever brush they happen to be using that day (carts, cars, paint, hands, fat bodies, canes, wheel chairs, etc).
