Anyone feel issues with stopping?
Discussion in 'General Tundra Discussion' started by Bdebs, May 4, 2021.
  1. May 4, 2021 at 4:26 PM
    Bdebs
    Bdebs [OP] Don’t Threaten Me With A Good Time!
    2020 Limited Crewmax TRD Offroad
    TRD Rear sway bar, Bilstein 6112, Bakflip MX4 Tonneau Cover
    I have a 2020 CM Limited stock with TRD off-road package with about 12,000 miles and recently started to notice that when I come to a complete stop, it feels like someone is bumping the truck causing it to “rock forward” without actually bumping my truck. I have searched and have not really found anything in particular. Some things say drive shaft or yoke? Possibly check brakes or rotors? Maybe transmission acting up? Has anyone had this occur and what was the solution? Thanks
  2. May 4, 2021 at 8:56 PM
    OnespeedTRD
    OnespeedTRD New Member
    Don
    San Diego
    2020 Tundra Limited TRD Off-Road
    275/70r18 Cooper AT3 XLT on SCS Ray 10s, Eibach Coilovers, DD 12" Exhaust, AJT Blackout Kit, Truxedo Pro X15, paint match/chrome delete.
    I've noticed the same thing. Its not all the time and I can't really pinpoint when it happens.
    I'm pretty sure what I'm feeling is rear axle wrap, and its just unloading and settling back to normal when coming to a complete stop.
    May not be what you're experiencing, but axle wrap is pretty common in leaf spring trucks, and you can certainly feel it at times.
  3. May 4, 2021 at 9:00 PM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    2nd gene are notorious for feeling like some one hits you when you are at a stop. That was just normal. Never heard on a 3rd gen tho.
  4. May 4, 2021 at 9:02 PM
    19crewmaxTRD
    19crewmaxTRD Tundra Enthusiast
    Seth
    2019 white tundra crewmax
    If your ac is on you could be feeling the motor idling up. I have to get used to it every year when the weather warms up. Engine speeds up and pushes through the brakes if you don’t have enough pressure on the brake pedal.
  5. May 5, 2021 at 6:14 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    When I have felt that in the Tundra or 4runner, it means that it is time to lube the driveline zerks. It is the exact issue you describe and shooting some grease in the ujoints and driveshaft zerk fittings has always corrected the issue.
    kittyhawk likes this.
  6. May 5, 2021 at 8:07 AM
    BecauseRacecar
    BecauseRacecar New Member
    Ohio
    '20 Tundra SR5 DC 4x4 Magnetic Gray
    Toyota removed all zerks in the last couple model years, not sure what years exactly, but definitely the 2020s, probably 2019s too.
    OP, does it do the same thing when you come to a stop in neutral? i.e: shift into neutral when you're still in the process of slowing down and see what happens. That could rule out trans behavior, because I've noticed this thing isn't very good at downshifting into 1st or 2nd (not that it downshifts past 3rd very often anyway)
  7. May 5, 2021 at 4:30 PM
    Bdebs
    I would have to try this and see
  8. May 5, 2021 at 4:32 PM
    Bdebs
    I’m also wondering if it is the brakes themselves because I feel a shift when I let off breaks from a complete stop to move like something is trying to grab/release. Almost as if something slips. This is different then what it has normally done and did not have this feeling before or on my previous cars or 2018 tundra
  9. May 5, 2021 at 6:07 PM
    jwatt
    jwatt I heart men
    Jack
    Oregon
    I ve experimented with this for the last year. If I use brakes normally, or firmly, there s some type of back lash that builds up, and it releases with a thump when I let off the brakes. I ve narrowed it down to braking normally, (my normal braking is 2 sec on, 2 sec off) until I m almost to a stop, then lightly apply brakes to stop. Most of the time I can let off the brakes with no thump.
  10. May 5, 2021 at 6:30 PM
    Wallygator
    It's the transmission kicking down to help with stopping
  11. May 5, 2021 at 6:37 PM
    RJVA
    RJVA Former Lurker
    Richard
    Idaho
    2008 Tundra Silver DC 4.7 4x4
    OEM 18" wheels off a 2.5 gen 275/70/18 Falken Rubitrek A/T FabFour Redsteel front bumper with HF winch. Dobinsons IMS with 2.25" coils (610) JBA UCA's Iron Man +300lb rear leaf packs with Dobinsons IMS shocks ECGS bushing in front diff Black Oak Led Flood Pods. 40watt (x2) Black Oak 20" light bar. 100 watt OEM style rear bumper, black powder coat, added aux reverse leds. Stubby AM/FM antenna Century Camper Shell with Roof rack and bed mat
    Trouble stopping? Just with pringles or beer.
    Bdebs[OP] and Wallygator like this.
