Anyone ever rekey their truck?
Discussion in '1st Gen Tundras (2000-2006)' started by carlsoncustoms, Aug 29, 2023.
  1. Sep 3, 2024 at 10:54 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    Funny, in my mind I read it as airbag too... so that's what I meant. Yeah, not much concern about someone breaking into your vehicle to turn off your airbag. :rofl:
    In fact, I've had a few vehicles that I removed the tabs in the lock tumbler. And they could be started with a screwdriver if you wanted to. Again, what's somebody going to do, break into every car on the street to see if one of them can be started without the key?
    whodatschrome[QUOTED] likes this.
  2. Sep 3, 2024 at 11:15 AM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    By rekey, I mean they change the internals of the lock cylinder to work with one key.
    As far as how much, that all depends on the locksmith and if they'll need anything additional. Given your tailgate and pass door issues.
  3. Sep 3, 2024 at 11:29 PM
    1stGen907
    1stGen907 New Member
    907
    2005 RC LB 4.7 4WD
    Have you tried lubricating the lock? Spray a bit of dry teflon lube in there, then spray some on the key, put it in the lock and work it back and forth and left and right to distribute the lube. Don't use anything gummy like grease or oil. Graphite will work, but use it sparingly. A little goes a long way. Paraffin wax also works well. Rub the key on the wax, then put it in the lock and work it for a while. Repeat as necessary. It's amazing what a little lubrication can do for a complex mechanical device like a lock.
