Anyone have a power source installed in their bed?
Discussion in 'General Tundra Discussion' started by TunaDr, Oct 5, 2020.
  1. Oct 5, 2020 at 8:37 AM
    TunaDr
    TunaDr [OP] New Member
    2007 Tundra
    I joined to see what is possible
    Hello, wondering what my options are for adding any power sources into the bed. Just want to future proof myself now. Should it be installed before a spray in liner or it can be installed after?
  2. Oct 5, 2020 at 9:20 AM
    DividedSky
    DividedSky New Member
    Jeff
    '18 Crewmax - ADS Mid Travel
    ADS 2.5's (rear bypass) U748 Leaf Springs
    You mean like I this?
    I’d do it after the bedliner. Easier to replace if it gets smashed or something. mine is a marine grade outlet and I used hot-glue to seal the end where the leads connect to the terminals. It came w a 10amp in-line fuse, but I have it hooked up to my switch panel (to control when it is on) so it is actually double fused.
    oh, and mine has a volt-meter readout so I know when my battery is getting too low.
    Wallygator likes this.
  3. Oct 5, 2020 at 9:27 AM
    Grendel
    Grendel New Member
    2016 Quicksand TRD PRO
    I installed this it has standard cigarette lighter and arb/dometic connector
  4. Oct 5, 2020 at 9:28 AM
    Tierhog
    Tierhog SIG-AHOLIC
    2016 Tundra Crewmax Limited 4WD
    Mostly stock/TRD accessories/Morimoto XBs
    We need to Tacoma powerbox. I believe Toyota already responded and said No. Lol
    Beesta likes this.
  5. Oct 5, 2020 at 9:45 AM
    timsp8
    NY
    I just ran 10 gauge wire to my bed and have outlets kinda like post 3, but mine are connected to my are cap. The are cap came with an outlet but 16 gauge wire and my fridge kept shutting off. I have 3 outlets - 2 12v and 1 usb with battery volt gauge.
    mZiggy and Beesta like this.
  6. Oct 5, 2020 at 9:56 AM
    Beesta
    Beesta New Member
    Jay
    Loudoun County
    2019 Pro Midnight Black Metallic
    I’d do before the bed liner so when you cut the hole it can be cover with the liner and all bare metal will covered to prevent rusting ... take your time on positioning and think wisely. Make sure to use step bit or hole saw if needed. Loom all wires underneath and follow factory cable runs for clean installs. Good luck.
  7. Oct 5, 2020 at 9:58 AM
    X2
    Make all the holes before the lining. Then install it after it's done.
  8. Oct 5, 2020 at 10:21 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Hells yeah! Her name is Svetlana.
  9. Oct 5, 2020 at 12:05 PM
    TunaDr
    2007 Tundra
    so 10 gauge wire straight to the battery with an inline fuse? has anyone done a battery to inverter for 110v plug outlet? thanks everyone for their input
  10. Oct 5, 2020 at 12:19 PM
    DividedSky
    Jeff
  11. Oct 5, 2020 at 1:32 PM
    timsp8
    NY
    10 gauge is probably overkill. I have a fridge that kept cutting out so I am overdoing it. An inverter will take more than 10 gauge. I’m messing with one now that is giving me errors on 17 ft of 4 gauge. You’ll need about 20 feet to get to the bed. It’s a 1000w inverter.
  12. Oct 5, 2020 at 2:53 PM
    abomb60
    abomb60 Maker of things
    Massachusetts
    2018 Tundra 1794 MGM
    Overkill is good if you don't know what you might need later. I'd run at least some 10 gauge from the main battery to the bed and for now just hook it up to some USB's if that's what you need. You could even pop in one of those BlueSea 12v fuse panels if you want provided the combined amp usage is ok for the wire gauge and length.
    Then later when you add your solar panels, 2nd battery and DC-DC charger you already have the wiring to the main battery :rofl:. Actually might has well go 8 or 6 gauge just in case. In all honesty I just learned this lesson. Ran 12 gauge from the battery to a 12v socket in the bed since that's all I needed then when I added my 20A DC-DC charger I had to run more wiring :mad:
  13. Aug 7, 2021 at 9:50 AM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    20’ is all? I was thinking it might be more like 25ft. Going from the battery, straight down the driver side rail to the front of the bed. Don’t want to short-change myself. @abomb60 you remember how long your run was?
    bert4x4 likes this.
  14. Aug 7, 2021 at 10:08 AM
    abomb60
    Massachusetts
    Sorry don't remember exactly but looking at my Amazon history I believe it was 25 ft that I ordered of 10 gauge. With all the wire routing that's probably the minimum I'd order. I also ran my back towards the tailgate so front of the bed would be less.
    bert4x4 and Mater[QUOTED] like this.
  15. Aug 7, 2021 at 10:16 AM
    Terndrerrr
    Terndrerrr 925000 miles to go
    Music City
    6UR-FE
    I have a second battery in the front passenger side corner of the bed. It’s not as OEM-looking as some of the setups here, but I like being able to easily remove it. And I haven’t drilled a single extra hole in my bed. The battery is in a trolling motor battery box with 12VDC and USB jacks and a battery level indicator. I can disconnect the battery and carry it and my Dometic fridge to another vehicle (say, a boat) for the day.
    Write-up here.
