Anyone has a 2019 Tundra 1794 2WD?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Pete1794, Oct 12, 2019.
  1. Oct 12, 2019 at 3:00 PM
    Pete1794
    Pete1794 [OP] New Member
    SC
    2019Tundra1794
    All stock
    Hey y’all. I have a 2019 Tundra 1794 2WD and I just cannot remember if it has a factory installed stock engine cover under or skid plate (not sure if this is the correct term). I’m also trying to make sure if the service tech forgot to put it back or I really do not have any. I did checked the dealer’s lot but unfortunately they do not have any 1794 on stock. Even my vehicle description doesn’t says any. Cause in my mind I know I have it. Crazy me. If you got time, pics are great too.
    Please help me on this. Thanks
    -Pete-
    p.s. not sure if this is the correct forum topic. Mods, please move as necessary. Thanks
  2. Oct 12, 2019 at 5:20 PM
    socaltundra951
    socaltundra951 Gentlemen Prefer Black Tundras
    Southern California
    Black CrewMax 5.7
    Doesn't the skid plate only come as part of a TRD package? Sport/Off Road/PRO?
  3. Oct 12, 2019 at 5:25 PM
    2Tall
    2Tall New Member
    Chance
    South MS
    2020 Super White CM SR5 4x4
    I don't believe 2wd trucks get the front skid plate. My 4wd SR5 non TRD has one but a friend's 2wd SR5 doesn't. You aren't missing much protection, it's really thin sheet metal.
  4. Oct 12, 2019 at 5:29 PM
    socaltundra951
    Southern California
    Black CrewMax 5.7
    Like I mentioned above, I think it's the TRD package. My 14 is 2WD with the TRD Off Road package and it has the skid plates .
  5. Oct 12, 2019 at 5:35 PM
    2Tall
    2Tall New Member
    Chance
    South MS
    You are probably correct on that. The TRD package adds all the extra skids(engine, transfer case, fuel tank) even on 2wd models. Were in my case on mine and my friend's aren't TRD, only thing I have is the engine skid and nothing else and his has nothing.
    Curious, since yours is 2wd and TRD, does it have the front tow hooks like the 4wd trucks have that kinda stick out in the front or the smaller ones I see on most 2wd trucks?
  6. Oct 12, 2019 at 5:53 PM
    knoxville36
    knoxville36 New Member
    Knoxville, TN
    2024 GMC Sierra 1500 Elevation w/3.0 Duramax
    If you have a 2wd = no skid plate
    2wd with TRD off-Road = skid plate
    All 4wd models = skid plate.
    Now, these are going to be the cheap black sheet metal skid that makes oil changes a challenge.
    Only the TRD Pros are going to have the thicker silver skid plate that is actually a true skid plate.
    nlg4021 likes this.
  7. Oct 12, 2019 at 6:21 PM
    socaltundra951
    Southern California
    Black CrewMax 5.7
    If you mean the ones that are down below the front license plate, no it doesn't have those.
  8. Oct 12, 2019 at 6:45 PM
    kcaustin66
    kcaustin66 New Member
    kevin
    Palestine Texas (East Texas)
    2015 Toyota Tundra CM 1794 4wd
    3” lift, black step bars, aftermarket wheels, LT305/55R20 was this way when I brought it.
    I thought all 1794 came with 4WD ?
  9. Oct 12, 2019 at 6:50 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Nope you can get all trims in 2wd
  10. Oct 12, 2019 at 6:55 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    My 2012 is an SR5 Texas edition 2wd and has the engine skid..
    I believe your window sticker should tell you wether or not you have the engine skid. Run the vin through Toyota’s website. Should tell you there also.
  11. Oct 12, 2019 at 6:55 PM
    markg
    markg New Member
    Mark
    NC
    2007 TRD
    my 2018, 1794 is 2WD and no skid plate
  12. Oct 12, 2019 at 7:15 PM
    Rubberdown
    I think I have a spare one in the attic if you are close in Houston.
  13. Oct 13, 2019 at 7:50 AM
    Pete1794
    SC
    2019Tundra1794
    All stock
    You’re correct about the TRD skid plate.
  14. Oct 13, 2019 at 7:54 AM
    Pete1794
    SC
    2019Tundra1794
    All stock
    Highly appreciate all your inputs. I was looking like this one. A thin black sheet of metal that covers the under engine. Like a splash guard from getting the engine dirty..
  15. Oct 13, 2019 at 7:57 AM
    Pete1794
    SC
    2019Tundra1794
    All stock
    @Rubberdown thanks for the offer bro. but Im here in South Carolina.
  16. Oct 14, 2019 at 5:48 AM
    Pete1794
    SC
    2019Tundra1794
    All stock
    Do you guys think this comes standard installed on any 2019 tundra? Picture was taken from internet for reference. Thanks.
    -Pete-
  17. Oct 14, 2019 at 6:55 AM
    NCSkeeter
    NCSkeeter New Member
    2019 Silver Tundra Crewmax 4x4 1794
    TRD Rear Sway Bar, Truxedo X15 Tonneau Cover, Toyota OEM Bed Mat
    Yes you should have a splash guard like you showed. My 4x4 1794 has one and I don’t have the TRD OR with engine skid plate. I see no reason a 2WD wouldn’t have the same.
  18. Oct 14, 2019 at 8:20 AM
    knoxville36
    Knoxville, TN
    As mentioned above, the engine skid plate is only going to come on 4wd or if you have the TRD off road package. Even the cheap sheet metal skid does not come on 2wd.
  19. Oct 14, 2019 at 8:25 AM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    You can have mine freeeeee!
  20. Oct 14, 2019 at 10:15 AM
    Pete1794
    SC
    2019Tundra1794
    All stock
    - Next time kabayan.
    Thanks again for all your inputs.
    saybng[QUOTED] likes this.
  21. Oct 15, 2019 at 4:25 PM
    kentran5397
    kentran5397 New Member
    Dallas. TX
    2014 Tundra 1794 Edition
    2019 Trd Pro LED Headlight 2019 1794 Grill LED Interior and Reverse Light LED Bedlight Vled Footwell LED Driver Side Grab Handle Bullet Fender Flares MX4 BakFlip Start X Remote Start Dual USB ports for the front and rear KO2 A/T Tires 275 60 R20 *Future Mods* TRD Rear Sway Bar Leveling Kit 38 gallon fuel tank swap
    Hi! I have a 2014 1794 Tundra and it did not come with a skid plate. It came with just a skid plate trim, which is completely non-functional. A buddy of mine has a 2013 Platinum and he too did not have a skid plate. I went on Amazon and ordered a TRD skid plate, completely worth it. With the TRD skid plate, you don't have to take it off to change the filter when doing an oil change.
  22. Oct 15, 2019 at 4:45 PM
    Pete1794
    SC
    2019Tundra1794
    All stock
    @kentran5397 thank you for your input.
    Just to update. I sent an email to Toyota and they replied
    “...found that the engine cover/splash shield is not listed as a published specification. We consulted with our product specialists who have advised that your 2019 Tundra should have some type of engine cover under the vehicle. Please see your servicing dealer for further confirmation.”
    I have not talked with them yet.
    kentran5397 likes this.