  16. Aug 7, 2021 at 10:48 AM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    Read through your write up. Looks like you used the bed mount bolt for the battery box as well? Didn’t see anything about that. I was going to do something similar to your idea with the plywood to mount my slide but got nervous the bed bolts might come loose from vibration. Might have to move my battery out of my cross-bed toolbox to underneath due to heat
    Terndrerrr likes this.
  17. Aug 7, 2021 at 11:51 AM
    Terndrerrr
    Music City
    6UR-FE
    The battery box should probably be more secured than it is. Right now, I just have tightly wrapped with a ratchet cord to the corner tie-down. I did think about mounting it to another piece of plywood that is secured by the bed bolt, but I'm not anticipating it going airborne.
    The plywood I used for the fridge slide is 19/32" I believe. It's thin enough that I could still get a good amount of the bed bolts threaded, and the fridge fits under my American Roll Cover. The bed bolts take a quite a bit of torque just to thread them (with plywood or without). Seems to me they were designed to not come loose. I had mine torqued down tight enough the plywood was every so slightly bent in around the bolt heads. They stayed very tight for the entirety of our recent 3,500 mile Colorado trip.
    Mater[QUOTED] likes this.
  18. Aug 14, 2021 at 5:16 AM
    Buckeye1977
    Buckeye1977 New Member
    I had mine installed after the Line-x.
  19. Sep 16, 2021 at 9:52 AM
    mZiggy
    mZiggy Honey badger
    Marc
    2020 Tundra SR5-CM; 2020 4R TRD Pro; 2008 4R SR5 v8
    Got pictures of your setup?
    I did this (see below) in my Tacoma and my wife's 4runner with 10ga wire and now that I have the Tundra I'd like to replicate it but not sure where to start, where to route up through the inside of the bedside, etc. Interested in where you placed yours in the bed cap since I'm getting a cap as well.
    Teddybear18, Wallygator and W3agle like this.
  20. Sep 17, 2021 at 12:53 PM
    timsp8
    NY
    I wanted something in the bed sides like that, but also don’t want anything permanent. This is something like what the ARE top came with. I replaced the housing and outlets.
    My fridge still cuts off. There’s about a .5-.7 voltage drop from the battery. Someone told me to ground the wire near the bed, which I’ve been too lazy to do.
  21. Sep 17, 2021 at 1:05 PM
    mZiggy
    mZiggy Honey badger
    Marc
    It's probably also due to the wiring from the ARE kit.
    I have an ARE shell on order and inquired about the power outlet option since it wasn't available on my previous ARE shell in my Tacoma.
    It gets run directly to battery but it's only 16ga wire, and 20ft long. Definitely not enough to support voltage drop along that length and support a fridge like a Dometic or similar.
    So I decided I'll do something similar on my own with 10ga, like my Tacoma project. I'm not in love with a non-permanent option in the Tundra bedside either. I like your solution of using the lip of the shell to mount it similarly to how ARE offers it.
  22. Dec 31, 2021 at 6:11 PM
    BaceKamp10
    BaceKamp10 New Member
    What outlet did you use? And did it come with housing for it? Or are the wires and connections exposed behind it?
    I’m about to have my camper shell installed but agonizing over the wiring situation. I did purchase the outlet from ARE but assumed it would be inadequate for running a fridge. Also I want a switch to cut power to the outlet any recommendations on an appropriate switch?
  23. Dec 31, 2021 at 6:18 PM
    mZiggy
    mZiggy Honey badger
    Marc
    I also have an ARE shell and skipped on the power outlet option because it's only 16ga wire and I'd want 10ga minimum, especially for the distance it's got to travel from the battery.
    On my Tacoma and the wife's 4R, I did this:
    Would like to replicate it in the bed of the tundra but getting through that bedside is a PITA, so not likely to happen... Lol
  24. Dec 31, 2021 at 6:33 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
  25. Dec 31, 2021 at 6:42 PM
    chrispick
    chrispick New Member
    chris
    I ran 4 AWG welding wire from the battery into the bed because Im using a cheap HF winch for pulling up street and dirt bikes into my tundra. wireless controller. works great.
    WVI likes this.
  26. Dec 31, 2021 at 7:20 PM
    trevorstuart24
    trevorstuart24 New Member
    I did a wire tap to a fuse in that’s only on when the engine is and ran a wire to the bed. Drilled a hole and mounted a cig lighter
  27. Dec 31, 2021 at 7:46 PM
    Terndrerrr
    Music City
    6UR-FE
    No issues. The relay keeps the batteries separated when the truck is off and allows both to charge just fine when the truck is running.
    I’d love to see your outlet setup when you’re done.
  28. Dec 31, 2021 at 8:07 PM
    Terndrerrr
    Music City
    6UR-FE
    I used 2ga to join the batteries via the relay. 12ga otherwise. Probably overkill, but that’s just keeping in line with the rest of the truck. :headbang:
    Mater likes this.
  29. Dec 31, 2021 at 8:30 PM
    timsp8
    NY
    It’s a solid housing that is open underneath. The wires go through a small hole on the side. I found it on Amazon and bought waterproof outlets to add. The housing came with outlets, but they were cheaper and didn’t say waterproof. I didn’t use any switch. I also pulled out all the ARE wire and redid it with 12 ga wire. Make sure to put disconnects in for when you need to remove the cap.
  30. Sep 1, 2022 at 3:07 PM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    Here’s my updated power in bed setup. Box fits perfectly where it’s located. Haven’t had to use the AC yet, but will be nice should I need to run power tools so where. Batteries, mppt and inverter are in the toolbox
